[modded]: L6i_R3443H1_G_0A.65.0BR + ELFs, Motorola SLVR L6 custom firmware by EXL
сообщение 15.3.2024, 8:00 Закрепленное сообщение!
For English speaking members
Custom firmware with ported and expanded ElfPack v1.0 with stock and original content for Motorola SLVR L2, SLVR L6, SLVR L6i, SLVR L6g, and similar phones. The ELF library was seriously updated and new ELFs were ported and added.
The firmware is prepared on the R3443H1 platform and is suitable for many phones like L2, L6, L6i, L6g, V19x, and some others on Neptune LTE SoC with a screen resolution of 128x160 cSTN and 8 MiB RAM. This platform has an auto-keypad lock. Separately, there is DRM with original new icons.
S/W: R3443H1_G_0A.65.0BR
Flex: SE5411AXXU10AB
Installation:
01. Charge the battery.
02. Enter Boot Loader mode by simultaneously pressing *, #, Red key when the phone is turned off.
03. Install Motorola USB Driver v3.7.0: 32-bit | 64-bit.
04. Connect the phone to the PC.
05. Flash the SBF firmware file using RSD Lite 3.8, you can flash it from under a virtual machine, see for more details the topic: Virtual machine images for Motorola, WinXP and Win2K phones for VirtualBox and VMware Player.
06. Additionally, you can flash the SBF firmware file of the updated graphics DRM package.
Changes:
01. CG1, CG7, CG18: RSA bypassed.
02. CG1: Changed Boot Screen.
03. CG1: All ELF patches have been added.
04. CG2, CG4: MotoMixer menu item was activated and renamed to ELFs.
05. CG2: FEM activated.
06. CG2: JAL activated.
07. CG2: *#9999#
08. CG2: Opcode Hand-Test-Command (Menu + 048263*) activated.
09. CG2: Added ELFs.
10. CG15: Timings in DRM/CG15 have been reduced.
11. CG2: Added various stock content.
12. CG1: Added the ability to remove SIM-Lock.
13. CG2: Funlight/Club Lights activated.
14. CG2: Increased volume in gain_table.bin and param_table.bin files, fixed file attributes.
15. CG1: MP3 bitrate limit increased to 320 kbps.
16. CG1: Removed message about "Invalid battery".
17. CG1: Added Java patches for access and signature bypass.
18. CG4: Fixed Cyrillic bold font in the Web browser.
19. CG4: Fixed ID3 tags in MP3 in Win-1251 encoding.
A description of some ELFs can be found in the ELFs by EXL: Nostalgia of development for Motorola P2K.
Attention! Some ELF applications require a running and minimized any Java application.
Task List:
01. CG1: Switch to the next track in audio player and video player.
02. CG1: Activate charging on "Invalid battery".
03. CG1: Port TFPG tasks.
01. -=Smart=-: for the idea of ​​creating firmware with original content.
02. Andy51: for ElfPack v1.0 and PortKit!
03. baat: for testing on Motorola SLVR L6.
04. Nordmind: for testing on Motorola SLVR L6i.
Mirrors:
01. https://firmware.center/projects/EXL/L6i_R3...25-Mar-2024.zip
Кастомная прошивка с портированным и дополненным ElfPack v1.0 со стоковым и оригинальным наполнением для телефонов Motorola SLVR L2, SLVR L6, SLVR L6i, SLVR L6g и подобных. Была серьёзно обновлена ELF-библиотека и портированы новые ELF'ы.
Изображение Изображение Изображение Изображение Изображение
Прошивка подготовлена на платформе R3443H1 и подходит для многих телефонов по типу L2, L6, L6i, L6g, V19x и некоторых других на Neptune LTE SoC с разрешением экрана 128x160 cSTN и количеством оперативной памяти 8 MiB RAM. На этой платформе имеется автоблокировка клавиатуры. Отдельно имеется DRM с оригинальными новыми иконками.
Установка:
01. Зарядить аккумулятор.
02. Зайти в Boot Loader по одновременному нажатию *, #, Красная трубка, когда телефон выключен.
03. Установить драйвера Motorola USB Driver v3.7.0: 32-bit | 64-bit.
04. Подключить телефон к PC.
05. Прошить SBF-файл прошивки с помощью RSD Lite 3.8, шить можно из-под виртуальной машины, см. подробнее тему: Образы виртуальных машин для телефонов Motorola, WinXP и Win2K для VirtualBox и VMware Player.
06. По желанию прошить SBF-файл обновлённого графического DRM-пакета.
Изменения:
