Keeptime.elf(Update to Keeptime1.2), The whole point timekeeping +alarm button timekeeping and calendar
Campanula
сообщение 10.7.2008, 7:06
Пользователь №: 176 749
smile.gif E殿园lpktool报到!
I am sorry, I am from China EDY(lpktool)
The whole point timekeeping + + alarm button timekeeping and calendar timekeeping clap.gif
10-band configuration, as follows:
file: / / b / edy / Keeptime /! file: / / b / edy / Keeptime / sound /! 14; 1; 1-7; 06; 20; k; 10; 07; 08; mp3; 1; k; amr; 0; 0
file: / / b / edy / Keeptime /! hour broadcast sound files path
file: / / b / edy / Keeptime / sound /! keys timekeeping path
14 under the keys for the broadcast of the keys (left softkey), can change the other key change to other keys, did not lock the keyboard, the keys timekeeping invalid for unknown reasons
14 behind the broadcast of the keys is a switch
1-7 weeks to switch the whole point timekeeping switch
06; 20 points on behalf of the entire broadcast of time
Behind the k: timekeeping switch (k open for timekeeping, g Commissioner for timekeeping)
10; 07; 08 representatives from key: * +7 +8
mp3: broadcast voice on behalf of the whole point format
Behind the 1: models (1 to 2 series e398 series lte for l7, such as lte2 series)
Behind the k: scenarios for the switch, the Commissioner: g
amr: the voice of keys broadcast format (as too many 1440, initially to do is MP3, larger than the allocated rate of 26 KBS, small E can not even play, so converted to amr, small size)
0 after the two representatives of the alarm clock or calendar event is the beginning of the time switch, the Commissioner for 0, 1 to open
Timekeeping voice:
http://www.namipan.com/d/739051afe41470743...05bca516de26400
edy.rar
There is an issue
Press the button-broadcast (unless it is left softkey), of other key keyboard did not lock in the circumstances, the Press newspaper failure, GAO Ren look at what causes trouble, and pay a source SDK smile.gif
Сообщение отредактировал Campanula - 13.8.2008, 4:16
wxm0831
сообщение 10.7.2008, 7:17
Пользователь №: 139 421
Модель телефона: e398-70R
Прошивка: 3398
thank you very much!
N!kola
сообщение 10.7.2008, 8:02
Из: Сербия
Пользователь №: 144 136
Модель телефона: E398(x2) | ROKR E8
Прошивка: Anarchy48R | Z-Mod
What the hell is this? Could anybody explain that...in russian....
Campanula
сообщение 10.7.2008, 8:07
QUOTE(N!kola @ 10.7.2008, 8:02) *
Can only say that the English
Mytza
сообщение 10.7.2008, 8:12
Пользователь №: 175 549
Модель телефона: Motorola v360
Прошивка: R4513_G-08.B7.ACR
I didn't understand neither , Can you explain in one phrase what exactly does, in the first post is to much expaining
wxm0831
сообщение 10.7.2008, 8:18
Прошивка: 3398
Я из Китая EDY wxm0831, я бы не сказал, что русские будут говорить только на китайском и английском языках.
сообщение 10.7.2008, 8:48
Цитата(Campanula @ Сегодня, 9:06)
Behind the 1: models (E398: 1/L7: 2)
Only ? no L7e ?
Keeptime.zip ( 7.84 килобайт )
Has forgotten to put a file TalkClock.с :-)
Campanula
сообщение 10.7.2008, 9:00
QUOTE(Osta @ 10.7.2008, 8:48) *
Only ? no L7e ?
Sorry, no L7E, a source, you can compile their own under
Key broadcast by the source om2804
Small changes
The whole point timekeeping + button timekeeping
Сообщение отредактировал Campanula - 10.7.2008, 9:01
сообщение 10.7.2008, 9:13
Цитата(Campanula @ Сегодня, 11:00)
Small changes
It is clear. Then we wait for testing from users of phones E398/L7..
