AndrewSOAD,
Ну как при таком grid не тормозить?
<?xml version="1.0" standalone="no"?>
<!-- Motorola Confidential Proprietary
Copyright © 2008 Motorola, Inc. All Rights Reserved.-->
<svg xmlns:moto="http://www.motorola.com/moto"
xmlns:ev="http://www.w3.org/2001/xml-events"
xmlns="http://www.w3.org/2000/svg"
version="1.2" baseProfile="tiny"
xmlns:xlink="http://www.w3.org/1999/xlink"
xml:base="../../">
<xml-stylesheet xlink:href="colors.css" type="text/css" />
<!-- highlight -->
<defs>
<g id="iconHighlight" visibility="inherit">
<image width="105" height="25" xlink:href="media/images/shadow_24bit.png" />
</g>
</defs>
<!-- highlight placements -->
<!-- scroll bar handler -->
<g id="highlightGroup" visibility="hidden" opacity="0">
<animate attributeName="opacity" from="0" to=".8" dur="250ms" begin="item.0.focusin" end="item.0.focusout" fill="freeze" />
<animate attributeName="opacity" from="0" to=".8" dur="250ms" begin="item.1.focusin" end="item.1.focusout" fill="freeze" />
<animate attributeName="opacity" from="0" to=".8" dur="250ms" begin="item.2.focusin" end="item.2.focusout" fill="freeze" />
<animate attributeName="opacity" from="0" to=".8" dur="500ms" begin="item.3.focusin" end="item.3.focusout" fill="freeze" />
<animate attributeName="opacity" from="0" to=".8" dur="500ms" begin="item.4.focusin" end="item.4.focusout" fill="freeze" />
<animate attributeName="opacity" from="0" to=".8" dur="500ms" begin="item.5.focusin" end="item.5.focusout" fill="freeze" />
<animate attributeName="opacity" from="0" to=".8" dur="500ms" begin="item.6.focusin" end="item.6.focusout" fill="freeze" />
<animate attributeName="opacity" from="0" to=".8" dur="500ms" begin="item.7.focusin" end="item.7.focusout" fill="freeze" />
<animate attributeName="opacity" from="0" to=".8" dur="500ms" begin="item.8.focusin" end="item.8.focusout" fill="freeze" />
<animate attributeName="opacity" from="0" to=".8" dur="500ms" begin="item.9.focusin" end="item.9.focusout" fill="freeze" />
<animate attributeName="opacity" from="0" to=".8" dur="500ms" begin="item.10.focusin" end="item.10.focusout" fill="freeze" />
<animate attributeName="opacity" from="0" to=".8" dur="500ms" begin="item.11.focusin" end="item.11.focusout" fill="freeze" />
<use id="bbox.0" transform="translate(-7,74)" xlink:href="#iconHighlight">
<set attributeName="visibility" to="visible" begin="item.0.focusin" end="item.0.focusout" />
</use>
<use id="bbox.1" transform="translate(69,74)" xlink:href="#iconHighlight">
<set attributeName="visibility" to="visible" begin="item.1.focusin" end="item.1.focusout" />
</use>
<use id="bbox.2" transform="translate(146,74)" xlink:href="#iconHighlight">
<set attributeName="visibility" to="visible" begin="item.2.focusin" end="item.2.focusout" />
</use>
<use id="bbox.3" transform="translate(-7,135)" xlink:href="#iconHighlight">
<set attributeName="visibility" to="visible" begin="item.3.focusin" end="item.3.focusout" />
</use>
<use id="bbox.4" transform="translate(69,135)" xlink:href="#iconHighlight">
<set attributeName="visibility" to="visible" begin="item.4.focusin" end="item.4.focusout" />
</use>
<use id="bbox.5" transform="translate(146,135)" xlink:href="#iconHighlight">
<set attributeName="visibility" to="visible" begin="item.5.focusin" end="item.5.focusout" />
</use>
<use id="bbox.6" transform="translate(-7,195)" xlink:href="#iconHighlight">
<set attributeName="visibility" to="visible" begin="item.6.focusin" end="item.6.focusout" />
</use>
