8 страниц V  1 2 3 > »
Elfs by motoedy[China], new:more elfs 05.09.2009
Campanula
сообщение 15.8.2008, 1:58 Закрепленное сообщение!
Пользователь №: 176 749
Welcome to China motoedy smile.gif www.motoedy.cn
http://translation2.paralink.com + http://translate.google.com/translate_t
newHITMOUSE by hantao
1,2,3,4,5,6,7,8,9
Exit: Red
Author: om2804 tim apple Editorer: 四夕 & 林子 L7E/L9: lpktool
Thanks to om2804 tim apple
new LRCPlayer_DesktopshowLRC_1.3
Прикрепленный файл LRCPlayer_DesktopshowLRC_1.3.rar   ( 480.3 килобайт ) Кол-во скачиваний: 884
[Updated 09-08-01]
Lin LRCPlayer_ modified version V1.3
[+] Add lyrics contour, in BG_LRC.CFG color profile settings in the settings to add "show the outline of the lyrics" set;
[+] When did the lyrics, the screen does not display lyrics and other non-related tips;
[+] To remove the panel in the A site or C site settings, the program will automatically determine which disk;
[+] LRCPlayer.lng documents are updated, LRCPlayer.cfg document changes to the original part used to re-configure the settings (such as the use of IT to start, etc.);
[Updated 09-07-30]
Lin LRCPlayer_ modified version V1.2
[+] Amendment can not be deployed for panel icon panel issues;
[+] When a song did not amend the LRC, the desktop display lyrics on a problem;
[+] Icon shows a high degree determines the number of rows and a high of 20 for his party, would like to show you a few lines of lyrics
[+] Can call with the panel and different icons and configuration, will be on the panel BG_LRC.CFG and BG_LRC.GIF document under the folder DeskTopFile; not call the default program directory;
[+] In setting a "desktop display the lyrics" and "show-screen lyrics when Changliang" choice;
~ 12.06.2009 ~
[LRCPlayer 1.3]
Hard-won source ah
* Based on modifications made to Tunes3.9
* Play button changes the interface is as follows:
123, respectively, for the side and so on, flash, screen
5 for the current playlist
8 on
7 players on the grounds to the lyrics of the skin interface interface
9 on the grounds the lyrics to the player skin interface interface
* Reduce the volume
# Increase the volume
0 to mute
Other operations with Tunes3.9
still lrc.cfg address for GBK encoding, LRCPlayer.cfg the last 2 bytes in order to initiate a 16-band event code
new Memorandum_Simplify the locking version
Прикрепленный файл Memorandum_Simplify_the_locking_version.zip   ( 9.92 килобайт ) Кол-во скачиваний: 559
new HDautoplay1.5
Прикрепленный файл HDautoplay1.5.zip   ( 2.48 килобайт ) Кол-во скачиваний: 517
Its working principle: plug in your headphones to monitor the incident code, and monitor the core event code (0404, that is, start-up events LRCPLayer.elf/Tunes.elf, when you start the event of LRCPlayer/Tunes.elf code changes, so please direct HEX to 0404 start for your event LRCPlayer/Tunes.elf code), auto-play button to use the simulation
To work only on the desktop
Lock Application--->Headset
Locked--->autoplay
Unlocked---> unautoplay
maybe only for 79R
RamEdit :
Redmenu_mod (ELF&SRC)
gif:L"*.gif"
CODE
Ring Styles=0936
ZtxtEdit=file://a/MotoCmd/Ztxtedit.elf
CODE
For 79R:
Power off=17
Silent power off=0000
Reset=0001
Switch in BOOT=0003
Unload Java=1806
MachoSettings=0973
Tunes=1889
MotoCMD1.8=0985
OPcode=2011
Personalise=0942
Initial Setup=0943
Message=1025
Video Camera=1021
Camera=1019
Bluetooch=1789
USB Settings=1022
Alarm Clock=1001
Datebook=8378
Skins=3237
Shortcuts=0929
Ring Styles=0936
pp_lrc_1.7.1
Прикрепленный файл ppplayerv1.7.zip   ( 135.61 килобайт ) Кол-во скачиваний: 817
* Revision of the map in support of GBK, shows in simplified and traditional Chinese \ Sun Wen \ text of the stick ..
