2 страниц V  1 2 >
Как сделать рабочий бэкап на Z6 (см. инструкцию) тестим способ на V8
dissent
сообщение 10.3.2008, 12:11
Пользователь №: 132 440
Модель телефона: V8
Не нашел что бы об этом еще здесь писали, но ребята с modmymoto.com научились делать рабочий бэкап Z6 с помощью flash&bakckup 3.0.7 который, соответственно, нормально вшивается обратно.
I have come up with a way to back up a z6 that works. I am able to decompress the compressed filesystems backed up with this method and get all the files out but I have
not tried to reflash the backup back onto the phone so be careful with this. Any reports of whether the backups work when flashed back or not would be appreciated.
Steps:
1.Download Flash&Backup 3.0.7. Must be this exact version for the hack to work.
2.Install Flash&Backup
3.Download the z6 profile for F&B from here
4.Download my hack Flash&backuphook.zip and place the contents in the F&B3 folder.
5.Run Flash&backuphook.exe (instead of running Flash&backup.exe as is normally the case)
6.F&B3 will load and a message box will appear that says "z6 code loaded"
7.Backup whatever code groups you want to backup with any of the F&B3 options
Please post here if you find something wrong with my program or if you have any comments (good or bad)
Oh and btw, if someone wants to come up with profiles for other motomagx phones (i.e. razr2 v8), feel free to use this stuff too, it should work just fine.
Also, if it doesnt work, try a different ramldr instead of the ramldr that comes with the z6 profile
Now with my new hack, people who have firmware on their phone they dont want to loose (such as carrier specific or country specific flexes) can join in the modding fun too.
For those curious about what this hack does, it basically redoes the "read a cg from the phone" part of the F&B code via code injection. The change is that it reads 0x200
bytes at a time instead of 0x100. Exactly why it works I dont know but hey, it works and thats good enough for me
http://www.modmymoto.com/forums/showthread.php?t=79071
на Z6 данный способ работает и бэкап шьется обратно нормально, соответственно, данный способ должен подойти и к V8, но проблема в том, что нету нормального профиля для V8 c рамлоадером A3.CF (в приложении профиль c A3.CC). Если просто поменять рамлоадер в этом профиле на новую версию, то F&B стопорится как только начинает читать кодовую группу (вернее даже вообще не хочет читать, встает на 0%), после чего тел просто перезагружается по таймауту.
Хак и профиль на V8 прилагаю (два варианта профиля Flash&backup_Backup_Profile_V8.rar - ramloader A3.C9, V8_Tmobile_Flash&backup_profile_BY_vermsky.rar - ramloader A3.CC) , остальные можно взять по ссылкам в оригинале сообщения.
Добавлено позже (10.3.2008, 15:16):
Забыл добавить, что с приложенными профилями прошить бекап на V8 у меня не получилось (сделать бэкап получилось на профиле с рамлоадером A3.CC, при подставлении других в этот профиль кодовые группы не читались вообще), мне кажется проблема в рамлоадерах и их соответствия текущему буту телефона. http://www.modmymoto.com/forums/showpost.p...mp;postcount=36
Сообщение отредактировал dissent - 10.3.2008, 12:28
Прикрепленный файл V8_Tmobile_FB3_profile_BY_vermsky.rar   ( 46.93 килобайт ) Кол-во скачиваний: 245
Прикрепленный файл FB3_Backup_Profile_V8.rar   ( 47.72 килобайт ) Кол-во скачиваний: 346
сообщение 10.3.2008, 13:28
дайте мне плиз профиль для z6 ,который тут выложен http://www.modmymoto.com/forums/showthread.php?t=79071 ,а то другой неработает!
