8 страниц V < 1 2 3 4 > »
Elfs by motoedy[China], new:more elfs 05.09.2009
Campanula
сообщение 15.8.2008, 1:58 Закрепленное сообщение!
Пользователь №: 176 749
Welcome to China motoedy smile.gif www.motoedy.cn
http://translation2.paralink.com + http://translate.google.com/translate_t
newHITMOUSE by hantao
1,2,3,4,5,6,7,8,9
Exit: Red
Author: om2804 tim apple Editorer: 四夕 & 林子 L7E/L9: lpktool
Thanks to om2804 tim apple
new LRCPlayer_DesktopshowLRC_1.3
Прикрепленный файл LRCPlayer_DesktopshowLRC_1.3.rar   ( 480.3 килобайт ) Кол-во скачиваний: 881
[Updated 09-08-01]
Lin LRCPlayer_ modified version V1.3
[+] Add lyrics contour, in BG_LRC.CFG color profile settings in the settings to add "show the outline of the lyrics" set;
[+] When did the lyrics, the screen does not display lyrics and other non-related tips;
[+] To remove the panel in the A site or C site settings, the program will automatically determine which disk;
[+] LRCPlayer.lng documents are updated, LRCPlayer.cfg document changes to the original part used to re-configure the settings (such as the use of IT to start, etc.);
[Updated 09-07-30]
Lin LRCPlayer_ modified version V1.2
[+] Amendment can not be deployed for panel icon panel issues;
[+] When a song did not amend the LRC, the desktop display lyrics on a problem;
[+] Icon shows a high degree determines the number of rows and a high of 20 for his party, would like to show you a few lines of lyrics
[+] Can call with the panel and different icons and configuration, will be on the panel BG_LRC.CFG and BG_LRC.GIF document under the folder DeskTopFile; not call the default program directory;
[+] In setting a "desktop display the lyrics" and "show-screen lyrics when Changliang" choice;
~ 12.06.2009 ~
[LRCPlayer 1.3]
Hard-won source ah
* Based on modifications made to Tunes3.9
* Play button changes the interface is as follows:
123, respectively, for the side and so on, flash, screen
5 for the current playlist
8 on
7 players on the grounds to the lyrics of the skin interface interface
9 on the grounds the lyrics to the player skin interface interface
* Reduce the volume
# Increase the volume
0 to mute
Other operations with Tunes3.9
still lrc.cfg address for GBK encoding, LRCPlayer.cfg the last 2 bytes in order to initiate a 16-band event code
new Memorandum_Simplify the locking version
Прикрепленный файл Memorandum_Simplify_the_locking_version.zip   ( 9.92 килобайт ) Кол-во скачиваний: 556
new HDautoplay1.5
Прикрепленный файл HDautoplay1.5.zip   ( 2.48 килобайт ) Кол-во скачиваний: 513
Its working principle: plug in your headphones to monitor the incident code, and monitor the core event code (0404, that is, start-up events LRCPLayer.elf/Tunes.elf, when you start the event of LRCPlayer/Tunes.elf code changes, so please direct HEX to 0404 start for your event LRCPlayer/Tunes.elf code), auto-play button to use the simulation
To work only on the desktop
Lock Application--->Headset
Locked--->autoplay
Unlocked---> unautoplay
maybe only for 79R
RamEdit :
Redmenu_mod (ELF&SRC)
gif:L"*.gif"
CODE
Ring Styles=0936
ZtxtEdit=file://a/MotoCmd/Ztxtedit.elf
CODE
For 79R:
Power off=17
Silent power off=0000
Reset=0001
Switch in BOOT=0003
Unload Java=1806
MachoSettings=0973
Tunes=1889
MotoCMD1.8=0985
OPcode=2011
Personalise=0942
Initial Setup=0943
Message=1025
Video Camera=1021
Camera=1019
Bluetooch=1789
USB Settings=1022
Alarm Clock=1001
Datebook=8378
Skins=3237
Shortcuts=0929
Ring Styles=0936
pp_lrc_1.7.1
Прикрепленный файл ppplayerv1.7.zip   ( 135.61 килобайт ) Кол-во скачиваний: 816
* Revision of the map in support of GBK, shows in simplified and traditional Chinese \ Sun Wen \ text of the stick ..
