[modded]: Vxxx_TRIPLETS_G_0B.09.72R + ELFs, Vxxx/TRIPLETS custom firmware by fkcoder & EXL
сообщение 6.3.2024, 14:07 Закрепленное сообщение!
For English speaking members
I decided to finish the work started by fkcoder on porting ElfPack to old Motorola phones on the TRIPLETS platform, which were released back in 2003, a whole 21 years ago! As a result, I ended up with a small custom modified firmware, in which I tried to preserve the stock and original design. In fact, the firmware is the first for these phones with a full-fledged ElfPack v1.0.
The firmware is prepared for TRIPLETS platform phones: V300, V303, V400, V500, V501, V525, V600 and some others with 4 MiB RAM.
S/W: TRIPLETS_G_0B.09.72R
Flex: SE6474AXXU1173
Do not flash on: E550, V535, V545, V550, V600i, V620, and other "Triplets Refresh" phones on the R376 platform.
Do not flash on: V330, V540, V547, V551, V555, V557, and other San2rini and San2rini 2 phones.
Do not flash over: TRIPLETS_G_0B.09.5xR and others firmwares with PDS4xxx instead of PDS2xxx, without completing the "get off the 5xR firmware" guide.
Installation:
01. Charge the battery.
02. Enter Boot Loader mode by simultaneously pressing *, #, Red key when the phone is turned off.
03. Install Motorola USB Driver v3.7.0: 32-bit | 64-bit.
04. Connect the phone to the PC.
05. Flash the SBF firmware file using RSD Lite 3.8 or Flash&Backup 3.09, you can flash it from under a virtual machine, see for more details the topic: Virtual machine images for Motorola, WinXP and Win2K phones for VirtualBox and VMware Player.
Changes:
01. CG1, CG18: RSA bypassed.
02. CG1: Changed Boot Screen.
03. CG1: All ELF patches have been added.
04. CG2, CG4: Mobile QQ menu item was activated and renamed to ELFs.
05. CG2: FEM activated.
06. CG2: JAL activated.
07. CG2: *#9999#
08. CG2: Menu cursor in the center.
09. CG4: Fixed cyrillic bold font in the Web browser.
10. CG4: ID3 tags in MP3 encoded Win-1251 have been fixed.
11. CG2: Added ELFs.
12. CG1: Timings in DRM/CG1 have been reduced.
13. CG2: Added various stock content.
14. CG2: Increased volume in gain_table.bin and param_table.bin files, fixed attributes.
15. CG1: Address checks are disabled.
A description of ELFs can be found in the ELFs by EXL: Nostalgia of development for Motorola P2K.
Attention! Some ELF applications require a running and minimized any Java application.
Task list:
01. Port ElfPack v2.0: it is ported and works but due to the small amount of RAM and a broken API in the firmware itself, which does not allow MotoCmd2 to run, there is no sense in a second version of ElfPack.
02. Port the patch to increase the resolution of JPG (1280x1024), GIF (640x480) and PNG (640x480) images.
01. fkcoder: idea, initial work, help.
02. комсомолец Биря: testing on Motorola V300, V600 and help.
Mirrors:
01. https://firmware.center/projects/EXL/Motoro...25-Mar-2024.zip
Решил доделать начатую fkcoder'ом работу по портированию ElfPack'а на старые телефоны Motorola на платформе TRIPLETS, которые вышли в релиз в далёком 2003 году, целых 21 год назад. По итогу у меня получилась небольшая модифицированная прошивка, в которой я постарался сохранить стоковое и оригинальное оформление. По сути прошивка первая для этих телефонов с полноценным ElfPack'ом.
Прошивка подготовлена для телефонов платформы TRIPLETS: V300, V303, V400, V500, V501, V525, V600 и некоторых других с количеством оперативной памяти 4 MiB RAM.
Не шить на: E550, V535, V545, V550, V600i, V620 и прочие Triplets Refresh, на платформе R376.
Не шить на: V330, V540, V547, V551, V555, V557 и прочие San2rini и San2rini 2.
Не шить поверх: TRIPLETS_G_0B.09.5xR и других с PDS4xxx вместо PDS2xxx, без выполнения Руководство: Как "слезть" с 5х прошивки.