dissent
сообщение 10.3.2008, 13:31
Модель телефона: V8
он на мотофане где-то лежит, вроде. в любом случае вот он
Прикрепленный файл Z6_profile___loader_for_F_B_3.rar   ( 49.02 килобайт ) Кол-во скачиваний: 1102
сообщение 10.3.2008, 14:09
блин,я на z6 бекап слил,но вот обратно он лезть нехочет(
dissent
сообщение 10.3.2008, 14:19
Модель телефона: V8
у тебя, похоже, та же проблема, разница бута и лоадера в профайле. похоже и бут и лоадер должны совпадать, возможно есть какие-то совместимые разные версии. сейчас попробую бут поставить такой же как и в лоадере
azt59
сообщение 10.3.2008, 14:23
Из: Perm
Пользователь №: 52 732
Модель телефона: E398/V3x/C650/Z6
Прошивка: ---
я могу ошибаться весь геморой со слитием бэкапа с новых трубок связан с изменённым форматом передачи данных...суть в том что бут телефона изначально поддерживает команду READ тоесть лоадер нам впринципе и не нужен просто нужно поправить алгоритм слития в прогах....что и сделал чел с modmymoto.com
dissent
сообщение 10.3.2008, 14:32
Модель телефона: V8
точно, только на некоторых лоадерах все нормально работает, а на более новых нет. начиная с a3.cd кодовые группы перестают читаться, соответственно есть вариант попробовать что бы бут соответствовал лоадеру, либо был совместим... просто видимо a3.cf который сейчас у меня в телефоне в данном плане не совместим с предыдущими версиями, даже sbf-recalc ругнулся на различие адресов при компиляции sbf файла с кодовой группой (слитой a3.cc лоадером) и лоадера a3.cf
Добавлено позже (10.3.2008, 17:37):
нигде не могу найти рефлеш бута a3.cc для v8, ни у кого нету или хотя бы не знает где взять?
Добавлено позже (10.3.2008, 18:20):
похоже действительно, бэкап не работает с бутом a3.cf, вариант - пробовать бут более ранней версии.
http://www.modmymoto.com/forums/showpost.p...mp;postcount=37
Neomoto
сообщение 10.3.2008, 17:00
Из: Белгород
Пользователь №: 72 604
Модель телефона: MotoZINE ZN5
Прошивка: sym X beta
шьется говоришь? выложи профиль с которым шьется, потому что у меня не вышло прошить.
dissent
сообщение 11.3.2008, 6:39
Модель телефона: V8
В общем, в текущей конфигурации, ни у кого с бутом A3.CF бэкап не работает (не делается правильно и, соответственно, не шьется). Работает нормально с более ранними версиями (A3.C9, A3.CC в частности, A3.CD - нет информации).
откатиться на более старый бут (из темы с прошивками для V8 на этом форуме) у меня не получилось, пишет что суперфайл не предназначен для рефлеша.
Сообщение отредактировал dissent - 11.3.2008, 8:41
ERICH KRAUSE
сообщение 11.3.2008, 10:39
Пользователь №: 97 339
Модель телефона: A3100, L7e
Прошивка: 5.2.20780 ROM 1.0.19
у меня с бутом A3.CC тоже бекап не встал
dissent
сообщение 11.3.2008, 10:59
Модель телефона: V8
Z6 или V8? если V8 то какой профайл использовал.
бэкапил и прошивал обратно не меняя никаких настроек или какие-то менял, какую группу (не все группы нормально бэкапятся)?
Well i already tried what you say... i made a backup then i flashed each one of them and i found this:
CG52 Can be flashed back
CG49 Yes
CG46 Yes
CG45 Yes
CG44 Yes
CG43 Yes
CG42 Yes
CG41 Yes
CG37 Nop... this one will kill the phone
CG36 and yes...
i have not tried them all but at least most of them
Советую все опыты проводить над CG46 (Language pack), канеш если у вас есть работающий рефлеш этой группы.
Огромная просьба владельцам V8, если у кого есть оригинальный language pack 002ее и bootloader телефона НЕ A3.CF, то сделайте бэкап CG46 по данному методу (с использованием сначала одного профайла для V8 в первом посте этой темы, а затем второго) и выложите сюда, я сам на своем телефоне проверю, если боитесь ее потерять в своем телефоне в случае неудачной прошивки.
Сообщение отредактировал dissent - 11.3.2008, 11:10
Abram
сообщение 11.3.2008, 14:44
Прелесть какая гадость
Из: .ru - рідна Україна
Пользователь №: 44 825
Прошивка: CyanogenMod
Random уже уведомлен, можем ждать оффициальной поддержки Z6 в FB.
сообщение 14.3.2008, 13:32
ну че,получилось у когонибудь обратно слитый бекап влить?
