90 страниц V < 1 2 3 4 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3875
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
bigserg555
сообщение 24.9.2006, 13:57
MotoSportsMen
Из: Рязань
Пользователь №: 53 831
Модель телефона: LG
Прошивка: Меняю как перчатки)
abatsk, автоматическую блокировку клавиатуры включай в ява приложении,которое идёт в комплекте.
elektro255
сообщение 24.9.2006, 19:49
Из: Poland, Siedlce
do you use MotoSymbian 1.5?
if you contact with Archy and together create monsterpack, it well be best of the best!!!
what you say about it?
I used motosymbian 1.4, about flex first i must make full stable final version :)
Алекс75, my CG1 can work without any other code groups, for fully working SW you need my CG1, and set some SEEM'S:
Keypad autoblock:
SEEM 004A_0001 adres 0x91 bit 1 (1-autolock enabled 0-autolock disabled)
Low Battery Sound:
SEEM 004A_0001 adres 0x91 bit 0 (1-sound enabled 0-sound disabled)
FlashLight [##]:
SEEM 0032_0001 address 0xE bit 0 (1-flashligh avaible 0-flashligh unavaible)
Заране спасибо если сделаешь патчи, хотябы на автоблокировку клавы!
This is very hard to make patches because for example keypad autoblock need to edited in 10 places of firmware (my compiled ASM code+edited some functions in SW and added jumps to my code)
later i will upload ARM Branch calculator what can help to insert your ASM code
SharkExE
сообщение 27.9.2006, 9:28
Из: Пермь
Пользователь №: 46 933
Модель телефона: SE w810i
Прошивка: R4DB005
Ну что можно сказать, все патчи (корелеты, мидлеты, удаление системных файлов, блок\разблокб доступ по блютуз) подходят как миленькие!!! вот мой набор патчей, не все я делал.
Прикрепленный файл 49r_patches__for_elektro_.rar   ( 1.58 килобайт ) Кол-во скачиваний: 932
Алекс75
сообщение 28.9.2006, 19:02
Мото-реаниматор
Из: Калининграда
Пользователь №: 30 882
Модель телефона: XT502
Прошивка: Android 2.2
Вы вот тут завели разговор подойдут или нет патчи от 49R для данной прошивы.Естественно да!!!!Любые рабочие патчи для 49 прокатят и на этой.В данной прошиве лишь частично изменен код,е более того,а так же дописан код в конце CG1 но ссылки в прошиве при этом меняться не должны иначе все рухнет.Т.е. все что "нарыто" на 49R подойдет и для данной прошивы все находится по одним и тем же смещениям.Вопрос возникает только по новым фичам-фонарик и автоблок.Просто изменений в прошиве достаточно много и перебирать все в поиске нужной не очень удобное да и не очень приятное занятие.Проще спросить у автора где находится автоблок и где фонарик.
elektro255
Where in CG1 there is an automatic lock-out and as access to a small lamp by pressing on # # .Какие НЕХ is necessary for writing down values in CG1 and where?
Алекс75
сообщение 8.10.2006, 11:57
Мото-реаниматор
Из: Калининграда
scool,
народ скажите этот монстр для е398 или на оригенальный е1 можно тоже зошить?
Все зависит от того какой у тебя бут в телефоне.Если 0А02 то НЕЛЬЗЯ!!!Телефон умрет!
