версия прошивки и бута в ОТП, понижение версии чревато получением Critical Error DEDE
Vilko
сообщение 25.7.2007, 18:16
Мотокодер
Пользователь №: 71
ROM:100012D8 Check_OTP_values                       ; CODE XREF: start_flash_normal+Ap
ROM:100012D8                                        ; pu_main+32p ...
ROM:100012D8                 PUSH    {R4,R7,LR}
ROM:100012DA                 SUB     SP, SP, #0x24
ROM:100012DC                 MOV     R4, #0xA
ROM:100012DE;
ROM:100012DE                 LDR     R0, =long_FFFFFFFFFFFFFFFF
ROM:100012E0                 LDR     R1, [R0]
ROM:100012E2                 LDR     R0, [R0,#4]    ; long -1
ROM:100012E4                 STR     R1, [SP]
ROM:100012E6                 STR     R0, [SP,#4]
ROM:100012E8;
ROM:100012E8                 LDR     R0, =long_FFFFFFFFFFFFFFFF
ROM:100012EA                 LDR     R1, [R0]
ROM:100012EC                 LDR     R0, [R0,#4]
ROM:100012EE                 STR     R1, [SP,#8]
ROM:100012F0                 STR     R0, [SP,#0xC]
ROM:100012F2;
ROM:100012F2                 MOV     R0, #0
ROM:100012F4                 ADD     R3, SP, #0
ROM:100012F6                 STRB    R0, [R3,#0x10]
ROM:100012F8                 MOV     R0, SP
ROM:100012FA                 BL      OTP_Check_1    ; reads OTPlow64 to arg0+8, OTPhi64 to arg0+0, sets OTPlow64 bit 64 to arg0+10, sets to 1 bit64 of OTPlow64
ROM:100012FE                 CMP     R0, #0xD0      ; was device ready?
ROM:10001300                 BNE     __answ_0A      ; dev was busy
ROM:10001302                 LDR     R0, =0x10092000
ROM:10001304                 LDRH    R0, [R0,#0x1A]
ROM:10001306                 LSL     R2, R0, #0x18
ROM:10001308                 LSR     R2, R2, #0x18  ; low byte of core-ver
ROM:1000130A                 LDR     R0, =long_FFFFFFFFFFFFFFFF
ROM:1000130C                 LDMIA   R0!, {R0,R1}
ROM:1000130E                 BL      _ll_shift_l
ROM:10001312                 STR     R0, [SP,#0x1C]
ROM:10001314                 STR     R1, [SP,#0x20]
ROM:10001316;
ROM:10001316                 LDR     R0, =off_10000000
ROM:10001318                 LDRB    R2, [R0,#0x14] ; 4 - boot-ver?
ROM:1000131A                 LDR     R0, =long_FFFFFFFFFFFFFFFF; -1
ROM:1000131C                 LDMIA   R0!, {R0,R1}
ROM:1000131E                 BL      _ll_shift_l
ROM:10001322                 STR     R0, [SP,#0x14]
ROM:10001324                 STR     R1, [SP,#0x18]
ROM:10001326;
ROM:10001326                 ADD     R1, SP, #0x1C
ROM:10001328                 LDMIA   R1!, {R0,R1}
ROM:1000132A                 ADD     R3, SP, #0
ROM:1000132C                 LDMIA   R3!, {R2,R3}
ROM:1000132E                 BL      _ll_cmpu
ROM:10001332                 BNE     __coreseq_ne_OTPhi64
ROM:10001334                 ADD     R1, SP, #0x14
ROM:10001336                 LDMIA   R1!, {R0,R1}
ROM:10001338                 ADD     R3, SP, #8
ROM:1000133A                 LDMIA   R3!, {R2,R3}
ROM:1000133C                 BL      _ll_cmpu
ROM:10001340                 BEQ     __ok_check_OTP ; coreseq_eq_OTPlow64
ROM:10001342
ROM:10001342 __coreseq_ne_OTPhi64                   ; CODE XREF: Check_OTP_values+5Aj
ROM:10001342                 ADD     R1, SP, #8
ROM:10001344                 LDMIA   R1!, {R0,R1}
ROM:10001346                 ADD     R3, SP, #0x14
ROM:10001348                 LDMIA   R3!, {R2,R3}
ROM:1000134A                 BL      _ll_cmpu
ROM:1000134E                 BCS     __not_FA       ; bootver higher than in otp
ROM:10001350                 MOV     R4, #0xFA
ROM:10001352                 B       __check_otp_final
ROM:10001354; ---------------------------------------------------------------------------
ROM:10001354
ROM:10001354 __not_FA                               ; CODE XREF: Check_OTP_values+76j
ROM:10001354                 ADD     R1, SP, #0
ROM:10001356                 LDMIA   R1!, {R0,R1}
ROM:10001358                 ADD     R3, SP, #0x1C
ROM:1000135A                 LDMIA   R3!, {R2,R3}
ROM:1000135C                 BL      _ll_cmpu
ROM:10001360                 BCS     __ok_check_OTP_; corever higher than in otp
ROM:10001362                 MOV     R4, #0xEA
ROM:10001364                 B       __check_otp_final
ROM:10001366; ---------------------------------------------------------------------------
ROM:10001366
ROM:10001366 __ok_check_OTP_                        ; CODE XREF: Check_OTP_values+88j
ROM:10001366                 MOV     R4, #0xA0
ROM:10001368                 B       __check_otp_final
ROM:1000136A; ---------------------------------------------------------------------------
ROM:1000136A
ROM:1000136A __ok_check_OTP                         ; CODE XREF: Check_OTP_values+68j
ROM:1000136A                 MOV     R4, #0xA0
ROM:1000136C                 B       __check_otp_final
ROM:1000136E; ---------------------------------------------------------------------------
ROM:1000136E
ROM:1000136E __answ_0A                              ; CODE XREF: Check_OTP_values+28j
ROM:1000136E                 MOV     R4, #0xA
ROM:10001370
ROM:10001370 __check_otp_final                      ; CODE XREF: Check_OTP_values+7Aj
ROM:10001370                                        ; Check_OTP_values+8Cj ...
