3 страниц V < 1 2 3
Раскриптованный DRM-контент Linux-телефонов Motorola на платформах EZX и MotoMAGX, Сохраняем наследие телефонов Motorola!
сообщение 3.2.2024, 18:02 Закрепленное сообщение!
For English speaking members
I needed to develop a utility that decrypts files protected by OMA DRM technology as part of a project to preserve a wide range of multimedia content once used in Motorola phones. Many users of EZX and MotoMAGX phones have encountered difficulties in transferring or saving unique standard ringtones, animations, images, videos, and Java applications to other devices because of DRM restrictions.
The drmhacker utility and its source code are available on GitHub:
https://github.com/EXL/drmhacker
The concept behind this utility isn't new—it was first used by Borman92 to remove copy protection from Java apps on EZX devices in EZX DRM hacker, Removing copy protection from Java applications topic. But the methods Borman92 used don't work on MotoMAGX phones, so I had to use some tools like IDA Pro and Ghidra, to dig into the MotoMAGX system SO-libraries and figure things out. In the end, I found and tested some new APIs to bypass the DRM and managed to decrypt the files.
In the following sections of the article, I will outline two methods for bypassing DRM protection. The first method can be implemented without the need for a physical device, while the second method is designed to operate directly on the phone itself.
1. Bypassing DRM Through QEMU Emulation
The method of hacking DRM protection without a physical device involves partial emulation of the phone's firmware and environment using the multifunctional QEMU emulator. DRM-protected files are tied to a specific phone firmware, but using QEMU you can emulate part of it and get decrypted files.
To use method tool, you need:
- Operating System: Ubuntu version 22.04 or newer. If you're using Windows, you should have Windows 10 with Windows Subsystem for Linux (WSL or WSL2) installed.
- Skills: You should know how to use the Linux command line and be familiar with SSH (Secure Shell) for remote connections.
- Software: QEMU, OpenSSH.
- Accounts: root:root, user:user
- Firmware: later versions Motorola EZX, all Motorola MotoMAGX.
1. Install the necessary dependencies then download the moto_drmhacker_kitchen.zip archive (mirrors are welcome!), unpack it.
sudo apt install qemu-system-arm openssh-client
cd ~/Downloads/
unzip moto_drmhacker_kitchen.zip
cd ~/Downloads/moto_drmhacker_kitchen/
2. Unpack the SBF firmware file containing the encrypted content you wish to decrypt. Use either SBF-Recalc 1.2.9.1 or RSD Lite 3.8 for this purpose. Refer to the method outlined in our guide "7. A Trick for Correctly Unpacking SBF and SHX Firmware" to ensure proper extraction using RSD Lite.
3. The following code groups are required from the unpacked firmware files:
  • CG43.smg (setup.img, contains the first part of the DRM keys).
  • CG44.smg (securesetup.img, contains the second part of the DRM keys).
  • CG52.smg (resource.img, contains all encrypted resources).
All these code groups are SquashFS images of file systems, they must be renamed to CG43.smg, CG44.smg, CG52.smg and placed inside the emulated environment.
4. Initiate the emulation to begin. Please wait approximately two to three minutes for the system to start up. You will know the process is complete when the prompt "Debian GNU/Linux 7 debian-armhf tty1" appears on the screen.
qemu-system-arm -M vexpress-a9 -kernel vmlinuz-3.2.0-4-vexpress -initrd initrd.img-3.2.0-4-vexpress -drive if=sd,file=debian_wheezy_armhf_standard.qcow2 -append "root=/dev/mmcblk0p2" -nic user,hostfwd=tcp::2222-:22
5. In the second terminal tab, transfer the required code groups to the emulator by using either SCP or SFTP, according to your preference. Use the username and password root, and accept any suggestions from SSH, such as adding the host to the "known_hosts" file.