<use id="bbox.7" transform="translate(69,195)" xlink:href="#iconHighlight">
<set attributeName="visibility" to="visible" begin="item.7.focusin" end="item.7.focusout" />
</use>
<use id="bbox.8" transform="translate(146,195)" xlink:href="#iconHighlight">
<set attributeName="visibility" to="visible" begin="item.8.focusin" end="item.8.focusout" />
</use>
<use id="bbox.9" transform="translate(-7,255)" xlink:href="#iconHighlight">
<set attributeName="visibility" to="visible" begin="item.9.focusin" end="item.9.focusout" />
</use>
<use id="bbox.10" transform="translate(69,255)" xlink:href="#iconHighlight">
<set attributeName="visibility" to="visible" begin="item.10.focusin" end="item.10.focusout" />
</use>
<use id="bbox.11" transform="translate(146,255)" xlink:href="#iconHighlight">
<set attributeName="visibility" to="visible" begin="item.11.focusin" end="item.11.focusout" />
</use>
</g>
<!-- icons -->
<g visibility="visible">
<!-- Note: scrollbar handler below assumes items will have id = "item.N" where N is a number -->
<g id="item.0" transform="translate(18,21)" focusable="true" nav-up="url(#item.11)" nav-down="url(#item.3)" nav-right="url(#item.1)" nav-left="url(#item.11)">
<image id="SmallIcon.0" opacity="0.6" width="45" height="45">
<animateTransform type="scale" from="1" to="1.3" dur="250ms" fill="freeze" begin="item.0.focusin" />
<animateTransform type="scale" from="1.3" to="1" dur="250ms" fill="freeze" begin="item.0.focusout" />
<animateTransform type="translate" from="0 0" to="-3 0" additive="sum" dur="250ms" fill="freeze" begin="item.0.focusin" />
<animateTransform type="translate" from="-3 0" to="0 0" additive="sum" dur="250ms" fill="freeze" begin="item.0.focusout" />
<animate attributeName="opacity" from="0.5" to="1" dur="500ms" begin="item.0.focusin" end="item.0.focusout" fill="freeze" />
<animate attributeName="opacity" from="1" to="0.5" dur="500ms" begin="item.0.focusout" end="item.0.focusin" fill="freeze" />
</image>
</g>
<g id="item.1" transform="translate(96,21)" focusable="true" nav-up="url(#item.9)" nav-down="url(#item.4)" nav-right="url(#item.2)" nav-left="url(#item.0)">
<image id="SmallIcon.1" opacity="0.6" width="45" height="45">
<animateTransform type="scale" from="1" to="1.3" dur="250ms" fill="freeze" begin="item.1.focusin" />
<animateTransform type="scale" from="1.3" to="1" dur="250ms" fill="freeze" begin="item.1.focusout" />
<animateTransform type="translate" from="0 0" to="-3 0" additive="sum" dur="250ms" fill="freeze" begin="item.1.focusin" />
<animateTransform type="translate" from="-3 0" to="0 0" additive="sum" dur="250ms" fill="freeze" begin="item.1.focusout" />
<animate attributeName="opacity" from="0.5" to="1" dur="500ms" begin="item.1.focusin" end="item.1.focusout" fill="freeze" />
<animate attributeName="opacity" from="1" to="0.5" dur="500ms" begin="item.1.focusout" end="item.1.focusin" fill="freeze" />
</image>
</g>
<g id="item.2" transform="translate(174,21)" focusable="true" nav-up="url(#item.10)" nav-down="url(#item.5)" nav-right="url(#item.3)" nav-left="url(#item.1)">
<image id="SmallIcon.2" opacity="0.6" width="45" height="45">
<animateTransform type="scale" from="1" to="1.3" dur="250ms" fill="freeze" begin="item.2.focusin" />
<animateTransform type="scale" from="1.3" to="1" dur="250ms" fill="freeze" begin="item.2.focusout" />
<animateTransform type="translate" from="0 0" to="-3 0" additive="sum" dur="250ms" fill="freeze" begin="item.2.focusin" />
<animateTransform type="translate" from="-3 0" to="0 0" additive="sum" dur="250ms" fill="freeze" begin="item.2.focusout" />
