3 страниц V < 1 2 3
R535_118109P_CYR.rc1, мод прошивки для Е6....
ddvn
сообщение 24.6.2008, 3:03
Пользователь №: 151 443
Модель телефона: E6
thanks, but all EQ are not working. Only Bassboost is working. I think, problem is file "mediaplayer" in CG43 (usr/SYSqtapp/mediaplayer).
ddvn
сообщение 3.7.2008, 1:33
Модель телефона: E6
Hi Bolik! pls help me! in My FW at Browser has some Profile's ThaiLand, i want remove this profiles in my FW, How do this ? thanks you so much
Сообщение отредактировал ddvn - 3.7.2008, 1:34
_Bolik_
сообщение 3.7.2008, 7:22
Motolancer
Из: UA Львів
Пользователь №: 111 986
Модель телефона: Razr XT910
Прошивка: 4.1.2 JB
CG42/connections, or try to run search with profilename in file...
ddvn
сообщение 3.7.2008, 13:32
Модель телефона: E6
But this is Profile Conection GPRS. I want delete profile in Browser (opera). I try to search this file but i not found. большой спасибо!
_Bolik_
сообщение 3.7.2008, 14:03
Motolancer
Из: UA Львів
Прошивка: 4.1.2 JB
shades.gif me have the same situation. smile.gif one profile in browser is locked and not editable....
ddvn
сообщение 3.7.2008, 14:19
Модель телефона: E6
ui sad.gif . I see in this topic R533_Ezh_0.1.1_RU . => this FW can run to multi App Java. How do Mod? Do you known? я не знаю smile.gif
_Bolik_
сообщение 3.7.2008, 15:29
Motolancer
Из: UA Львів
Прошивка: 4.1.2 JB
am (application manager) patch
translate it with google... u must replace in any HEXeditor selected bytes
ddvn
сообщение 3.7.2008, 15:55
Модель телефона: E6
thanks! forum has'nt button Thanks? if has i 'll thank you. Hope you help me more for my FW smile.gif
(3.7.2008, 17:19):
Hi Bolik.
My FW has 2 problems
- when i run Browser, it show dialog box "Additional call charges may apply.\n\nContinue?" , some other FW not has this problem. do you known fix it. plz tell me
- i want add 2 app java in my FW, i add files jar & jad into CG34\preloadapps\javaapps and file JavaDB
CODE
00001||1||0||/usr/data_resource/preloadapps/javaapps/PlatinumSudoku.jar||/usr/data_resource/preloadapps/javaapps/PlatinumSudoku.jad||67dc1191-2928-4938-abce-1a73cb5ce490||001 00002||1||0||
but not show at menu when flash my FW. plz help me.
Thank you so much.
Сообщение отредактировал ddvn - 4.7.2008, 17:46
_Bolik_
сообщение 3.7.2008, 17:48
Motolancer
Из: UA Львів
Прошивка: 4.1.2 JB
it`s not a problem. it`s warning, cause traffic cost some your money. i dont know how to fix it, but i dont care, cause it is once before every internet session
00001||1||0||/usr/data_resource/preloadapps/javaapps/PlatinumSudoku.jar||/usr/data_resource/preloadapps/javaapps/PlatinumSudoku.jad||67dc1191-2928-4938-abce-1a73cb5ce490||001 00002||1||0||/usr/data_resource/preloadapps/javaapps/Emap.jar||/usr/data_resource/preloadapps/javaapps/Emap.jad||67dc1191-2928-4938-abce-1a73cb5ce490||002
try to wrote id`s of that java apps in file(s) SysMenuTree (CG34 and CG43)
ddvn
сообщение 5.7.2008, 1:48
Модель телефона: E6
Hi Bolik! I try to write ID in file SysMenuTree, but it does'nt show in menu.
CODE
Item=67dc1191-2928-4938-abce-1a73cb5ce490
ddvn
сообщение 8.7.2008, 9:11
Модель телефона: E6
Hi! Bolik. my FW is R533_G_11.12.10P and it has'nt EDGE. If i want Enable EDGE like your FW. What i do?
CG is what . Sorry if i annoy to you
_Bolik_
сообщение 8.7.2008, 9:19
Motolancer
Из: UA Львів
Прошивка: 4.1.2 JB
EDGE is present in firmwares starting with R535_... or refer to www.motorolafans.com to sticky theme in E6 section "enabling edge..." or something else. You must edit some bytes in SEEM with radiocomm
R535_118109P_CYR.rc1, мод прошивки для Е6.... · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
3 страниц V < 1 2 3
Текстовая версия Сейчас: 4.8.2025, 12:22
