GrandFinal-RockMantic Vers III
vertalet
сообщение 4.1.2008, 7:46
Из: России, Костромы
Пользователь №: 106 588
Модель телефона: 398, Nokia 6120
Прошивка: MotoSymba 79, 3.83
Fixed [15-DES-2007] :
- fix for no remove or delete java from TRANS_SD
- Fix bug in Firmware
- fix for all java accses
- fix for top speed accses menu
- fix Flex bugs
- fix DRM Speed
- fix Firmware for fast Corelets[VirtualCorelet]
Fixed [19-DES-2007] :
- Fixed_for_E398_Version_[19-DES-2007] :
- Fixed for no Delete Apps
- Fixed for Store Apps in Phone Memory and Trans_SD
- Fixed for Fast Accses DATA Java or making a move DATA Java
- Fixed for Enable Heap_J1100_C1496[midlet & corelet]
- Fixed CODE[xx_JAVA] for Enable Heap_J1100_C1496[midlet & corelet]
- Fixed CODE[xx_JAVA]_not_remove_java and Support Heap_J1100_C1496
- Fixed Ringstyle_in_ss for icon MisCalls
- Fixed Firmware for Stable System in CG2
- Remove Patch :
@Green call dialled & received calls(2 second back to Dialed Calls)
@Green call dialled & received calls[Not Work in my MP]
=>not stable for my Firmware_49R_Mod_by_POER
Reflash ROKR-E1 [19-DES-2007] :
- Fixed CG1 for Fast Accses JAVA
- Fixed CG1 for Fast Accses MENU
- Remove Patch Green call dialled & received calls
Update :
- Update SEEM Code
- SEEM update for no Restart in your phone
- SEEM Audio
- SEEM Video
- Best SEEM Code for Accses DATA
- Fixed WebSessions for all Operator Indonesian
Fixed Code Firmware for Work Java in Trans and Memory Phone:
Java Not Support because Code Firmware not Suport :
00168A30xx : 121C46B4xx
up to
001AC928xx : 121AB6ACxx
Mod to Support java Heap :
00168A30xx : 1203EB9Cxx
Up to
001AC928xx : 121C46B4xx
Please await GFMantic_vers4_FinishEpisodeFromManticVersion..:az :
thanks...
- PoerHardware aka RedKingMaster
- Poer@Soft
Review :
- GF-Mantic_Vers3 :
[UPDATE] 19-DES-2007
Download Full MosterPack for E398@E1[07.D0]
- Workt_GF_Mantic(E398@E1)_15.4MB ----------- Click here
Download Reflash_Firmware for ROKR-E1[0A.02]
- Reflash_for GF_Mantic(ROKR-E1)_5.64MB ----- Click here
Перевод SerKis:
Быстрая скорость меню
- Загружает любые файлы через инет
- Звук чистый и громкий (без хрипа динамиков)
- Отлично настроены SEEM
Платформа : 373_G_0E.30.49R_Mod_by_POER
Флэкс : GF_RockMantic[From High Power E1]
DSP : MOD_by_POER
Яз. пакет : Мультишрифтовый
Языки : English[5Fnt],Indonesian,BHS Madura,BHS Jowo,Malaysian.
DRM : Супер быстрое_MOD_by_POER
Защита : Пароль 1234
Преимущества :
- Все преимущества Rock_Mantic Version
- Rock_Mantic Vers2,3,3.01,4,4Final,4Final_UPDATE,
Применены все существующие старые патчи, а вот и новые:
- Смена mma_ucp вместе со скином 1.01
- увеличен хип(1100-мидлеты,1500-корелеты)
- увеличена скорость
- новые значки для входящих и исход. вызовов
- по зеленой кнопке - входящие и исход. вызовы
- аймей вызывается не по *#06# а по *9999
- безлимитный диктофон
- нет глюков при патче на убирание сс из явы
- эльфы 1.0
- жмем на смарт клавишу 1 раз-фото,2 раза-видео
- иконка включенного будильника в стутус сторке
Включает исправленые ошибки GrandFinalRockMantic II
+ Убраны все глюки с явой
+ Убраны все глюки с флэксом
+ Настроена скорость DRM
+ Убран глюк при открытии меток явы
Исправленые ошибки:
Для е398:
+ Сделано под е398
+ Не удаляются игры
+ Быстрей работают и запускаютя котлеты
+ Убран патч При удерживании зелёной входишь во входящие вызовы
+ Добавлена иконка пропущеных вызовов в статус строке вместо стиля опевещания
+ Доработаны SEEM
- Английский язык (во время прошивки уберите галочку с CG4(Языковый пакет)
Для Е1 (только Reflash):
Вот еще ссылки на версию для 398. Предоставлены Pux.