* Cancel version of the patch did not play ... GBK's patch map, garbled show ..
* Some small bug amendment ..
* Only version of the patch
This version of the six, to see the name of the folder you know the type:
If, desktop_walkman, on behalf of the desktop that shows the time, the interface for the walkman
The rest and so on (Note: iris for the past Xiaoyu's colorful interface)
Another: a patch version of the map for migration 0x10c3e800 (increase has been offset start-CG1), non-offset this, please make its own decisions
Revised: 16 hexeditor (such as UltraEdit32, etc.) to open elf, search 0x10c3e800, replace your address migration
PP_reader_1.1
Прикрепленный файл ppreader_no_patch.zip   ( 26.93 килобайт ) Кол-во скачиваний: 530
Прикрепленный файл pp_reader_v1.1.zip   ( 98.57 килобайт ) Кол-во скачиваний: 627
Increase:
1, to support the GBK code, that can display traditional.
2, in the setting / folder under map.set document offset patch, the hex address of the patch + CG1 address, I provided a patch for the use of 398. 398 can not use the default for 0x10C3E800.
3, at the right point in time to read software code to open the menu option to resolve the utf_8 file to open in the first few garbled.
1, the English word would be forcibly cut off, did not get
2, does not support L7E ...
3, to replace paper map, the size of 47k.
Patch file also changed, and 398 in place are adequate.
Other models to find your own! ! !
After the test, did not play in the system memory of the 398 patch can not run on non-patch version! ! !
Color Clock
1.6
Прикрепленный файл Color_T_v1.6.zip   ( 9.53 килобайт ) Кол-во скачиваний: 608
Color_T v1.3
Прикрепленный файл Color_T_v1.3.zip   ( 69.38 килобайт ) Кол-во скачиваний: 708
Author: Kalvinxp (bimonthly)
Source: EDY Прикрепленное изображениеПрикрепленное изображениеПрикрепленное изображение
0 1 2 3 4 5 ... F
0x00000000 XX XX XX bond packages
0x00000010 XX XX clock line coordinates of the clock ordinate
0x00000020 XX XX XX hours of high color
0x00000030 XX XX XX hours of low color
0x00000040 XX XX XX isolation: the color
0x00000050 XX XX XX high-minute color
0x00000060 XX XX XX low-minute color
0x00000070 XX XX XX XX XX XX this line of the first byte as a font type, 2 bytes for the border or shadow (0 without any results,Plus 1 frame, plus 2 after the shadow of the shadow of the former plus 3); the first 3-5 bytes for the effect of color ,No. 6 bytes for the digital space
PS: XX on behalf of a byte
ElfOpen2.4.1
Прикрепленный файл ElfOpen_2.4.1.zip   ( 27.14 килобайт ) Кол-во скачиваний: 676
thanks for om2804!