SCP:
scp -P 2222 CG43.smg CG44.smg CG52.smg root@localhost:
root@localhost's password: root
SFTP:
sftp -P 2222 root@localhost
Connected to localhost.
sftp> put CG43.smg
sftp> put CG44.smg
sftp> put CG52.smg
sftp> quit
6. In the third tab of the terminal, access the emulated system on QEMU by logging in through SSH from Linux. The username is root and the corresponding password. Once logged in, verify that all required files are present:
ssh -p 2222 root@localhost
ls
CG43.smg  CG44.smg  CG52.smg  chroot.sh  magx-root  unsquash.sh  utils
7. Using specially prepared scripts, run the unpacking of three SquashFS images, then switch to DRM cracking mode and decrypt all encrypted files in the firmware:
./unsquash.sh
./chroot.sh
undrm.sh
uncrypt.sh
If needed, individual files within the firmware can be decrypted using the following method:
cd /usr/data_resource/picture/
8. Once the uncrypt.sh script has finished executing, you will find the resulting archive, named uncrypted.tgz, at the root of the magx-root directory. Proceed to move this archive to your host system.
SCP:
scp -P 2222 root@localhost:magx-root/uncrypted.tgz uncrypted.tgz
tar -xvzf uncrypted.tgz
SFTP:
sftp> get magx-root/uncrypted.tgz
sftp> quit
The resulting archive, containing encrypted content files, can be extracted using either a standard archiving utility on Ubuntu or through the command line in the terminal.
9. Shut down QEMU in the SSH session:
exit
poweroff
exit
The QEMU window will close after a while.
10. Please note that in the firmware for the latest generation of phones on the EZX platform, everything is similar except for the fact that the code groups are numbered differently:
  • CG34.smg (resource.img, contains all encrypted resources).
  • CG42.smg (setup.img, contains the first part of the DRM keys).
  • CG37.smg (securesetup.img, contains the second part of the DRM keys).
The code groups in EZX firmware are CramFS image files of the file systems. For convenience, it's best to unpack them using the uncramfs utility on the host machine. Subsequently, repackage them into an archive format, such as TAR or TGZ. You can then transfer these archives into the emulated environment, placing them in the directories specified by the unsquash.sh script. These directories are where you should also place the DRM keys and encrypted files. As for content from older EZX phones like the Motorola E680i and A780, it can currently be decrypted only on the devices themselves.
ps.gif Certain code groups in EZX phones can be unpacked even with an initial empty offset that consists of blank space (FF bytes). To fix this, simply remove these bytes using a hex editor, such as HxD, or the dd command-line utility.
2. Bypassing DRM by utilizing a physical phone on the EZX or MotoMAGX platform.
The process here is straightforward. First, the target device must be flashed or modified to enable the execution of third-party native executable code with using a custom firmware or a special archives that exploit vulnerabilities. Next, the appropriate utilities – drmhacker_e680, drmhacker_ezx, and drmhacker_magx – should be placed on the device. Finally, the decryption of the necessary files is carried out either through Telnet or directly via the device's console:
./drmhacker_e680 /diska/preload/java/Application.drm.jar Application.jar
./drmhacker_ezx /usr/data_resource/pictures/Picture.drm.jpg Picture.jpg
./drmhacker_magx drm_sp /usr/data_resource/pictures/Picture.drm.jpg Picture.jpg
./drmhacker_magx drm_sp /usr/data_resource/pictures/Animation.dcf Animation.gif
Thanks to the help of VINRARUS, special one-line scripts were written that allow us to slightly automate the process of decrypting DCF and DRM files in the firmware directly on the phone itself.
find /usr/data_resource/picture -type f -name "*.dcf*" | while read FILE; do F="${FILE%.*}"; drmhacker_magx drm_sp "$FILE" "${F##*/}"; done
find /usr/data_resource/picture -type f -name "*.drm*" | while read FILE; do F1="${FILE%.drm*}"; F2="${FILE##*.drm}"; drmhacker_magx drm_sp "$FILE" "${F1##*/}$F2"; done
3. Additional information and mirrors:
Here is the directory where you can download archives containing the scripted files and utilities:
https://firmware.center/projects/EXL/Motorola/DRM
Release of the drmhacker on GitHub:
https://github.com/EXL/drmhacker/releases/download/v1.0/drmhacker_linux_x86_64.zip
Debian image credits by aurel32:
https://people.debian.org/~aurel32/qemu/armhf/
https://people.debian.org/~aurel32/qemu/armel/
PUNK-398 -- For motivation, testing and idea.
mhous33 -- For testing and editing the English translation.
