[Release] - BudmannG's TSI v2.0 MP R452H6 F/W
Bud
сообщение 20.7.2008, 17:44
Пользователь №: 174 217
Модель телефона: Rizr Z3
Here it is people,
This is the release of one of the best MP out to date.
It is running R452H6 F/W with RSA removed.
Based off of a stock PDS, NOT MODDED PDS
It also has all the best seem edits available.
25 skins I do believe.
Custom SU/SD Sounds.
Dual Boot v4.0
So enjoy!
Java Apps
DAP
File Changer
HelpMeMoto
VC 1.60
Patches
1.Zoom
2.Name and Time in Alarm
3.Corelet in Java List
4.Java Black screen
5.Java FS access
6.Java works with USB
7.New Date Format
8.Video Resolution
9.Large Clock Font
10.Access to Kjava via OBEX
11.Access to the launch of functions from corolet
12.Access RAM from corolet
13.Alarm in Status Bar
14.Alarm Enable/Disable on green button
15.All values allowed in seems
- The Text marquee does not work because of this patch.
16.Attenuation/Fading Backlight
17.Cancel Kjava Certs
18.Change snooze time in alarm
- To change the snooze time you will have to edit seem 004A offset 9A is to set the minutes and 9B is to set how many times you want it to ring normaly before it automatically turns it off.
19.Clear sound when changing volume
20.Clock in status bar
21.Debug 118 for clock in status
22.Delete lock operator start s/w
23.Dictaphone
24.Dualboot 1.01 Z3
25.Georeferencing sort multimedia
26.House indicator
27.iTunes in menu
28.Keypad backlight 104
29.MMA skin
- You will have to edit each mma that is in the skin files to change the home keys.
30.Powerdown Menu
31.Reminder missed time on sms
32.Reminder missed time of the missed calls
33.Remove unnecessary folders from your phone
34.Speed corolet
35.Temporary unblocking softkeys with messae recieval
36.Temporary unblocking sofykeys with phone call
37.The icon incoming calls in the status bar
38.USB Charging
39.Vibro in Kjava
40.Vibro-connecting with BT
41.Visible passwords
42.Vst in a/mobile
43.Display Activity
44.Java heap
45.Remove second Icon In Java list
46.No delete recent calls on sim removal
47.Vibration on Call
48.New Data Format
49.Manual Managment of Backlight
- Pressing the * key will turn the back light off immediately, press any other key to turn it back on.
50.Speed Z3
51.Next Play
IPB Image
Stock PDS TSI v2.0 DOWNLOAD LINK!
Modded PDS TSI v2.0 DOWNLOAD LINK!
Patches List Download Link!
FLASH AT YOUR OWN RISK!
Please only post problems here if there are any!
Anything you want to undo please PM me do not post it here!
I will update the post later with more details. But for now I will let the MP preview tell it all!
Good luck and enjoy!
BudmannG
:cheers:
Сообщение отредактировал Bud - 20.7.2008, 18:28
[Release] - BudmannG's TSI v2.0 MP R452H6 F/W · For English speaking members · Forum
Текстовая версия Сейчас: 14.9.2025, 16:19