* Cancel version of the patch did not play ... GBK's patch map, garbled show ..
* Some small bug amendment ..
* Only version of the patch
This version of the six, to see the name of the folder you know the type:
If, desktop_walkman, on behalf of the desktop that shows the time, the interface for the walkman
The rest and so on (Note: iris for the past Xiaoyu's colorful interface)
Another: a patch version of the map for migration 0x10c3e800 (increase has been offset start-CG1), non-offset this, please make its own decisions
Revised: 16 hexeditor (such as UltraEdit32, etc.) to open elf, search 0x10c3e800, replace your address migration
PP_reader_1.1
Прикрепленный файл ppreader_no_patch.zip   ( 26.93 килобайт ) Кол-во скачиваний: 526
Прикрепленный файл pp_reader_v1.1.zip   ( 98.57 килобайт ) Кол-во скачиваний: 622
Increase:
1, to support the GBK code, that can display traditional.
2, in the setting / folder under map.set document offset patch, the hex address of the patch + CG1 address, I provided a patch for the use of 398. 398 can not use the default for 0x10C3E800.
3, at the right point in time to read software code to open the menu option to resolve the utf_8 file to open in the first few garbled.
1, the English word would be forcibly cut off, did not get
2, does not support L7E ...
3, to replace paper map, the size of 47k.
Patch file also changed, and 398 in place are adequate.
Other models to find your own! ! !
After the test, did not play in the system memory of the 398 patch can not run on non-patch version! ! !
Color Clock
1.6
Прикрепленный файл Color_T_v1.6.zip   ( 9.53 килобайт ) Кол-во скачиваний: 601
Color_T v1.3
Прикрепленный файл Color_T_v1.3.zip   ( 69.38 килобайт ) Кол-во скачиваний: 701
Author: Kalvinxp (bimonthly)
Source: EDY Прикрепленное изображениеПрикрепленное изображениеПрикрепленное изображение
0 1 2 3 4 5 ... F
0x00000000 XX XX XX bond packages
0x00000010 XX XX clock line coordinates of the clock ordinate
0x00000020 XX XX XX hours of high color
0x00000030 XX XX XX hours of low color
0x00000040 XX XX XX isolation: the color
0x00000050 XX XX XX high-minute color
0x00000060 XX XX XX low-minute color
0x00000070 XX XX XX XX XX XX this line of the first byte as a font type, 2 bytes for the border or shadow (0 without any results,Plus 1 frame, plus 2 after the shadow of the shadow of the former plus 3); the first 3-5 bytes for the effect of color ,No. 6 bytes for the digital space
PS: XX on behalf of a byte
ElfOpen2.4.1
Прикрепленный файл ElfOpen_2.4.1.zip   ( 27.14 килобайт ) Кол-во скачиваний: 673
thanks for om2804!
mma_ucp:
Phone book
Dialling services ---- Quick dial, voice dial, and attribution for (Fixed dial), Incall setup, RecentCall, Call Forward
Message
Security
ELF & JAVA procedures ---- JAVA procedures, MOTO Manager (AIM), ELF (mixing machine), FELX procedures (WEB shortcut), SEEM editor (Mobile QQ), HEX editor (themes)
Access to the network ---- browser, StoredPages,WebHistory,GotoURL,BRWSetup,WebSessions
Multimedia---- Sounds,Pictures,Video,ITUNES,Camera,VideoCamera
Tools ---- alarm clock, DateBook, calculator, voice record, data backup tools (IM), SIM APP
settings----Personalize,IntlSetup,JAVAtools,CarSetting,PhoneStatus,FEM