VINRARUS -- For one-liners scripts.
В рамках проекта по сохранению различного наследия и контента, который был использован в телефонах Motorola, мне потребовалось создать утилиту, которая расшифровывает файлы, защищённые с помощью технологии OMA DRM. Наверняка все обладатели EZX и MotoMAGX телефонов сталкивались с подобными защитами из-за которых уникальные стандартные рингтоны, анимации, изображения, видеоролики и Java-приложения было невозможно передать на другие устройства.
Собственно, саму утилиту drmhacker и её исходный код можно найти на GitHub'е:
Идея, используемая в утилите не нова и уже когда-то применялась Borman92'ом в теме EZX DRM hacker, Снятие защиты от копирования с Java-приложений, вот только на MotoMAGX устройствах DRM API, которые использовал Borman92 недоступны, поэтому мне пришлось взять в руки IDA Pro вместе с Ghidra и немного заняться реверс-инжинирингом SO-библиотек MotoMAGX. В итоге новые DRM API были найдены, а их работа проверена, что в итоге привело к успешной расшифровке требуемых файлов.
Ниже будут описаны два метода обхода DRM, первый предполагает отсутствие физического устройства, а второй будет работать на самом устройстве.
1. Использование эмуляции QEMU для обхода DRM
Метод взлома DRM-защиты без наличия физического устройства предполагает частичную эмуляцию прошивки и окружения телефона с помощью многофункционального эмулятора QEMU. Файлы защищенные DRM привязаны к определённой прошивке телефона, но с помощью QEMU можно заэмулировать её часть и получить раскриптованные файлы.
Требования: Ubuntu 22.04 LTS и выше, либо Windows 10 + WSL/WSL2, Linux command-line skills, SSH skills.
Зависимости: QEMU, OpenSSH.
Логины и пароли: root:root, user:user
Платформа: Поздние EZX и все MotoMAGX телефоны и смартфоны.
1. Установите необходимые зависимости и загрузите архив moto_drmhacker_kitchen.zip (зеркала приветствуются!), распакуйте его в любое удобное место.
cd ~/Downloads/
2. Распакуйте SBF-файл прошивки контент из которой вы хотите раскриптовать с помощью программы SBF-Recalc 1.2.9.1 или RSD Lite 3.8 (см. метод описанный здесь: 7. Трюк для корректной распаковки SBF и SHX прошивок).
3. Из распакованных файлов прошивки требуются следующие кодовые группы:
  • CG43.smg (setup.img, содержит первую часть ключей DRM).
  • CG44.smg (securesetup.img, содержит вторую часть ключей DRM).
  • CG52.smg (resource.img, содержит все закриптованные ресурсы).
Все эти кодовые группы являются SquashFS-образами файловых систем, их необходимо переименовать в CG43.smg, CG44.smg, CG52.smg и поместить их внутрь эмулируемого окружения.
4. Запускаем эмуляцию на исполнение, ждём примерно две-три минуты до приглашения системы "Debian GNU/Linux 7 debian-armhf tty1".
5. Во второй вкладке терминала перемещаем необходимые кодовые группы внутрь эмулятора с помощью SCP или SFTP, на ваш вкус. Пользователь и пароль root, согласитесь со всем тем, что предложит SSH вроде добавления хоста в файл "know_hosts".
