2 страниц V  1 2 >
|Z3 MP| [Release] iZ3 H6 MP! The first iTunes MP for Z3.
Bud
сообщение 9.8.2008, 22:20
Пользователь №: 174 217
Модель телефона: Rizr Z3
iZ3 H6 MP!
The First MonsterPack with iTunes for Z3!
IPB Image
Created by:
BudmannG
CandymanMike
RSA removed. ONLY FLASH THIS PACK IF YOUR PHONE IS RSA REMOVED.
There is a version for Modded PDS and a version for Stock PDS. Please make sure you download and flash the correct version for your phone.
Patches:
Don't Crypto PDS (in modded pds version)
Zoom Z3 (replaces 50% and 75% zoom in pics to 200% and 250%)
Name and Time in Alarm (shows name and time for each alarm in list)
Corelets in Java List (shows corelets in the java list)
Java Black Screen (black screen while java loads instead of white)
Java FS Access (allows for full system access from java)
Java Works with USB (java continues to run when plugged into usb)
New Data Format (adds day of week to 31-Dec-99)
Video Resolution (set default video recording to large res)
Large Clock Font (makes the digital clock font larger)
Access to Kjava via OBEX (for transferring games via bluetooth)
Access to RAM from Corelet (allows corelet to access system memory)
Access to Launch of Functions from Corelet (allows a corelet to launch functions)
Alarm in Status Bar (shows icon in status bar when alarms are active)
Alarm Enable/Disable on Green Button (turn alarm on and off with green key)
Attenaution2 (backlight fade)
Cancel Kjava Certs (allows running of java without certs)
Change Snooze Time in Alarm (set to 8 minutes with a maximum of 50 times)
Clear Sounds When Changing Volume (clears the default sounds when changing volume)
Clock in Status Bar (shows a digital clock in the status bar)
Debug on 118 (for proper function of clock in status bar)
Delete Lock Operator Start S/W (allows running of don't crypto patch for modded pds)
Dictaphone (removes beeps from voice recorder)
Dualboot 1.01 Z3 (allows for running of dualboot)
Georeferencing Sort Multimedia (sorting style for multimedia)
House Indicator (shows house icon next to operator when plugged in to usb, charger or headphones)
iTunes in Menu (allows calling of corelets from itunes menu option)
Keypad Backlight 104 (allows manual control of the keypad backlight)
MMA in Skin (place mma_ucp of mma dependant skins in that skins folder)
Powerdown Menu (holding red key will bring up powerdown menu with options 'shutdown', 'restart', 'skins' and 'menu')
Reminder Missed Time on SMS (will give reminder every 60 sec of missed sms)
Reminder Missed Time on Missed Calls (will give reminder every 60 sec of missed call)
Remove Unnecessary Folders (removes folders not needed from phone)
Speed Corelet (helps virtual corelet run faster)
Temporary Unblocking Softkeys w/ Call (unlocks softkeys on incoming call)
Temporary Unblocking Softkeys w/ Text (unlocks softkeys on incoming text)
Icon Incoming Call in Status Bar (replaces ringstyle icon with call icon until missed calls are checked)
USB Charging (allows you to turn usb charging on and off without a seem edit)
Vibro in Kjava (allows for selecting of vibrate style in java. currently set to 'short' [requires seem edit to change])
Vibro-Connect w/ Bluetooth (allows for selecting vibe style for bluetooth connect. currently set to 'none'. [requires seem edit to change])
Visible Passwords (shows passwords instead of *****)
VST in a/mobile (allows for the VST to be placed in a/mobile/vst)
Display Activity (changes display timeout options to 'off', '20 sec', '40 sec', '1 minute' and '2 minutes')
Remove Second Icon in Java List (removes the second icon from the java list)
No Delete Recent Calls on Sim Replace (does not delete recent calls when sim card is replaced)
Speed Z3 (speeds up the phone operation)
Next Play (automatically plays next song in list)
Replace Exit with Edit in Phonebook (still shows exit, but will take you to edit)
SEEM edits and other mods:
No Name DRM sped up drastically with motospeed
Ringlights enabled and installed (extra ringlight files in download pack)
mma_ucp files for mma dependant skins installed in the skin for proper function with mma in skin patch
AT&T & T-Mobile websession installed
Custom Bootscreen
Custom Startup Sound
Custom Slider Tones
Modified audio_config
Modified ui_config
Picture grid view
Unlimited Video Recording
Video Recording in mp4 format
iTunes Routed to the Browser Key
...too many to list or even remember!