Campanula
сообщение 10.7.2008, 9:29
QUOTE(Osta @ 10.7.2008, 9:13) *
Uh. Forum www.motoedy.cnE398 and L7 users have been testing
You need to create the keys broadcast sound files
1440 amr voice, the need to create a common synthesis, this button timekeeping smooth, no longer on the clock after the newspaper suspended again minutes
go_eclipse
сообщение 10.7.2008, 9:54
Из: Одесса
Пользователь №: 94 287
Модель телефона: V3i
Прошивка: BC 3.04
перевод 1поста эл. переводчиком. Реально трудно понять. надо попробовать сделать
Извините, я есть из Китая EDY(lpktool) только говорят, что английский sad.gif
целая точка timekeeping + + сигнальная кнопка timekeeping и календарь timekeeping clap.gif
10-ленточная конфигурация, как указано ниже:: / / b / edy / Keeptime /! файл: / / b / edy / Keeptime / звук /! 14; 1; 1-7; 06; 20; k; 10; 07; 08; mp3; 1; k; amr; 0; 0: / / b / edy / Keeptime /! передача часа звучат путь файлов: / / b / edy / Keeptime / звук /! путь timekeeping ключей
14 под ключами для передачи ключей (левый softkey), может изменить другое ключевое изменение на другие ключи, не блокировал клавиатуру, ключи timekeeping выключен по неизвестным причинам
14 после передачи ключей - это переключатель
1-7 недель, чтобы переключить целый переключатель timekeeping точки
06; 20 точек от имени полной передачи времени k: переключатель timekeeping (k открытый для timekeeping, Комиссар g для timekeeping)
10; 07; 08 представителей от ключа: * +7 +83: широковещательный голос от имени целой точки форматируют 1: моделирует (E398: 1/L7: 2) k: сценарии для переключателя, Комиссар: g: голос ключей передавал формат по радио (как слишком много 1440, изначально для делания - это MP3, больший, чем размещенная норма 26 KBS, маленький E не может даже играть, так что превращенный в amr, мелкота)
0 после двух представителей будильника или события календаря - это начало переключателя времени, Комиссар за 0, 1, чтобы открыться
voice:://www.namipan.com/d/739051afe41470743...05bca516de26400.rar
проблема кнопка-широковещательна (если бы только это не было оставлено softkey), другой ключевой клавиатуры не замыкал в обстоятельствах, отказ газеты Прессы, GAO Ren смотрит на что доставит хлопоты, и оплачивает источник SDK smile.gif
Колокольчик Сообщение отредактировал - Сегодня, 12:11
Прикрепленные файлы
Прикрепленный файл larms.rar ( 338.32 килобайт ) Кол-во скачиваний: реально трудно понять
Meate
сообщение 10.7.2008, 10:22
Физик
Пользователь №: 175 612
Модель телефона: iphone
Прошивка: iOS 7 b1
русские объясните пожалуйста кто понял
DmT
сообщение 10.7.2008, 11:01
Мото-Портной
Пользователь №: 129 181
Скажите ему чтоб в следующий раз пояснения картинками рисовал, а то английский у него немного загадочный
Сообщение отредактировал DmT - 10.7.2008, 11:02
N!kola
сообщение 10.7.2008, 15:45
Из: Сербия
Button timekeeping...What on Earth does that mean...
Skilos
сообщение 10.7.2008, 18:45
Пользователь №: 149 958
Модель телефона: Motorola E1 original
Прошивка: Mpx De Luxe 49r
It looks like our chinese friend uses google translator either. Надо попросить китайцев, которые говорят по-английски, чтобы они по-нормальному перевели
Ter0n
сообщение 11.7.2008, 5:01
Пользователь №: 149 955
Прошивка: error 0x89
Может проще найти китайцев которые говорят по русски ?
