A603NK v.2, зарубежный монстр... продолжение версии 1
lexan2888
сообщение 23.7.2007, 16:58
Пользователь №: 64 373
A603NK v.2
« on: July 18, 2007, 10:17:10 pm »
A603NK v.2
(E398 Monster Pack made by are_goenk)
Firmware : R373_G_OE.30.49R
Flex : AreGoenk
Language Packs : LP 002E (Multifonts LP)
DSP : 6235A500
DRM : are_goenk's costumized DRM
Firmware
Original R373_G_OE.30.49R with some patches :
Autokeypadlock (can be enabled and disabled using Synerj Tools)
Flashlight by pressing **
Full s/w access from java (works with Synerj Tools, GP editor, etc.)
Added 5 new symbols on key 1
Auto SMS delivery report 1.18 (fix MMS report - always included), can be enabled and disabled using Message Options menu
Change zoom when viewing picture: 50%=250% and 75%=200%
Name and time in the list of alarm clock (fix)
Store photo without menu
Java midlet display timeout
No delete Recent Calls history on SIM change
Java with the cable works
Bluetooth activity time set to 5 minutes
Cancelation of checking signature java
Change the order of menu in sound
Change the order of menu in video
Change the order of menu in camera and pictures
Change the order of symbols from (. ? ! , @ ' - _ : ; ( ) to . , ? ! : ; ( ) - @ _ ')
Change indicates of the battery
No sound on volume change
Remove all unnecessary folders from flex
Remove unnecessary TF folder
Remove RingerID for SMS
Send file through BT devided into 5 grups (each group has different icon, not using video icon)
Group 1 : htm html oms mht chm php swf
Group 2 : txt doc pdf rtf xls cdr vsd
Group 3 : exe dll ocx ax bat com ini inf sys equine sis shx smg fpa
Group 4 : zip rar 7z pb cab
Group 5 : wav avi mpg mpeg ogg mmf
Flex
Based on Motolovers flex (by Gayoe), modded by me
Smart key = iTunes, and camera key = Camera
Go to next song on iTunes by pressing handsfree button
Joy stick shortcuts: up (Alarm Clock), left (Ring Styles), right (Recent Calls) and down (Date Book)
Shortcuts (MENU + keypad number) :
1. Lock Phone (code: 1234)
2. Write New SMS
3. USB Settings
4. Quick Dial
5. Message Inbox
6. Synerj Tools
7. Change Language/Font
Skins
Stock Moto Skin (using new stock icons) as default skin
Black Walkman (based on MotoNoir skin)
iFone (with some minor modded)
BlackWidow (modded)
LunaElementR (modded)
The Hot Smile (based on The Hot One skin)
Note :
Video Camera, iTunes, Voice Dial, Airplane and USB Setting's icons change when the skin's changed(not a DRM icon).
Java Applications
iTunes Revolution 1.4 BETA 2 by Pizzadox619
Dictaphone
Opera Mini 3.1.8295
Synerj Tools
TalkTimer (stopwatch application)
Sounds & Ringtones
SMS Notification Talk as SMS alert
Chiyo-chan - Tsukurimashou (from Noebinya MP) as alarm sound
SmackMyB##chUp (from W398seXperience MP) as incoming call alert
Stock IMY tones
Using equal treble and bass Gain Table to produce good and clear sound.
Language Packs
English (multifonts : Verdana, Simpsons, Hendell Tell, Little Square and Kristen ITC)
Indonesian (Verdana font)
Boso Jowo (Verdana font), made by are_goenk
All languages can use English iTap
DRM
It's a light DRM (so the battery life should lasts longer)
No APN bug
Note :
Don't change the DRM unless you want to loose the multifonts feature (but you can change all DRM icons to suit your taste)
Additional
1 stock Moto wallpaper + 11 cool wallpapers
Screenshots
DOWNLOAD
Special thanks to :
Gayoe
Montox
zigot
elektro255
pizzadox619
eddy0904
Font makers who made all fonts in multifonts LP
Skin makers who made the skins and icons that I modded and used in this MP
All Indonesian Motolovers Forum's members
Sorry if I missed someone to thanks to
Note :
Please inform me if you found any bugs.
Please do a safe modding. Don't forget to backup first !
Unlock Code: 1084
Security Code: 413556
Krol_07
сообщение 23.7.2007, 17:06
Из: Котово [Волгоградская область]
Пользователь №: 141 459
Прошивка: Mpx398 De Luxe
Второй и последний скин прикольные smile.gif Кто нить может выложить?
ApxuBatop
сообщение 23.7.2007, 17:48
Мото-Художник
Пользователь №: 65 512
Модель телефона: iphone 5
Прошивка: от Е398
Самый нормальный скин - это первый.
