2 страниц V  1 2 >
Fallen Angel MP, mp for V360
Last1Left
сообщение 20.3.2008, 20:38
Из: Romania
Пользователь №: 161 862
Модель телефона: v360 ACR / Nokia N82
Прошивка: FallenAngel
Fallen Angel MP for V360
IPB Image
FEATURES:
Phone model: v360
Flex: Last1Left Flex 1.5
Tehnology: v360 Quadband
compatible with bootloaders 08A0 and 08D0
- create a backup before flashing
Others:
- clock in status bar
- lock/unlock keypad anywhere in menu: Menu key + Menu key
- hotkeys
- removed master clear and master reset from menu
- new elf pack
- Shutdown menu
- EDGE
- no multifont
- 10 languages (US English, Romanian, Russian, French, Greek, German, Italian, Spanish, Portuguese and Turkish)
- .zip files in video folder
- dnp.prf with changes for 11 languages: US English, Romanian, Russian, French, Greek, German, Italian, Spanish, Portuguese, Turkish and Chinese
- removed RSA verification
- customized bootscreen
- java heap increased to 1400kb
- compatible with sticky firmwares (AER, E0R)
- on/off keypad backlight option (in Initial Setup)
- Corelet menu icon (in Multimedia)
- USB Charging option (in Initial Setup)
- Airplane Mode in Initial Setup
- Reboot Phone option (in Settings - Phone Status)
- useless folders on TF removed
- Display Timeout 20sec, 40sec, 1 minute, 2 minutes
- new and improved Autolock keypad option (in Initial Setup) – keypad locks at the time set for Display Timeout
- Automatic unlocking of keypad
- Imei on * 6
- * + * opens Main Menu from almost everywhere (running a Java app, browsing, during call etc)
- retain calls list (dialed and received) when changing sim card
- sound&vibration when using the side volume keys eliminated
- mms size 1000kb (network dependant)
- improved sms/mms delivery reports feature. You can now select Yes or No and your choice will be retained
- sms ringing tone is the default one (the one selected in Ringing Styles) even for phonebook entries that have a custom tone associated
- ringtones and phonebook contacts pictures from TF
- Blacklist category in Phonebook
- snooze time in Alarm Clock changed from 8 min to 10 min
- automatic photo saving (after selecting Store)
- new zoom levels when viewing pictures (200 and 250 instead of 50% and 75%)
- corelets listed in Apps&Games (can be loaded in memory from here, but they still need to be launched using the Corelet icon in Multimedia menu)
- also, corelets can be moved to TF (possible better for the battery)
- java apps working with the usb cable connected
- all Java apps (from TF and from phone’s memory) are shown in a single list
- full Java access to system files
- tuning of display backlight behavior in Java apps from the phone’s menu
- Java apps can be suspended (and can continue working) in background
- no confirmation asked when running Java apps from datebook
- custom vibration style in Java apps
- status line in Java apps can be removed
- all folders accessible in OBEX mode
- increased Bluetooth standby time
- receive all kind of files through BT (in video folder),
- send all files through BT using MotoCmd.elf
- The Bitrate of Mp3’s is increased to 320kb
- alarm clock icon in status line
- blacklist
- full java acces to system files
- saving photo without menu
- 10 skins (all skins are made by JithinSK)
- 12 java applications and 1 java game
- webssession for Romania Orange and Vodafone
- video styles
- no discharge sound
- start up and shut down sounds
- unlock code: 0000
- security code: 000000
Full descrition here
Download
QUOTE
Сообщение отредактировал Last1Left - 21.3.2008, 8:38
Azamyha
сообщение 20.3.2008, 21:56
Пользователь №: 152 271
Модель телефона: L7 red
Прошивка: MotoWalkman L7
неплохой вроде монстрик. Я правильно понимаю, что если его полностью на L7 поставить, то будут проблемы со звонками?
fast driver
сообщение 21.3.2008, 9:23
Из: Украина г.Харьков
Пользователь №: 132 738
Модель телефона: V3X
Прошивка: R252211_EnerGy_[E6P]
крутой монстрик!РЕСПЕКТ! нужно поставить дружбану! Выложи скинчыки, уж очень хорошие! Когда поставлю отпишусь. clap.gif clap.gif clap.gif
Azamyha, и не тока.
и по возможностям перекладите это!