Skins installed:
Nat Blue
Crystal Black
MotoMagx
Black&Blue
iField
Orange & Black Apple
Evolution Lime
iBlack
Eclipse
iTunes1
Black as Moto
Blink
Royal Blue
Vampd Black
Black II Edited
Poeticfolly_Black
*all skins slightly edited to fit large clock font patch
Java Apps installed:
iTunes
---Will look like this in the pack:
IPB Image IPB Image
---With attached skin applied:
IPB Image IPB Image
HelpMeMoto
MP3 Tools
FileChanger
MiniCommander
MotoID
Motorola SETUP
Opera Mini
Yahoo! Go
Windows Live Messenger
Students Calculator
Clock
There is a version for modded PDS and a version for stock PDS. Please flash the correct version to your phone to avoid any error messages after flash. The whole pack can be flashed in blank mode. * + power = blank
Thanks to my fellow members of Team Rizr and the members of M3 and all skin, drm and font creators.Thanks to all of the modders before me who worked so hard to find the seems and hidden features that make modding possible. Extra special thanks go out to CandymanMike for his work on Revolution MP and BudmannG on TSI v2.0. Also to Ugunit89. You are the man. If it wasn't for you we wouldn't have these patches working on H6 at all! Or iTunes for that matter!And of course thanks to the russian modders who made Avalanche. If it wasn't for them, we wouldn't have had the patches to port for H6.
Pack includes:
iZ3 H6 MP in .shx format
A .rar file containing:
additional ringlights files
clock in status bar pack including:
special skiman clock in status bar script
clock tables in several colors
instructions for installation
A .rar file containing literally thousands of extra wallpapers (all clean. sorry guys )
A text copy of this description
Hope you enjoy!
Click Pic to Download Stock PDS Version:
IPB Image
Click Pic to Download Modded PDS Version:
IPB Image
Download Skins file
Bud
сообщение 10.8.2008, 12:29
Just so you know this is not any part of the avalanche mp. I have ported all the patches with a friend and myself. We worked very hard on this mp because no one else is working on H6 f/w. I did not use any part of the avalanche mp. I used the patches that bigserg posted for me in the english forum.
I give the Avalanche mp credit because it was the first mp with that many patches added to it. That is all! I give credit where credit is due.
sadface
сообщение 10.8.2008, 18:35
Пользователь №: 110 110
Модель телефона: Z6 + Kingston 2GB
Прошивка: 44R + PE
извиняюсь за обвинения.
Добавлено позже (10.8.2008, 22:38):
а вот как iTunes запустили на Z3 ?
Bud
сообщение 10.8.2008, 19:38
Yes iTunes works on the z3. My friend Ugunit got it working. This is just the beta version of iTunes so there are some glitches in it.
1. You cannot have auto update time and date on, it has to be off.
2. You cannot have the heap_java_2000 patch applied. Because it slows it down and has problems.
sasha45
сообщение 10.8.2008, 20:39
Пользователь №: 46 095
Так стоп... Это корелет iTunes или эльф? Мне очень хочется это знать=))
Bud
сообщение 10.8.2008, 20:43
This is corolet iTunes no elfs. This is the real deal!
sasha45
сообщение 10.8.2008, 21:03
Блииин.. This is cool =))
Bud, правильно ли я понимаю: Modded PDS это с патчем Don't Crypto?
Добавлено позже (11.8.2008, 1:32):
Ну чтож. Поставил я себе сие чудо. Какие первые впечатления. Русский язык отсутствует, но это не беда. По флешке телефон шарит быстрее, чем на аваланче (на том монстре мелодии долго открывались). Баг с подсветкой остался.
Теперь наверное главное для меня чудо. iTunes действительно работает и это на самом деле корелет, а не эльф. По поподву других глюков отпишусь потом. Это я написал так, на скорую руку и тока от первого впечатления.
Пока авторам монстра респект за работающий iTunes =)
Сообщение отредактировал sasha45 - 10.8.2008, 21:08
Bud
сообщение 10.8.2008, 21:49
Yes modded pds has the don't crypto patch applied.
sasha45
сообщение 10.8.2008, 22:03
Bud, how create dataBase in iTunes?
