4 страниц V  1 2 3 > »
|L7e MP| "RHYTHM OF LIFE (iTUNES)" зарубежный патченный монстр, прошивать его ТОЛЬКО после снятия RSA !
сообщение 13.3.2008, 14:23
Сам не тестил (поэтому делайте бекапы в том числе и PDS !!) нашел на
http://www.modmymoto.com/forums/showthread.php?t=62290 Для тех кому скучно
скриншот http://www.freewebs.com/rhmotozone/cover.jpg
RHYTHM OF LIFE (iTUNES) MP
on
R452D_G_08.01.0AR
Flex:
GSTHAWAIIHGIN082
DRM :r452d_g_08.02.06r_drm0101
1) Video camera resolution is set to CIF (352x288) by default (no need to enter menu and set resolution there).
Quality settings are also unlocked and you can save videos to the phone memory (not only memory card) when capturing at that resolution.
2) Lots of patches from Motofan are applied: recent calls lists are not cleared after changing sim card;
entering main menu by pressing Menu and * in different situations (e.g., while transferring files via bluetooth);
web sessions can be set as default by pressing the send key; redialling interval changed to 7 seconds instead of 1 min;
voice recorder does not send regular beeps to the other party; keypad lights can be switched on/off from the menu;
‘battery low’ sound interval increased 5 times (for people with good memory); reduced ‘keypad locked’ window so the clock is now visible
(skin must place the clock in the upper portion of the display); different ringtones for calls and messages from a contact;
modified and extended keypad layout for entering symbols; usb charging can be enabled/disabled from the menu;
changed zoom levels in the picture viewer; optimised video fast forwarding/rewinding during playback.
3) Alarm clock: Alarms can be enabled/disabled using the send key. Alarm is not disabled after going off, it will remain on for the next day
(it can be disabled only from the alarm clock menu). Snooze interval changed to 5 minutes instead of 8.
Both alarm names and times are displayed in the list.
4) Java:
Java Heap increased up to 1400K which has a positive effect on applications like Opera or Jimm;
Java apps can run while usb cable is connected; corelets are visible in the application lists; java signature verifications are removed
(no need to replace certificates, just set java permissions to ‘Never ask’). Java apps have access to the phone file system (including system files),
corelets have access to some seems, kjava folder is visible in OBEX mode. The Itunes works !
You can send java apps via bluetooth or copy them to phone memory/memory card using the send key.
Short press of the voice key selects storage devices. DRM protection when downloading content is removed.
5) Vibro "Point" at a raising of a tube of the subscriber. Vibro "Point" at connection on BlueTooth.
Skins :
1) Win Xp
2) ipod
3) w880
4) Walkman Milk
Java Applications :
1) iTUNES
2) Opera Mini 2.0
3) Mig33 Plus !
4) Asphalt 2 v1.0.2 (Games)
5) File Protect
Extra :
1) keypads Lights Are on.
2) Record Video In Mp4
3) Funlight are Enable
4) Engineering Menu Avaiable
5) Multimedia Sound Is Loud And Clear
6) New iTUNES Bootscreen
7) iTUNES Icon In Multimedia
8) Sms store in Sim
9) Call Guard
при прошитии рекомендую снять галочку с прошития ленгпака
т.к. скорее всего нерусский стоит.
ссылка для скачивания ==>>> https://motofan.ru/firmware/?action=view&id=1097
Pieeer
сообщение 13.3.2008, 16:05
Из: Нижний Новгород
Пользователь №: 120 756
Модель телефона: l7e, E2, Е3
Прошивка: 0AR, Maxx E2
сообщение 13.3.2008, 16:37
Цитата(Pieeer @ Сегодня, 18:05)
Поддержим наших производителей!!)))
они на моём рефлеше :-)) основаны
beat_lis
сообщение 13.3.2008, 18:27
Пользователь №: 124 357
Модель телефона: V3x
Прошивка: LifeTec for V3x V2
Только хотел сказать, неуспел :-) Это же почти полная копия...Время покажет...
JKmoto
сообщение 13.3.2008, 19:11
Пользователь №: 111 708
Модель телефона: RIZR Z3
Прошивка: HYBRID v0.3
Osta респект, и уважуха,
а "разработчикам" монстра позор, своего они ничего в монстр не внесли или монстр делался по мануалу по использованию SHXcodec? - Разбираем файл прошивки, бросаем в папочку дрм скачаный с какого то сайта, ленг в етуже папочку, в другую папочку разбираем файл рефлеша от Osta (кстати, Osta а у тебя разрешение на использование твоего рефлеша в "монстре"спрашивали?), все файлики из етой папочки кидаем в нашу первую папочку, собираем файл прошивки, прошиваем монстр, устанавливаем скины, заливаем чужые симы (наверно самий сложний етап в разработке етого "монстра") и ставим https://forum.motofan.ru/index.php?showforum=146 iTunеs, сливаем бекап монстра и сохраняем монстр в формате SHX."Монстр" готов.
сообщение 14.3.2008, 7:09
не сильно , но ребята хорошие , зря вы их хаете. :-)
прошу отписыватся в теме только по данному монстру.
Kirillos
сообщение 14.3.2008, 11:46
Из: Питера
Пользователь №: 161 627
Модель телефона: Motor l7e
Прошивка: new style v2.1
Сообщение отредактировал Kirillos - 14.3.2008, 11:47
сообщение 14.3.2008, 12:49
Цитата(Kirillos @ Сегодня, 13:46)
а где ссылка на скачку?
закинул к нам на сайт , качайте ->> https://motofan.ru/firmware/?action=view&id=1097
Kirillos
сообщение 14.3.2008, 12:52
Из: Питера
а реально как нибудь сделать ее русской?
сообщение 14.3.2008, 12:58
а ты напиши, что в ней не-русского , может скажем как переделать
|L7e MP| "RHYTHM OF LIFE (iTUNES)" зарубежный патченный монстр, прошивать его ТОЛЬКО после снятия RSA ! · Кастомные прошивки для Motorola RIZR Z3, KRZR K1, W490, W510, ROKR W6, SLVR L7e, L7i, L7x, L71, L72, L9 · Forum
> Быстрый ответ
Текстовая версия Сейчас: 27.4.2024, 13:32
