|L7e MP| "DarkestSideMOTO" зарубежный патченный монстр, прошивать его ТОЛЬКО после снятия RSA !
сообщение 13.3.2008, 14:12
Сам не тестил (поэтому делайте бекапы в том числе и PDS !!) нашел на
http://www.modmymoto.com/forums/showthread.php?t=67000 Для тех кому скучно
http://www.fileden.com/files/2007/1/4/592267/screen2.png + http://www.fileden.com/files/2007/1/4/592267/screen_11.png
*DarkestSideMOTO MP*
CAUTION!
This is an RSA Removed Monster Pack. Be sure that you have already removed the RSA Protection from your phone prior to flashing...
Note:
Purple - Update/Fix/Addition/Changes
Red - Bug/Not Functioning
Firmware:
R452D_G_08.01.0AR(originally, from Osta's Reflash... not much change)
Flex: GSTL71T678MV084
Key Features:
Features From Osta's Firmware Reflash Applied
Funlights Enabled(L9 Version - thanks to greatdude10)
Status Light Enabled
Blue Led Light Enabled - While phone is charging, a blue light on the light sensor lit up(Status Light must be on)
Browser Key remapped to iTunes for fast and easy access
Shortcuts Activated(Update v1.3)
Smart Key remapped to "Middle Soft Key" for shortcut use so other phone functions are accessible while using bluetooth[previously mapped to browser key](Update v1.3)
Grid View available when browsing with picture
Records Video in MP4 Format
Increase MP3 volume in wired headset
Java Heap Size increased from 1400k to 2000k [Update v1.1]
Fixed the exit button in alarm function[Update v1.2]
DRM timing are now 30-50% decreased for faster menu navigation and specially when typing SMS(Update v1.3)
Sending Predefined Animation on both SMS(emp)/MMS(gif) activated[as zer0s requested](Update v1.3)
Font:
iPhone Font by mgregor(Update v1.3)
Adventure Font by mgregor(v1.1-v1.2)
LP: 0903
DRM:
Seven DRM by sevenalive(slightly modified the battery indicator, java boot and hellomoto bootscreen...
Skins:
3 default skin
some ported skin by urcheekyangel(ported from Lei):
Dark
Fullmoon
MusicEDT-SuperEdit
WMP PE
WoW
Java Application:
Corelets:
Updated Image Editor[ripped from L9] - NOT Working, problem caused by iTunes... (cannot run/load 2 corelets simultaneously and it'll remain this way... I'll not going to fix this anymore cause there are NO fix for it... if you want to use the image editor, uninstall iTunes first)
iTunes with Chemical as the default skin...
Midlet:
Opera Mini
KD Player
XploreMe
Digital Audio Player
Motorola Text
Motorola Setup
Backup
GlobalTime(update v1.2)
AntiGnat(update v1.2)
StopWatch(update v1.2)
StudentCalculator PR(update v1.2)
Java Games:
Asphalt2 [From my STOCK FLEX]
ME: Splinter Cell CT[From my STOCK FLEX]
MysteryPinballMansion[From my STOCK FLEX]
Pipes[FREEWARE](Update v1.3)
Free Space: 16.9MB
Final Note: Image Editor and mediaviewer are the only things I know that is bugged. Image Editor has a conflict with iTunes(cannot run 2 corelets at the same time[read above]), mediaviewer under iTtunes are NOT working also...Special Thanks to the people mentioned above for their mod, skin, patches etc. that were included on my MP...
OPINIONS and SUGGESTIONS are welcomed... just don't
при прошитии рекомендую снять галочку с прошития ленгпака
т.к. скорее всего нерусский стоит.
ссылка для скачивания ==>>>
beat_lis
сообщение 13.3.2008, 19:05
Пользователь №: 124 357
Модель телефона: V3x
Прошивка: LifeTec for V3x V2
И зачем буржуям ставить адаптированный ImageEditor(который NOT WORK! :-) и https://forum.motofan.ru/index.php?showforum=146 iTunеs, (который состоит из основного и фонового), если есть VC&ImageEditor? И что там "mediaviewer под тьюнсом"? Не хочет работать пока? Зачем тогда описывать... Ну, со светом побаловались, с сенсором... До революции далеко(тем более, она уже свершилась!) Прошу простить за лирику...
Kirillos
сообщение 14.3.2008, 12:39
Из: Питера
Пользователь №: 161 627
Модель телефона: Motor l7e
Прошивка: new style v2.1
прошивался, полная ерунда
Offset
сообщение 14.3.2008, 15:38
Leo
Пользователь №: 126 712
Прошивка: 2BR
Kirillos, согласен...буржуи уже как и на е398 biggrin.gif монстров клипают...патчи и прочая начинка наша...а сборка их...хех laugh.gif
wanted90
сообщение 3.5.2008, 5:52
Из: Тольятти
Пользователь №: 160 168
Модель телефона: v3i+E398+L7+L7E
Прошивка: <new style v 2.1>
буржуи они и есть буржуи!!! монстр полная лажа !!!
$ALEXEI$
сообщение 11.7.2008, 19:27
Из: КОНОША
Пользователь №: 170 609
Модель телефона: Motorola L7e
Прошивка: NewStyle_v2.1
Да буржуи у себя на сайте считают, что этот монстр лучше нашего! Хотя в нём всё от русских создателей, кроме ленга наверное! И лучше он никак не может быть!
|L7e MP| "DarkestSideMOTO" зарубежный патченный монстр, прошивать его ТОЛЬКО после снятия RSA ! · Кастомные прошивки для Motorola RIZR Z3, KRZR K1, W490, W510, ROKR W6, SLVR L7e, L7i, L7x, L71, L72, L9 · Forum
> Быстрый ответ
Текстовая версия Сейчас: 3.8.2025, 16:12