mma_ucp:
Phone book
Dialling services ---- Quick dial, voice dial, and attribution for (Fixed dial), Incall setup, RecentCall, Call Forward
Message
Security
ELF & JAVA procedures ---- JAVA procedures, MOTO Manager (AIM), ELF (mixing machine), FELX procedures (WEB shortcut), SEEM editor (Mobile QQ), HEX editor (themes)
Access to the network ---- browser, StoredPages,WebHistory,GotoURL,BRWSetup,WebSessions
Multimedia---- Sounds,Pictures,Video,ITUNES,Camera,VideoCamera
Tools ---- alarm clock, DateBook, calculator, voice record, data backup tools (IM), SIM APP
settings----Personalize,IntlSetup,JAVAtools,CarSetting,PhoneStatus,FEM
MMRingStyle
Shortcuts
Connection ---- Bluetooth, USBSetting, sync, network, airpin mode, headset
03FC instant messaging (IM)
03D1 (chat room)
03DF (AIM)
03ED (WEB shortcut)
03DE (themes)
03D9 (Mobile QQ)
039A (fixed dial-up)
Please use P2KTOOL hidden settings
The more open, and then put mma_ucp
The MMA for the E398. Other models, a separate production ~
new
Backupsms
Прикрепленный файл backupsms__09_08_31.zip   ( 14.28 килобайт ) Кол-во скачиваний: 499
CODE
IN1=0x04E6
IN2=0x04E7
OUT1=0x07CD
OUT2=
PATH=file://b/backups/
CODE
[SMST]
app=/b/Elf/MotoCmd/smsv.elf
type=id
09-08-31
Amendments to the multi-page copies of reading support. (Known Bug: Unable to get part of the recipient)
Skin.elf
CODE
[SKI]
app=/b/Elf/MotoCmd/Skin.elf
type=id
new
Auto change skin when you startup your phone
Skins in dick a
Skins in dick c
Please add to AutoRun
PP_DnpEditor:
Прикрепленный файл PP_DnpEditor.elf   ( 19.44 килобайт ) Кол-во скачиваний: 785
UnRAR/Un7z:
CODE
[RAR]
app=/b/Elf/MotoCmd/unrar.elf
CODE
[7z]
app=/b/Elf/MotoCmd/un7z.elf
6Elfs only for 79R
Gomeno(Lock Application --> JAVA APPS)
flashlight on VOICE + VOICE :
Lockvideo(Lock Application --> Headset)
Screener picture:
newPlug-in for MotoCMD: ConfigEditor oт 林子 English Verson by Last1left
Прикрепленный файл ConfigEditor_eng.zip   ( 8.35 килобайт ) Кол-во скачиваний: 527
для редактирования файлов: .res .ini .menu .lng.run
CODE
[INI]
app=/a/Elf/MotoCmd/ConfigEditor.elf
[MENU]
[RES]
[LNG]
[RUN]
new DEC HEX BIN Converter oт 林子 English Verson by Last1left
Прикрепленный файл NumBasis_eng.zip   ( 6.38 килобайт ) Кол-во скачиваний: 439
new Motocmd2.0
QUOTE(Fenja @ 1.9.2009, 17:43) *
Campanula, in what of difference between MotoCmd.elf, MotoCmd-DDRM.elf, MotoCmd-DXDRM.elf?
CODE
MotoCmd.elf don't need Icons
MotoCmd-DDRM.elf is old Verson
Please use MotoCmd-DXDRM.elf
Icons for MotoCmd
Please add in your DRM!(CG15)
695                 mp3.amr .m4a .mid
696                 device
697                 dir
698                 txt .umd .doc .lng .lrc .smst
699                 elf
700                 exe
701                 html
703                 jad
704                 jar
705                 main
706                 null
707                 rar
708                 sys
709                 video.3gp .mp4
710                 zip
711                 ini .cfg .set .run .lib .rlt .rm .pat
712                 mei .jc
713                  Waiting..
CODE
Register=0x03DC
Map=110F0824
Sytem=0;Hidden system files: 0/no 1/yes
ReadLast=1;Read last open Folder: 0/no 1/yes
ChangeType=1;Scroll Display file names : 0/no 1/yes
UseZipBrowser=1;ZIP Browser Switch:1 use MotoCmdZIP, 0 use MotoCmd Plug-in(UnZip.elf)
BookDir=/a/Elf/MotoCmd/bmk/Ebook.txt;file of BookDir
AutoDir=/a/Elf/MotoCmd/AutoRun.elf;file of AutoRUN
DrmDir=/a/Elf/MotoCmd/Adddrm.elf;file of Adddrm
HexDir=/a/Elf/MotoCmd/HexEditor.elf;file of HexDir
TxtDir=/a/Elf/MotoCmd/Ztxtedit.elf;file of TXTEdit
[MEI]
app=/a/Elf/MotoCmd/ElfInstaller.elf
[JC]
app=/a/Elf/MotoCmd/Jc.elf
[GIF]
app=/a/Elf/MotoCmd/Iv.elf
AutoRun for MotoCmd2.0, No AutoRun
Adddrm for MotoCmd2.0,Plaese Add to AutoRun
Example:b/Moto/Drm/Green/329-336.gif
Open MotoCmd2.0,You can Long press 0,Then Press Menu,Update battery pack.