Насчет 2 полезных фич в монстре....К сожалению у меня не было оригинальной CG1 для Е1 поэтому сравнивал с прошивами с польз монстров но больно геморно либо все патчи откатывать а потом сравнивать либо при сравнении учитывать каждое изменение в пользовательской прошиве короче долго и геморно...Значит так обе эти фичи сделаны именно в CG1 причем включение фонарика активируется-деактивируется в симах(в каком еще не определил) но после прошивки CG1 и CG3 с данного монстра фонарик не работал а после заливки EEPROM с него же все стало ок.Сейчас качаю оригинального монстра для Е1 на базе 49R для сравнения
CG1 всетаки хочу найти где именно изменения касающиеся фонарика и автоблока.Если их будет много(изменений),а их достаточно много то сделаю скрины по каким смещениям что изменено и выложу в теме если у кого то будет желание помочь в поисках этих 2 фич помогайте.Сегодня уже 3 патча протестил в поисках изменений касающихся автоблока и фонарика пока что результат нулевой... :(
abatsk
сообщение 8.10.2006, 12:08
Пользователь №: 77 083
Модель телефона: Samsung i9003
Прошивка: Android
А когда я прошил CG1 и CG3 так у меня фонарик работал без проблемм и автоблокировка тоже!
elektro255
сообщение 11.10.2006, 5:20
Из: Poland, Siedlce
Thank for new version МР, but question remains....
Where in CG1 there is an automatic lock-out and as access to a small lamp by pressing on # # .What НЕХ is necessary for writing down values in CG1 and where?
you don't understand, there is no one address in CG1 and addresses changinging in new version, becouse this is not normal patch. Code for this feauters is linked with exists procedures in flash and to make patches you need recalculate some jumps.
And for flashlight ## SEEM was changed to SEEM32 byte 16h bit 1
For menu access *# is SEEM32 byte 0Eh bit 0
lv333
сообщение 11.10.2006, 6:57
Из: Украина, Киев
Пользователь №: 45 916
Прошивка: СМ 10
Цитата(Stranger @ Среда, 11 Октября 2006, 9:47)
А вообще хоть кто-нибудь смог скачать с рапиды? У меня ничего не выходит. Если не трудно, перезалейте еще куда-нибудь
http://www.avservice.com.ua/moto/elektro25...d_v0.2b_49R.rar
Украинский трафик ;)
Bent
сообщение 11.10.2006, 9:40
MoTo Marvellous
Пользователь №: 63 874
Модель телефона: L7
Stranger, расскажу :) Берёшь FlashBackup 2.62---Создание прошивок---Ставишь модель телефона Е790/Е1 ROKR--Полная прошивка(FullFlash)---выбираешь этот файл SW(bin)--Пишешь название прошивки :)--Галочка должна стоять на "Умное отсечение пустот...."---Создать.
Прошиваешь спокойно PST(если будешь шить им то в конце прошивки выйдет ОШИБКА не чего страшного) или FlashBackup 3.
Удачи.А насчёт Flasher у меня он вообще не работает ошибка приложения пишет...мне то собственно и пофиг я всегда PST прошиваю,но хотел для новизны попробовать :)
Теперь к автору.Очень радует тот факт то что автор держит слово!Сказал после 10 октября будет продолжение и выполнил обещание это очень хорошо!
По монстру...Что за белая полоска вверху где батарейка,антена и т.д.? :) Не одно ява приложение не работает(я думаю дело в скине.Забыл наверно автор убрать "Лёгкий скин" поскольку скин стоит новый)
Про мелодии,картинки и т.д. говоришь не уместно :) Самое главное! Функции работают исправно,перезагрузки пропали
elektro255 Well done the Main thing you have constrained the promise and have laid out updating after October, 10th! I respect with such people!
Reload have disappeared, functions work on hurrah.
Question - That for a white strip on above there where a battery. network, etc.??? Appendices Java do not work (likely you when skin put has forgotten to clean a tick with " Easy skin ")
Sorry for English I use the translator:)
P.S. блин только что перевёл PROMT то что он сам же и написал такая фигня получается bigsmile; буду надеятся что автор поймёт о чём я...
elektro255
сообщение 11.10.2006, 10:49
Из: Poland, Siedlce
java not woking because file J2MEST is broken and white bar on top depends from skin, but SW now is stable and you can start making monsters with this CG1 because i don't have time to make FLEX DRM etc. :)
Текстовая версия Сейчас: 27.4.2024, 14:14