MMRingStyle
Shortcuts
Connection ---- Bluetooth, USBSetting, sync, network, airpin mode, headset
03FC instant messaging (IM)
03D1 (chat room)
03DF (AIM)
03ED (WEB shortcut)
03DE (themes)
03D9 (Mobile QQ)
039A (fixed dial-up)
Please use P2KTOOL hidden settings
The more open, and then put mma_ucp
The MMA for the E398. Other models, a separate production ~
new
Backupsms
Прикрепленный файл backupsms__09_08_31.zip   ( 14.28 килобайт ) Кол-во скачиваний: 495
CODE
IN1=0x04E6
IN2=0x04E7
OUT1=0x07CD
OUT2=
PATH=file://b/backups/
CODE
[SMST]
app=/b/Elf/MotoCmd/smsv.elf
type=id
09-08-31
Amendments to the multi-page copies of reading support. (Known Bug: Unable to get part of the recipient)
Skin.elf
CODE
[SKI]
app=/b/Elf/MotoCmd/Skin.elf
type=id
new
Auto change skin when you startup your phone
Skins in dick a
Skins in dick c
Please add to AutoRun
PP_DnpEditor:
Прикрепленный файл PP_DnpEditor.elf   ( 19.44 килобайт ) Кол-во скачиваний: 784
UnRAR/Un7z:
CODE
[RAR]
app=/b/Elf/MotoCmd/unrar.elf
CODE
[7z]
app=/b/Elf/MotoCmd/un7z.elf
6Elfs only for 79R
Gomeno(Lock Application --> JAVA APPS)
flashlight on VOICE + VOICE :
Lockvideo(Lock Application --> Headset)
Screener picture:
newPlug-in for MotoCMD: ConfigEditor oт 林子 English Verson by Last1left
Прикрепленный файл ConfigEditor_eng.zip   ( 8.35 килобайт ) Кол-во скачиваний: 521
для редактирования файлов: .res .ini .menu .lng.run
CODE
[INI]
app=/a/Elf/MotoCmd/ConfigEditor.elf
[MENU]
[RES]
[LNG]
[RUN]
new DEC HEX BIN Converter oт 林子 English Verson by Last1left
Прикрепленный файл NumBasis_eng.zip   ( 6.38 килобайт ) Кол-во скачиваний: 438
new Motocmd2.0
QUOTE(Fenja @ 1.9.2009, 17:43) *
Campanula, in what of difference between MotoCmd.elf, MotoCmd-DDRM.elf, MotoCmd-DXDRM.elf?
CODE
MotoCmd.elf don't need Icons
MotoCmd-DDRM.elf is old Verson
Please use MotoCmd-DXDRM.elf
Icons for MotoCmd
Please add in your DRM!(CG15)
695                 mp3.amr .m4a .mid
696                 device
697                 dir
698                 txt .umd .doc .lng .lrc .smst
699                 elf
700                 exe
701                 html
703                 jad
704                 jar
705                 main
706                 null
707                 rar
708                 sys
709                 video.3gp .mp4
710                 zip
711                 ini .cfg .set .run .lib .rlt .rm .pat
712                 mei .jc
713                  Waiting..
CODE
Register=0x03DC
Map=110F0824
Sytem=0;Hidden system files: 0/no 1/yes
ReadLast=1;Read last open Folder: 0/no 1/yes
ChangeType=1;Scroll Display file names : 0/no 1/yes
UseZipBrowser=1;ZIP Browser Switch:1 use MotoCmdZIP, 0 use MotoCmd Plug-in(UnZip.elf)
BookDir=/a/Elf/MotoCmd/bmk/Ebook.txt;file of BookDir
AutoDir=/a/Elf/MotoCmd/AutoRun.elf;file of AutoRUN
DrmDir=/a/Elf/MotoCmd/Adddrm.elf;file of Adddrm
HexDir=/a/Elf/MotoCmd/HexEditor.elf;file of HexDir
TxtDir=/a/Elf/MotoCmd/Ztxtedit.elf;file of TXTEdit
[MEI]
app=/a/Elf/MotoCmd/ElfInstaller.elf
[JC]
app=/a/Elf/MotoCmd/Jc.elf
[GIF]
app=/a/Elf/MotoCmd/Iv.elf
AutoRun for MotoCmd2.0, No AutoRun
Adddrm for MotoCmd2.0,Plaese Add to AutoRun
Example:b/Moto/Drm/Green/329-336.gif
Open MotoCmd2.0,You can Long press 0,Then Press Menu,Update battery pack.