UginC390
сообщение 14.3.2008, 14:36
Из: Запорожье
Пользователь №: 80 755
Модель телефона: Motorola L7 & Z6
Прошивка: L7CS и wkmod_FINAL
Бут А3.СС
сообщение 14.3.2008, 15:31
у меня слить то получилось,но вот обратно лезть невкакую нехочет...
serega011
сообщение 14.3.2008, 16:34
Из: Таганрог-МинВоды
Пользователь №: 122 624
Модель телефона: v500, Z6, E8
Прошивка: R75, R60_G_80.33.44R
Блин, как вы все делаете:)? качал уже наверное три разных профиля для Z6 и ни с одним программа не видит телефона, хотя слышно, что при включении программы телефон переводится в другой режим.
сообщение 14.3.2008, 16:37
в бут режиме нужно подключать
serega011
сообщение 15.3.2008, 6:56
Угу спасибо, получилось.
Mailik
сообщение 18.3.2008, 16:00
Пользователь №: 133 755
Модель телефона: ROKRZ6
Прошивка: 44R+PoL
Вот слил я допустим бэкап таким методом. При попытке обратно залить не провредиться телефон если бэкап криво слился?
Сообщение отредактировал Mailik - 18.3.2008, 16:06
Adanos
сообщение 18.3.2008, 16:48
Пользователь №: 155 471
Модель телефона: Milestone
Прошивка: 2.1 Задолбала...
не знаю, но слить я тоже слил!
Сообщение отредактировал Adanos - 18.3.2008, 16:48
Mailik
сообщение 18.3.2008, 16:54
Прошивка: 44R+PoL
Была не была, попробую сшить
Abram
сообщение 18.3.2008, 17:09
Э, народ, шить-то надо РСД, предварительно создав сбф файл.
Mailik
сообщение 18.3.2008, 17:21
Прошивка: 44R+PoL
Абрам спасибо. Так и хотел сделать. Абрам, а тел таким макаром убить можно?
Теперь sbf собрать не могу, пишет типо header не хватает
Сообщение отредактировал Mailik - 18.3.2008, 17:51
dissent
сообщение 18.3.2008, 17:49
Модель телефона: V8
не шей те группы, рабочих рефлешей которых еще нет
Abram
сообщение 18.3.2008, 17:50
Сомневаюсь. сбфрекалк не даст тебе залить кг большего размера, чем можно.
Алгоритм таков: берем фулфлеш, разбираем, нужные нам групы заменяем, остальные удаляем. Дескриптор и описание оставляем, а ещё лучше копируем в укромное место (они нужны для сборки).
Не забываем включить опции пересчёта всех кг и создания нового дескриптора.
Добавлено позже (18.3.2008, 19:52):
Я в своё время свой тел поднял полным монстром.
Mailik
сообщение 18.3.2008, 17:57
Прошивка: 44R+PoL
Спасибо за своевременный ответ. Сейчас попробую собрать sbf
И ещё вопросик. Если я хочу только одну КГ собрать, к примеру CG46, мне нужно headers и пр. также в sbf сборку кидать?
44R это ведь фулфлеш?
Сообщение отредактировал Mailik - 18.3.2008, 18:03
dissent
сообщение 18.3.2008, 18:03
Модель телефона: V8
hmg должен быть обязательно в той же папки где и CG и ramloader, включи галку Advanced -> write new descriptor
ты еще телефон не прошивал ни разу? прошивка украинская? если да, то ни в коем случае не пробуй на CG46 в случае чего ты ее потеряешь без возможности восстановить, придется лить другой версии, без русского голосового набора. (Если у тебя Razr2 V8)
Сообщение отредактировал dissent - 18.3.2008, 18:06
Mailik
сообщение 18.3.2008, 18:08
Прошивка: 44R+PoL
Можете ткнуть меня носом туда, где расписывается как и чем разбирать прошивку?
Через SBFrecalc не могу разбить. При нажатии на кнопку Split Flash File вылезает ошибка "An exception of class NilObjectException was not handled. The application must shut down"
Уже решил. Удалил файл прошивки и заново разархивировал. Теперь split сработал нормально. Что теперь делать, чтоб собрать свой бэкап?
Уточняю, у меня Z6, прошивка русская. 44R как заводская. А телефон прошивал уже. Я новичок в сборке/пересборке прошивок
Сообщение отредактировал Mailik - 18.3.2008, 18:16
dissent
сообщение 18.3.2008, 18:15
Модель телефона: V8
пользуешь sbf-recalc 1.2.8?