Bud
сообщение 10.8.2008, 22:18
To create data base> Menu button is the green call button. In there it will have a Create iTunes db. If you want album art you will have to use mediamonkey to get the album art on the phone.
If you want to change skins in the iTunes. Download the skins file. Then put it in the iTunes folder on your tf. Then open iTunes in the phone go to menu>settings>Change skins. Then you can go to the menu again. There will be a change skin link now, click it go to the skin you want to use and select the resource file of that skin. Close iTunes Then restart if That dont change it try restarting the phone.
Good luck.
Axis10
сообщение 11.8.2008, 3:20
Из: Сыктывкар
Пользователь №: 132 841
Модель телефона: L7/L9
Прошивка: ACR_RB/04R
выложите Itunes
Bud
сообщение 11.8.2008, 3:35
I dont understand Axis. What are you asking?
EXTRA
сообщение 11.8.2008, 8:08
Из: Беларусь>Барановичи
Пользователь №: 129 664
Модель телефона: ROKR E6, Defy
Bud
how install Itunes??
explain in detail??
Добавлено позже (11.8.2008, 8:09):
Bud
explain in detail??
Bud
сообщение 11.8.2008, 11:46
This is a MP with iTunes in it already installed. Use f&b3 To flash all cg's in blank mode. Then use the guide I posted on getting your iTunesDB. iTunes will autostart on its own when you start the phone. It is also linked to the browser key on the phone.
bigserg555
сообщение 11.8.2008, 11:59
MotoSportsMen
Из: Рязань
Пользователь №: 53 831
Модель телефона: LG
Прошивка: Меняю как перчатки)
Axis10 asks to give him iTunes from yours MP for Z3
Bud
сообщение 11.8.2008, 12:04
Here is a link to it you have to install using midway.
Download iTunes here!
Features:
MediaViewer
iTunes DataBaseCreator
Voice Recorder
Skin Changer
SMS Alarm
(PhoneBookTools was removed because it doesn't work for our version of phones)
Keys:
- * to Minimize/Hide
- 0 to Unload and all Exit Plugins
- Back Key works like back button
- Green Call Key for Menu
Known Issues:
AutoUpdate time will cause itunes to crash
Java Heap patches might negatively affect performance.
iTunesDB creator might have problems with larger amounts of music
Things Needed:
RSA Removed and a Patch to cancel checking Java Certs
Either iTunes Button Patch or iTunes Shorcut Seem edit(Used to Start iTunes )
Patch for Corelet in Java List( Used to initialize iTunes )
How to Install:
If you have any previous corelets installed then delete them( unless you plan on running dual corelet.)
Now Install iTunes Only with MIDway through the Java App Loader(Guide Here)
When it asks you to run click yes and itunes should pop up in about 20 secs(planning to lower that time later).
From here you can either create an iTunesDataBase from the menu or you could use MotoTunes.
iTunes can be started from the iTunes button or a shortcut seem edit after.
Credits
Credits to the original maker of this iTunes version PoerHardware. The original iTunes for L7e/K1/Z3 by Archy. And to Valleo's VirtualCorelet because I used that as a reference.
(11.8.2008, 12:05):
Thank you bigserg555!
sasha45
сообщение 11.8.2008, 12:32
Bud, в монстре есть ужасный глюк с громкостью. Когда в iTunes громкость ставишь на 2 или 1 ступень, то она пропадает вообще. Помогает следующее: выключить iTunes, зайти в мелодии, запустить любую песню, там громкость будет на 0. Поставить громкость хотя бы на 1 ступень, потом запустить iTunes и все работает снова. Но ставить громкость в iTunes на ступень 1 или 2 нельзя, звук пропадает. Почему так?
Извиняюсь, у меня плохо с переводом с русского на англ. Поэтому буду писать так.
Axis10
сообщение 11.8.2008, 16:45
Из: Сыктывкар
Thanks for all ever so much!
Сообщение отредактировал Axis10 - 11.8.2008, 17:51
EXTRA
сообщение 11.8.2008, 16:51
как в iTunes включить музыку???
Сообщение отредактировал EXTRA - 11.8.2008, 20:01
Прикрепленный файл iTunesProMod.rar   ( 378.68 килобайт ) Кол-во скачиваний: 186
sasha45
сообщение 11.8.2008, 17:00
EXTRA, создай базу данных песен, и они появятся в списке песен в iTunes. Как это сделать, посмотри на предыдущей странице.
sasha45
сообщение 11.8.2008, 17:32
Axis10, не, ну ты бы как-нибудь по вежливее попросил. И чем тебя этот не устраивает? Все нормально качается.