QUOTE
map is our Chinese Transcoding
For example:
Map=110F0824 ,This is a patch of gb2uc. It's used to gbk to uc
UnZip.elf PP_lrc.elf LRCPlayer.elf MotoCmd.elf ....must to use this patch (Map=10C3E800)
ZtxtEdit.elf use 3 maps
1:patch (Map=110F0824) :gbk to uc
2:gb2big5.map : gb to big5
3:uc2gbk.map : :uc to gbk ,This is used to edit txt.
Russian friends, British friends ,Do not need to use maps....
give you the src of ZtxtEdit , MotoCmd2.0.0.1 and LRCPlayer1.4
Прикрепленный файл motocmd2.0_scr.rar   ( 165.03 килобайт ) Кол-во скачиваний: 443
Спасибо всем разработчикам эльфпака и эльфов!
Сообщение отредактировал Campanula - 6.9.2009, 6:55
Прикрепленный файл ElfOpen_2.3.1.zip   ( 33.39 килобайт ) Кол-во скачиваний: 547
Прикрепленный файл ElfOpen_2.3.zip   ( 32.16 килобайт ) Кол-во скачиваний: 356
Прикрепленный файл LRCplayer_1.1.zip   ( 179.46 килобайт ) Кол-во скачиваний: 547
Прикрепленный файл Color_T_1.1.zip   ( 81.69 килобайт ) Кол-во скачиваний: 734
Прикрепленный файл Color_T_v1.2.zip   ( 68.73 килобайт ) Кол-во скачиваний: 509
Прикрепленный файл LRCplayer_1.2.1.zip   ( 363.82 килобайт ) Кол-во скачиваний: 858
Прикрепленный файл LRCplayer_1.2.zip   ( 189.02 килобайт ) Кол-во скачиваний: 978
Прикрепленный файл LRCPlayer_1.3.zip   ( 440.51 килобайт ) Кол-во скачиваний: 436
Прикрепленный файл backupsms__09_6_20.zip   ( 13.7 килобайт ) Кол-во скачиваний: 424
Прикрепленный файл Memorandum_V1.0.zip   ( 18.46 килобайт ) Кол-во скачиваний: 468
Прикрепленный файл backupsms__09_6_23.zip   ( 15.07 килобайт ) Кол-во скачиваний: 435
Прикрепленный файл Memorandum_V1.1.zip   ( 176 килобайт ) Кол-во скачиваний: 581
AKAmasol
сообщение 23.9.2008, 6:06
Из: Казань
Пользователь №: 163 680
Прошивка: DaRII [test15] Mod
Написано: "Remove Read tags and Skins". "Удалить Читать теги и Скины" - на плеер не очень пожоже... К тому же Campanula разрабатывает ещё один плеер-плагин PPPlayer, тогда зачем ему несколько?
Alesha_Pl
сообщение 23.9.2008, 6:14
Из: Россия, г.Петрозаводск
Пользователь №: 42 716
Прошивка: 49R+EP1+EP2
AKAmasol, да нет из плеера удалены чтение тэгов и поддержка скинов. И этот плеер работает как тюнс (можно на пункт меню вешать). А PPPlayer он для проигрывания музыки из мотосмд. И еще они оба поддерживают формат lrc.
AKAmasol
сообщение 23.9.2008, 7:42
Из: Казань
Тексты песен?
Alesha_Pl
сообщение 23.9.2008, 7:51
Ну уж не знаю что это и зачем
LRC:file://b/mobile/audio/lrc/**.lrc
Вот пример файла
Сообщение отредактировал Alesha_Pl - 23.9.2008, 7:55
Прикрепленный файл 3_Doors_Down___Here_Without_You.rar   ( 818 байт ) Кол-во скачиваний: 110
om2804
сообщение 23.9.2008, 16:24
МотоКодер
Из: Архангельск
Пользователь №: 95 055
Прошивка: DaR
AKAmasol
сообщение 23.9.2008, 17:01
Из: Казань
Это точно тексты песен. Открывается блокнотом. Только нужно время текста редактировать под каждую песню shout.gif
Campanula
сообщение 24.9.2008, 4:25
QUOTE(om2804 @ 23.9.2008, 16:24) *
I will ask to Kalvinxp
and will give the SRC for you!
I am pleased to motofan and friends playing phone!
tadziu
сообщение 24.9.2008, 6:12
Из: Poland
Пользователь №: 170 677
Tunes_LRC played olny .lrc file...?
