L7, R4517, 1ER, Patches, Hello, I port patches to R4517.1ER, need help with more
bfielding
сообщение 22.6.2007, 6:25
Пользователь №: 139 035
Модель телефона: L7, L9
Прошивка: R4517>R4513, R452J
Hello everyone, and greetings from M3. I am bfielding. I spend most of my time porting the ACR patches over to R4517.1ER
I would like to share my patches, and also ask for help with some more.
Included Patches:
Change color when java starts 102
Change symbols order
Clear sound and vibration
Corelets in java list
Display activity
Do not delete calls on SIM change
Full java list
iTap 15k
Java work USB cable 102
Keypad lock + unlock / menu + menu
Opcode Menu + 0
Remove 911 and 112
Save photo without menu
Zoom 200% and 250%
I am needing help with these patches:
Blacklist
Night mode
Autokeylock
Send instead of Exit in phonebook
Edit instead of exit in alarms
In every case I have found the offsets, but the patch requires a unique value for each firmware to change it to. I do not know how to figure out the value specific to 1ER. I have only been changing them to the ACR value. Can anyone help? It would be much appreciated. Thank you.
bfielding
сообщение 24.6.2007, 0:10
offsets in 1er for these patches
blacklist
49FF6C
49FFB0
4A7962
i am unsure what to change the offset 4A7962 to
autokeylock
2E5E7E
526654
i am unsure what to change offset 2E5E7E to
swap name and time in alarms
27F296: 6B5A2800D0023302A063E000A063
27F3FC: 71312020
27F412: 4C16
27F44E: AB00771F3439940848E530059009
27F4A4: 2000
this patch produces a wierd result. the name of the alarm is changed to a time that is neither installation time nor alarm time
Active
сообщение 25.6.2007, 3:19
Из: Зеленоград
Пользователь №: 104 027
Прошивка: Mpx398 DeLuxe
Included Patches:
Display activity
Full java list
iTap 15k
Opcode Menu + 0
Remove 911 and 112
Zoom 200% and 250%
Blacklist
Night mode
Autokeylock
Привет всем, примите мои поздравления от M3. Я bfielding. Я потратил много времени портируя патчи ACR в R4517.1ER
Я пожелал опубликовать свои патчи, А также попросить помощи в решении некоторых вопросов.
Вложенные патчи:
Изменение цвета при запуске Явы %)
Изменен порядок символов %)
Чистый звук и вибра
Корелеты в списке Явы
Активность дисплея
Входящие/исходящие вызовы остаются после смены сим карты
Полный список Явы
iTap 15Kb
Ява работает при воткнутом USB cable 102
Блокировка клавиатуры menu + menu
Opcode Menu + 0
Удалены экстренные вызовы 911 and 112
Фотографии сохраняются сразу
Зум 200% and 250%
Мне нужно помощь со следующими патчами:
Черный список
Ночной режим
Автоблокировка
Замена "выход" на "отпр. сообщ." в телефонном справочнике
Замена "выход" на "редактировать" в будильнике
В каждом случае я нашел оффсет, но патч требует замены некоторых параметров в самой прошивке. Я не знаю как вычислить (figure out) особеннности параметров (value specific) для 1ER. Я только изменил их для параметров ACR. Может кто помочь? Это будет очень ценно. Спасибо.
bfielding
сообщение 25.6.2007, 4:41
я использую интерактивного переводчика для этого
погашения в 1er для этих участков
черный список
49FF6C
49FFB0
4A7962
я неуверен, что изменить погашение 4A7962 на
автоматический замок kaypad
2E5E7E
526654
я неуверен, что изменить погашение 2E5E7E на
c380гуру
сообщение 31.7.2007, 20:39
Из: Пенза
Пользователь №: 51 473
Модель телефона: iPhone 5s + 4s
Прошивка: не обновлял
bfielding,
please give link on a your firmware for i'm can download
and give me your icq number for my help for you
Сообщение отредактировал c380гуру - 31.7.2007, 20:41
bfielding
сообщение 10.9.2007, 3:08
Цитата(c380гуру @ 31.7.2007, 20:39) *
bfielding,
im fine now. i figured out how to flash r4517 onto r4513. thanks though.
L7, R4517, 1ER, Patches, Hello, I port patches to R4517.1ER, need help with more · For English speaking members · Forum
Текстовая версия Сейчас: 13.9.2025, 11:41