ROM:10001370                 BL      check_OTP_for_something
ROM:10001374                 LDR     R1, =0x5677
ROM:10001376                 CMP     R0, R1
ROM:10001378                 BNE     __exit
ROM:1000137A                 MOV     R4, #0xA0
ROM:1000137C
ROM:1000137C __exit                                 ; CODE XREF: Check_OTP_values+A0j
ROM:1000137C                 ADD     R0, R4, #0
ROM:1000137E                 ADD     SP, SP, #0x24
ROM:10001380                 POP     {R4,R7}
ROM:10001382                 POP     {R3}
ROM:10001384                 BX      R3
ROM:10001384; End of function Check_OTP_values
эта процедурка запускается в буте при включении телефона, контролирует поколения(версии) прошивки и бута. если версии меньше прописанных в отп- бут не даст запустить прошивку и выдаст на экран Critical error
версия прошивкии - соответственно это dсw CG1+1A
версия бута - dcb бут+14
рекомендую сравнивать с текущей при обновлении и сильно думать если отличия есть
Vilko   версия прошивки и бута в ОТП   25.7.2007, 18:16
Osta   а чтобы пускало и не выдавало возможно ли переука...   26.7.2007, 6:07
Vilko   Osta, эти значения и проверка - в буте. который м...   26.7.2007, 6:24
Archy   Вылечил DEDE так - https://forum.motofan.ru/index.p...   26.7.2007, 7:40
Osta   но версия прошивки в Cg1 ? хоть прошивку ниже мо...   26.7.2007, 8:50
Vilko   Osta, да, прошивку-то конечно можно ) только не н...   26.7.2007, 10:50
Archy   Мндаааа. Короче говоря ни новая, ни старая версия ...   26.7.2007, 12:02
AlexKooper   Почитал. Не понял. cg1+ 1А = то же самое что меша...   26.7.2007, 12:10
Archy   В том и дело что какая-то зараза каким-то образом ...   26.7.2007, 12:40
yakk   В том и дело что какая-то зараза каким-то образом...   27.7.2007, 18:01
miha-il2   А в ОТП это закрытая зона флешки или находится там...   29.7.2007, 7:48
yakk   А в ОТП это закрытая зона флешки или находится та...   29.7.2007, 8:26
Vilko   yakk, ты АБСОЛЮТНО неправильно понял. ну то-есть ...   29.7.2007, 10:10
miha-il2   А доступ на изменение запрешён на уровне железа ил...   29.7.2007, 11:41
Archy   Я всё-же спрошу, для понимания ситуации - по слуха...   30.7.2007, 6:50
Vilko   Archy, если он ставит туда старый бут+патч - то е...   30.7.2007, 7:20
miha-il2   А в ОТП может увеличиваться версия при перепрошивк...   6.8.2007, 5:51
Vilko   miha-il2, не просто может, а именно прошивка его ...   6.8.2007, 7:50
KAMTOS   А прошивка может переписать всю отп (тип бута, ime...   6.8.2007, 10:48
miha-il2   Я спрашивал по поводу: щас при перепрошивке рабочи...   7.8.2007, 5:32
logotoy73   Есть V3i с DEAD, есть запись состояния OTP до этой...   30.4.2008, 15:00
motoprogger   Какой это бут? А это какой? Выложи сюда весь ста...   1.5.2008, 9:26
-=M@STER=-   bigsmile;   1.5.2008, 22:10
KAMTOS   Была такая идея, но! в OTP нельзя понизить в...   1.5.2008, 23:15
zema00   Скажите, как можно слить с тела этот ОТП ? Ой, из...   13.4.2010, 22:21
azt59   огм, а зачем собственно?   26.4.2010, 4:59
версия прошивки и бута в ОТП, понижение версии чревато получением Critical Error DEDE · Ломаем и строим! · Forum
Текстовая версия Сейчас: 17.9.2025, 0:01