QUOTE
map is our Chinese Transcoding
For example:
Map=110F0824 ,This is a patch of gb2uc. It's used to gbk to uc
UnZip.elf PP_lrc.elf LRCPlayer.elf MotoCmd.elf ....must to use this patch (Map=10C3E800)
ZtxtEdit.elf use 3 maps
1:patch (Map=110F0824) :gbk to uc
2:gb2big5.map : gb to big5
3:uc2gbk.map : :uc to gbk ,This is used to edit txt.
Russian friends, British friends ,Do not need to use maps....
give you the src of ZtxtEdit , MotoCmd2.0.0.1 and LRCPlayer1.4
Прикрепленный файл motocmd2.0_scr.rar   ( 165.03 килобайт ) Кол-во скачиваний: 448
Спасибо всем разработчикам эльфпака и эльфов!
Сообщение отредактировал Campanula - 6.9.2009, 6:55
Прикрепленный файл ElfOpen_2.3.1.zip   ( 33.39 килобайт ) Кол-во скачиваний: 550
Прикрепленный файл ElfOpen_2.3.zip   ( 32.16 килобайт ) Кол-во скачиваний: 360
Прикрепленный файл LRCplayer_1.1.zip   ( 179.46 килобайт ) Кол-во скачиваний: 551
Прикрепленный файл Color_T_1.1.zip   ( 81.69 килобайт ) Кол-во скачиваний: 736
Прикрепленный файл Color_T_v1.2.zip   ( 68.73 килобайт ) Кол-во скачиваний: 512
Прикрепленный файл LRCplayer_1.2.1.zip   ( 363.82 килобайт ) Кол-во скачиваний: 858
Прикрепленный файл LRCplayer_1.2.zip   ( 189.02 килобайт ) Кол-во скачиваний: 983
Прикрепленный файл LRCPlayer_1.3.zip   ( 440.51 килобайт ) Кол-во скачиваний: 436
Прикрепленный файл backupsms__09_6_20.zip   ( 13.7 килобайт ) Кол-во скачиваний: 426
Прикрепленный файл Memorandum_V1.0.zip   ( 18.46 килобайт ) Кол-во скачиваний: 473
Прикрепленный файл backupsms__09_6_23.zip   ( 15.07 килобайт ) Кол-во скачиваний: 438
Прикрепленный файл Memorandum_V1.1.zip   ( 176 килобайт ) Кол-во скачиваний: 583
Dead_Moroz
сообщение 15.8.2008, 4:08
Из: Бишкек
Пользователь №: 158 765
Модель телефона: SLVR 7
Прошивка: Iron series
Campanula,
Hold a second, what I understood from your post is:
- this elf can work like cmdopen.elf but unlike cmdopen.elf we can write up to 8 elfs to its configuration;
- we can add items (or change existing items) in mma_ucp and "hang" elfs to them right?
If yes, it is great!!!
Can you please make it clear? We cannot understand you!
Campanula
сообщение 15.8.2008, 4:21
QUOTE(Dead_Moroz @ 15.8.2008, 4:08) *
Campanula,
yes
to cope with the use of Editor mma_ucp
mma_ucp:
Phone book
Message
Security
MMRingStyle
Shortcuts
Сообщение отредактировал Campanula - 15.8.2008, 4:40
Dead_Moroz
сообщение 15.8.2008, 4:26
Из: Бишкек
Campanula,
Does it work with L7e?