<animate attributeName="opacity" from="0.6" to="1" dur="500ms" begin="item.2.focusin" end="item.2.focusout" fill="freeze" />
<animate attributeName="opacity" from="1" to="0.6" dur="500ms" begin="item.2.focusout" end="item.2.focusin" fill="freeze" />
</image>
</g>
<g id="item.3" transform="translate(18,81)" focusable="true" nav-up="url(#item.0)" nav-down="url(#item.6)" nav-right="url(#item.4)" nav-left="url(#item.2)">
<image id="SmallIcon.3" opacity="0.6" width="45" height="45">
<animateTransform type="scale" from="1" to="1.3" dur="250ms" fill="freeze" begin="item.3.focusin" />
<animateTransform type="scale" from="1.3" to="1" dur="250ms" fill="freeze" begin="item.3.focusout" />
<animateTransform type="translate" from="0 0" to="-3 -6" additive="sum" dur="250ms" fill="freeze" begin="item.3.focusin" />
<animateTransform type="translate" from="-3 -6" to="0 0" additive="sum" dur="250ms" fill="freeze" begin="item.3.focusout" />
<animate attributeName="opacity" from="0.6" to="1" dur="500ms" begin="item.3.focusin" end="item.3.focusout" fill="freeze" />
<animate attributeName="opacity" from="1" to="0.6" dur="500ms" begin="item.3.focusout" end="item.3.focusin" fill="freeze" />
</image>
</g>
<g id="item.4" transform="translate(96,81)" focusable="true" nav-up="url(#item.1)" nav-down="url(#item.7)" nav-right="url(#item.5)" nav-left="url(#item.3)">
<image id="SmallIcon.4" opacity="0.6" width="45" height="45">
<animateTransform type="scale" from="1" to="1.3" dur="250ms" fill="freeze" begin="item.4.focusin" />
<animateTransform type="scale" from="1.3" to="1" dur="250ms" fill="freeze" begin="item.4.focusout" />
<animateTransform type="translate" from="0 0" to="-3 -6" additive="sum" dur="250ms" fill="freeze" begin="item.4.focusin" />
<animateTransform type="translate" from="-3 -6" to="0 0" additive="sum" dur="250ms" fill="freeze" begin="item.4.focusout" />
<animate attributeName="opacity" from="0.6" to="1" dur="500ms" begin="item.4.focusin" end="item.4.focusout" fill="freeze" />
<animate attributeName="opacity" from="1" to="0.6" dur="500ms" begin="item.4.focusout" end="item.4.focusin" fill="freeze" />
</image>
</g>
<g id="item.5" transform="translate(174,81)" focusable="true" nav-up="url(#item.2)" nav-down="url(#item.8)" nav-right="url(#item.6)" nav-left="url(#item.4)">
<image id="SmallIcon.5" opacity="0.6" width="45" height="45">
<animateTransform type="scale" from="1" to="1.3" dur="250ms" fill="freeze" begin="item.5.focusin" />
<animateTransform type="scale" from="1.3" to="1" dur="250ms" fill="freeze" begin="item.5.focusout" />
<animateTransform type="translate" from="0 0" to="-3 -6" additive="sum" dur="250ms" fill="freeze" begin="item.5.focusin" />
<animateTransform type="translate" from="-3 -6" to="0 0" additive="sum" dur="250ms" fill="freeze" begin="item.5.focusout" />
<animate attributeName="opacity" from="0.6" to="1" dur="500ms" begin="item.5.focusin" end="item.5.focusout" fill="freeze" />
<animate attributeName="opacity" from="1" to="0.6" dur="500ms" begin="item.5.focusout" end="item.5.focusin" fill="freeze" />
</image>
</g>
<g id="item.6" transform="translate(18,141)" focusable="true" nav-up="url(#item.3)" nav-down="url(#item.9)" nav-right="url(#item.7)" nav-left="url(#item.5)">
<image id="SmallIcon.6" opacity="0.6" width="45" height="45">
<animateTransform type="scale" from="1" to="1.3" dur="250ms" fill="freeze" begin="item.6.focusin" />
<animateTransform type="scale" from="1.3" to="1" dur="250ms" fill="freeze" begin="item.6.focusout" />
