Welcome to China motoedy www.motoedy.cn
http://translation2.paralink.com + http://translate.google.com/translate_t
newHITMOUSE by hantao
Author: om2804 tim apple Editorer: 四夕 & 林子 L7E/L9: lpktool
Thanks to om2804 tim apple
new LRCPlayer_DesktopshowLRC_1.3
[Updated 09-08-01]
Lin LRCPlayer_ modified version V1.3
[+] Add lyrics contour, in BG_LRC.CFG color profile settings in the settings to add "show the outline of the lyrics" set;
[+] When did the lyrics, the screen does not display lyrics and other non-related tips;
[+] To remove the panel in the A site or C site settings, the program will automatically determine which disk;
[+] LRCPlayer.lng documents are updated, LRCPlayer.cfg document changes to the original part used to re-configure the settings (such as the use of IT to start, etc.);
[Updated 09-07-30]
Lin LRCPlayer_ modified version V1.2
[+] Amendment can not be deployed for panel icon panel issues;
[+] When a song did not amend the LRC, the desktop display lyrics on a problem;
[+] Icon shows a high degree determines the number of rows and a high of 20 for his party, would like to show you a few lines of lyrics
[+] Can call with the panel and different icons and configuration, will be on the panel BG_LRC.CFG and BG_LRC.GIF document under the folder DeskTopFile; not call the default program directory;
[+] In setting a "desktop display the lyrics" and "show-screen lyrics when Changliang" choice;
~ 12.06.2009 ~
[LRCPlayer 1.3]
Hard-won source ah
* Based on modifications made to Tunes3.9
* Play button changes the interface is as follows:
123, respectively, for the side and so on, flash, screen
5 for the current playlist
8 on
7 players on the grounds to the lyrics of the skin interface interface
9 on the grounds the lyrics to the player skin interface interface
* Reduce the volume
# Increase the volume
0 to mute
Other operations with Tunes3.9
still lrc.cfg address for GBK encoding, LRCPlayer.cfg the last 2 bytes in order to initiate a 16-band event code
new Memorandum_Simplify the locking version
new HDautoplay1.5
RamEdit :
Redmenu_mod (ELF&SRC)
gif:L"*.gif"
Ring Styles=0936
ZtxtEdit=file://a/MotoCmd/Ztxtedit.elf
pp_lrc_1.7.1
PP_reader_1.1
Color Clock
1.6
Color_T v1.3
Author: Kalvinxp (bimonthly)
Source: EDY
0 1 2 3 4 5 ... F
0x00000000 XX XX XX bond packages
0x00000010 XX XX clock line coordinates of the clock ordinate
0x00000020 XX XX XX hours of high color
0x00000030 XX XX XX hours of low color
0x00000040 XX XX XX isolation: the color
0x00000050 XX XX XX high-minute color
0x00000060 XX XX XX low-minute color
0x00000070 XX XX XX XX XX XX this line of the first byte as a font type, 2 bytes for the border or shadow (0 without any results,Plus 1 frame, plus 2 after the shadow of the shadow of the former plus 3); the first 3-5 bytes for the effect of color ,No. 6 bytes for the digital space
PS: XX on behalf of a byte
ElfOpen2.4.1
thanks for om2804!
new
Backupsms
[SMST]
app=/b/Elf/MotoCmd/smsv.elf
type=id
09-08-31
Amendments to the multi-page copies of reading support. (Known Bug: Unable to get part of the recipient)
Skin.elf
new
Auto change skin when you startup your phone
Skins in dick a
Skins in dick c
Please add to AutoRun
PP_DnpEditor:
UnRAR/Un7z:
6Elfs only for 79R
Screener picture:
newPlug-in for MotoCMD: ConfigEditor oт 林子 English Verson by Last1left
new DEC HEX BIN Converter oт 林子 English Verson by Last1left
new Motocmd2.0
Campanula, in what of difference between MotoCmd.elf, MotoCmd-DDRM.elf, MotoCmd-DXDRM.elf?
