a huge problem with Motorola v360, excuse me for the English
_d5
сообщение 10.6.2007, 10:02
Пользователь №: 136 783
Hello,
first of all excuse me for the english, i am from Bulgaria and my Russian is quite poor, which is a pity.
i tried to upload a new firmware on my Motorola v360, which was bought from Orange France. i am a total lamer in this sphere so i read some instructions in one of our forums. unfortunately, i didn't make a back up of the firmware, which was on my moto, but i have wrote down the versions of the files. So this was the stuff with which my phone worked:
Flex version: SE6599AXXE416F
S/W Version: R4513_G_08.B7.AER
i followed the instructions and downloaded the program RDS Lite. i pressed *,#, and the red button and the moto went in the special mode. I downloaded the "standard firmware for v360" from the forum - motofan.ru. i decided to download the most downloaded software from motofan.ru, i did so i connected the phone, the RDS lite program recognized it after the installation of the drivers, and i pressed start. than RDS lite started to "execute something" and thr procents started running to 100, i thought that everything was okay, but obviously it was not. when rds lite executed everything, it tried to restart the phone, but the procents ran to 100 and the phone didnt reboot, RDS lite than said "please reboot the phone manually" i tried, but only the keyboard lighted, and nothing else happened, the display stayed black, i disconnected the phone from the usb, i tried to start it again, but nothing happened.
I tried with some other firmwares from the site motofan.ru, but no result.
i gave up, and gave the phone to a service, after two days they said that the phone is DEAD.
i gave the phone to the biggest mobile phone company in Bulgaria, it is still there... 5 days so far, and i think that they would not be able to fix too.
Could this phone work again, is it really dead, and if it could be fixed, what should i do???
Thank you in advance!
Best regards
Usaaf
сообщение 10.6.2007, 17:09
Пользователь №: 123 072
Модель телефона: Motorola L7
Прошивка: R4513_G_08.B7.E0R
Я конечно сильно извиняюсь, но для тех кто может помочь и нифига не понял вкраце поясню:
Чел из Балгарии имеет v360, решил его перепрошить, но не сохранил бэкап...
Зато записал версии прошивки и флекса
Затем он слил rsd lite, скачал какую-то "стандартную прошивку для v360" с нашего форума,
ввел тело в флэш и начал прошивать... Когда rsd написав, что он перезагружает тело, дошёл до 100%
и таки не перезагрузил. Вообщем он сам пробывал включить, но тело только клавой мигало и не включалось. Он слил еще какието прошивки с motofan, таже фигня.
Отнес в сервис, там сказали тело сдохло. Он отнес в крупнейщую компанию, торгующую сотовыми в Болгарии, и оно еще там.
Вообщем ему интересно, можно ли чтонибудь сделать?
_d5
сообщение 10.6.2007, 19:56
I can't understand Russian...
c380гуру
сообщение 10.6.2007, 20:19
Из: Пенза
Пользователь №: 51 473
Модель телефона: iPhone 5s + 4s
Прошивка: не обновлял
_d5,
on the aer/eor it never flashing firmwares acr,abr,dcr,b7r and etc. flash standart AER or EOR firmware. may be problem more ist it.. And use rsd lie 3.0
Usaaf simply translated your message in a russian.
Сообщение отредактировал c380гуру - 10.6.2007, 20:23
_d5
сообщение 11.6.2007, 6:28
Цитата(c380гуру @ 10.6.2007, 20:19) *
_d5,
Thanks to @Usaaf for the translation, thanks to @C380guru for the help, so as far as i understand, i have messed up the phone, because i have uploaded ACR and ABR to ans AER phone, and if i upload AER firmware, will everything be okay.
Please give me a working link to RDS Lite 3, because i have RDS 2,xx.
Thanks to all of you, if i fix everything you have at least a beer from me drinks_cheers.gif
Akceptor
сообщение 11.6.2007, 6:37
За Гомеза!
Из: Ивано-Франковск@Ukraine
Пользователь №: 39 521
Прошивка: 19.5.3.obake-maxx
I'm back! May be...
_d5,
There is no need to use RSD 3.xx
U may flash your phone using even RSD-Lite 2.5 - just flash correct firmware.
But, if U want - catch the link https://motofan.ru/soft/?action=list&parent=3
RSD_Lite 3.7
Сообщение отредактировал Akceptor - 11.6.2007, 6:40
c380гуру
сообщение 11.6.2007, 13:36
Из: Пенза
_d5,
you must use rsd lite 2.5 and up versions.
a huge problem with Motorola v360, excuse me for the English · Motorola RAZR V3i, V3r, V3re, V3ie, V3ire, SLVR L7, L7 iTunes, PEBL U6, V360 · Forum
Текстовая версия Сейчас: 28.7.2025, 3:44