Campanula
сообщение 24.9.2008, 7:03
QUOTE(tadziu @ 24.9.2008, 6:12) *
Only **. lrc lyrics
But support for the songs and playing as tunes
Сообщение отредактировал Campanula - 24.9.2008, 7:04
Campanula
сообщение 4.10.2008, 5:18
Elfopen2.0
2008.10.04
+ Repair Association HexEditor1.3 appeared to open the B disc read only file BUG
+ Repair Association HexEditor1.3 not save BUG
Campanula
сообщение 13.10.2008, 2:03
ElfOpen2.2
2008.10.13
+ Rewrite the code to optimize
+ Significantly reduce the use of memory. Only 7kb
tadziu
сообщение 13.10.2008, 18:25
Из: Poland
(13.10.2008, 18:39):
elfloader 4.2
AKAmasol
сообщение 15.10.2008, 14:06
Из: Казань
"gsm_flash_dev.elf Map IDC" what is it?
simba4
сообщение 15.10.2008, 14:07
Пользователь №: 122 706
Модель телефона: v3i
this is a map for ida pro dissasembelr
Campanula
сообщение 18.10.2008, 7:30
LRCPlayer_1.1
2008.10.18
SRC:
[LRCPlayer 1.1]
With the basic Tunes v3.4 use the same, in addition to the Tunes of the original has been replaced by 2 and 5 and 7 to 9 (Zhelia a key ms flash led the E398 is not it?)
Now playing in the interface, by 5 to enter lrc interface, and the interface lrc, 2 by the return of player interface
In addition to the Zhelia a key, key in the rest of the lrc interface with the player features the same interface
lrc.cfg patch is the address or map the path of the file
That is, LRCPlayer not distinguish between the versions, according to lrc.cfg only to determine whether the version of the patch and the patch addresses ...
make form tunes_3.4&PP_Lrc1.6.3
like this:Прикрепленное изображениеПрикрепленное изображение
Patch Version For:E398_49R/L7_ACR/L7_09R/V360
no Patch Version : GB2UC.MAP: file://b/ELF/gb2uc.map
OK,Let's go!
Сообщение отредактировал Campanula - 18.10.2008, 7:30
newbieholic
сообщение 18.10.2008, 16:03
Пользователь №: 180 492
Модель телефона: Motorola
LRCPlayer very cool!
Btw, I don't undestand about lrc.cfg.
What should I do with lrc.cfg?
Coz my phone reboot when switching to lrc interface if the music file didn't have lyric file.
How to solve this?
Thanks for the reply
<49R patch version>
newbieholic
How to solve this?
<49R patch version>
croccio
сообщение 18.10.2008, 21:56
Пользователь №: 161 521
Модель телефона: L7 Slvr, c350
my phnìone reboot when i open LRCPlayer_1.1
Campanula
сообщение 19.10.2008, 0:11
QUOTE(newbieholic @ 18.10.2008, 16:03) *
How to solve this?
<49R patch version>
Look at the picture!
For example
My phone is E398_49R
If your phone is E398_49R,and you hope to use Patch Version ,So you must to:
TO put a patch on CG1:LRCplayer_1.1\gb2uc\Patch Version\gb2uc_E398_49R.fpa
LRCplayer_1.1\cfg\lrc cfg\E398\lrc.cfg
If your phone is E398_49R,and you hope to use No Patch Version ,So you must to:
TO put GB2UC.MAP on :/b/GB2UC.MAP(LRCplayer_1.1\gb2uc\no Patch Version\GB2UC.MAP)
LRCplayer_1.1\cfg\lrc cfg\normal\lrc.cfg
(19.10.2008, 0:21):
QUOTE(croccio @ 18.10.2008, 21:56) *
my phnмone reboot when i open LRCPlayer_1.1
You phone is E398 /L7 or V360
this elfloader for E398
If your phone is L7 or V360 ,SO you must to put a patch on CG1(Srs_sys_heap_by_Macho)Патчи для L7/V360 or Патчи для L7/V360
If your phone is E398 ,So you have to put a patch on CG1(Corelet 880 JAVA 1496 )
Сообщение отредактировал Campanula - 19.10.2008, 5:19
newbieholic
сообщение 19.10.2008, 6:50
Yes, I have sure about the file.