1.GrandFinal Rock-Mantic III На ifolder
2.GrandFinal Rock-Mantic IIIНа depositfiles
3.GrandFinal Rock-Mantic III На slil
З.Ы монстр не мой!! На авторство не претендую. Выложил для общего обозрения.
Сообщение отредактировал vertalet - 8.1.2008, 15:37
бес шумный
сообщение 4.1.2008, 9:33
Из: MotoFan.Ru - все для моторола
Пользователь №: 140 421
Модель телефона: MOTOMARAZM(z6,e398)
Прошивка: 373_49r/60_44r
как всегда,ничего нового...все взято у нас...
Alek1989
сообщение 4.1.2008, 10:30
Пользователь №: 98 294
Модель телефона: Rokr E1
Прошивка: R373_G_0E.30.42R
Помогите с русским ленгом для етого монстра.....Когда ставишь свой- глюк в статус строке- там де пишеться ам или рм- черный квадрат...Как исправить?
Япона атец
сообщение 4.1.2008, 20:30
Из: moto@conference.jabber.ru
Пользователь №: 154 904
Модель телефона: V3i. E1. E2
Поставь 24 часа :)
ABTOP
сообщение 4.1.2008, 20:57
Из: USSR)
Пользователь №: 148 318
Модель телефона: нету
Alek1989
сообщение 4.1.2008, 21:29
Цитата(Япона атец @ 5.1.2008, 0:30) *
Та я догадался, но все же....
SerKis
сообщение 4.1.2008, 23:14
Пользователь №: 158 904
Модель телефона: L9 (Убит)
Прошивка: S Blank Neptune LTE2
vertalet Перевод W.O.X.:
Ты наверное ошибся это мой перевод на Лэтсмото
vertalet
сообщение 5.1.2008, 9:09
SerKis, и вправду ошибся, извиняюсь, просто материал брал supertрубки, а там перевод выложил W.O.X.
Сообщение отредактировал vertalet - 5.1.2008, 9:10
Makasimka
сообщение 5.1.2008, 17:36
Пользователь №: 113 740
Модель телефона: moto e398
Прошивка: 49r
вообще прошу стоит качать?
goods
сообщение 5.1.2008, 20:40
Пользователь №: 91 380
Модель телефона: E398 + 1Gb
Прошивка: DaR
Eric Cartman
сообщение 7.1.2008, 23:09
Пользователь №: 92 405
Модель телефона: A1200
Прошивка: Silent_Bob's
У меня часы в верхней строке не отображаются. Лэнг не менял.
Сообщение отредактировал Eric Cartman - 8.1.2008, 16:36
Zhenek_
сообщение 8.1.2008, 7:56
Пользователь №: 128 350
Модель телефона: HS820
Eric Cartman,
ты ставил руский ленг?
МихАйс
сообщение 8.1.2008, 10:57
Из: г. Воронеж
Пользователь №: 63 323
Модель телефона: Moto G
goods, +1 ... и музыку выложите плиз
r.o.m.a.N
сообщение 8.1.2008, 12:19
Motoroma
Пользователь №: 95 283
Прошивка: 49R 4.4.4
- увеличен хип(1100-мидлеты,1500-котлеты)
Поправь
Аш жрать захотелось))))
Сообщение отредактировал r.o.m.a.N - 8.1.2008, 12:21
Sahka5444
сообщение 8.1.2008, 17:38
Пользователь №: 132 213
Прошивка: MPX_DELUXE 373_49r
Флуд....
goods
сообщение 8.1.2008, 18:09
Прошивка: DaR
кароч скачал этот монстр, качал по 2 ссылке, походу половины патчей вообще нету, часов в сс нет, ява не во весь экран.... но единственное что порадовало так это настойки звука
З.Ы. кому надо вот скины, музыка и картинки.
Сообщение отредактировал goods - 8.1.2008, 18:10
Zhenek_
сообщение 8.1.2008, 18:16
Sahka5444,
твоё сообщение и есть
Цитата(Sahka5444 @ Сегодня, 20:38)
Флуд....
Snap 18
сообщение 9.1.2008, 14:08
Пользователь №: 120 257
Модель телефона: C390/E398
Прошивка: R365_G_OB.03.06R
Афтар или другие пользователи, очень прошу выложить патчи и откаты для них. Интересует больше все патч на звук 320 Кбит\сек, и на откат о доставке смс. Заранее спасибо.