SCP:
SFTP:
sftp> put CG43.smg
sftp> put CG44.smg
sftp> put CG52.smg
sftp> quit
6. В третьей вкладке терминала логинимся по SSH из под Linux внутрь эмулируемой системы в QEMU с паролем и пользователем root и проверяем что все нужные файлы на месте:
ls
7. Запускаем групповую распаковку образов SquashFS, затем переходим в режим взлома DRM и раскриптовываем все зашифрованные файлы в прошивке специально подготовленными скриптами:
./unsquash.sh
./chroot.sh
undrm.sh
uncrypt.sh
Если нужно, то можно раскриптовать лишь отдельные файлы из прошивки, например, таким способом:
8. После успешного завершения работы скрипта uncrypt.sh в корне директории magx-root должен появиться архив uncrypted.tgz, забираем его на хост:
SCP:
SFTP:
sftp> quit
Полученный архив можно распаковать как стандартными средствами Ubuntu, так и через терминал. В нём будут содержаться раскриптованные файлы.
9. Завершаем работу QEMU в SSH-сессии:
exit
poweroff
exit
Через некоторое время окно QEMU закроется.
10. Примечание по прошивкам последнего поколения телефонов на EZX-платформе. В них всё аналогично за исключением того, что кодовые группы имеют другую нумерацию:
  • CG34.smg (resource.img, содержит все закриптованные ресурсы).
  • CG42.smg (setup.img, содержит первую часть ключей DRM).
  • CG37.smg (securesetup.img, содержит вторую часть ключей DRM).
Кодовые группы у EZX являются CramFS-образами файловых систем, поэтому их удобнее всего будет распаковать утилитой uncramfs на хосте, затем запаковать в какой-нибудь архив, к примеру, TAR или TGZ и аналогично поместить их внутрь эмулируемого окружения, в скрипте unsquash.sh обозначены директории в которые нужно поместить DRM-ключи и закриптованные файлы. Контент из более древних EZX-телефонов, таких как Motorola E680i, A780 и ещё более ранних пока можно раскриптовать лишь на самих устройствах.
ps.gif Некоторые кодовые группы в EZX-телефонах могут распаковываться с пустым смещением, которое забито пустотой (FF-байтами) в начале. Поэтому просто обрежьте эту пустоту с помощью HEX-редактора по типу HxD или утилиты dd.
2. Использование физического телефона на платформе EZX или MotoMAGX для обхода DRM
Здесь всё просто. Целевое устройство прошивается или модифицируется для возможности запуска стороннего нативного исполняемого кода (кастомная прошивка, специальные архивы с использованием уязвимостей и пр.), затем на устройство загружаются соответствующие утилиты drmhacker_e680, drmhacker_ezx или drmhacker_magx и через Telnet или просто через консоль на самом устройстве выполняется процедура расшифровки требуемых файлов:
Благодаря помощи VINRARUS'а были написаны специальные скрипты-однострочники, позволяющие немного автоматизировать процесс расшифровки DCF и DRM файлов в прошивке прямо на самом телефоне:
3. Список раскриптованного контента / List of decrypted content:
01. Motorola AURA R1 (MotoMAGX)
02. Motorola AURA R1 Celestial Edition (MotoMAGX)
03. Motorola AURA R1 Diamond Edition (MotoMAGX)
04. Motorola ROKR E8 (MotoMAGX)
05. Motorola ROKR EM30 (MotoMAGX)
06. Motorola VE66 (MotoMAGX)
07. Motorola ROKR EM35 (MotoMAGX)
08. Motorola ZINE ZN5 T-Mobile (MotoMAGX)
09. Motorola Z6w (MotoMAGX)
10. Motorola JEWEL U9 (MotoMAGX)
11. Motorola PEBL U9 (MotoMAGX)
12. Motorola Tundra VA76r (MotoMAGX)
13. Motorola RAZR² V8 (MotoMAGX)
14. Motorola RAZR² V8 Luxury Edition (MotoMAGX)
15. Motorola ROKR Z6 (MotoMAGX)
16. Motorola RIZR Z6 (MotoMAGX)
17. Motorola A910 (EZX)
18. Motorola A910i (EZX)
19. Motorola ROKR E2 (EZX)
20. Motorola E680 (EZX)
21. Motorola E680i (EZX)
22. Motorola PEBL U9 Gold Edition (MotoMAGX)
4. Дополнительная информация и зеркала:
Директория где можно скачать архивы с раскриптованными файлами и кухню:
Релиз утилиты на GitHub:
Авторство образов Debian от aurel32:
Спасибо пользователям:
PUNK-398 -- За мотивацию, тестирование и идею.
mhous33 -- За редактирование English-перевода и тестирование.