Яуген
сообщение 23.7.2007, 18:14
Пользователь №: 101 871
А как можно увидеть дрм? smile.gif Выложите плиз скины
sadface
сообщение 23.7.2007, 18:54
Пользователь №: 110 110
Модель телефона: Z6 + Kingston 2GB
Прошивка: 44R + PE
Блин возможно монстр и клёвый но перевод бы не помешал. А то ctrl+c ctrl+v каждый заделает.
А 2 скин улёт.
Zhenek_
сообщение 24.7.2007, 20:07
Пользователь №: 128 350
Модель телефона: HS820
да а перевести не кто не может.......
Pandorec
сообщение 24.7.2007, 20:43
Из: Украина>Днепр
Пользователь №: 106 159
Модель телефона: ...E398>Rokr E1
-Автоблок клавы
-Фонарик на **
-Полный доступ из явы (Работает с Synerj, GP editor, etc.)
-Добавлено 5 символов на кнопку 1
-Автоматический смс отчет (для ммс всагда вкл) может быть активирован и дизактивирован через настройки
-Изменен зум при просмотре картинок 50%=250% and 75%=200%
-Имя и время будильника
-Сохранение фото без меню
-Ява мидлеты показываю таймаут??? Это я не понял
-История звонков не удаляется при смене симки
-Ява с кабелем работает
-Время работы БТ 5мин
-Изменено порядок меню в Аудио, видио, камере и картинках
-Изменен порядок символов (. ? ! , @ ' - _ : ; ( ) to . , ? ! : ; ( ) - @ _ ')
-Изменен индикатор батареи
-Нет звуков при изменении громкости
-Удалены ненужные папки их телефона и флешки
-Удален ID звонка на СМС
-Передаваемые файлы по БТ делятся на 5 групп (Каждая группа имеет свой значек, не значек видео)
Flex
Построен на Motolovers flex (by Gayoe), моддифицирован мной (им)
Смарт кнопка = iTunes, кнопка камеры = камера.
Переход на другую песню при нажатии кнопки на наушниках.
Положение джойстика Вверх = Будильник, Лево = стили оповещения,
Право = Пропущеные звонки, Вниз это я не знаю что... походу спавочник
МЕТКИ:
2. Write New SMS
3. USB Settings
4. Quick Dial
5. Message Inbox
6. Synerj Tools
Примечание:
Иконки Камеры, голосового набора,режима полета и ЮСБ синхронизации меняется при смене скина (Они не в ДРМ)
Перевел сходу.... если что извеняйте... чем смог - тем помог
Сообщение отредактировал Pandorec - 24.7.2007, 20:57
volkin
сообщение 25.7.2007, 9:01
Из: Казанда
Пользователь №: 117 767
Прошивка: 255_mod_v0.3_49R
Да не это перевести надо было. А монстр на русский!))
RomarioMOTO
сообщение 25.7.2007, 21:42
Из: Иркутск- сити
Пользователь №: 92 891
Прошивка: eMOD v. 0.3
Ну это вообще глупо.. Монстр перевести на русский можно установив русский ленг
Яуген
сообщение 27.7.2007, 11:02
RomarioMOTO, вообще-то все говорят, чтобы надо бы описание на русский перевести, ты немного не въехал biggrin.gif biggrin.gif
Rnb and Rap 26 Rus
сообщение 27.7.2007, 15:06
Из: 26 Rus
Пользователь №: 127 331
Модель телефона: HTC One (m8)
Прошивка: Андрей 6.0.1
Homo pumpies - человек качающийся!
Ничё экстраординарного не появилось...Да и скины не очень...
DirecT
сообщение 28.7.2007, 12:03
Пользователь №: 131 343
Прошивка: MotoWalkman49R
Выложите скины кто скачал и прошился. Заранее спасибо....
Nikola89
сообщение 29.7.2007, 18:58
Пользователь №: 120 287
Модель телефона: v500
Прошивка: 373_49
мда..почти что было то и осталось..скины 2 и последний ни чего а остальные так се...не очень то впечатлили..
Blaze
сообщение 30.7.2007, 10:21
MOTO Chemist
Из: г. Данков
Пользователь №: 43 325
Прошивка: R3624_G_0B.93.0CR
A603NK v.2 49R для E398
Flex : AreGoenk
Language Packs : LP 002E (Мультишрифтовой LP)
DSP : 6235A500
DRM : are_goenk's
Прошивка :
Оригинал R373_G_OE.30.49R с некоторыми примененными патчами :
1. Автоматическая блокировка клавиатуры (может быть включена и отключена при помощи Synerj Tools)
2. Фонарик при нажатии **
3. Полный доступ java (работы с Инструментами Synerj, редактором GP, и т.д.)