PItBuLL
сообщение 9.1.2008, 14:12
Из: Волгодонск
Пользователь №: 154 213
Модель телефона: Atrix 4G
как у Стаса!
Snap 18, вот тебе патч на звук 320 Кбит\сек
czShaDoW
сообщение 30.1.2008, 15:22
Пользователь №: 117 034
Модель телефона: ROKR E1
Прошивка: Mpx_e398[Final]_49R
Выложите пажалуйста дрм с этого монстра с иконками белоруских оператораторов
naykava
сообщение 6.2.2008, 16:35
Пользователь №: 74 301
Прошивка: 49R_em0.3_ns+my edit
Цитата(Snap 18 @ 9.1.2008, 16:08) *
Афтар или другие пользователи, очень прошу выложить патчи и откаты для них. Интересует ... патч ... на откат о доставке смс. Заранее спасибо.
Патч "Отчет о доставке СМС для 373_49" и откат к нему.
Прикрепленный файл Otchet_o_dostavke373_49.rar   ( 1.04 килобайт ) Кол-во скачиваний: 87
team_pro
сообщение 9.2.2008, 1:30
Из: Minsk
Пользователь №: 140 324
Прошивка: LCA
ДРМ нужно.....плиззз
Рысёнок
сообщение 9.2.2008, 13:41
Мисс Мотофан 2008
Из: Ставрополь
Пользователь №: 87 000
Модель телефона: E398+6120C
Прошивка: 49R
Diablo™
сообщение 9.2.2008, 20:53
on line
Из: Казань
Пользователь №: 66 901
Модель телефона: Samsung s24
скины классные. Может выложит кто?
toxi22
сообщение 19.2.2008, 1:19
Из: Украина, г. Житомир
Пользователь №: 163 884
Прошивка: R373_G_OE.30.44R
Здравствуйте!
Сразу извеняюсь за написание текста, так как меня уже бесит то, что:
1. В этом монстре вырубается подцветка в Java приложениях. Как это исправить?
2. Когда ставлю тело на зарядку и в это время сижу, например в Джиме, то подцветка вырубается и не включается, пока я не отключу зарядку.
3. Отображение цифр в формате ххх-ххх-хх. Как вернуть нормальный вид?
4. Не работает пункт меню "Непрерывная подцветка дисплея". Он всё-равно вырубается через 20 секунд.
Авторам данного моснтра большой респект, за то, что они увеличили heap для Java и корелетов.
Но а всё остальное подстроили "по себя", а не для всех.
Заранее спасибо...
Rene
сообщение 19.2.2008, 4:34
Пользователь №: 73 537
Модель телефона: Z6+2G
Прошивка: PE2.0
Откати патч управления подсветкой в ява приложениях.
Это включается и отключается с помощью P2Ktools, в скрытых настройках.
Сообщение отредактировал Rene - 19.2.2008, 4:36
toxi22
сообщение 19.2.2008, 5:10
Где патч можно скачать? Если не трудно, то подскажите. А то на форуме поиск наверно почистили и он практически ничего не может найти...
Такой функции в программе P2K Tools VS v3.0.1.148 и P2K Tools 0.8.6 - не нашёл ...
Rene
сообщение 19.2.2008, 5:22
Прошивка: PE2.0
toxi22
У меня в P2K Tools 0.8.6 есть.
Добавлено позже (19.2.2008, 8:26):
Скачай этот архив и все файлы из архива премести в попку с программой P2K Tools 0.8.6 << Скачать >>
Сообщение отредактировал Rene - 19.2.2008, 5:27
toxi22
сообщение 19.2.2008, 6:04
Спасибо тебе Rene. После установки файлов из архива, появилось намного больше опций... Благодарю...
toxi22
сообщение 4.3.2008, 21:54
Кто подскажет, где скачать откат патча "Управления подсветкой в ява приложениях", чтобы потсветка не вырубалась в ява приложениях...
Rene
сообщение 4.3.2008, 22:37
Прошивка: PE2.0
Попробуй вот этот. Только бэкап на всякий пожарный случай не забудь сделать.
toxi22
сообщение 6.3.2008, 5:01
Спасибо ещё раз тебе....
Yurock
сообщение 1.8.2009, 19:48
Из: DREZDEN
Пользователь №: 203 786
Модель телефона: Rokr E1&E1000
Прошивка: "Dar44"-"Wfun"
vertalet Выложи скины[b] thumbsup.gif а?
Текстовая версия Сейчас: 12.9.2025, 9:18