Mailik
сообщение 18.3.2008, 18:18
Прошивка: 44R+PoL
Да. Как теперь собрать прошивку?
В наличи папка с разобранным фулфлешем и папка с бекапами всех CG телефона
Кинул в одну папку все CG телефона и *.hmg, ramdld.smg из фулфлеша. Пытаюсь собрать. Пишет, "Error CG to long. This can crashes you phone"!!!
Сообщение отредактировал Mailik - 18.3.2008, 18:29
dissent
сообщение 18.3.2008, 18:29
Модель телефона: V8
создаешь отдельную папку и копируешь туда из разобранного фулфлеша файл *.hmg и *RAMLOADER.smg, а из бекапа копируешь группу, которую хочешь прошить. далее в sbf-recalc advanced-> write new descriptor и жмешь Open CG-Folder - выбираешь эту созданную папку в которую ты скопировал что нужно и жмешь ReCalc Checksum когда процесс завершится (в логе будет написано successful или done не помню) жмешь Create SBF-File в созданной папке появится новая папка с готовым флешем, его и шьешь через https://motofan.ru/soft/ РСД lite 3.9 или выше
Добавлено позже (18.3.2008, 21:30):
не надо все кидать, кинь какую-нибудь одну любую CG (только не CG46 если у тебя Razr2 V8)
Mailik
сообщение 18.3.2008, 18:34
Прошивка: 44R+PoL
А все CG сразу нельзя чтоли собрать?
Не катит. Взял я CG31 SBF recalc при попытке собрать пишет, что CG слишком большая. Думаю https://forum.motofan.ru/index.php?showforum=143 Flash&backup криво всё таки слил у меня baskup. CG31 рамзером 79кб получилась, а должна 16кб.
Сообщение отредактировал Mailik - 18.3.2008, 18:40
dissent
сообщение 18.3.2008, 18:37
Модель телефона: V8
все нет, бекапятся нормально не все группы, механизм еще не отработан. Это раз, и во вторых зачем шить все группы если ты только тестируешь?
Mailik
сообщение 18.3.2008, 18:43
Прошивка: 44R+PoL
А какие группы бекапятся? В какой группе что лежит? Если я хочу восстановить установленные приложения, то это какая cg будет?
Судя по размеру CG42 слилась правильно. За что она отвечает и как проверить нормально ли она работает?
Сообщение отредактировал Mailik - 18.3.2008, 18:51
dissent
сообщение 18.3.2008, 18:50
Модель телефона: V8
CG52
Mailik
сообщение 18.3.2008, 18:57
Прошивка: 44R+PoL
В общем бэкап может и слился, но нужно группы переразбить вручную видимо.
Абрам у тебя какие CG нормально шились?
Сообщение отредактировал Mailik - 18.3.2008, 21:57
Abram
сообщение 19.3.2008, 15:42
Все smile.gif. Интерес представляют только 43 и 52 (остальные подписаны)
Mailik
сообщение 19.3.2008, 16:29
Прошивка: 44R+PoL
У меня в бекапе CG неправильно разбиты. Специально разобрал прошу и сравнил одноимённые CG, размеры отличаются сильно.
wasp2007
сообщение 26.3.2008, 8:18
Пользователь №: 167 411
Модель телефона: Z6
Прошивка: R60_G_80.33.44R
А у меня в бекапе размеры все практически совпадают за исключением СГ52. Но при попытке их разложить unsquashfs под Cygwin выдает ошибку и программа виснет sad.gif
Пробовал СГ из виложенных на форуме прошивок все работает. Где грабли?
Судя по всему Flash&backup 3.0.7. криво читает прошивку.
ПС пробовал два разных профайла для загузчиков A3CC и 03CD (у меня A3CC) читалась прошивка и там и там shades.gif
Интересный факт при подключении тела к Flash&backup 3.0.7. программа выдавала ошибку (прошивка не определена, версия на определена), но тело подключало (загорался зеленый квадратик).
Сообщение отредактировал wasp2007 - 26.3.2008, 8:20
Mailik
сообщение 15.4.2008, 20:29
Прошивка: 44R+PoL
У меня тоже модель телефона не определялась, но квадратик был зелёным
Как сделать рабочий бэкап на Z6 (см. инструкцию) тестим способ на V8 · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
2 страниц V  1 2 >
Текстовая версия Сейчас: 13.9.2025, 14:38