Сообщение отредактировал fast driver - 21.3.2008, 9:26
obnorskiy
сообщение 21.3.2008, 13:52
Из: Чебоксары
Пользователь №: 88 439
Модель телефона: ROKR Е8
А что за прошивка? AER или ACR? И что-то я там МВ не заметил
MotorV360
сообщение 21.3.2008, 14:58
Пользователь №: 119 908
Модель телефона: V360
Прошивка: ACR
прошился.Вроде ничего.работает.Основа ACR.Ставьте все кто хочет новизны.Из минусов то что стоит один Virtual Corelet.Даже тюнса нет.Мне например проблема установить корелет,т.к вендузятина стоит через эмуль, при подключении к прогам в п2к режиме ругается.Ладно хоть в буте проги нормально работают.Жаль что прог под Linux таких нет пока(винда бесит) sad.gif .Лэнг ещё слегка не по-русски в некоторых местах,но это мелочи.АВТОР-RESPECT тебе!!! thumbsup.gif clap.gif
Ядерный
сообщение 22.3.2008, 13:50
Художник
Из: Ростов
Пользователь №: 82 730
Модель телефона: HtcDiamond,Love;v360
Прошивка: Touch Flo, Dicar&Sny
картинка не открывается, перелейте плз
Dikiy chaynik
сообщение 22.3.2008, 17:57
Пользователь №: 109 061
Прошивка: Moto _Innovation_b7r
Может кто подсказать - почему при установке другого лэнга исчезают часы из статус-строки?
MotorV360
сообщение 23.3.2008, 7:29
Прошивка: ACR
Качайте на здоровье целиком с рапиды http://www.rapidshare.ru/621439
paska
сообщение 23.3.2008, 16:15
Пользователь №: 125 251
Модель телефона: Motorola L6
Прошивка: R3511
На L7 можно ставить?
MotorV360
сообщение 23.3.2008, 18:49
Прошивка: ACR
paska, на L7 только лэнг,ДРМ и флекс.
paska
сообщение 26.3.2008, 6:57
Прошивка: R3511
Я умудрился весь монстр поставить на L7 biggrin.gif Не подскажите с какого сайта брали монстра.
brestwolf
сообщение 26.3.2008, 18:18
Пользователь №: 151 975
Модель телефона: e770v/v360
Прошивка: Q-MUSIC/life style
Люди,кто может по русски описать все эльфы и патчи установленые в монстре,а то с некоторыми вродь разобрался,а некоторые не знаю, извините что делают
Zhenek_
сообщение 26.3.2008, 18:25
Пользователь №: 128 350
Модель телефона: HS820
скины прям так нормальные, а больше ничего нового неувидел
denami
сообщение 27.3.2008, 11:46
Пользователь №: 123 692
Прошивка: вроде есть...
поставил себе данного монстра. Впечатление не однозначное: несколько не "русские" фразы в лэнге,
Часы в формате am/pm для телефона кажысь не очень удобные, картинка на внешнем экрне при раскрытии с первого раза не яснаяя (долго присматриваясь понял --- наушники), автоблокировка клавиатуры на раскладушке это лишнее. Радует свежее оформление, наличие Elf-ов (хотя их мало покачто). Сам поп себе монстр кажеться довольнотки шустрым не задумчивым.
Откачусь ли на LifeStyle покачто не решил.
Сообщение отредактировал denami - 27.3.2008, 11:52
pluto747
сообщение 27.3.2008, 16:25
Из: Санкт - Петербург
Пользователь №: 128 645
Прошивка: R373_G_0E_30.79R
fast driver
сообщение 27.3.2008, 21:46
Переводю то что здеся! (Если что переводчик у меня слабенький!)
ОСОБЕННОСТИ:
Телефонная модель: v360
Гибкий шнур: Гибкий Шнур 1.5 Last1Left
совместимый с bootloaders 08A0 и 08D0
- создайте дублера перед высвечиванием
Другие:
- часы в строке состояния
- заприте/отпирайте вспомогательную клавиатуру где-нибудь в меню: Ключ меню + Ключ меню
- горячие клавиши
- удаленная главная ясность и главный сброс из меню
- новый пакет эльфа
- Меню закрытия
- КРАЙ
- нет multifont
- 10 языков (АМЕРИКАНСКИЙ Английский, Румынский, Русский, Французский, Греческий, Немецкий, Итальянский, Испанский, Португальский и Турецкий)
- .zip файлы в видеопапке
- dnp.prf с изменениями для 11 языков: АМЕРИКАНСКИЙ Английский, Румынский, Русский, Французский, Греческий, Немецкий, Итальянский, Испанский, Португальский, Турецкий и Китайский
- исключенная проверка RSA
- настроенный bootscreen
- java куча возросла к 1400kb
- совместимый с липкими микропрограммами (AER, E0R)
- вкл/выкл выбор лампы вспомогательной клавиатуры подсветки (в Начальной Установке)
- Икона меню Corelet (в Мультимедиа)
- Выбор Заряжения USB (в Начальной Установке)
- Метод самолета в Начальной Установке
- Перезапустите Телефонный выбор (в настроечных Параметрах - Телефонный Статус)
- бесполезные папки на исключенном TF
- Покажите Перерыв 20sec, 40sec, 1 минута, 2 минуты