I run LRCPlayer from a/elf
So, where should I put lrc.cfg?
In a/elf or any other folder?
Skilos
сообщение 19.10.2008, 6:56
Пользователь №: 149 958
Модель телефона: Motorola E1 original
Прошивка: Mpx De Luxe 49r
Wow! Campanula, big thanks, that really works!!!
But there are some minor bugs (or it is a feature? biggrin.gif )
1) When there are no lyrics the phone reboots
2) Someteimes strings come over each other
Another bad thing is that thу name of the .mp3 file should be exactly the same as the name of the .lrc file
So? if there are any differencies (number of the song, for example), the lyrics is not shown.
Is it possible to search for lyrics by pattern?
Campanula
сообщение 19.10.2008, 8:13
~ 19.10.2008 ~
[LRCPlayer 1.2]
+ Repair without the resumption of the lyrics
+ Overlapping restoration fonts
+ Memory issue restoration release
+ Increase in the English lyrics wrap show
Сообщение отредактировал Campanula - 19.10.2008, 8:16
newbieholic
сообщение 20.10.2008, 0:16
I have try version 1.2 but still reboot only when switch to lyric interface on song that doesn't have lyrics file.<br />How to make it no reboot?<br />Thanks.
Campanula
сообщение 6.11.2008, 2:58
~ 06.11.2008 ~
[LRCPlayer 1.2.1]
new gb2uc map and new gb2uc map Patch
Excerpts Tunes v3.5 modeled to modify ~ ~
* The lyrics interface fast forward / rewind time when it will follow the changes
* The lyrics may be revised interface fast-forward / rewind, will not release key players to start the bug .. at least I tried many times will the ...
* Amendments to the skin color and background color of the lyrics of the conflict. . . ~
* Revision of the map files for decoding GBK, in simplified and traditional Chinese support \ Sun Wen \ text of the stick (as long as you have the support of the cg4 ..)
* To amend the issue back into analog button to make it .. Always (0xFF .. ms simulation of the key does not exist Kazakhstan ~ ~)
* Amendments to the lyrics will be long dead card bug (at least for now I have no problem testing ~)
pp_lrc_1.7.1
PP_reader_1.1
Increase:
ElfOpen2.3.1
+ ElfOpen shielding monitor the functions of the incident code, that is to say, to return, the system did not feature the original!
If you want to retain the original features, please use the 2.2
Сообщение отредактировал Campanula - 6.11.2008, 6:08
newbieholic
сообщение 6.11.2008, 11:10
I'm very interesting with LRC Player.
I have used version 1.2.1
Use new gb2uc map patch.
And update libgen by macho 4.5.
But why still reboot when switch to lyric interface if no lyric file? sad.gif
Please tell me how to fix this...
Thanks.
<E1_49R>
Campanula
сообщение 7.11.2008, 2:12
QUOTE(newbieholic @ 6.11.2008, 11:10) *
Thanks.
<E1_49R>
look this:https://forum.motofan.ru/index.php?act=Post&CODE=02&f=142&t=121909&qpid=1207968
tadziu
сообщение 7.11.2008, 17:43
Из: Poland
ppreader only chinise version...?
sk8erboy
сообщение 8.11.2008, 9:40
Пользователь №: 185 607
Campanula support ~ ~
I am proud of you ~ ~
newbieholic
сообщение 10.11.2008, 5:52
@campanula I have try patch 1500K
Can you post your LRCPlayer screenshot
when switching to lyrics interface that lyrics file doesn't exist
rottenlife
сообщение 11.11.2008, 15:10
Пользователь №: 132 793
Модель телефона: E398/ROKR
Прошивка: R373_G_0E.30.49R
yes, LRC 1.2.1 is still reboot when press 5 on playing mp3 with no lyrics.
i've also use patch new heap java edited by macho.
Nixxell
сообщение 14.11.2008, 7:53
Пользователь №: 164 062
Прошивка: ACR_RB
У кого нибудь работает ElfOpen? если работает опишите по русски подробнее как у вас это получилось?
tadziu
сообщение 18.11.2008, 18:08
Из: Poland
@Campanula can you insert here elfloader.lib and lib.o for ElfOpen2.3.1...?
