[APP] bLock, Block - A Screen Lock Based On Sdl/qt
Kundan
сообщение 31.8.2011, 4:18
Из: INDIA
Пользователь №: 217 510
Модель телефона: Motorola A1200
Busy
This is another Phone Lock application inspired from qeiLock and based on SDL.
Created by - BRUCELEE
Features:
QUOTE
- uses the system current wallpaper and font
- 'slide to unlock' like qeiLock has
- show usb connection type
- bottom and top panel can be shown/hidden by dragging
- the clock can be dragged around and remembers the position
- screen slide between normal and settings state
- the settings option list can be scrolled by dragging it
- Vibrate when touching buttons
- If the SDL libraries are found in /mmc/mmca1/games/lib the bLock/data/lib folder is cleaned
Attention:
QUOTE
I don't recommend opening the settings window more than 16 times per application session.
Reason:
For faster startup I choosed to load the settings data only when entering settings as most of the time users won't open settings but block their phones.
So the settings data will load/unload each time you open/close settings.
For some reason something is not cleaned in memory. And so after about 16 loadings of the settings class loading it takes a lot.
I'll try to fix this...
Download:
QUOTE
- bLock.v.1.1a.patch - Extract over the installed bLock.v.1.0
- bLock.v.1.0.mpkg - If you already have SDL libs in /mmc/mmca1/games/lib
- bLock.v.1.0-with-libs.mpkg - If you don't have SDL libs or you're not sure
- bLock.v1.1a+libs.mpkg.zip - If you don't have SDL libs or you're not sure
- bLock.v.1.0-src.zip - The source code.
Screenshots:
IPB ImageIPB ImageIPB ImageIPB Image
Сообщение отредактировал Kundan - 31.8.2011, 4:27
_Bolik_
сообщение 1.9.2011, 9:45
Motolancer
Из: UA Львів
Пользователь №: 111 986
Модель телефона: Razr XT910
Прошивка: 4.1.2 JB
неплохой, кстати, блокиратор екрана. из личных наблюдений (в сравнении с queilock)
- реализована (частично) поддержка gif-анимации в фоне.
- при входящем закрывается (а не виснет)
- есть вибро на слайдере
- слайдер и верхняя панель настроек - выдвижные...
за развитием проекта можно следить тут
[APP] bLock, Block - A Screen Lock Based On Sdl/qt · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 27.4.2024, 19:05
