abstract mp v3x by uwie, abstract mp v3x by uwie
uwie
сообщение 11.4.2009, 6:55
Пользователь №: 183 590
Модель телефона: v3x
firmware: E6P firmware
flex: abstract
drm: historical drm
skin: evo, historical, heartless, extremerazr, russomax, desolate, blackmmv2
font: 26 fonts en ita ru ukr spain turkish with all itap
java: itunes, ebuddy, DAP, Google maps, VirtualCorelet, Wincore, YBlite, MMA mobile editor, Skintools, mp3 tools, ctheme, my space
shortcut using videocall key
videocall key + 1 = corelet
videocall key + 2 = Itunes
videocall key + 3 = virtual corelet
videocall key + 4 = wincore
videocall key + 5 = skin
to unload corelet:
1. itunes = press '#' then left soft key then choose 'red circle with cross inside'
2. virtual corelet = press menu then unload VC
3. wincore = press start then unload
to change corelet
unload first corelet which running then use the shortcut that i explained above, then call corelet (videocall key + 1)
attention : the heap is small and this was max heap, so don't be surprised if corelet closed suddenly with message application error..just run corelet with shortcut again and call corelet again...
about elf (press smartkey)
1. iTvolume.elf.. this elf to make itunes sound more able to be controlled..when u call corelet itunes.. run iTvolume.elf first then call corelet.. then press the volume key up until it reach max or volume down until zero in itunes..
after that use number 2 to increase the volume and number 8 to decrease the volume
2. getmypds.elf... this elf to backup your pds in drive a...
3. headset.elf... .
4. funlights.elf... the flash and keypad will blink blink if we have incoming call
5. autolock.elf... it can lock automaticly
6. Stime.elf.. it can show the time when we play java application
7. light.elf.. it was created for e770v but it can be used for v3x too.. it increase the brightness and make it dark if we do nothing to our phone..
8. hex editor.elf.. its for hex editing..
9. BT saver.elf... its recomended to give autorun.. i save all data that we download using our browser java or dekstop browser in b/recieved/
10.switch to boot.. it can used to go to bootloader.. but i don't recommend this when u want to flash an mp...
11.multibkg. elf... zedder said it can change background every 8 minutes.. it's working
12.flex editor.elf.. it's for flex (cg2 code) editing.. u can add some function using LG Flex editor
something that u must know about cg2 code or abstract flex
1. all network band i have included..
2. browser key can be used to take screenshot..
3. videocall key can be used to shortcut.. if u want to make shortcut.. just press and hold videocall key
4. smartkey for elf
5. when u play java,, u won't be distrubbed by sms.. java application priority
about cg1..
1. dualboot..
2. bootscreen changed..
3. 'software update' in phone status be replaced with enter bootloader..
4. C+C to turn on flash light when u got black out...
about drm..thanks to citroen..
it used historical drm..
about font.. thanks to $mert nick.. for creating this multifont 26 font en italy russia ukraina spain turkish with all itap...
thanks to slay to convert to different bootloader..
how to flash
1. download the correct bootloader..full charge battery first.. then backup your websession first,, flash with motokup only with slow speed..then upload your backup websession using Bezols's P2KTools P2K_Toolsor p2kcommander..
2. create folder b/recieved --(btsaver.elf function) can save any downloaded file that unsupported by motorola
3. create folder e/mobile/picture/multi (place your wallpaper to be changed automaticly every 8 minutes... multi bkg.elf)
note:
i didn't responsible for anything.. take your own risk..read all guides before flashing.. hope u like it.. don't compare with another mp..each mp has minus and plus.. any critic i'll accept to improve it next time
i want to thanks to
$mert (nick)-for multifont 25 font spain, italy en russia,turkish, with all itap..
slay- for some wallpaper and converting to another bootloader
citroen- historical drm and inspiring alot and so many help,and historical skin
zedder, mig, chick_v, only sun for some elf
semssedin- for lending me some icon drm and heartless skin and some question
paule213- for evo, and russomax skin
extreme razr v3x skin author- for extreme razr skin
black mmv2 skin author- for black mmv2 skin
desolate author- for desolate skin
elvis, for answering some question
and all people who helps me alot and answering my dump question...
forgive me if there is some one left that i mentioned...
dowload
0671 -- Download
0681/0682 -- Download
0683/0684 -- Download
Сообщение отредактировал citroen - 29.9.2009, 19:26
6 страниц V  1 2 3 > »
Ответов(1 - 9)
citroen
сообщение 11.4.2009, 9:50
MotoAuto
Из: Minsk, Belarus
Пользователь №: 95 640
uwie,
nice/ good work
uwie
сообщение 11.4.2009, 10:47
thanks to all people in motofan.. sory for beginner.. how to mirror in this forum?
mettis
сообщение 11.4.2009, 11:38
Пользователь №: 174 854
Прошивка: 85
как я понимаю в этом монстре нету русского языка?
citroen
сообщение 11.4.2009, 11:40
MotoAuto
Из: Minsk, Belarus
mettis,
а 1 пост читать кто будет ????
mettis
сообщение 11.4.2009, 14:08
Прошивка: 85
Цитата(citroen @ 11.4.2009, 17:40) *
mettis,
упс, точно shuffle.gif просто по энглиш не бум-бум...вот бы описание на русском)
jzy20
сообщение 12.4.2009, 1:37
Пользователь №: 177 583
Модель телефона: E770V
Прошивка: R25
great
you did it
uwie
сообщение 12.4.2009, 6:21
thanks man.. jzy20 is there any elf for v3x..??
jzy20
сообщение 13.4.2009, 2:01
Прошивка: R25
uwie,
now?
NO
we can not get the src of the other elves,
so many elf we can not solve
(13.4.2009, 11:56):
laugh.gif laugh.gif so good!!!
(13.4.2009, 11:58):
很个性的桌面,呼呼
CrashX
сообщение 13.4.2009, 5:55
Из: Севастополь-Барнаул
Пользователь №: 39 257
Модель телефона: Moto MAXX
Прошивка: self.custom()
good work!!!
а как он сделал дрм, вертикальный? это что где менять пришлось? и часики еще в статус строке при включеной яве как у SE?
abstract mp v3x by uwie, abstract mp v3x by uwie · Кастомные прошивки для Motorola 3G · Forum
Текстовая версия Сейчас: 17.5.2024, 15:17