Register=0x03DC
Map=110F0824
Sytem=0;Hidden system files: 0/no 1/yes
ReadLast=1;Read last open Folder: 0/no 1/yes
ChangeType=1;Scroll Display file names : 0/no 1/yes
UseZipBrowser=1;ZIP Browser Switch:1 use MotoCmdZIP, 0 use MotoCmd Plug-in(UnZip.elf)
BookDir=/a/Elf/MotoCmd/bmk/Ebook.txt;file of BookDir
AutoDir=/a/Elf/MotoCmd/AutoRun.elf;file of AutoRUN
DrmDir=/a/Elf/MotoCmd/Adddrm.elf;file of Adddrm
HexDir=/a/Elf/MotoCmd/HexEditor.elf;file of HexDir
TxtDir=/a/Elf/MotoCmd/Ztxtedit.elf;file of TXTEdit
[MEI]
app=/a/Elf/MotoCmd/ElfInstaller.elf
[JC]
app=/a/Elf/MotoCmd/Jc.elf
[GIF]
app=/a/Elf/MotoCmd/Iv.elf
AutoRun for MotoCmd2.0, No AutoRun
Adddrm for MotoCmd2.0,Plaese Add to AutoRun
Example:b/Moto/Drm/Green/329-336.gif
Open MotoCmd2.0,You can Long press 0,Then Press Menu,Update battery pack.
map is our Chinese Transcoding
For example:
Map=110F0824 ,This is a patch of gb2uc. It's used to gbk to uc
UnZip.elf PP_lrc.elf LRCPlayer.elf MotoCmd.elf ....must to use this patch (Map=10C3E800)
ZtxtEdit.elf use 3 maps
1:patch (Map=110F0824) :gbk to uc
2:gb2big5.map : gb to big5
3:uc2gbk.map : :uc to gbk ,This is used to edit txt.
Russian friends, British friends ,Do not need to use maps....
give you the src of ZtxtEdit , MotoCmd2.0.0.1 and LRCPlayer1.4
you can make them for our Russian friends, British friends
Спасибо всем разработчикам эльфпака и эльфов!
Сообщение отредактировал Campanula - 6.9.2009, 6:55
HITMOUSE.elf ( 14.21 килобайт ) Кол-во скачиваний: 683 |
LRCPlayer_DesktopshowLRC_1.3.rar ( 480.3 килобайт ) Кол-во скачиваний: 807 |
[Updated 09-08-01]
[Updated 09-07-30]
~ 12.06.2009 ~
[LRCPlayer 1.3]
Hard-won source ah
8 on
* Reduce the volume
0 to mute
Memorandum_Simplify_the_locking_version.zip ( 9.92 килобайт ) Кол-во скачиваний: 485 |
new HDautoplay1.5
HDautoplay1.5.zip ( 2.48 килобайт ) Кол-во скачиваний: 450 |
Its working principle: plug in your headphones to monitor the incident code, and monitor the core event code (0404, that is, start-up events LRCPLayer.elf/Tunes.elf, when you start the event of LRCPlayer/Tunes.elf code changes, so please direct HEX to 0404 start for your event LRCPlayer/Tunes.elf code), auto-play button to use the simulation
To work only on the desktop
Lock Application--->Headset
Locked--->autoplay
Unlocked---> unautoplay
maybe only for 79R
Locked--->autoplay
maybe only for 79R
RamEdit :
RAMEDIT.zip ( 9.97 килобайт ) Кол-во скачиваний: 574 |
redmenu.zip ( 22.96 килобайт ) Кол-во скачиваний: 508 |
gif:L"*.gif"
CODE
Ring Styles=0936
CODE
For 79R:
Power off=17
Silent power off=0000
Reset=0001
Switch in BOOT=0003
Unload Java=1806
MachoSettings=0973
Tunes=1889
MotoCMD1.8=0985
OPcode=2011
Personalise=0942
Initial Setup=0943
Message=1025
Video Camera=1021
Camera=1019
Bluetooch=1789
USB Settings=1022
Alarm Clock=1001
Datebook=8378
Skins=3237
Shortcuts=0929
Ring Styles=0936
Power off=17
Reset=0001
Switch in BOOT=0003
Unload Java=1806
MachoSettings=0973
Tunes=1889
MotoCMD1.8=0985
OPcode=2011
Personalise=0942
Initial Setup=0943
Message=1025
Video Camera=1021
Camera=1019
Bluetooch=1789
USB Settings=1022
Alarm Clock=1001
Datebook=8378
Skins=3237
Shortcuts=0929
Ring Styles=0936
pp_lrc_1.7.1
ppplayerv1.7.zip ( 135.61 килобайт ) Кол-во скачиваний: 752 |
* Revision of the map in support of GBK, shows in simplified and traditional Chinese \ Sun Wen \ text of the stick ..