- выбор (в Начальной Установке) вспомогательной клавиатуры нового и усовершенствованного Автозамка - замки вспомогательной клавиатуры в то время установленный для Перерыва Показа
- Автоматическое отпирание вспомогательной клавиатуры
- Imei на * 6
- * + * открывает Главное Меню от почти всюду (запуск яванского приложения, рассматривая, в течение вызова etc)
- сохраните список (набрано номер и получено) вызовов, заменяя sim карту
- sound&vibration, используя исключенные ключи бокового объема
- mms размер 1000kb (иждивенец сети)
- усовершенствованная sms/mms особенность сообщений поставки. Вы можете сейчас выбрать, Да или Никакой и ваш выбор не будет сохранен
- sms длинный гудок - типовое значение один (то выбрало со Звонким Шиком) даже для входов телефонной книги, которые имеют связанный тон традиции
- ringtones и картины контактов телефонной книги от TF
- Категория Blacklist в телефонной Книге
- вздремните время в Будильнике, замененном от 8 минут до 10 минут
- автоматическое сохранение фотографии (после отбора Магазина)
- новые резкие подъем вверх уровни, просмотр картин (200 и 250 вместо 50% и 75%)
- corelets составил список в Apps&Games (может быть загружен в памяти от здесь, но их все еще нужно начать, используя икону Corelet в Мультимедийном меню)
- также, corelets может быть перемещен на TF (возможный лучше для батарейки)
- java приложения, работающие с usb соединенным кабелем
- все яванские приложения (от TF и от phone’s памяти) показаны в едином списке
- полный яванский доступ к файлам системы
- настройка поведения лампы показа подсветки яванские приложения из phone’s меню
- Яванские приложения могут быть подвешены (и может продолжать работу) в фоне
- никакое подтверждение не спрашивало, управляя яванские приложения от datebook
- стиль вибрации традиции в яванских приложениях
- линия статуса в яванских приложениях может быть исключена
- все папки, доступные в методе OBEX
- увеличенное время резервирования Bluetooth
- получите весь вид файлов через БРИТИШ (в видеопапке) Телеком,
- пошлите все файлы через БРИТИШ Телеком, использующий MotoCmd.elf
- Bitrate Mp3’s увеличен к 320kb
- икона будильника в линии статуса
- blacklist
- полный java acces к файлам системы
- сохранение фотографии без меню
- 10 кож (все кожи сделаны JITHINSK)
- 12 java приложений и 1 java игра
- webssession для румынского Апельсина и Vodafone
- видеостили
- нет отводного звука
- стартуйте и закрытый вниз звучит
- отоприте код: 0000
- код безопасности: 000000
Don Omar(TenderFog)
сообщение 27.3.2008, 21:47
Пользователь №: 116 887
Модель телефона: E1,RАZR2 V8 2 Gb
Прошивка: The Life 2 NexGen
оформи правильно или тема будет снесена, посмотри как нормальные люди оформляют
_CD_
сообщение 28.3.2008, 7:55
Из: Россия, Н. Новгород, MegaNET
Пользователь №: 90 844
Модель телефона: V360_Upgraded
Прошивка: Fallen Angel ACR
На внешнем экране русские буквы не отображаются. Их просто нет в лэнге.
И-тайпа тоже нет.
Добавлено позже:
Подкорректировал лэнг. Теперь на внешнем экране есть русский, а заодно появился iType.
Также выкладываю подкорректированный dnp.prf.
Сообщение отредактировал _CD_ - 28.3.2008, 13:00
Прикрепленный файл FallenAngel_LP_rus_v360__external_screen.rar   ( 1.14 мегабайт ) Кол-во скачиваний: 406
pluto747
сообщение 28.3.2008, 16:51
Народ как скачаивать?... киньте пожалуйста прямую ссылку...
_CD_
сообщение 28.3.2008, 20:10
Кстати, необходимо включить "SMS Unicode". А то с СМС облом какой то вышел smile.gif
c380гуру
сообщение 28.3.2008, 22:58
Из: Пенза
Пользователь №: 51 473
Модель телефона: iPhone 5s + 4s
Прошивка: не обновлял
Вот зеркало на депозите:
depositfiles
Прошу закинуть в шапку!
pluto747
сообщение 30.3.2008, 8:33
fast driver
сообщение 30.3.2008, 8:46
Цитата(pluto747 @ 30.3.2008, 11:33) *
MOOLINKS
сообщение 3.4.2008, 8:01
Пользователь №: 165 962
Модель телефона: motorola v 360
Прошивка: life stule
Обьясните пожалуйста как русский лэнг поставить? И можете ли вы выложить все патчм с этого монстра ПОЖЛУЙСТО?
turbon
сообщение 3.4.2008, 10:57
Пользователь №: 81 198
Модель телефона: zn5
Прошивка: Symbiosis IV
Вообще обсуждение монстра ведётся здесь http://inbrite.com/index.php?name=Forums&a...opic&t=1275
У Last1Left самые лучшие монстры!