If yes, can you help me to "hang" Tunes 2.8 to a custom menu item "Tunes"? I added it (custom menu Tunes) to "Connection" section. But I don't know its ivent code. Can you give me some advice?
Campanula
сообщение 15.8.2008, 4:49
You need out L7E useless menu
Dead_Moroz
сообщение 15.8.2008, 4:50
Из: Бишкек
To everybody
Короче, здесь нужен доброволец с телефоном e398
применяете выложенный mma_ucp и устанавливаете выложенный эльф.
Эльф Flex нельзя удалять из списка.
Прописанные эльфы рекомендуется положить в /b/elf/
Эльф выполняет функцию запуска других эльфов из пунктов меню.
Пока это все что я понял.
Добавлено позже (15.8.2008, 9:54):
Campanula,
Only useless menu?
How about "custom menu items"? There have not been menu "Tunes", so I added it. But I don't know its ivent code. Is it real to make this menu item launch Tunes.elf?
Campanula
сообщение 15.8.2008, 6:20
QUOTE(Dead_Moroz @ 15.8.2008, 4:50) *
To everybody
Campanula,
Only useless menu?
Only useless menu
Dead_Moroz
сообщение 15.8.2008, 8:49
Из: Бишкек
Ok, thanks. I'll chek it out soon.
Добавлено позже (15.8.2008, 14:02):
Ребята, вот оно - теперь можно запускать эльфы из пунктов меню.
friend 1
сообщение 15.8.2008, 9:07
Пользователь №: 136 759
Модель телефона: L7e
Прошивка: 01.0AR NO RSA
Эльф работает только на Е398?
Сообщение отредактировал friend 1 - 15.8.2008, 9:24
Dead_Moroz
сообщение 15.8.2008, 9:11
Из: Бишкек
Campanula,
0x00; file: / / b / Elf / SMS_viewer.elf!
0x00; file: / / b / Elf / MotoCmd.elf!
can u give some detiled information abot this. It is pretty hard to understand your first post.
Добавлено позже (15.8.2008, 14:26):
сам до конца не разобрался с ивентами. у меня предположение: активируете ненужные пункты через мма эдвансд эдитор, затем необходимо найти ивенты вашей модели к каждому пункту. прописываете эльфы и все вроде. только последние 3 эльфа из списка как запускаются не понял. руки до компа не дошли еще.
-SeGa-
сообщение 15.8.2008, 11:28
Из: Росто-На-Дону
Пользователь №: 178 348
Модель телефона: L7 - seТ700
Прошивка: =)
для л7е я ето сделалал, и без всякого эльфа.
friend 1
сообщение 15.8.2008, 14:36
-SeGa-
Неподелишся методом?
сообщение 15.8.2008, 14:57
вот пример Инструкция по установке эльфов
Dead_Moroz
сообщение 15.8.2008, 15:47
Из: Бишкек
Данный эльф, как я понял, является продолжением 'темы' cmdopen, только в отличие от него может запускать до 8 эльфов из пунктов меню.
Протестирую, отпишусь.
Serega666
сообщение 15.8.2008, 18:37
Из: г. Харцызск
Пользователь №: 146 951
Модель телефона: E1 с 07D0
Прошивка: Моя с Reflash'а 49R
Работает biggrin.gif но если пункт меню рабочий, то при нажатии кнопки "Выход" из Эльфа запускается сам пункт меню, и еще не могу поставить эльф iTunes на пункт меню
Dead_Moroz
сообщение 16.8.2008, 5:06
Из: Бишкек
Serega666,
Автор темы писал, (да и так наверное ясно) что нужно активировать неиспользуемые (нерабочие пункты меню, напр. "радио" на L7e).
А тюнс я повесил по этой инструкции. Всё просто.