EXTRA
сообщение 11.8.2008, 20:39
sasha45
когда создаю базу данных песен...тормозит на 56% ивсё((
Bud
сообщение 11.8.2008, 23:06
Make sure the auto update time and date is turned off. I have not had a problem with the sound ever so I really do not know how to fix it. My volume shuts off at 0.
Try using mototunes to create a iTunes DB. Or even mediamonkey will work to do that.
sasha45
сообщение 12.8.2008, 2:37
Bud, Ok.
OldWiseCat
сообщение 12.8.2008, 6:27
Из: Фрязино
Пользователь №: 120 158
Модель телефона: RIZR Z3 | MPx200
Прошивка: 0DR patched | WM 5.0
заранее извиняюсь за глупый вопрос. Монстр основан на 05R? значит эльфы работать не будут?
сообщение 12.8.2008, 9:19
Цитата(EXTRA @ Сегодня, 10:26)
OldWiseCat
ODR
по-моему он основан на арабской R452H6_G_08.00.05R_
Bud
сообщение 12.8.2008, 11:27
OldWiseCat This is not 0dr this is H6 firmware. It is the fastest out to date.
Extra Please stop comparing this to Avalanche. As I said before this is in no way the Avalanche MP!
sasha45
сообщение 12.8.2008, 17:32
EXTRA, сделай тогда как я. Я когда ще не понял как создать б\д, скачал программку, называется Moto Tunes. Это программка для компа. Она позволяет создавать на флешке не тока б\д мелодий для тюнса, но также и плейлисты.
Bud, а у тебя есть откат на патч "Плавное погашение подсветки"?
Bud
сообщение 12.8.2008, 21:23
I hope you are asking for the attenuation undo patch, fading backlight?
Here it is in the attachment.
Сообщение отредактировал Bud - 12.8.2008, 21:27
Прикрепленный файл Attenuation_Fading_Light__H6__UNDO.rar   ( 619 байт ) Кол-во скачиваний: 163
sasha45
сообщение 13.8.2008, 2:38
Offset
сообщение 13.8.2008, 8:55
Leo
Пользователь №: 126 712
Прошивка: 2BR
sasha45, насколько я помню это не глюк громкости, а глюк самого тюнса. Проблема решается переустановкой! wink.gif
Дагестан
сообщение 13.8.2008, 17:43
Из: Россия
Пользователь №: 97 197
Модель телефона: E1, L7, W510, Z3
Откат подсветки не работает.
Bud
сообщение 13.8.2008, 22:49
Дагестан Try to reflash the MP it sounds like not everything went through to the phone.
Дагестан
сообщение 14.8.2008, 12:12
Из: Россия
OldWiseCat
сообщение 14.8.2008, 13:01
Из: Фрязино
а как софт кнопки переназначить?! что-то там как висело сообщения на левой и видеокамера на правой так и висит. в мма прописаны справочник и сообщения, по мнению телефона у него на клавшах тоже висят справочник и сообшения! а там всё равно сообщения и видеокамера((( нид хэлп!
Bud
сообщение 14.8.2008, 13:40
OldWiseCat You can change the softkeys by going into the skin files and changing the mma in each skin.
Дагестан Flash the monster pack again to try and fix your problem.
OldWiseCat
сообщение 14.8.2008, 15:55
Из: Фрязино
Bud,
так я и правил мма! а оно всё равно так..
sasha45
сообщение 14.8.2008, 18:35
OldWiseCat, насколько я помню тебе надо править не мма, а сам скин. потому что там для каждого скина берется свой мма.
@DimoK@
сообщение 15.8.2008, 7:37
Пользователь №: 153 884
Модель телефона: K1
Прошивка: R452F
Bud, как можно установить отдельно iTunes? Когда я его устанавливаю, то при запуске пишет "ошибка приложения".
nothing
сообщение 15.8.2008, 8:01
Из: Луганск
Пользователь №: 121 257
Модель телефона: Rizr Z3 & Rokr EM30
Прошивка: Avalanche.mod
Откати патч "Хип на яву 2мб"
2 страниц V  1 2 >
> Быстрый ответ
Текстовая версия Сейчас: 3.8.2025, 14:10
