[New MP] NARUTO v1.2_49R, Монст для E398 и Rokr
Rene
сообщение 24.2.2008, 12:36
Пользователь №: 73 537
Модель телефона: Z6+2G
Прошивка: PE2.0
This MP is for ROKR with BL 0A.02 and E398@ROKR with BL 07.D0
Firmware : R373_G_0E.30.49R from Original Firmware
Flex : NARUTO_v1.2...49R
DSP : 623BAB00
GT/PT : Loud & Wide 3D Surround Sound
System Sound : Modified by me
DRM : Speed up to 50-75%
Technology : Quad-band GSM (850/1900 and 900/1800)
Web Sessions : All Indonesian Operators
Language : 002E English no iTap 6 fonts, Bhs. Indonesia, and Boso Jowo
Fonts : - Nokia Sans
- Rickshaw
- Zhang
- Amazon
- Kaneiwa
- Cafe Noirй
Phone Memory :
--Free : 235 Kb
--Used : 3780 Kb
--Total : 4015 Kb
Skin :
- Naruto-1 by mojave edited by Zh@ng-L14ng
- Naruto-2 by spiderio mod by majdi244 edited by Zh@ng-L14ng
- Naruto-3 by malas edited by Zh@ng-L14ng
Bonus Skin :
- Miss VN by songlong88
- AQUA by JithinSK
- Xin Nian by bmk33, angie1987, gechongwei, aleck36
(mma_ucp replaced DRM icons)
Pictures :
- 10 pictures for wallpaper + 30 EMS pictures
Sounds :
- 4 ringtones : 1 sound for alarm, 3 sound taken from Naruto Soundtrack
Video :
- No video
Java :
- Aero WMP iTunеs
- Dictaphone 2.0.1
- eBuddyBeta 0.91.0 build 2840
- MediaViewerApplet 1.0.0
- MiniCommander 3.2.1
- Opera Mini v3.1.7203
- PowerDown
- shMessenger Platinum 2.0.5
- SynerJ Tools v2.8 (for 49R)
- Virtual Corelet 1.27
Features :
- Abolish Alarm OFF from list
- Abolish control by illumination Java
- Access main menu everywhere
- Access to seem 004a from corelets
- Add new simbol ± І і Ѕ ј ѕ
- Alarm icon on status line
- Auto delivery report sms 1.18
- Autokeypadlock
- Autostart Java from DateBook
- Background in Player v2.3n (skin on c) fix
- Bluetooth up to 5 minutes
- Camera button : 1x camera, 2x videocam
- Cancel Destroy Activity GPRS Session
- Change display timeout activity (20 sc, 40 sc, 1 minute, 2 minutes)
- Change incoming SMS reminder time interval to 2 minutes
- Change keypadlock-unlock
- Change menu opcode
- Change menu sounds, pictures, and videos
- Change mma_ucp together with skin 3.0 (mma_ucp is taken from the folder of skin)
- Change rapid Ringstyle
- Change simbols order . , ? ! @ - : / _ & ‘ = % " ; \ ^ ~ $ Ґ Ј € ¤ © ® Ѕ ј І є * # [ ] > < ± Ч + ( )
- Change the Record Format Files on YY-MM-DD_HHMM
- Change zoom to 200% and 250%
- Clock on status line
- Complete access to the file (Java,BT,OBEX)
- Display analog clock or No digital clock on desktop
- ELF (Executable and Linkable Format) is replacing MotoMixer
- Failure Master Clear & Master Reset
- File list sort by date or alphabetical order are replacing Animation
- Flashlight shortcut (only on desktop)
- Green call dialled & received calls
- Increase Java Heap (MIDlets - 1352 KB, Corelets - 1496 KB)
- Increase Ringtone is replacing Preffered Card
- Java black background
- Java full access patch
- Java with the cable works
- Keysound (system tones) is replacing Battery Saving
- Missed Calls icon on status line (replacing Ringstyle icon temporary)
- MP3 bitrate up to 320kbps
- New Recent Calls list icon
- No del call on sim change
- No vibe and sound when changing volume
- Pseudo Playlist 5.0
- Quick access sounds & pictures (only on desktop)
- Reboot on Chat
- Reduce Level of Brightness
- Reflect Corelet in the list Java
- Removal limitation system file
- Remove DRM protection
- Remove ID the melody of subscriber from sms
- Remove Status Line in Java 1.40
- Send SMS on Phonebook left softkey
- Send file through Bluetooth divided into 5 groups with icons