4. Добавленны 5 новых символов на клавише 1
5. Автоматическое оповещение о SMS сообщении 1.18 (MMS оповещение - всегда включенно), можно включить и отключить в меню сообщений
6. Изменен zoom, при просмотре изображений: 50 % = 250 % и 75 % = 200 %
7. Название и время в списке будильника
8. Сохранение фото без использования меню
9. Java midlet отображает время блокировки
10. Не удаляются Последние вызовы при смене SIM-карты
11. Работа java с кабелем
12. Время обнаружения Bluetooth 5 минут
13. Отмена проверки подписи java
14. Изменен порядок меню в Мелодиях
15. Изменен порядок меню в Видео
16. Изменен порядок меню в Камере и Картинках
17. Изменен порядок символов (. ? ! , @ ' - _ : ; ( ) to . , ? ! : ; ( ) - @ _ ')
18. Изменен индикатор батареи
19. Отсутствует оповещение о повышении или понижении громкости звука
20. Удалены все ненужные папки из Flex
21. Удалены все ненужные папки с карты памяти TF
22. Удалено ID оповещение о SMS
23. Отправка файлов по Bluetooth в 5 групп (каждая группа имеет разные иконки, не используя видео иконка)
Группа 1 : htm html oms mht chm php swf
Группа 2 : txt doc pdf rtf xls cdr vsd
Группа 3 : exe dll ocx ax bat com ini inf sys equine sis shx smg fpa
Группа 4 : zip rar 7z pb cab
Группа 5 : wav avi mpg mpeg ogg mmf
Flex :
* Основан на Motolovers flex (by Gayoe), модифицированный are_goenk
* Смарт клавиша = iTunes, и клавиша камеры = Камера
* Переход к следующей песне в iTunes by pressing через handsfree при нажатии кнопки
* Иконки рабочего стола: вверх (Будильник), влево (Стили оповещения), в право (Последние вызовы), вниз (Ежедневник)
* Метки (МЕНЮ + число) :
1. Блокировка телефона (Код: 1234)
2. Написать новое сообщение
3. USB синхронизация
4. Быстрый набор
5. Входящие сообщения
6. Synerj Tools
7. Изменить Язык/Шрифт
Скины :
* Stock Moto Skin (использует новые значки) скин поумолчанию
* Black Walkman (основан на MotoNoir)
* iFone (с некоторой незначительной модификацией)
* BlackWidow (модифицированный)
* LunaElementR (модифицированный)
* The Hot Smile (основан на The Hot One)
Примечание :
Видео Камера, iTunes, Голосовой набор, Режим в самолете и значки Настройки USB изменяется, когда происходит замена скина (значки из DRM не используются).
Java-приложения :
* iTunes Revolution 1.4 BETA 2 by Pizzadox619
* Dictaphone
* Opera Mini 3.1.8295
* Synerj Tools
* TalkTimer
Мелодии :
* SMS оповещение с голосом
* Chiyo-chan - Tsukurimashou (из Noebinya MP) установлен в качестве оповещающего звука
* SmackMyB##chUp (из W398seXperience MP) установлен в качестве звонка
* Пара IMY тонов
Языковой пакет:
* Английский язык (мультишрифты: Verdana, Simpsons, Hendell Tell, Little Square и Kristen ITC),
* Индонезийский язык (шрифт Verdana)
* Boso Jowo (шрифт Verdana), сделанный are_goenk
Все языки могут использовать английский iTap
DRM :
* Это - ускоренный DRM (таким образом срок службы аккумулятора должен длиться дольше)
* Отсутствует ошибка с APN
Примечание :
Не изменяйте DRM, если Вы не хотите лишиться поддержки мультишрифтов (но Вы можете изменять все значки DRM, чтобы удовлетворить вашему вкусу)
Дополнительно :
1 обои с Moto + 11 крутых обоев
Скриншоты :
Скачать : A603NK v.2 49R для E398 (15.17 MB)
Особенная благодарность :
1. Gayoe
2. Montox
3. zigot
4. elektro255
5. pizzadox619
6. eddy0904
7. Изготовители шрифта, которые сделали все шрифты в LP мультишрифтов
8. Изготовители скинов, которые сделали скины и значки, которые модифицированы are_goenk
9. Члены всего индонезийского Форума Motolovers
________________________
При размещении данного материала обязательно указывать автора перевода на русский язык: Blaze
tsesaleks
сообщение 31.8.2007, 19:09
Гость
Похож на Motolovers, кстати, отличная прошивка! Скачаю, сравню, какая лучше sport_boxing.gif
В друзья
gimrock
сообщение 8.9.2007, 20:16
Пользователь №: 117 253
Модель телефона: E398>E1
Прошивка: Dream a reality
дайте плиз скины, или хотябы последний
goblin
сообщение 12.9.2007, 9:33
Главный Новостник
Из: Рязань
Пользователь №: 103 933
Модель телефона: Е2
Прошивка: =Kaleidoscope=
A603NK v.2, зарубежный монстр... продолжение версии 1 · Кастомные прошивки для Motorola E398, E398B, E399, E375, E378i, C698p, E790, ROKR E1 · Forum
Текстовая версия Сейчас: 3.8.2025, 17:18