Serega666
сообщение 16.8.2008, 18:13
Из: г. Харцызск
Я имел введу что iTunes не ставиться на пункт меню с помощью этого эльфа
Сообщение отредактировал Serega666 - 16.8.2008, 18:32
Воха
сообщение 19.8.2008, 0:20
Сектант Xiaomi
Из: Дніпро 🇺🇦
Пользователь №: 145 492
Прошивка: Android 12-13
Норм
А можно создать в mma_ucp новые пункты меню, типа ~1 ~2 ~3, и прописать в них запуск определённых эльфов? Или пункты с несуществующими значениями функций, и эти значения использовать для запуска эльфов
Motohobiman
сообщение 19.8.2008, 5:32
Из: Ukraina
Пользователь №: 81 710
Прошивка: Слава Украине!
Вечный мотодроллер;)
Нет нельзя,ивент у этих пунктов одинаков,распознавание происходит по ID,видимо используется таблица какая-то. Вот если бы эльфам прикручивать ID по мотостандарту,то да можно было-бы.
Воха
сообщение 19.8.2008, 8:11
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
А разве ID и ивент разные вещи? Я думал что 6 и 7 офсет в метке есть и ID и ивентом
Motohobiman
сообщение 19.8.2008, 9:38
Из: Ukraina
Разные,хоть и связаны тематически.
tadziu
сообщение 21.8.2008, 21:26
Из: Poland
Пользователь №: 170 677
me files:
elfopen.txt
QUOTE
03ED;file://b/Elf/Backuper.elf!
03DE;file://b/Elf/MidTransfer.elf!
03FC;file://b/Elf/Screener.elf!
03D1;file://b/Elf/MultyPhoto.elf!
03DF;file://b/Elf/Auto_RSMS.elf!
0x00;file://b/Elf/MotoCMD-standard.elf!
made:wxm0831,lpktool[edy]!
adder:www.motoedy.cn!
03D1 (chat room)
03DF (AIM)
03ED (WEB shortcut)
03DE (themes)
mma_ucp - screen
why not work...?
Сообщение отредактировал tadziu - 21.8.2008, 21:28
Campanula
сообщение 22.8.2008, 4:21
QUOTE(tadziu @ 21.8.2008, 21:26) *
me files:
elfopen.txt
03D1 (chat room)
03DF (AIM)
03ED (WEB shortcut)
03DE (themes)
mma_ucp - screen
why not work...?
Look:
0x00;file://b/Elf/MotoCMD.elf!
tadziu
сообщение 22.8.2008, 7:46
Из: Poland
Campanula
сообщение 6.9.2008, 7:08
2008.9.6
288 Clock
Color_T v1.0
Profile (each line below)
XX XX XX bond portfolio launched
XX XX clock to coordinate the clock ordinate
XX XX XX peak hours of color
XX XX XX low hours of color
XX XX XX, isolation: the color
Campanula
сообщение 7.9.2008, 5:21
2008.9.7
288 Clock
Color_T v1.1
+ Can increase border
+ Optional two kinds of shadows
+ Optional font types (0 xD standby for large fonts, 0 x7 for the status bar fonts, font can also choose other)
0 1 2 3 4 ... F
0x00000000 XX XX XX bond portfolio launched
0x00000010 XX XX clock to coordinate the clock ordinate
0x00000020 XX XX XX peak hours of color
0x00000030 XX XX XX low hours of color
0x00000040 XX XX XX, isolation: the color
0x00000070 XX XX XX XX XX line for the first one byte font types, the first two bytes for the border or shadow (0 without any effect, a Canadian border, plus 2 after the shadow of the former shadow and 3)
Section 3-5 bytes for the effects of color
novis
сообщение 7.9.2008, 6:54
Из: г.Ижевск
Пользователь №: 76 691
Прошивка: 79r
в ельфе Color_T v1.1 при смене времени цифры накладываются друг на друга. у всех так или настраивать можно? когда экран обновится то все нормально стает.