<animateTransform type="translate" from="0 0" to="-3 -6" additive="sum" dur="250ms" fill="freeze" begin="item.6.focusin" />
<animateTransform type="translate" from="-3 -6" to="0 0" additive="sum" dur="250ms" fill="freeze" begin="item.6.focusout" />
<animate attributeName="opacity" from="0.6" to="1" dur="500ms" begin="item.6.focusin" end="item.6.focusout" fill="freeze" />
<animate attributeName="opacity" from="1" to="0.6" dur="500ms" begin="item.6.focusout" end="item.6.focusin" fill="freeze" />
</image>
</g>
<g id="item.7" transform="translate(96,141)" focusable="true" nav-up="url(#item.4)" nav-down="url(#item.10)" nav-right="url(#item.9)" nav-left="url(#item.6)">
<image id="SmallIcon.7" opacity="0.6" width="45" height="45">
<animateTransform type="scale" from="1" to="1.3" dur="250ms" fill="freeze" begin="item.7.focusin" />
<animateTransform type="scale" from="1.3" to="1" dur="250ms" fill="freeze" begin="item.7.focusout" />
<animateTransform type="translate" from="0 0" to="-3 -6" additive="sum" dur="250ms" fill="freeze" begin="item.7.focusin" />
<animateTransform type="translate" from="-3 -6" to="0 0" additive="sum" dur="250ms" fill="freeze" begin="item.7.focusout" />
<animate attributeName="opacity" from="0.6" to="1" dur="500ms" begin="item.7.focusin" end="item.7.focusout" fill="freeze" />
<animate attributeName="opacity" from="1" to="0.6" dur="500ms" begin="item.7.focusout" end="item.7.focusin" fill="freeze" />
</image>
</g>
<g id="item.8" transform="translate(174,141)" focusable="true" nav-up="url(#item.5)" nav-down="url(#item.11)" nav-right="url(#item.9)" nav-left="url(#item.7)">
<image id="SmallIcon.8" opacity="0.6" width="45" height="45">
<animateTransform type="scale" from="1" to="1.3" dur="250ms" fill="freeze" begin="item.8.focusin" />
<animateTransform type="scale" from="1.3" to="1" dur="250ms" fill="freeze" begin="item.8.focusout" />
<animateTransform type="translate" from="0 0" to="-3 -6" additive="sum" dur="250ms" fill="freeze" begin="item.8.focusin" />
<animateTransform type="translate" from="-3 -6" to="0 0" additive="sum" dur="250ms" fill="freeze" begin="item.8.focusout" />
<animate attributeName="opacity" from="0.6" to="1" dur="500ms" begin="item.8.focusin" end="item.8.focusout" fill="freeze" />
<animate attributeName="opacity" from="1" to="0.6" dur="500ms" begin="item.8.focusout" end="item.8.focusin" fill="freeze" />
</image>
</g>
<g id="item.9" transform="translate(18,201)" focusable="true" nav-up="url(#item.6)" nav-down="url(#item.1)" nav-right="url(#item.10)" nav-left="url(#item.8)">
<image id="SmallIcon.9" opacity="0.6" width="45" height="45">
<animateTransform type="scale" from="1" to="1.3" dur="250ms" fill="freeze" begin="item.9.focusin" />
<animateTransform type="scale" from="1.3" to="1" dur="250ms" fill="freeze" begin="item.9.focusout" />
<animateTransform type="translate" from="0 0" to="-3 0" additive="sum" dur="250ms" fill="freeze" begin="item.9.focusin" />
<animateTransform type="translate" from="-3 0" to="0 0" additive="sum" dur="250ms" fill="freeze" begin="item.9.focusout" />
<animate attributeName="opacity" from="0.6" to="1" dur="500ms" begin="item.9.focusin" end="item.9.focusout" fill="freeze" />
<animate attributeName="opacity" from="1" to="0.6" dur="500ms" begin="item.9.focusout" end="item.9.focusin" fill="freeze" />
</image>
</g>
<g id="item.10" transform="translate(96,201)" focusable="true" nav-up="url(#item.7)" nav-down="url(#item.2)" nav-right="url(#item.11)" nav-left="url(#item.9)">