Dikiy chaynik
сообщение 3.4.2008, 12:56
И-тайпа тоже нет.
Добавлено позже:
Поставил твой лэнг. Появились названия стилей на внешнем экране, но зато пропали будильники и список эльфов. Захожу в соответствующие меню, а там пусто. Хотя судя по надписям на софт-кнопках всё на месте.
_CD_
сообщение 4.4.2008, 5:36
Я не могу сейчас сказать из-за чего это произошло, т.к. у меня такой проблемы не возникало. Поэтому просьба к тем, кто его прошивал - также прокомментировать работу ленга.
incline
сообщение 7.4.2008, 17:41
Пользователь №: 107 184
отличный монстр!!
присоединяюсь к brestwolf, расскажите эльфах
fast driver
сообщение 11.4.2008, 11:54
incline, на этот вопрос есть спец. тема! вот!
Sta
сообщение 17.4.2008, 16:52
Пользователь №: 85 769
Модель телефона: motorola v360
Немог бы подсказать как это сделать, а то писать смски транслитом не айс sad.gif sad.gif sad.gif
brestwolf
сообщение 18.4.2008, 19:48
Прога п2к тулз,скрытые настройки-сообщения-хранить смс в юникоде.Вот и всё
Sta
сообщение 18.4.2008, 20:31
Callonme
сообщение 25.4.2008, 12:31
Пользователь №: 106 000
Модель телефона: Motorola v360
Прошивка: ACR
Норма монтсрик thumbsup.gif !!!))) А нет скина Pulse для Mediaviewer(если кто может сделайте tongue.gif )!? Зарание спасибо! clap.gif clap.gif clap.gif clap.gif
Callonme
сообщение 9.5.2008, 4:54
Прошивка: ACR
А в памяти телефона есть песенка(Dj raj - megamix)Выложите плз полную версию! cool.gif
Хенки
сообщение 9.5.2008, 10:59
Пользователь №: 141 331
Прошивка: other
монстр хороший
возможно ли переделать отображение времени ?
Ky Kiske
сообщение 11.5.2008, 14:04
Из: Магнитогорск
Пользователь №: 112 832
Модель телефона: XT-502 (XT5)
монстр хороший.. тока проблема есть , с эльфами. при попытке закинуть новый эльф патч с либами фб3 вежливо говорит "read beyond any file" насколько я понял это нехватка места в CG1 , но как-то веть до этого закинули либу?! Что нужно сделать в этом случае?
fast driver
сообщение 13.5.2008, 4:59
если ты говориш что нехватка места в групе,то зач надо освободить! FAQ (по освобождению места)- есть! ищи его в ветке FAQ на мотофане!
obnorskiy
сообщение 15.5.2008, 7:15
Из: Чебоксары
Прошился-таки я этим монстром. Впечатления проиворечивые. Сразу же сменил кривой ленг-пак - часы в статус строке слетели (вероятно особенность патча, но на Лайф Стайл такого не было), дрм и скины на любителя, поэтому тоже сменил на свои. Порадовали работающие эльфы и меню на удержании красной кнопки. Удивительно, что патч на раскрытие/закрытие флипа есть, а самого МВ нет. Не понравилось одно - за сутки телефон два раза ребутнулся при попытке войти в корелет. В отсутствие новых монстров для 360 можно сказать, что этот не плох, хотя каплану пора подумать о создании нового монстра. Пока похожу с этим, но если ребуты не прекратятся, то откачусь на ЛайфСтайл.
Ну как прошился, так и откатился. После удаления конфигов МВ, экран стал черный. Долго думать не стал прошился заново, но после этого почему-то скины стали криво отоброжаться. Больше думать сил не было - откатился. Мнение такое: монстр очень даже ничего, вот только все его части жестко привязаны друг-другу.
Сообщение отредактировал obnorskiy - 16.5.2008, 13:49
MOOLINKS
сообщение 16.5.2008, 5:39
Как отменить повтор одного вызова на один? И как добавить эфект вибро?
obnorskiy
сообщение 16.5.2008, 6:12
Из: Чебоксары
Первый вопрос не понял. Эффект вибро (HAPTICS) в Fallen Angel включен.
2 страниц V  1 2 >
Текстовая версия Сейчас: 2.8.2025, 6:42