01. CG1, CG7, CG18: Снят RSA по методу LTE2 (хоть это и LTE телефон).
02. CG1: Изменён Boot Screen.
03. CG1: Добавлены все ELF-пачти в т.ч на увеличение System Heap.
04. CG2, CG4: Активирован MotoMixer и переименован в ELFs.
05. CG2: Активирован FEM.
06. CG2: Активирован JAL.
07. CG2: *#9999#
08. CG2: Активирован Opcode Hand-Test-Command (Menu + 048263*).
09. CG2: Добавлены ELF'ы.
10. CG15: Уменьшены тайминги в DRM/CG15.
11. CG2: Добавлен различный стоковый контент.
12. CG1: Добавлена возможность снятия SIM-Lock.
13. CG2: Активирован Funlight/Club Lights.
14. CG2: Увеличена громкость в файлах gain_table.bin и param_table.bin, исправлены атрибуты.
15. CG1: Увеличен битрейт MP3 до 320 kbps.
16. CG1: Удалено сообщение про "Недопустимую батарею".
17. CG1: Добавлены Java-патчи на доступ и обход подписи.
18. CG4: Исправлен жирный (bold) кириллический шрифт в Web-браузере.
19. CG4: Исправлены ID3-теги в MP3 в кодировке Win-1251.
Список патчей / List of Patches:
R3443H1_65.0BR_Airplane_Mode.fpa
R3443H1_65.0BR_Canvas_All_Keys.fpa
R3443H1_65.0BR_Canvas_Longkey_Timer.fpa
R3443H1_65.0BR_ElfDirectory.fpa
R3443H1_65.0BR_ElfPack_v1.0.fpa
R3443H1_65.0BR_IncreaseHeap_1400KB.fpa
R3443H1_65.0BR_Invalid_Battery_Fix.fpa
R3443H1_65.0BR_itoa.fpa
R3443H1_65.0BR_Java_Drop_Signature_Checks.fpa
R3443H1_65.0BR_Java_Unlock_File_System.fpa
R3443H1_65.0BR_Java_Unlock_System_Files.fpa
R3443H1_65.0BR_MP3_320_kbps.fpa
R3443H1_65.0BR_Register_ElfPack_v1.0.fpa
R3443H1_65.0BR_Write_Locked_PDS.fpa
Список ELF'ов / List of ELFs:
2048-P2K
Backuper
BadApple
Benchmark
Block
Dumper
ElfBox
FBrowser
FireEffect
Flex
HexEditor
MotoCMD
Neko
NumBasis
Overclock
Perlin
RedMenu
Screenshot
SeemEditor
Snake
Spout
TalkClock
Tunes
VibroHaptic
Y3D
Y3DO
Описание некоторых ELF'ов можно посмотреть в теме: ELFs by EXL: Ностальгия разработки под Motorola P2K.
Внимание! Некоторые ELF-приложения требуют запущенное (любое) и свёрнутое Java-приложение.
Список задач:
01. CG1: Переключение на следующий трек в аудиоплеере и видеоплеере.
02. CG1: Активация зарядки на "Недопустимой батареи".
03. CG1: Портировать TFPG-таски.
Спасибо:
01. -=Smart=-: за идею создания прошивки с оригинальным наполнением.
02. Andy51: за ElfPack v1.0 и PortKit!
03. baat: за тестирование на Motorola SLVR L6.
04. Nordmind: за тестирование на Motorola SLVR L6i.
Зеркала:
Прикреплённые файлы:
Прикрепленный файл L6i_R3443H1_G_0A.65.0BR_modded_25-Mar-2024.zip   ( 23.4 мегабайт ) Кол-во скачиваний: 11
Glazier
сообщение 15.3.2024, 18:00
Пользователь №: 254 102
Модель телефона: Motorola Slvr L6
Хорошая прошивка, мне понравилась!
сообщение 23.3.2024, 20:38
Glazier, You're Welcome!
сообщение 28.3.2024, 20:24
Благодаря Diokhan обнаружилась интересная особенность Motorola SLVR L2 -- те эльфы, которые используют графический 2D-ускоритель ATI Imageon W2240 на L6, не работают в случае с L2, поскольку похоже что у него отсутствует этот чип на самой плате телефона.
Сказать точно это трудно, поскольку чип W2240 находится под экраном и на другой стороне материнской платы.
В основном ATI Imageon W2240 отвечает за быстрое и аппаратное кодирование H.263 и JPEG и по сути смысла ставить его в телефон без камеры и возможности фотосъёмки и видеосъёмки у Motorola не было. Отсутствие чипа снижало конечную стоимость Motorola SLVR L2 в сравнении с Motorola SLVR L6.
сообщение 28.3.2024, 20:51
Для сравнения фотографии плат L6 с поднятыми защитными экранами и L2 с заводскими экранами. Как видно, чип ATI Imageon действительно отсутствует на L2, это видно через отверстия. Спасибо за фотографии Diokhan!
Таким образом, ELF'ы, которые используют GPU/видеоускоритель ATI Imageon W2240 работать будут только на L6.
Список таких ELF'ов:
2048-AHI (версия 2048-UIS будет работать).
BadApple (использует ATI Imageon).
Benchmark (использует ATI Imageon для GPU теста).
FireEffect (использует ATI Imageon).
Neko (использует ATI Imageon для вывода масочных изображений на главный экран).
Perlin (использует ATI Imageon).
Screenshot (использует поверхности ATI Imageon для быстрого аппаратного снятия скриншотов).
Spout (использует ATI Imageon).
Y3D (использует ATI Imageon).
Y3DO (использует ATI Imageon).
сообщение 2.5.2024, 13:22
Достался по воле случая Motorola SLVR L2, поднял экран там где должен сидеть чип ATI Imageon и там действительно пустое место.
Теперь отсутствие чипа ATI Imageon в L2 подтверждено 100%
[modded]: L6i_R3443H1_G_0A.65.0BR + ELFs, Motorola SLVR L6 custom firmware by EXL · Кастомные прошивки для Motorola SLVR L2, L6, L6g, L6i, V19x, V235 · Forum
Текстовая версия Сейчас: 12.5.2024, 3:47