<image id="SmallIcon.10" opacity="0.6" width="45" height="45">
<animateTransform type="scale" from="1" to="1.3" dur="250ms" fill="freeze" begin="item.10.focusin" />
<animateTransform type="scale" from="1.3" to="1" dur="250ms" fill="freeze" begin="item.10.focusout" />
<animateTransform type="translate" from="0 0" to="-3 0" additive="sum" dur="250ms" fill="freeze" begin="item.10.focusin" />
<animateTransform type="translate" from="-3 0" to="0 0" additive="sum" dur="250ms" fill="freeze" begin="item.10.focusout" />
<animate attributeName="opacity" from="0.6" to="1" dur="500ms" begin="item.10.focusin" end="item.10.focusout" fill="freeze" />
<animate attributeName="opacity" from="1" to="0.6" dur="500ms" begin="item.10.focusout" end="item.10.focusin" fill="freeze" />
</image>
</g>
<g id="item.11" transform="translate(174,201)" focusable="true" nav-up="url(#item.8)" nav-down="url(#item.0)" nav-right="url(#item.1)" nav-left="url(#item.10)">
<image id="SmallIcon.11" opacity="0.6" width="45" height="45">
<animateTransform type="scale" from="1" to="1.3" dur="250ms" fill="freeze" begin="item.11.focusin" />
<animateTransform type="scale" from="1.3" to="1" dur="250ms" fill="freeze" begin="item.11.focusout" />
<animateTransform type="translate" from="0 0" to="-3 0" additive="sum" dur="250ms" fill="freeze" begin="item.11.focusin" />
<animateTransform type="translate" from="-3 0" to="0 0" additive="sum" dur="250ms" fill="freeze" begin="item.11.focusout" />
<animate attributeName="opacity" from="0.6" to="1" dur="500ms" begin="item.11.focusin" end="item.11.focusout" fill="freeze" />
<animate attributeName="opacity" from="1" to="0.6" dur="500ms" begin="item.11.focusout" end="item.11.focusin" fill="freeze" />
</image>
</g>
</g>
<!-- text labels, defined last so they render atop the icons -->
<g id="textGroup" class="textMMGridSel" font-size="18" fill-opacity="0" visibility="hidden" >
<textArea id="Label.0" x="-10" y="0" width="100%" moto:lines-max="1" moto:scroll-direction="horizontal"
text-align="center" moto:bidi="true"
moto:truncate="ellipsis"
moto:scroll="stop"
moto:scroll-speed="10">
<set attributeName="moto:scroll" to="start" begin="item.0.focusin" end="item.0.focusout"/>
<animate attributeName="fill-opacity" from="0" to="1" dur="250ms" begin="item.0.focusin" end="item.0.focusout" fill="freeze" />
</textArea>
<textArea id="Label.1" x="-10" y="0" width="100%" moto:lines-max="1" moto:scroll-direction="horizontal"
moto:scroll="stop"
<set attributeName="moto:scroll" to="start" begin="item.1.focusin" end="item.1.focusout"/>
<animate attributeName="fill-opacity" from="0" to="1" dur="250ms" begin="item.1.focusin" end="item.1.focusout" fill="freeze" />
</textArea>
<textArea id="Label.2" x="-10" y="0" width="100%" moto:lines-max="1" moto:scroll-direction="horizontal"
moto:scroll="stop"
<set attributeName="moto:scroll" to="start" begin="item.2.focusin" end="item.2.focusout"/>
<animate attributeName="fill-opacity" from="0" to="1" dur="250ms" begin="item.2.focusin" end="item.2.focusout" fill="freeze" />
</textArea>
<textArea id="Label.3" x="-10" y="0" width="100%" moto:lines-max="1" moto:scroll-direction="horizontal"
moto:scroll="stop"
<set attributeName="moto:scroll" to="start" begin="item.3.focusin" end="item.3.focusout"/>
<animate attributeName="fill-opacity" from="0" to="1" dur="250ms" begin="item.3.focusin" end="item.3.focusout" fill="freeze" />
</textArea>
<textArea id="Label.4" x="-10" y="0" width="100%" moto:lines-max="1" moto:scroll-direction="horizontal"