Установка:
01. Зарядить аккумулятор.
02. Зайти в Boot Loader по одновременному нажатию *, #, Красная трубка, когда телефон выключен.
03. Установить драйвера Motorola USB Driver v3.7.0: 32-bit | 64-bit.
04. Подключить телефон к PC.
05. Прошить SBF-файл прошивки с помощью RSD Lite 3.8 или Flash&Backup 3.09, шить можно из-под виртуальной машины, см. подробнее тему: Образы виртуальных машин для телефонов Motorola, WinXP и Win2K для VirtualBox и VMware Player.
Изменения:
01. CG1, CG18: Снят RSA.
02. CG1: Изменён Boot Screen.
03. CG1: Добавлены все ELF-пачти.
04. CG2, CG4: Активирован Mobile QQ и переименован в ELFs.
05. CG2: Активирован FEM.
06. CG2: Активирован JAL.
07. CG2: *#9999#
08. CG2: Курсор меню по центру.
09. CG4: Исправлен жирный (bold) кириллический шрифт в Web-браузере.
10. CG4: Исправлены ID3-теги в MP3 в кодировке Win-1251.
11. CG2: Добавлены ELF'ы.
12. CG1: Уменьшены тайминги в DRM/CG1.
13. CG2: Добавлен различный стоковый контент.
14. CG2: Увеличена громкость в файлах gain_table.bin и param_table.bin, исправлены атрибуты.
15. CG1: Отключены проверки адресов.
Список патчей / List of Patches:
1_Bootsplash_72R.fpa
2_Elfpack_Bootsplash_72R.fpa
3_Elfpack_Deregister_Mobile_QQ_72R.fpa
4_Elfpack_Register_72R.fpa
5_Elfpack_Elf_Directory_72R.fpa
6_MotoSpeed_72R.fpa
7_Drop_Security_Addresses_Check_72R.fpa
8_Unlock_PDS_SIM-Lock_SEEMs_72R.fpa
Список ELF'ов / List of ELFs:
2048-P2K
Ambilight
Benchmark
Dumper
ElfBox
FireEffect
Neko
Overclock
Perlin
Screenshot
Spout
VibroHaptic
Yeti3D
Описание ELF'ов можно посмотреть в теме: ELFs by EXL: Ностальгия разработки под Motorola P2K.
Внимание! Некоторые ELF-приложения требуют запущенное (любое) и свёрнутое Java-приложение.
Список задач:
01. Портировать ElfPack v2.0: он портирован и работает, но из-за небольшого количества памяти и сломанного API в самой прошивке, что не позволяет запускать MotoCmd2, смысла во второй версии ElfPack'а нет.
02. Портировать патч на увеличение разрешения изображений формата JPG (1280x1024), GIF (640x480) и PNG (640x480).
Спасибо:
01. fkcoder: идея, изначальные работы, помощь.
02. комсомолец Биря: тестирование на Motorola V300, V600 и помощь.
Зеркала:
Прикреплённые файлы:
Прикрепленный файл Vxxx_TRIPLETS_G_0B.09.72R_modded_25-Mar-2024.zip   ( 17.12 мегабайт ) Кол-во скачиваний: 1
сообщение 23.3.2024, 18:51
+ Небольшое обновление прошивки 25-Mar-2024:
1. CG2: Активирована функция автообновления времени по сети оператора.
2. CG2: Добавлен стоковые трек Digital Signal.mid
3. CG2: Активированы и добавлены мелодии на включение (Start~up.mp3) и выключение (Power~down.mp3, работает почему-то не всегда).
4. CG2: Обновлён Dumper.elf, исправлена ошибка.
5. Добавлена информация про прошивку с помощью Flash&Backup 3.
За тестирование прошивки спасибо Bs0Dd, скачать новую версию монстрпака можно в стартовом посте темы.
[modded]: Vxxx_TRIPLETS_G_0B.09.72R + ELFs, Vxxx/TRIPLETS custom firmware by fkcoder & EXL · Кастомные прошивки для Motorola V300, V500, V535, V547, V551, V600, V620, V635, V80, A630, RAZR V3 · Forum
Текстовая версия Сейчас: 27.4.2024, 8:00