* Cancel version of the patch did not play ... GBK's patch map, garbled show ..
* Some small bug amendment ..
* Only version of the patch
This version of the six, to see the name of the folder you know the type:
If, desktop_walkman, on behalf of the desktop that shows the time, the interface for the walkman
The rest and so on (Note: iris for the past Xiaoyu's colorful interface)
Another: a patch version of the map for migration 0x10c3e800 (increase has been offset start-CG1), non-offset this, please make its own decisions
Revised: 16 hexeditor (such as UltraEdit32, etc.) to open elf, search 0x10c3e800, replace your address migration
PP_reader_1.1
ppreader_no_patch.zip ( 26.93 килобайт ) Кол-во скачиваний: 468 |
pp_reader_v1.1.zip ( 98.57 килобайт ) Кол-во скачиваний: 561 |
Increase:
1, to support the GBK code, that can display traditional.
2, in the setting / folder under map.set document offset patch, the hex address of the patch + CG1 address, I provided a patch for the use of 398. 398 can not use the default for 0x10C3E800.
3, at the right point in time to read software code to open the menu option to resolve the utf_8 file to open in the first few garbled.
1, the English word would be forcibly cut off, did not get
2, does not support L7E ...
3, to replace paper map, the size of 47k.
Patch file also changed, and 398 in place are adequate.
Other models to find your own! ! !
After the test, did not play in the system memory of the 398 patch can not run on non-patch version! ! !
Color Clock
1.6
Color_T_v1.6.zip ( 9.53 килобайт ) Кол-во скачиваний: 537 |
Color_T v1.3
Color_T_v1.3.zip ( 69.38 килобайт ) Кол-во скачиваний: 640 |
Source: EDY
0 1 2 3 4 5 ... F
ElfOpen2.4.1
ElfOpen_2.4.1.zip ( 27.14 килобайт ) Кол-во скачиваний: 613 |
thanks for om2804!
mma_ucp:
Phone book
Dialling services ---- Quick dial, voice dial, and attribution for (Fixed dial), Incall setup, RecentCall, Call Forward
Message
Security
ELF & JAVA procedures ---- JAVA procedures, MOTO Manager (AIM), ELF (mixing machine), FELX procedures (WEB shortcut), SEEM editor (Mobile QQ), HEX editor (themes)
Access to the network ---- browser, StoredPages,WebHistory,GotoURL,BRWSetup,WebSessions
Multimedia---- Sounds,Pictures,Video,ITUNES,Camera,VideoCamera
Tools ---- alarm clock, DateBook, calculator, voice record, data backup tools (IM), SIM APP
settings----Personalize,IntlSetup,JAVAtools,CarSetting,PhoneStatus,FEM
MMRingStyle
Shortcuts
Connection ---- Bluetooth, USBSetting, sync, network, airpin mode, headset
03FC instant messaging (IM)
03D1 (chat room)
03DF (AIM)
03ED (WEB shortcut)
03DE (themes)
03D9 (Mobile QQ)
039A (fixed dial-up)
Please use P2KTOOL hidden settings
The more open, and then put mma_ucp
The MMA for the E398. Other models, a separate production ~
