12 страниц V < 1 2 3 4 > »
E8_silence-7, Мод на основе 13r_e (обновление от 26.02.13)
smaylik
сообщение 15.11.2010, 18:37 Закрепленное сообщение!
Пользователь №: 173 531
E8_Silence-7
Autor: D-Boy
Based on: R6718_G_71.10.13R_E
Описание
Originally Posted by D-Boy
E8_Silence-7_Magicbox/ProcessMgr_13R_FW, I'm back...
Make sure that non-modded phones first be flashed with the correct version of noRSA bootloader!
When flashing is done, it's best to do master clear (Delete All Data) to achieve the best operating results!
Master Clear (Delete All Data):
Menu - Settings - Phone settings - Reset - Delete all data (Password: 000000)
Built-in input reason, the main clearance time is longer, about two minutes, please be patient!
I am the Lord because there is no clear result of the use of the obligation is not answered!!
I will begin by thanking those who contribute to the development of E8: ilove3D,龙 猪,泪,蜜蜂,maybeloveu,爱因,无印,Ro1ne, too many of them, endless lists, in short, thank you very much!
Thanks to ilove3D for the Magicbox, very powerful Task Manager, to 泪 for mgxInstaller, Rokr Mgr, Rokr tools and maybeloveu for the ProcessMgr.
Brush Pack is based on the ilove3D's Pro3 changes.
In accordance with their own ideas to add something.
I modified the package has always been the pursuit of speed and stability, unnecessary little things to add.
Divided into two versions, Magicbox version and ProcessMgr + Mpkgbox2.0 version.
Magicbox need to register, see the specific registration www.magxcn.com
for the free version, available to Friends of the machine is not up.
To maintain system stability, I do not like the built-in switch programs directly, so we only choose to forward to. CG36, CG46, CG52 components are used in cramfs format, improve system speed.
Brush Pack main features are as follows:
Both versions have built-in tears mgxInstaller, can choose to install into the menu or mpkgbox mgx or magicbox.
set which adds tears Rokr Mgr.
Built-in input methods. But need to manually import the theme and character input method.
After completion of the main brush clearance, the MarsInput folder into the phone memory unKnown can be.
\ MarsInput \ db may be replaced by your own font.
\ MarsInput \ theme can put themselves under the subject input method.
To keep the system speed at highest possible, sub-menu icons are disabled, you can enable them by yourself.
Sub.mgx
Also provides us with tears of gratitude to remove the installation tool in the menu mgx Mpkg Mgr, Thank you very much!
mpkg_mgr.mgx
For memory card partitioning you can use ilove3d's partitioner.
e8_parter_fixed.mgx
Other specific plug-it:
Note: This package in addition to built a music radar, but not built, or any other mgx java software, all software installed machine of their choice friends.
Set according to capture breath after running, choose to start automatically, after each boot can be automatically run.
If you press the music button after power is not exhaled, more like twice. After the first breath, after press time will be able to exhale.
the outgoing speed is fast.!
I thank those who have supported Friends of the machine, very grateful!
Скрины
E8_silence-7_Mod_ver_1.1
Перепакованная мной версия мода, пока тестовая.
Особенности:
- добавлен русский язык
- libezxappbase.so.1.0.0 заменена на патченую
- убраны китайские твики
- MagicBox заменен на MgxBox
- переработано меню
- авторан свапа на 3ий раздел флэш карты
- поддержка ext3 и ext2 разделов
- добавлен zCpuOverclock
- zTaskMan на зеленой кнопке
- Активировано HSA
- в файловом менеджере пункты ext и root
- EasyTheme как в zMod'e
- и по мелочам всякое
Если есть какие-либо пожелания или найдете баги пишите.
Известные БАГи сборки на данный момент( в следующей версии постараюсь устранить)
- не работает кнопка "нотка"
Установка
-Удалить все автораны с телефона и карты памяти, шрифты и прочую ерунду.
-переключиться на стандартный скин.
-Прошейте No_RSA_boot (если у вас его нет)
-Настройки\Настройки телефона\сброс\"Удалить все данные"
-прошейте монстр.
-если телефон не загружается, прошейте CG31 для своего бута.
-подождали 10 минут, после включения телефона и Настройки\Настройки телефона\сброс\"Удалить все данные" (Может показаться,что тел завис, это не так)
-после включения ждите 10 минут... перезагрузите телефон вручную.
-после включения ждите 10 минут. Телефон готов к использованию.
Скачать
E8_Silence-7_ProcessMgr_13R_FW.rar - http://u.115.com/file/t1bd5b56a9
E8_Silence-7_MagicBox_13R_FW.rar - http://u.115.com/file/t166a2a594
E8_Silence-7_Mod_ver_1.1 - http://depositfiles.com/files/x6mbu9djz
Версия 1.3.1 от J()KER'a
Описание
Скачать
Сообщение отредактировал Sereg_K - 4.3.2013, 8:47
K()t
сообщение 19.11.2010, 7:39
Из: Niko City, Ukraine
Пользователь №: 202 229
Прошивка: CM
pes992, Попробуй сток, а потом З-Мод
pes992
сообщение 19.11.2010, 8:04
Из: Кемерово
Пользователь №: 184 606
Модель телефона: V80,Е398,XT5
Прошивка: Android 2.2
K()t,
В Рдс почему то кнопка старт не жметься
N!kola
сообщение 19.11.2010, 8:27
Из: Сербия
Пользователь №: 144 136
Модель телефона: E398(x2) | ROKR E8
Прошивка: Anarchy48R | Z-Mod
Temporary solution for the music button!! Use RokrToolsPro smile.gif set feature "Set keyboard shortcut" ON! Now when you press the music button RokrTools will open and when you hold it the MusicPlayer will open smile.gif
Cheers!
K()t
сообщение 19.11.2010, 9:34
Прошивка: CM
pes992, переименуй прошивку 1.sbf, кинь её в корень диска С.
pes992
сообщение 19.11.2010, 9:49
Из: Кемерово
Прошился,но только с другого компа,не знаю в чем дело
Сообщение отредактировал pes992 - 19.11.2010, 9:50
K()t
сообщение 19.11.2010, 9:52
Прошивка: CM
pes992, такое частенько бывает на "Семёрках" и "Вистах"
pes992
сообщение 19.11.2010, 11:27
Из: Кемерово
на семерке сначала ставил-не пошло,на другом компе точно такае же семерка и прошился
CurtizZ
сообщение 19.11.2010, 12:27
Пользователь №: 219 228
Модель телефона: Moto G3 1\8
N!kola,
I've tested E8_Silence-7. I think there isn't special advantages.
P.S. Installed Myth 1.1 again...
P.P.S Is only one Myth is existing? I saw here "Last Myth" if I'm not mistaken...
smaylik
сообщение 16.12.2010, 14:41
Новая сборка 1.2
- Кнопка "нотка" работает
- Все скрипты теперь не русском и английском
- Изменена программа работы с темами
- Исправлен косяк с Mplayer'ом
- Мелкие исправления (конфиги и пр.)
http://depositfiles.com/files/6zegvn7mf
Сообщение отредактировал smaylik - 16.12.2010, 14:52
yomoyo
сообщение 21.12.2010, 12:25
Из: Одесса
Пользователь №: 182 416
Модель телефона: с650-l7-v3i-e8-charm
Прошивка: та всякие
так как монстр? что-то 5 дней и ни одного cry.gif поста_)
E8_silence-7, Мод на основе 13r_e (обновление от 26.02.13) · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 21.6.2024, 21:10
