someone pls show me the way to remove RSA for K1 without testpoint ? thanks !
![]() remove RSA without testpoint |
anhvu2875 |
![]() Мастер ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 249 Регистрация: 2.11.2007 Пользователь №: 152 593 Модель телефона: K1 , RAZR2 V8 2GB Рейтинг: 28 ![]() |
AstaRoth |
![]() Бошетунмай ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Группа: Почётные мотофаны Сообщений: 3 115 Регистрация: 5.11.2005 Из: СЕВЕРОДВИНСК,29, РФ ☭ Пользователь №: 57 206 Модель телефона: E2=>Zn5=>Defy+=>Nubia Прошивка: Ъбфбймус Edition ![]() Настроение: reBOOT Рейтинг: 4098.5 ![]() |
Read this theme Ура ! Снятие RSA без Тест-пойнта и разбора телефона !
Цитата Here will FAQ with all necessary. He will be updated !! Watch! The Excellent news !! https://forum.motofan.ru/index.php?act=Attach&type=post&id=153992 https://forum.motofan.ru/index.php?act=Attach&type=post&id=153993 FAQ : The Author of the method rodrigocastrill - adminstrator of cell phone Brasilian forum. the original of the subject of the entry in mode BLANK programme method. Adaptation - Osta (forum.motofan.ru) Beside foreigner all are got on yahoo and we must be not worse :-) Ithaca: on computer must be a system Windows and installed P2K driver Skachati P2K driver On hand beside you must be a telephone with completely charged batery, without sim cards and without flash-card, connect the telephone with computer it is necessary without extension plug-wires and other shit, only Telephone Native USB-cord USB Computer USB Computer , which BEHIND , rather then AHEAD OF computer! . This procedure is done 1-n once so POSSIBLE get the computer from beneath table for joining in USB port Behind! Otherwise you much risk! The Cord must be NATIVE , which was when buying. Check for your telephone on compatibility with program: Skachivaete archive and start file Start.exe , choose Vkladku Operations hereinafter handset - here choose Z3 (if beside you Z3 or L7e) or K1 (K1) Attached scene The Telephone will carry in boot-mode : you switch off the telephone, jam the buttons * and # and press redden button of the cut-in. Podsoedinyaete telephone to computer - a program his(its) is determined as Connect Choose Read Backup - and note the mark only PDS unless appears the error - save the received file and this signifies that Your telephone is supported прогой. If errors - hereinafter do not do! Disconnect the telephone from PC and do not do that is written further. You Take out and again put battery of the telephone. The Telephone will carry in boot-mode: you switch off the telephone, jam the buttons * and # and press redden button of the cut-in. If all well, that Now removes----------------------------->> RSAPODSOEDINYAETE telephone to computer - program his(its) determined as Connect Attached scene 1. You Press Write Backup and choose Z3__BOOTCORE_TP.bkp (if beside you Z3 or L7e) or K1__BOOTCORE_TP.bkp (in the event of K1). The Program will do its deal, telephone is switched off. 2. You Close the program. You Take out and again вставляете battery of the telephone. 3. You Include the telephone on red button. The Screen will be dark. 4.Телефон will be in Blank-mode. You Start program RAMLDR2 (from archive) 5. ZHmyom Send Loader, program отпишется "ready" 6. ZHmyom Write Boot - flood Boot_0AC0_patch.bin program отпишется "ok" Take out and again вставляете battery of the telephone. You Press Redden button. You Close program RAMLDR2 and start program FlashBаckup 7. We Interweave patched (refer to their list below) lace trim in Flash&backup with chosen by profile to your models of the telephone Take out and again вставляете battery of the telephone. You Press Redden button. You Close the program FlashBаckup and start the frob RAMLDR2. You Take out and again put battery of the telephone. You Press Redden button. 8. In program RAMLDR2 ZHmyom Send Loader, the program отпишется "ready"; 9. ZHmyom Write Boot - flood Boot_Start_SW.bin (the program once again must confiscate OK.) We Include the telephone, and rejoice cancelling RSA and DUALBUTU and the whole that in lace trim patched. Attention : If beside you AFTER of the whole procedure something not so with telephone and if (only if !) does not help such procedure: 1. have pulled out akkum on 1 minute from telephone. 2. Have Inserted the cord a Telephone USB port computer on Maternal charge, rather then ahead of компа! 3. have jammed * and # and not releasing them, have inserted akkum and not releasing * and # have pressed redden button 4. Since minute we wait while https://motofan.ru/soft/ РСД Lite is determined telephone. 5. If defines as "Unknown device " , that overload the computer and do all ditto once again. If defines after several such procedures ONLY as "Unknown device " , ONLY then go in subjects FAQ on TP for L7e Z3 K1 (iron Test-Point) to obtain the mode BLANK , what obtain , begin on FAQ from the first post of this subject with point "4.Telephone will be in Blank-mode. You Start program RAMLDR2 (from archive) " and on FAQу hereinafter And Use This Page Sorry bad English , because We a Russians - and drink vodka with Elk and Bear ! Сообщение отредактировал AstaRoth - 26.1.2008, 7:13 |
Текстовая версия | Сейчас: 12.9.2025, 16:50 |