Campanula
сообщение 11.7.2008, 5:06
Update to Keeptime1.1
Last night for the battery, start-up found that the volume automatically change 0, om2084 also read over the code, the code found om2084 scenarios
To optimize the code, removing scenarios, the whole point re-broadcast voice production, dual-format
The scenarios only control the whole point timekeeping, the newspaper has no control over the keys (to control only through the switch)
Important that the newspaper did not limit the voice of
Suitable models Update (1 to 2 series e398 series lte for l7, such as lte2 series)
Keeptime.elf
Прикрепленный файл keeptime_1.1.rar   ( 6.11 килобайт ) Кол-во скачиваний: 174
Keeptime Sound :http://www.namipan.com/d/dd41f193149f5112f...5b8729801797600
SRC
Сообщение отредактировал Campanula - 11.7.2008, 6:07
Hellscream
сообщение 11.7.2008, 6:07
Из: Кемерово
Пользователь №: 57 645
Модель телефона: N80
Я в шоке от их английского. Что делает этот эльф? Зы: 3 пост говорит)))
Campanula
сообщение 11.7.2008, 6:15
QUOTE(Hellscream @ 11.7.2008, 6:07) *
Press newspaper and broadcast the whole point
Nixxell
сообщение 11.7.2008, 21:35
Пользователь №: 164 062
Прошивка: ACR_RB
Предпологаю.. (но могу ошибаться).. это эльф с помощью которого можно сэкономить время разряда батарее....
beat_lis
сообщение 13.7.2008, 1:26
Пользователь №: 124 357
Модель телефона: V3x
Прошивка: LifeTec for V3x V2
Делаем ставки?Кто ближе угадает smile.gif Особенно эта фраза мне нравится: Сценариев только контролировать весь точке времени, газета имеет никакого контроля над ключами (для контроля только через коммутатор)
Hellscream
сообщение 13.7.2008, 9:31
Из: Кемерово
Попытку перевода на русский я не читал, старался сам понять. Без пол литра нереально...
Chik_v
сообщение 13.7.2008, 10:29
Из: Херсон
Пользователь №: 116 653
Прошивка: i570EXXJH7
Помоему это изменённый TalkClock, только что изменено непонятно.
Nixxell
сообщение 13.7.2008, 21:28
Прошивка: ACR_RB
alarm button timekeeping... наводит на мысли что это эльф будильник
сообщение 14.7.2008, 7:11
Говорящие кнопки + Говорящие часы + говорящий будильник + говорящий календарь
при разряженной батареи громкость выставляется в 0
Автор оптимизировал код от om2084
Двойной формат звуковых файлов mp3/amr
Звуки на клавиши в одной папке , звуки для часов в другой
для абсолютного понятия отличий этого эльфа от эльфа TalkClock
нужны файлы keeptime.c и keeptime.h
Campanula
сообщение 14.7.2008, 7:19
QUOTE(Osta @ 14.7.2008, 7:11) *
OK, the line tomorrow
DDA-E398
сообщение 14.7.2008, 23:05
Из: Нижегородская обл.
Пользователь №: 166 356
Модель телефона: E2, A910, Е398, ATRIX2
Прошивка: разные
Роботаю...
выложите кто-нибудь звуки для него.С меня +
сообщение 15.7.2008, 6:19
в первом посту есть
pawaman
сообщение 17.7.2008, 5:54
Пользователь №: 133 288
Модель телефона: L7e noRSA
Прошивка: R452D_G_08.01.0AR
Там по китайски) А на L7e есть такое? шо то и ома эльф и этот не хочет мне время говорить челофечьим голосом... Отпишитесь у кого работает, плиз.
_Xan_
сообщение 18.7.2008, 10:21
Пользователь №: 95 532
Прошивка: ACR_RB
Дайте пож русскую озвучку..)
Добавлено позже (18.7.2008, 14:24):
или хотяб перезалейте из озвучку на русский файлообменник, а то с ихнего со скоростью 1 кб\с качает...
+Osta
с просьбами звуков сюда http://www.findsounds.com
Campanula
сообщение 13.8.2008, 4:45
Update Keeptime_1.2.elf
Support an arbitrary time frame, the whole point timekeeping
Sound files continue to use the Keeptime1.1
Сообщение отредактировал Campanula - 13.8.2008, 4:49
Keeptime.elf(Update to Keeptime1.2), The whole point timekeeping +alarm button timekeeping and calendar · Эльфы, их разработка и портирование · Forum
Текстовая версия Сейчас: 1.8.2025, 22:57
