90 страниц V « < 2 3 4 5 6 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3882
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Stalker.mg
сообщение 26.10.2006, 18:06
Evil
Пользователь №: 57 954
Модель телефона: iPhone 5
~Gangs2er~, перевод приблизительный, не дословный
fixed bug with mainmenu access in java aplets
убран баг с доступом к рабочему столу из явы(вроде так)
now kyeypad autolock working full stable
автоблокировка стабильная
fast menu access without SIM card by pressing *5
если нет симки, то включи телефон и нажми * 5 и вызовется главное меню
fixed bug with flashlight (when writing SMS flashalight will no turn on)
убран баг с фонариком(при наборе текста и т.п.)
- new java plugin in MV to change extra feauters settings
новый плагин для МВ с крутыми настройками
new flex (updated MV, only stable skins, 178 SMS storage, unlimited calls history...)
новый флекс(МВ, стабильный скин, сохраняется 178 смс, безлимитный список истории вызовов)
SW now is tested and it is FULL STABLE
проша тестирована и полностью стабильна
fixed bugs in Flasher.exe, removed all files from program dir, and decreased size of exe file to 247kB
убраны баги в проге для прошивания
ORA
сообщение 26.10.2006, 18:10
Из: Ижевск
Пользователь №: 91 715
Прошивка: R373_0.2b(49R)
Список изменений:
-Исправлен глюк с выходом в главное меню из явы (я не поянл что ето)
-Автоболок клавиатуры полностью стабилен
-Быстрый доступ к меню без вставленой симкарты по нажатию *5
-Исправлен глюк с фанариком (при наборе смс не включается)
- Новый ява плагин в Медиа Вивере для изменения "особых" настроек :)
- Новый флекс (обновлённый MV, только стабильные скины, память смс 178 штук, безлимитное количество вход\исход звонков)
- Прошивка протестирована и ПОЛНОСТЬЮ СТАБИЛЬНА
-Исправлены глюки во Flasher`e (прошивальщике) удалены лишние директории и уменьшен ехе фаил до 247kв
elektro255
сообщение 26.10.2006, 18:22
Из: Poland, Siedlce
А скин MOTO удалять можно?
я не знаю
выложите плиз "new java plugin in MV to change extra feauters settings" плюс дам.... :)
проверь приложение
BackgaMan
сообщение 26.10.2006, 18:40
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Удалил ни чего не произошло!
elektro255
сообщение 26.10.2006, 19:27
Из: Poland, Siedlce
Цитата(X3MAL @ Четверг, 26 Октября 2006, 21:59)
Переведите кто нибудь пожалуйста для elektro255:
elektro255, скажи пожалуйста можно ли ставить на твою прошивку патчи, такие как передача файлов по блутус, изменение системных звуков, доступ к файловой системе,изменение блокировки, т.п. Слышал что у тебя на прошивке защита какая-то от изменений стоит, и карта другая (не так ли?), вот потому и спрашиваю, уж больно привык к любимым патчам...
you can use any patch for 49R
protected is only my signature (sw name & boot splash)
BackgaMan
сообщение 26.10.2006, 19:34
Мотоумелец
Цитата(krotE398. @ Четверг, 26 Октября 2006, 23:07)
Плизз, кто скачал можно ли залить в другое место? С сайта автора (респект ему) обе ссылки с мини оперой не дружат!
Вот кому ещё надо скачиваем здесь!
elektro255
сообщение 26.10.2006, 20:25
Из: Poland, Siedlce
постоянно включённый отчёт о доставке не всем нужен. (((
if i add this option i will make settings for turn on turn of this feature
Если это реально, пожалуйста, увеличь количество SMS, которые могут храниться в телефоне.
make more than 178 SMS can be difictual, but maybe possible to make 255 but more than 255 can be impossible to do :)
Ага, понял, просто нельзя изменять цыфровую подпись, тогда второй вопрос - а дуал-бут присутствует? Всем спасибо за ответы.
is not dual-boot in my SW, but you can install this
elektro255
сообщение 27.10.2006, 14:57
Из: Poland, Siedlce
я добавил на стороне cсылки к файлам SHX (fulfalsh,reflash)
elektro255
сообщение 27.10.2006, 19:34
Из: Poland, Siedlce
Парни у меня вопрос...Как включить что бы постоянно был отчёт о доставке(как я понял он тут присутствует,но,я отправляю смс,а отчёт не приходит)
it wil be in future SW versions. This SW is stable version of v0.2b so doesn't have nothing new
elektro255
сообщение 28.10.2006, 8:39
Из: Poland, Siedlce
elektro255, when I made full reset with this SW my phone did not start any more...
So it's a bug obviously...
And also I got some trobbles with external GPRS internet - it doesn't work at all...
all this bugs depends on flex, i don't have time to make flex, so i making only CG1 and adding my flex :) If you will you can use any flex for 4xR (motosymbian MPX398 ... ), or you can make monsterpacks based on my CG1, so please give me only bugs from CG1 not flex
about 178 sms storage:
just fill seem 0144 by FF and fill all records of seem 007D by FF, then phone should store 178 SMS (if one SMS is not longer than one record of SEEM 007D)
about *#06# and *#9999# codes
i'm replaced code of this functions by my code because this functions is useless for normal user
For another feauters in yours flex use plugin for MV or my Java app
Сообщение отредактировал BackgaMan - 28.11.2006, 19:24
Текстовая версия Сейчас: 26.5.2024, 23:54