- Set default Right Softkey in web sessions
- Store photo without menu
- Time and Name in the list of the alarm clocks
- Time update 10 sec
- Unlimit dictaphone
- Unlock all seems
Seem Edit :
- Call Register max 60 number
- Message Status displayed on Outbox Message
- Playing Java without interupt incoming message
- Video Recording in mp4 format
Shortcuts keys :
- * + * : Flashlight
- 0 + * : Pictures
- 0 + # : Sounds
- Green button : 1x to Dialled Calls, Hold to Received Calls
- Camera button : 1x to Picture Cam, 2x to Video Cam
- Up : Ringstyle
- Down : Phonebook
- Left : Dial Services
- Right : Tools
- Smartkey : Dictaphone
- Menu + 1 : USB Settings
- Menu + 2 : Bluetooth Setup
- Menu + 3 : Phone Status
- Menu + 4 : Personalise
- Menu + 5 : Change Skin
- Menu + 6 : Change Font
- Menu + 7 : Initial Setup
- Menu + 8 : SynerJ Tools v2.8
- Menu + 9 : Opera Mini
- Menu + 10 : eBuddyBeta
- Menu + 11 : shMessenger
- Menu + # : Change Ringstyle
- Menu + 0 : Opcode
- Menu + Menu : Back to Main Menu
For ROKR :
- Menu + Unlock keypad
For E398@ROKR :
- Menu + Red : Lock keypad
- Menu + Green : Unlock keypad
Thanks to :
- Indonesian Motomodders @ motolovers.or.id
- All Motomodders @ modmymoto.com, motohell.com, and motomodders.net
- gayoe for the porting of patches
- Montox for iTunеs
- Valleo for Virtual Corelet and MediaViewerApplet
- spiderio, mojave, malas, songlong88, JithinSK, bmk33, angie1987, gechongwei, aleck36 for skin
- om2804 for his ELFs, Andy51 for Elfpack v.1, and G-XaD for MotoCommander.ELF
- majdi244 for skin & cust_startup and cust_goodbye animations
- Crash Overburn, Exploited, JithinSK, gayoe, are_goenk, NiKSY, Motomaniacs, MATRICE@kecap, Nalimen, zigot, Taromoto, Rismayana for supports
- All Motorola Fans
Notes :
- Phone Unlock Code : 1234
- Phone Security Code : 000000
- To Delete, Move, Copy, or Assign to Categories for files on Sounds, Pictures, and Videos...
you have to Mark the file first with press "0" button
- If the iTunеs doesn't load correctly, please delete iTunеs folder on TF.
- Copy the Elf folder (incl. in package) onto your TF for running ELF.
Flash program recommended :
- Flash&Backup 3.xx (all version)
- РСД Lite (version 3 or above)
DOWNLOAD LINK :
-E398@ROKR скачать с depostfiles
-E398@ROKR скачать с rapidshare
-E398@ROKR скачать с Ifolder
-ROKR
Скачать:
Ява
Скины
Drm для E398
drm для rokr
Звук с монстра
Русский leng
Большое спасибо tsesaleks, если бы не он, этого бы монстра здесь не было!
автор не я.
Если кто поставил эту прошивку и обнаружил такую проблему что у вас нет настройки времени и даты, то это для вас:
-Скачаваем other_features
-Кидаем их в папку с программой P2Ktools
-Запускаем P2Ktools
-Ждем когда подключится
-Заходим на вкладку "скрытые настройка"
-Нажимаем считать
-Выбираем "исходная настройка"
-Снимаем галочки со второго и третьего пункта сверху, а на четвертом пункте сверху ставим галочку
-Нажимаем "записать"
-Делее перезагружаем телефон
-Радуемсяsmile.gif, теперь можно настривать дату и время вручную.
Сообщение отредактировал Rene - 26.2.2008, 18:40
kolpak
сообщение 24.2.2008, 13:13
Пользователь №: 101 401
Выложите кто нибудь его в другое место, тока не на рапиду буду благодарен
Zhenek_
сообщение 24.2.2008, 13:58
Пользователь №: 128 350
Модель телефона: HS820
стиль анимэ, вообщем оформление вообще непонравилось...
Rene
сообщение 24.2.2008, 18:45
Прошивка: PE2.0
Из -за чего выложил? скорость понравилась. drm красивый. Вообще кульный. Ну это мое мнение.
