Dirty Fingers MP B7R, v360
dirtyfingers
сообщение 4.10.2008, 1:56
Из: Argentina
Пользователь №: 182 852
Модель телефона: v360
[HR]
Firm Description:
Firm B7R (a little faster in operation and slightly better signal reception that ACR).All changed with the latest versions of patch´s Iceman using soft Resman.
CODE
Acess_to_semm_from_corelet_1.0
Activity_main_Display_1.0
Alarm_clock_icon_1.2
Backlight_ + _JAVA_1.0
Bitrate_1.0
BlackList_3.01
Bluetooth_time_1.0
BugFix_recieve_EMail_1.2
Change_order_in_menu_1.0
Charge_1.0
Clock_in_Status_Bar_1.52
CORElet_in_Menu_1.0
Corelets_in_java_list_1.0
Debug_on_1.16
Discharge_tone_1.0
Full_Java_List_improved_from_menu_2.0
Increase_iTap_Dictionary_2.0
Invert_color_of_Bootsplash_in_Java_2.0
iTAP_in_Corelet_1.0
Java_run_in_DBK_without_Confirm_1.0
Java_work_with_cable_2.2
Key_tone_in_Java_1.0
Layout_1.0
Lock_delete_call_by_changed_SIM_1.0
Master_reset_clear_1.0
MMS_1.0
Name_and_time_in_ALMCLCK_1.0
New_format_MMC_1.0
Night_mode_3.0
No_busy_audio_channels_by_Low_Batt_tone_at_playback_and_talk_with_increase_inter
val_between_disharge_tone_1.0
No_distinctive_alerts_1.0
No_menu_after_foto_1.0
No_Sound_Cam_for_Silent_style_1.0
No_tone_for_change_volume_1.0
Pseudo_play_list_1.0
Reboot_in_SW_upgrade_1.0
Redial_time_1.0
Remove_dir_from_flash_1.0
Remove_dir_from_phone_1.0
Remove_drm_protect_1.0
Remove_tone_for_change_devices_if_playing_music_1.0
Replace_funk_of_soft_key_1.0
Replace_Tap_iTap_by_Green_key_1.0
SMS_report_2.0
Write_Lock_Seem_1.0
Zoom_1.0
USB Charge Menu
Corelet
[HR]
DRM Description:
L7drm100_modv1.4 by trickybitch
IPB Image
QUOTE
Alright, coz quite a few ppl downloaded my mod, im giving or updated version of it:
I've changed few more icons to match full bar of battery / Mette signal. DRMs are speeded up with motospeed by 50-60% as well.
Credits to creators of DRM 100% green and glossy: Xuan Anh and NiNJaHw.
[HR]
Langpack Description:
Font "Minimal" by Bullfrog
IPB Image
[HR]
Flex Description:
The skins belong: Ifield, Royal Blue, Black2edit by JithinSK / SnowFire by , Amorablue by 蓝色眼泪/ GreenBirdV2.1 by Mtin / Moto ko, Motoedy by 或许 / Blue by ANDdREj.
IPB Image
Wallpaper taken from a pack that walks around without turning author known.
IPB Image
Last version of all applications including Java (authors in the image).
IPB Image
Integrate the most useful applications that require access to the file system to virtual corelet because the firm does not accept this from midlet. All residents plugins were erased to improve speed.
Since mototool can be configured:
CODE
Beginning as night (0-23)
End of night mode (0-23)
Time light of external display (1-10)
Using without CHIP (0 = yes / no = 1)
Change ringing quickly to hold pressed * (1-5)
"-" Telephone numbers (0 = yes / no = 1)
Home week in the calendar (0 = Sun / Mon = 1)
Time of discovered BT (1-10)
Order (0 = Name / 1 = Time)
Sound low battery (6=low/99=high/234=null)
Blacklist (0 = category "blacklist" is blocked / 3 = off)
IPB Image
Change the menu "Web Access" with a list of applications that use WAP more useful.
IPB Image
Most belong to sounds including Iphone.
IPB Image
EMS taken from the MP of motoKDE osta and dimka of motofan.ru
IPB Image
Menu Management with flip closed by Yuet
IPB Image
You can:
CODE
Changing the style ring
Place a call to some recent issue
see the storage space
Enabling and disabling alarms
Changing the mode of connecting USB
Turn on and off the BT
Record sound with Dictaphone
EDGE enabled, Quaband activated, and another bunch of changes made by SEEM.
The applications do not ask for access (j2me_domain_registry.sm modified)
Sound improved (gain_table.bin and param_table.bin modified)
[HR]
Note:
Look in a/mobile/settings/ and find seemlist.txt, now edit it for have option in mootool in your language). If you no use english or spanish need edit a/dnp.prf before change langpack. Change name of shortcuts to your language.
Change a/websession.bin with file of your local operator. Remember edit MMS option.
Only flash your phone with RSDlite. The .SHX is compiler to 08.A0. Recompiler for other boot is need.
If you want can active sound key, all the necessary files are included, but i think that it make slow the phone.
The second category of the phonebook is the blacklist. Care to restore your phonebook backup.
If your language no use standar simbol like Chinese, Russian, Arabic then you need activate seem "sms unicode".
If you set work without CHIP and your SIM have pass then you phone can not connect to line provider.
[HR]
Download:
IPB Image
[HR]
Ответов(1 - 9)
ed101
сообщение 4.10.2008, 11:29
Пользователь №: 67 945
Модель телефона: RAZr V3e
Azamyha
сообщение 10.10.2008, 9:13
Пользователь №: 152 271
Модель телефона: L7 red
Прошивка: MotoWalkman L7
объясните, пожалуйста, как можно поставить эту прошивку на Л7? dirtyfingers,can you give the password?
Сообщение отредактировал Azamyha - 10.10.2008, 9:18
Motoroler2006
сообщение 10.10.2008, 10:31
Пользователь №: 81 921
Модель телефона: L7 & V535->620
Azamyha,
тут ясно написано что монстр для v360 и пасс тоже: v360
Сообщение отредактировал Motoroler2006 - 10.10.2008, 10:34
Calvin Klein
сообщение 12.10.2008, 8:24
MyMoto
Пользователь №: 110 201
Модель телефона: E8
Прошу автора монстра лично перевести описание монстра на русский! thumbsup.gif
dirtyfingers
сообщение 12.10.2008, 16:17
Из: Argentina
QUOTE(Calvin Klein @ 12.10.2008, 5:24) *
I find it very difficult to translate Russian. I do not know if these asking me to translate the description or whether those asking me permission to do so. If you can translate the MP and the description of Russian, do it thumbsup.gif
QUOTE(Azamyha @ 10.10.2008, 6:13) *
the pasword is: v360
Ossir
сообщение 3.11.2008, 5:00
Пользователь №: 181 308
Модель телефона: Motorolik l7
А этот монстр можно поставить на л7? Он поддерживает руский язык? Автор нерусь?
dirtyfingers
сообщение 5.11.2008, 1:48
Из: Argentina
no way ! it is b7r
used only firm xxx_rb in your phone
MonstrE1
сообщение 10.11.2008, 13:04
Из: Нижний Новгород
Пользователь №: 79 096
будьте добры выложте скины с етого монстра!
они ведь 176x220 ?
vilgus
сообщение 6.12.2008, 7:16
Пользователь №: 72 240
Прошивка: 5AR
кто нить ставил?
Текстовая версия Сейчас: 23.5.2024, 3:08