VINRARUS -- За однострочники.
Прикреплённые файлы / Attached files:
Прикрепленный файл SBF-Recalc_1.2.9.1.zip   ( 995.37 килобайт ) Кол-во скачиваний: 16
Прикрепленный файл drmhacker_linux_x86_64.zip   ( 46.37 килобайт ) Кол-во скачиваний: 12
сообщение 20.2.2024, 0:17
20. Motorola E680
Firmware: R51_G_0F.51.A1P
Files: GSLE680T672LC017_L001_S008_P017_GSLE680T672LC017
Раскриптованный эксклюзивный контент с телефона Motorola E680, в архиве имеются анимации, изображения, видеоролики, рингтоны и звуки. Превью некоторых изображений и анимаций ниже, полный релиз в архиве.
Изображения:
Анимации:
Список рингтонов:
Список мелодий и рингтонов
MOTO_1.mid
MOTO_2.mid
MOTO_3.mid
MOTO_4.mid
MOTO_5.mid
MOTO_6.mid
MOTO_7.mid
MOTO_8.mid
MOTO_9.mid
MOTO_10.mid
MOTO_11.mid
MOTO_12.mid
MOTO_13.mid
MOTO_14.mid
MOTO_15.mid
MOTO_16.mid
MOTO_17.mid
MOTO_18.mid
MOTO_19.mid
MOTO_20.mid
MOTO_21.mid
MOTO_22.mid
MOTO_23.mid
MOTO_24.mid
MOTO_25.mid
MOTO_26.mid
MOTO_27.mid
MOTO_28.mid
MOTO_29.mid
MOTO_30.mid
MOTO_31.mid
MOTO_32.mid
MOTO_33.mid
MOTO_34.mid
MOTO_35.mid
MOTO_36.mid
MOTO_37.mid
MOTO_38.mid
MOTO_39.mid
MOTO_1.mid
MOTO_2.mid
MOTO_3.mid
MOTO_4.mid
MOTO_5.mid
MOTO_6.mid
MOTO_7.mid
MOTO_8.mid
MOTO_9.mid
MOTO_10.mid
MOTO_11.mid
MOTO_12.mid
MOTO_13.mid
MOTO_14.mid
MOTO_15.mid
MOTO_16.mp3
MOTO_17.mid
MOTO_18.mid
MOTO_19.mid
MOTO_20.mid
MOTO_21.mid
MOTO_22.mid
MOTO_23.mid
MOTO_24.mid
MOTO_25.mid
MOTO_26.mid
MOTO_27.mid
MOTO_28.mid
MOTO_29.mid
MOTO_30.mid
MOTO_31.mid
MOTO_32.mid
MOTO_33.mid
MOTO_34.mid
MOTO_35.mid
MOTO_36.mid
MOTO_37.mid
MOTO_38.mid
MOTO_39.mp3
MOTO_1.mmf
MOTO_2.mmf
MOTO_3.mmf
MOTO_4.mmf
MOTO_5.mmf
MOTO_6.mmf
MOTO_7.mmf
MOTO_8.mmf
MOTO_9.mmf
MOTO_10.mmf
MOTO_11.mmf
MOTO_12.mmf
MOTO_13.mmf
MOTO_14.mmf
MOTO_15.mmf
MOTO_16.mmf
MOTO_17.mmf
MOTO_1.mp3
MOTO_2.mp3
MOTO_3.mp3
Прикреплённые файлы:
Прикрепленный файл Motorola_E680_Content.zip   ( 23 мегабайт ) Кол-во скачиваний: 10
сообщение 20.2.2024, 0:19
21. Motorola E680i
Firmware: E680I_G_0D.C5.A4P
Files: GSOE680IT674KV006_L001_S015_P004_GSOE680IT674KV006
Раскриптованный эксклюзивный контент с телефона Motorola E680i, в архиве имеются анимации, изображения, видеоролики, рингтоны и звуки. Превью некоторых изображений и анимаций ниже, полный релиз в архиве.