Сообщение отредактировал tadziu - 18.11.2008, 18:09
Campanula
сообщение 20.11.2008, 5:49
QUOTE(tadziu @ 18.11.2008, 18:08) *
4.8+
Rysso_TyPucTo
сообщение 6.2.2009, 13:14
Из: Донецк
Пользователь №: 170 012
Прошивка: Dream a Reality 44R
P.S. C отечественными либами работать отказывается(вечный ребут )
Сообщение отредактировал Rysso_TyPucTo - 6.2.2009, 14:20
Z.d.u.n.e.X
сообщение 20.2.2009, 22:14
Из: Poland
Пользователь №: 186 451
Модель телефона: LG GT540
Прошивка: Android
ColorT 1.5.1
Прикрепленный файл Color_T_v1.5.1.zip   ( 9.32 килобайт ) Кол-во скачиваний: 94
MaratMD
сообщение 20.2.2009, 23:59
Пользователь №: 180 950
Z.d.u.n.eX,respect and thanks you!
Zabiyaka72
сообщение 21.2.2009, 13:49
Из: Украина Запорожье Бабурка
Пользователь №: 99 926
Модель телефона: v 360
Прошивка: R4513_G_08.B7.ACR
Сообщение отредактировал Zabiyaka72 - 21.2.2009, 13:50
Zhook
сообщение 24.2.2009, 10:36
Пользователь №: 112 507
Прошивка: 49R em 0.3
Цитата(Zabiyaka72 @ 21.2.2009, 16:49) *
В закрепленном сообщении под скринами...
0 1 2 3 4 5 ... F
Сообщение отредактировал Zhook - 24.2.2009, 10:37
VEX
сообщение 24.2.2009, 10:46
Из: Нижний Новгород
Пользователь №: 156 303
Модель телефона: e398,V3,T190,L7
Прошивка: R373_44R_v2.8
Вот первёл на русский smile.gif ,довольно интересные часы wink.gif .
Color_T v1.5.1
Автор: Kalvinxp
Мод: JustinLee
Сайт: www.motoedy.cn
Конфигурация и описание файла (в каждой строке, ниже)
0 1 2 3 4 5 6... F
0x00000000 XX XX XX Кнопки выхода (по умолчанию * + # + красная кнопка)
0x00000010 XX XX Позиция часов, координаты X и Y
0x00000020 XX XX XX Цвет часа (1 часть)
0x00000030 XX XX XX Цвет часа (2 часть)
0x00000040 XX XX XX Цвет : (1 часть)
0x00000050 XX XX XX Цвет минут (1 часть)
0x00000060 XX XX XX Цвет минут (2 часть)
0x00000070 XX XX XX Цвет : (2 часть)
0x00000080 XX XX XX Цвет секунд (1 часть)
0x00000090 XX XX XX Цвет секунд (2 часть)
0x000000A0 XX XX XX XX XX XX XX XX XX XX XX XX
В последней строке первым байтом задаётся (ID) шрифта,в пределах 01 ~ 08 и 0C ~ 0E;
2-Цветовые эффекты(0 без эффекта,1 просто обводка,2 тень справа,3 тень с лева);
3-5 Байты цветовые эффекты;
6- Заливка часов(0 без заливки (лучше не ставить, будет смазывание секунд),1 все цифры, а также секунды с заливкой,2 цвет заливки, только для секунд);
7-9 цвет границы;
10-Граница часов(0 без границы ,1 с границей,2 с границей, только секунды) ;
11-Расстояние между цифрами;
12-Эффект беготни часов (1 вкл, 2 выкл)
Прикрепленный файл Color_T_v1.5.1.zip   ( 9.25 килобайт ) Кол-во скачиваний: 147
P.S Эх опоздал я,на 10 минут,с переводом...
Сообщение отредактировал VEX - 24.2.2009, 10:50
Zabiyaka72
сообщение 24.2.2009, 10:54
Сообщение отредактировал Zabiyaka72 - 24.2.2009, 10:55
Elfs by motoedy[China], new:more elfs 05.09.2009 · Эльфы, их разработка и портирование · Forum
Текстовая версия Сейчас: 26.7.2025, 17:21