moto:scroll="stop"
<set attributeName="moto:scroll" to="start" begin="item.4.focusin" end="item.4.focusout"/>
<animate attributeName="fill-opacity" from="0" to="1" dur="250ms" begin="item.4.focusin" end="item.4.focusout" fill="freeze" />
</textArea>
<textArea id="Label.5" x="-10" y="0" width="100%" moto:lines-max="1" moto:scroll-direction="horizontal"
moto:scroll="stop"
<set attributeName="moto:scroll" to="start" begin="item.5.focusin" end="item.5.focusout"/>
<animate attributeName="fill-opacity" from="0" to="1" dur="250ms" begin="item.5.focusin" end="item.5.focusout" fill="freeze" />
</textArea>
<textArea id="Label.6" x="-10" y="0" width="100%" moto:lines-max="1" moto:scroll-direction="horizontal"
moto:scroll="stop"
<set attributeName="moto:scroll" to="start" begin="item.6.focusin" end="item.6.focusout"/>
<animate attributeName="fill-opacity" from="0" to="1" dur="250ms" begin="item.6.focusin" end="item.6.focusout" fill="freeze" />
</textArea>
<textArea id="Label.7" x="-10" y="0" width="100%" moto:lines-max="1" moto:scroll-direction="horizontal"
moto:scroll="stop"
<set attributeName="moto:scroll" to="start" begin="item.7.focusin" end="item.7.focusout"/>
<animate attributeName="fill-opacity" from="0" to="1" dur="250ms" begin="item.7.focusin" end="item.7.focusout" fill="freeze" />
</textArea>
<textArea id="Label.8" x="-10" y="0" width="100%" moto:lines-max="1" moto:scroll-direction="horizontal"
moto:scroll="stop"
<set attributeName="moto:scroll" to="start" begin="item.8.focusin" end="item.8.focusout"/>
<animate attributeName="fill-opacity" from="0" to="1" dur="250ms" begin="item.8.focusin" end="item.8.focusout" fill="freeze" />
</textArea>
<textArea id="Label.9" x="-10" y="0" width="100%" moto:lines-max="1" moto:scroll-direction="horizontal"
moto:scroll="stop"
<set attributeName="moto:scroll" to="start" begin="item.9.focusin" end="item.9.focusout"/>
<animate attributeName="fill-opacity" from="0" to="1" dur="250ms" begin="item.9.focusin" end="item.9.focusout" fill="freeze" />
</textArea>
<textArea id="Label.10" x="-10" y="0" width="100%" moto:lines-max="1" moto:scroll-direction="horizontal"
moto:scroll="stop"
<set attributeName="moto:scroll" to="start" begin="item.10.focusin" end="item.10.focusout"/>
<animate attributeName="fill-opacity" from="0" to="1" dur="250ms" begin="item.10.focusin" end="item.8.focusout" fill="freeze" />
</textArea>
<textArea id="Label.11" x="-10" y="0" width="100%" moto:lines-max="1" moto:scroll-direction="horizontal"
moto:scroll="stop"
<set attributeName="moto:scroll" to="start" begin="item.11.focusin" end="item.11.focusout"/>
<animate attributeName="fill-opacity" from="0" to="1" dur="250ms" begin="item.11.focusin" end="item.11.focusout" fill="freeze" />
</textArea>
</g>
</svg>
xml:base="../../">
<!-- highlight -->
<defs>
</g>
</defs>
</use>
</use>
</use>
</use>
</use>
</use>
</use>
</use>
</use>
</use>
</use>
</use>
</g>
<!-- icons -->
</image>
</g>
</image>
</g>
</image>
</g>
</image>
</g>
</image>
</g>
</image>
</g>
</image>
</g>
</image>
</g>
</image>
</g>
</image>
</g>
</image>
</g>
</image>
</g>
</g>
moto:scroll="stop"
</textArea>
moto:scroll="stop"
</textArea>
moto:scroll="stop"
</textArea>
moto:scroll="stop"
</textArea>
moto:scroll="stop"
</textArea>
moto:scroll="stop"
</textArea>
moto:scroll="stop"
</textArea>
moto:scroll="stop"
</textArea>
moto:scroll="stop"
</textArea>
moto:scroll="stop"
</textArea>
moto:scroll="stop"
</textArea>
moto:scroll="stop"
</textArea>
</g>
</svg>