Изображения:
Анимации:
Список рингтонов:
Acoustica.mid
Air.mid
Alert.mid
Amber.mid
Bells.mid
'Bit_&_Bytes.mid'
Clubland.mid
Cocktail.mid
Cosmic.mid
Ding.mid
Door_Bell.mid
Harmonics.mid
Helix.mid
Interlude.mid
MOTO_1.mid
MOTO_2.mid
MOTO_3.mid
MOTO_4.mid
MOTO_5.mid
MOTO_6.mid
MOTO_7.mid
MOTO_8.mid
MOTO_9.mid
MOTO_10.mid
MOTO_11.mid
MOTO_12.mid
MOTO_13.mid
MOTO_14.mid
MOTO_15.mid
MOTO_16.mid
MOTO_17.mid
MOTO_18.mid
MOTO_19.mid
MOTO_20.mid
MOTO_21.mid
MOTO_22.mid
MOTO_23.mid
MOTO_24.mid
MOTO_25.mid
MOTO_26.mid
MOTO_27.mid
MOTO_28.mid
MOTO_29.mid
MOTO_30.mid
MOTO_31.mid
MOTO_32.mid
MOTO_33.mid
MOTO_34.mid
MOTO_35.mid
MOTO_36.mid
MOTO_37.mid
MOTO_38.mid
MOTO_39.mid
Moon.mid
New_Flow.mid
Pacific.mid
Passion.mid
Provincial.mid
Radiance.mid
Random.mid
Reactive.mid
Reasonance.mid
Re-Invention.mid
Sensation.mid
Sky_Blue.mid
Snaggle.mid
Sonic.mid
Standard.mid
Sunset.mid
Sunshine.mid
Tempo.mid
Triads.mid
Up_and_Down.mid
Vapor.mid
Walking_Around.mid
Wild_Style.mid
Wind_Chimes.mid
MOTORAVE.mp3
MOTOREVERB.mp3
MOTOTRIPPY.mp3
MOTOYEAH.mp3
MOTOYO.mp3
Прикрепленный файл Motorola_E680i_Content.zip   ( 27.04 мегабайт ) Кол-во скачиваний: 13
сообщение 23.2.2024, 1:14
Firmware: R6632_G_81.17.04R
Files: GSJPICOHGINGOLD_S002_E002_R005_G003
Раскриптованный эксклюзивный контент телефона Motorola PEBL U9 Gold Edition, являющийся лимитированной версией Motorola PEBL U9 в золотом цвете, выпущенной в Индии. В архиве имеются анимации, изображения, видеоролики, рингтоны и звуки. Превью некоторых изображений и анимаций ниже, полный релиз в архиве.
Изображения:
Анимации:
Список рингтонов:
rt_flawless.mid
rt_glisten.mid
rt_moto.mp3
rt_seductive.mid
rt_sequin.mid
Анимации внешнего дисплея и прикреплённые файлы:
Прикрепленный файл Motorola_U9_Gold_Content.zip   ( 10.77 мегабайт ) Кол-во скачиваний: 12
Раскриптованный DRM-контент Linux-телефонов Motorola на платформах EZX и MotoMAGX, Сохраняем наследие телефонов Motorola! · Motorola на Linux OS · Forum
3 страниц V < 1 2 3
4 чел. читают эту тему (гостей: 4, скрытых пользователей: 0)
Текстовая версия Сейчас: 29.4.2024, 9:38