Phone book
Message
Security
MMRingStyle
Shortcuts
03D1 (chat room)
03DF (AIM)
03ED (WEB shortcut)
03DE (themes)
03D9 (Mobile QQ)
mma_ucp.zip ( 1.28 килобайт ) Кол-во скачиваний: 600 |
ElfOpen.zip ( 6.29 килобайт ) Кол-во скачиваний: 567 |
new
Backupsms
backupsms__09_08_31.zip ( 14.28 килобайт ) Кол-во скачиваний: 427 |
CODE
IN1=0x04E6
IN2=0x04E7
OUT1=0x07CD
OUT2=
PATH=file://b/backups/
IN2=0x04E7
OUT1=0x07CD
OUT2=
CODE
[SMST]
type=id
09-08-31
Skin.elf
Skin.elf ( 13.46 килобайт ) Кол-во скачиваний: 775 |
CODE
[SKI]
app=/b/Elf/MotoCmd/Skin.elf
type=id
type=id
new
Skins in dick a
A_Skin.elf ( 2.27 килобайт ) Кол-во скачиваний: 490 |
Skins in dick c
C_Skin.elf ( 2.27 килобайт ) Кол-во скачиваний: 541 |
PP_DnpEditor:
PP_DnpEditor.elf ( 19.44 килобайт ) Кол-во скачиваний: 624 |
UnRAR/Un7z:
un7z.elf ( 11.48 килобайт ) Кол-во скачиваний: 753 |
unrar.zip ( 56.79 килобайт ) Кол-во скачиваний: 635 |
CODE
[RAR]
app=/b/Elf/MotoCmd/unrar.elf
CODE
[7z]
app=/b/Elf/MotoCmd/un7z.elf
6Elfs only for 79R
Gomeno(Lock Application --> JAVA APPS)
flashlight on VOICE + VOICE :
Lockvideo(Lock Application --> Headset)
flashlight79r.ZIP ( 592 байт ) Кол-во скачиваний: 396 |
Gameno.zip ( 2.16 килобайт ) Кол-во скачиваний: 383 |
Lockvideo.zip ( 2.16 килобайт ) Кол-во скачиваний: 384 |
PowerDown.zip ( 4.53 килобайт ) Кол-во скачиваний: 401 |
StartUp.zip ( 4.29 килобайт ) Кол-во скачиваний: 389 |
AutoRSMS.zip ( 2.16 килобайт ) Кол-во скачиваний: 399 |
AutoRecord.elf ( 5.38 килобайт ) Кол-во скачиваний: 530 |
Screener picture:
ConfigEditor_eng.zip ( 8.35 килобайт ) Кол-во скачиваний: 447 |
для редактирования файлов: .res .ini .menu .lng.run
CODE
[INI]
app=/a/Elf/MotoCmd/ConfigEditor.elf
[MENU]
[RES]
[LNG]
[RUN]
[MENU]
[RES]
[LNG]
[RUN]
NumBasis_eng.zip ( 6.38 килобайт ) Кол-во скачиваний: 377 |
new Motocmd2.0
motocmd2.zip ( 239.88 килобайт ) Кол-во скачиваний: 644 |
AutoRun.zip ( 5.52 килобайт ) Кол-во скачиваний: 435 |
Adddrm.zip ( 3.97 килобайт ) Кол-во скачиваний: 424 |
CODE
MotoCmd.elf don't need Icons
MotoCmd-DDRM.elf is old Verson
Please use MotoCmd-DXDRM.elf
Icons for MotoCmd
Please add in your DRM!(CG15)
695 mp3.amr .m4a .mid
696 device
697 dir
698 txt .umd .doc .lng .lrc .smst
699 elf
700 exe
701 html
703 jad
704 jar
705 main
706 null
707 rar
708 sys
709 video.3gp .mp4
710 zip
711 ini .cfg .set .run .lib .rlt .rm .pat
712 mei .jc
713 Waiting..
Icons for MotoCmd
696 device
697 dir
699 elf
700 exe
701 html
703 jad
704 jar
705 main
706 null
707 rar
708 sys
709 video.3gp .mp4
710 zip
712 mei .jc
713 Waiting..
CODE
Register=0x03DC
Map=110F0824
[MEI]
[JC]
[GIF]
QUOTE
Map.zip ( 255.12 килобайт ) Кол-во скачиваний: 413 |
For example:
motocmd2.0_scr.rar ( 165.03 килобайт ) Кол-во скачиваний: 355 |
txtedit.zip ( 166.08 килобайт ) Кол-во скачиваний: 464 |