Zhenek_
сообщение 24.2.2008, 19:27
Rene,
да я ж тебя неупрекаю smile.gif Я просто высказал свой взгляд, а может кому и нравится такой стиль оформления
MARKyxa
сообщение 25.2.2008, 5:55
(/\/\)otoModer
Из: Города грехов
Пользователь №: 158 437
Прошивка: IOS
In progress
Только ДРМ прикольный, оформление мне не нравится
Diablo™
сообщение 25.2.2008, 17:24
on line
Из: Казань
Пользователь №: 66 901
Модель телефона: Samsung s24
хотелось бы отметить, что это один из немногих монстров с конкретной тематикой...
MARKyxa
сообщение 26.2.2008, 4:19
(/\/\)otoModer
Из: Города грехов
Прошивка: IOS
In progress
Diablo,
Кстати да, этот монстрик полностью придержан одной темы, в отличии от других, которые имеют кучи скинов и все на разную тему
Rene
сообщение 26.2.2008, 9:46
Прошивка: PE2.0
Если кто с английским дружит, выложите пожалуйста перевод. Перевод сделанный переводчикам не выкладывать.
DrumS
сообщение 26.2.2008, 16:05
Из: Гомель
Пользователь №: 142 234
Модель телефона: ROKR E1
Прошивка: TheLiferelease(49r)
Классное оформление и пашет быстро thumbsup.gif ( тем более что это один из моих самых любимых мультиков )) ) У меня вопрос нашел вроде баг там у тебя есть раздел ЧАТ так когда на него наводишся телефон перезагружается (
Rene
сообщение 26.2.2008, 16:39
Прошивка: PE2.0
DrumS
Это не баг, а специальный патч стоит. например хочешь перезагрузить телефон, выбрал чат, и хлоп перезагрузился
Сообщение отредактировал Rene - 26.2.2008, 18:35
Zhenek_
сообщение 26.2.2008, 17:25
Rene,
Orphen
сообщение 21.4.2008, 10:40
Пользователь №: 162 644
Модель телефона: E398, PSP Slim&Lite
Прошивка: Life II Gold xD
Хороший монстр сам на нем сидел. только очень яркий. оформление оч понравилось. но я не такой большой поклнник наруто) лучше по деф ноту сделали б МП)
MARKyxa
сообщение 21.4.2008, 11:41
(/\/\)otoModer
Из: Города грехов
Прошивка: IOS
In progress
Rene,
KILLER-UA
сообщение 21.4.2008, 13:31
Из: Луганска
Пользователь №: 146 769
Прошивка: !ЧАСТО МЕНЯЮ!
это случайно не с e398mod.com сайта?
tsesaleks
сообщение 21.4.2008, 13:35
Из: Тюмень
Пользователь №: 147 944
Прошивка: R4441D_G_08.03.05R
Оформление для детей, а скорость хорошая, я 3 дня тестил, соседке первоклашке поставил, от ей оформление очнь понравилось.
Midnight)sky
сообщение 21.4.2008, 15:04
Из: Ukraine, Kyiv
Пользователь №: 108 947
Модель телефона: N900
Прошивка: Maemo 5
По скринам - просто супер! Если б они ещё были...
Orphen
сообщение 21.4.2008, 17:10
ага поржали)) нормальное оформление блин)
MucTuk
сообщение 21.4.2008, 18:36
Из: Moscow
Пользователь №: 85 049
Модель телефона: v3x
Прошивка: 0.8.6.2
скорее всего скрины были выложены на файлообменник откуда были удалены...
от чего тут ржать? или ты считаешь что таким образом будешь выглядеть оригинально?
яндекс -> название монстра -> вот те и скрины...
Orphen
сообщение 21.4.2008, 18:44
О_о ты о чтом? я говорю хорошее оформление у монстра. сам с ним ходил недельку гдето
MoNtRaY
сообщение 24.4.2008, 20:31
Пользователь №: 170 472
Стттрёмный....монстр...
На мой взгляд кроме опеределённой тематики) как многоуважаемые уже сказали в монстре не чё и нету!(
Обидно!
MonstrE1
сообщение 28.1.2009, 20:11
Из: Нижний Новгород
Пользователь №: 79 096
выложте кто-нибудь скины с моснтра плиззз
BAK
сообщение 29.1.2009, 12:07
Из: Украина, Полтава
Пользователь №: 189 804
Модель телефона: Motorola E1
Прошивка: R373_G_0E.30.49R
Качай с первого поста по силке ROKR
Текстовая версия Сейчас: 11.9.2025, 15:50
