90 страниц V « < 86 87 88 89 90 >
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3875
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
r.o.m.a.N
сообщение 10.6.2008, 0:00
Motoroma
Пользователь №: 95 283
Прошивка: 49R 4.4.4
http://ifolder.ru/6918897
Metalor
сообщение 11.6.2008, 16:22
Из: Минск <BEL>
Пользователь №: 151 548
Подскажите адрес для патча замены бутскрина на 79 0.3 версии электромода.
Maden
сообщение 11.6.2008, 20:32
Из: Украина, г.Львов
Пользователь №: 143 249
Модель телефона: fly iq256+Е398
Прошивка: Mpx398 Updated
Metalor, в патчи обращайся, тут врятли кто даст.
Garibaldi
сообщение 13.6.2008, 5:12
Из: Оренбург
Пользователь №: 131 311
Модель телефона: E398/Е770v
Прошивка: 49R_EM_ADVANCED/E1P
Metalor,
на 79 0.3 не нашел, но возможно, что совпадает с ближайшими модами.
Вот адреса от двух модов:
[R373...79R(0.4a1) Electro255]
Electro255=8393D3
[R373...46R(0.4a4) Electro255]
Electro255=844283
М.б. от первого подойдет. Проверь!
Metalor
сообщение 13.6.2008, 10:07
Из: Минск <BEL>
Garibaldi, спс те конечно, но на
Electro255=8393D3
тело ваще сдохло, а на
Electro255=844283
human83
сообщение 13.6.2008, 10:23
Пользователь №: 95 584
Модель телефона: E398@iPOD
Прошивка: 49R
[Patch_Info]
Firmware=R373_G_0E.30.79R
Description=Autogenerated patch to change boot splashscreen.
Author=elektro255 (by personalization tool)
[Patch_Code]
00C5FFFF:
Metalor
сообщение 14.6.2008, 9:28
Из: Минск <BEL>
human83, попробовал твой адрес - 00C5FFFF, но ничего не изменилось - бутскрин остался той же ёлочкой, что и был.... shout.gif
r.o.m.a.N
сообщение 14.6.2008, 11:21
Motoroma
Прошивка: 49R 4.4.4
004DD263 попробуй
[79R_v03]
SW_ident_off=903515
SW_ident_val=37
Imei_enabled=ff
logo_offset = 4DD263
imei_off1 = 3F4E9D
imei_off2 = 3F4F27
imei_off3 = 7AAD0
flashlight_off3 = 31CCE1
imei_code_off = 299B64
imei_code = B5F01C0E24002070B0E5F311F8152801D12A4F35A9641C38F311F86A2800D123986421003001F592
fl_code =   B5FF480722002165F000F804BCFFBC08471846C0477846C0E59FC004E12FFF1C000020B9102BD63F
Metalor
сообщение 14.6.2008, 13:44
Из: Минск <BEL>
r.o.m.a.N, этот адрес убивает тело, я определил адрес прогой Samsung Flash Imager - это тоже было 004DD263 - тело сдохло, тогда я вычислил адрес патча без замены на адрес электросайта - 4DC1E3 - на 12 строк выше, и получил нормальную замену бутскрина, только осталась строка сайта электро!
Как я понял нельзя заменить строку ареса сайта электро, или можно???? unsure.gif Ответьте народ!
r.o.m.a.N
сообщение 14.6.2008, 16:56
Motoroma
Прошивка: 49R 4.4.4
Строка должна остаться
Текстовая версия Сейчас: 28.4.2024, 4:30