Campanula
сообщение 7.9.2008, 7:09
QUOTE(novis @ 7.9.2008, 6:54) *
fix in the next Version
Campanula
сообщение 11.9.2008, 4:57
2008.9.11
Color Clock
Color_T v1.2
+ Solve the problem of overlapping time (should not occur in the legend of the 98 bar)
+ Join the digital custom spacing (0 pitch for the system default), this system is in default on the basis of distance with offset, mainly to solve the border and with the shadow effect, the number is relatively crowded.
Campanula
сообщение 19.9.2008, 1:15
2008.9.19
Color Clock
Color_T v1.3
0x00000070 XX XX XX XX XX XX XX the first line a bit for the types of fonts, 2 bytes for the border or shadow (0 without any results, plus a border, plus 2 after the shadow of the shadow of the former plus 3)
The first 3-5 bytes for the effect of color, 6 bytes for the digital space, the 7th to the effect Marquee (1 open, closed 0)
tadziu
сообщение 20.9.2008, 13:57
Из: Poland
how i can change position...?
Campanula
сообщение 21.9.2008, 4:42
QUOTE(tadziu @ 20.9.2008, 13:57) *
what mean?
WalkеR
сообщение 21.9.2008, 5:34
Пользователь №: 169 789
Прошивка: [R373_G_0E.30.79R]
Campanula,
It mean change position on display, left, right, up, down
Campanula
сообщение 21.9.2008, 5:54
Color Clock
Color_T v1.3
0 1 2 3 4 5 ... F
Сообщение отредактировал Campanula - 21.9.2008, 5:55
tadziu
сообщение 21.9.2008, 9:57
Из: Poland
i want like this
Campanula
сообщение 22.9.2008, 4:25
QUOTE(tadziu @ 21.9.2008, 9:57) *
i want like this
here you are !
For you
and look at the picture!
0 1 2 3 4 5 ... F
0x00000010 XX XX clock line coordinates of the clock ordinate (This!)
(22.9.2008, 6:59):
Tunes_Lrc_2.0
2008.9.22
Remove Read tags and Skins
make form tunes_2.95&PP_Lrc1.5.4
Patch Version For:E398_49R/L7_ACR/L7_09R
no Patch Version : GB2UC.MAP: file://b/ELF/gb2uc.map
LRC:file://b/mobile/audio/lrc/**.lrc
OK,Let's go!
Сообщение отредактировал Campanula - 22.9.2008, 7:02
rottenlife
сообщение 22.9.2008, 8:41
Пользователь №: 132 793
Модель телефона: E398/ROKR
Прошивка: R373_G_0E.30.49R
i've tried Tunes_lrc and it works well.
advantages:
- the lyrics shown more precise time than the pp_player
disadvantages:
- the light is not stay all the time like the pp_player, so we can't see the lyrics all the time (after some second, the light goes down)
- it can't be used with Tunes elf. altough i've succeded to edit the elf's to works from same location (b/Tunes) but the lang and the generated playlist is not the same since Tunes_lrc is based on Tunes 2.9 and i use Tunes 3.3
suggestions:
- maybe om2804 can develop his tunes to show the lyrics based on his new version of Tunes
- there's an option to make light stays or not (when we want to see the lyrics, the light stays on, if not then the light goes off)
Campanula
сообщение 22.9.2008, 9:23
well
AKAmasol
сообщение 22.9.2008, 15:52
Из: Казань
Пользователь №: 163 680
Прошивка: DaRII [test15] Mod
Что делает эльф Tunes_Lrc_2.0?
Alesha_Pl
сообщение 23.9.2008, 4:29
Из: Россия, г.Петрозаводск
Пользователь №: 42 716
Прошивка: 49R+EP1+EP2
AKAmasol, странный вопрос - наверно музыку играет и песни поет.
Elfs by motoedy[China], new:more elfs 05.09.2009 · Эльфы, их разработка и портирование · Forum
Текстовая версия Сейчас: 9.9.2025, 14:09
