[Cliq 2] CyanogenMod 7, прошивка (МОД) для Motorola Cliq 2
сообщение 26.9.2011, 17:47
CyanogenMod 7 for Cliq 2
Неофициальный порт CyanogenMod для moto cliq2
На основе cyanogenmod7 и android 2.3.5
Developer
SunRain(wanggjghost) - Main Developer
DJGHOSTS3V3N - Code Cleaner/Tweek Adder
Project Home
https://github.com/SunRain
I want to thanks :
- Quarx2k, tpruvot, turl, J_r0dd, adlx and many other guys that help me in porting (I may forgot other, sorry)
- Cyanogen & all the people involved in the CyanogenMod project for CM sources
- Google & all the people involved in the Android project for AOSP sources
- Moto for the cliq2
WARNING:
As always, I take no responsability for damaged phones, the user has full responsability. I am not responsible for any data loss and or bricked phones.I assume the user has read this README file and knows what he is doing.
Update Log
Release pre-alpha3
Fix camera/camcorder problem
Fix problem in recovery
Fix keypad backlight
Update some rc files, more stable
2011-09-08
Release pre-alpha2.
Much fixes
2011-09-05
Fix the sound & torch problem.
Use ti audio encoder & decoder
WORKING:
calling/sms, BT, wifi, fm, sound, flash-light, sensor, vibrator, usb, camera, camcorder, keypad
NOT WORKING:
mute switch hardware key, gps , wma decoder
bootmenu=>oc function
I'm sure more ...
WARNING
The oc function and cpu scheduler funtion in bootmenu is not tesed, I suggest U DON'T test it now, maybe it is dangerous.
HOW TO INSTALL
It works only on cliq2 foryo(2.2.2)
U should install the 2nd-init( bootmenu ) first.
Use the custom recovery in bootmenu to install this rom.
DON'T FORGET to do a wipe after U install this rom.
Original Thread and Download:
ТЕМА
ROM
Google App
Сообщение отредактировал Neko-mata - 26.10.2011, 5:10
Ответов(1 - 7)
Dyuran
сообщение 26.4.2012, 6:54
Пользователь №: 232 970
Модель телефона: mb611
Здраствуйте,прошил cm7 прошивка хорошая.
Из минусов -не работает кнопка переключения на вибру
Так в остальном все хорошо.На данный момент тестирую MIUI 2.3.9 это китайская прошивка,но мне удалось ее руссифицировать.Если в этой теме появится более 5 человек которые захотят MIUI для cliq2 то я создам отдельную тему.Спасибо за внимание,извините за оффтоп.
Сообщение отредактировал Dyuran - 26.4.2012, 6:56
MARKyxa
сообщение 26.4.2012, 7:18
(/\/\)otoModer
Из: Города грехов
Пользователь №: 158 437
Прошивка: IOS
In progress
Dyuran,
так создайте, отблагодарим )
sanpin
сообщение 1.11.2015, 20:48
Пользователь №: 173 241
Модель телефона: e398-L7e
Здравствуйте. У кого есть подробная пошаговая инструкция по утсановке СМ7?
Воха
сообщение 1.11.2015, 22:38
Сектант Xiaomi
Из: Дніпро 🇺🇦
Пользователь №: 145 492
Прошивка: Android 12-13
Норм
Что не так, с той что в шапке?
sanpin
сообщение 2.11.2015, 18:12
Я прошил до версии 2.3.4 а вот на СМ7 остановился. С уважением. Какие проги нужны, файлы. Нужную тему ни где не нашёл. Что-то не получается. Вот и спрашиваю и прошу пошагово мне помочь
Сообщение отредактировал sanpin - 2.11.2015, 18:14
Воха
сообщение 2.11.2015, 20:04
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
Может не стоит насиловать труп?
Вот из шапки:
1. Это работает только на 2.2.2
2. Сперва нужно установить загрузочное меню (bootmenu)
3. Используйте кастомное рековери в bootmenu для установки прошивки
4. Не забудьте сделать wipe после устанвки прошивки
(и насколько я понял- там проблема с GPS и её прийдётся фиксить)
Сами прошивки скорее всего в недрах китайских сайтов https://translate.google.com/translate?hl=r...orum-142-1.html
пробуйте расшифровать перевод гугла- там много прошивок, в т.ч и MIUI
Сообщение отредактировал Воха - 2.11.2015, 20:07
lcrmslcrms
сообщение 2.11.2015, 20:55
Пользователь №: 191 309
Прошивка: 42r/wm6.1/wm5.0
sanpin,
1,Сделать рут вот этим
Прикрепленный файл MotorolaOneClickRoot_psouza4.zip   ( 1.34 мегабайт ) Кол-во скачиваний: 165
архивом
2. из архива выше скопировать на диск С 3 файла adb.exe, AdbWinApi.dll,AdbWinUsbApi.dll
2.скачайте архив
разархивируйте содержимое в /data/ папка с архива
3.в смартфоне .включить отладку по usb
4.подключить смартфон к компьютеру
5. запустите командную строку
6. по очереди выполните описанные ниже команды
C:/> adb shell $
$ su
# cp -R /sdcard/bootmenu /data/bootmenu
# cd /data/bootmenu
# chmod 755 *
# ./install.sh
# rm -R /data/bootmenu
reboot
7.телефон перзагрузится
8. отключите отладку по usb
9.выключите смартфон
10.нажмите кл вкл загорится красный светодиод затем он поменяет цвет на синий сразу нажмите кнопку громкости вниз
вы попадёте в recowery , для выбора пунктов используйте качельки громкости ,для подтверждения действия нажми клавишу вкл
Сообщение отредактировал lcrmslcrms - 2.11.2015, 21:59
[Cliq 2] CyanogenMod 7, прошивка (МОД) для Motorola Cliq 2 · Прошивки для телефонов на Android OS · Forum
Текстовая версия Сейчас: 11.8.2025, 10:20
Форум живёт: 8110 дней
