8 страниц V < 1 2 3 4 5 > »
Elfs by motoedy[China], new:more elfs 05.09.2009
Campanula
сообщение 15.8.2008, 1:58 Закрепленное сообщение!
Пользователь №: 176 749
Welcome to China motoedy smile.gif www.motoedy.cn
http://translation2.paralink.com + http://translate.google.com/translate_t
newHITMOUSE by hantao
1,2,3,4,5,6,7,8,9
Exit: Red
Author: om2804 tim apple Editorer: 四夕 & 林子 L7E/L9: lpktool
Thanks to om2804 tim apple
new LRCPlayer_DesktopshowLRC_1.3
Прикрепленный файл LRCPlayer_DesktopshowLRC_1.3.rar   ( 480.3 килобайт ) Кол-во скачиваний: 881
[Updated 09-08-01]
Lin LRCPlayer_ modified version V1.3
[+] Add lyrics contour, in BG_LRC.CFG color profile settings in the settings to add "show the outline of the lyrics" set;
[+] When did the lyrics, the screen does not display lyrics and other non-related tips;
[+] To remove the panel in the A site or C site settings, the program will automatically determine which disk;
[+] LRCPlayer.lng documents are updated, LRCPlayer.cfg document changes to the original part used to re-configure the settings (such as the use of IT to start, etc.);
[Updated 09-07-30]
Lin LRCPlayer_ modified version V1.2
[+] Amendment can not be deployed for panel icon panel issues;
[+] When a song did not amend the LRC, the desktop display lyrics on a problem;
[+] Icon shows a high degree determines the number of rows and a high of 20 for his party, would like to show you a few lines of lyrics
[+] Can call with the panel and different icons and configuration, will be on the panel BG_LRC.CFG and BG_LRC.GIF document under the folder DeskTopFile; not call the default program directory;
[+] In setting a "desktop display the lyrics" and "show-screen lyrics when Changliang" choice;
~ 12.06.2009 ~
[LRCPlayer 1.3]
Hard-won source ah
* Based on modifications made to Tunes3.9
* Play button changes the interface is as follows:
123, respectively, for the side and so on, flash, screen
5 for the current playlist
8 on
7 players on the grounds to the lyrics of the skin interface interface
9 on the grounds the lyrics to the player skin interface interface
* Reduce the volume
# Increase the volume
0 to mute
Other operations with Tunes3.9
still lrc.cfg address for GBK encoding, LRCPlayer.cfg the last 2 bytes in order to initiate a 16-band event code
new Memorandum_Simplify the locking version
Прикрепленный файл Memorandum_Simplify_the_locking_version.zip   ( 9.92 килобайт ) Кол-во скачиваний: 556
new HDautoplay1.5
Прикрепленный файл HDautoplay1.5.zip   ( 2.48 килобайт ) Кол-во скачиваний: 513
Its working principle: plug in your headphones to monitor the incident code, and monitor the core event code (0404, that is, start-up events LRCPLayer.elf/Tunes.elf, when you start the event of LRCPlayer/Tunes.elf code changes, so please direct HEX to 0404 start for your event LRCPlayer/Tunes.elf code), auto-play button to use the simulation
To work only on the desktop
Lock Application--->Headset
Locked--->autoplay
Unlocked---> unautoplay
maybe only for 79R
RamEdit :
Redmenu_mod (ELF&SRC)
gif:L"*.gif"
CODE
Ring Styles=0936
ZtxtEdit=file://a/MotoCmd/Ztxtedit.elf
CODE
For 79R:
Power off=17
Silent power off=0000
Reset=0001
Switch in BOOT=0003
Unload Java=1806
MachoSettings=0973
Tunes=1889
MotoCMD1.8=0985
OPcode=2011
Personalise=0942
Initial Setup=0943
Message=1025
Video Camera=1021
Camera=1019
Bluetooch=1789
USB Settings=1022
Alarm Clock=1001
Datebook=8378
Skins=3237
Shortcuts=0929
Ring Styles=0936
pp_lrc_1.7.1
Прикрепленный файл ppplayerv1.7.zip   ( 135.61 килобайт ) Кол-во скачиваний: 816
* Revision of the map in support of GBK, shows in simplified and traditional Chinese \ Sun Wen \ text of the stick ..
* Cancel version of the patch did not play ... GBK's patch map, garbled show ..
* Some small bug amendment ..
* Only version of the patch
This version of the six, to see the name of the folder you know the type:
If, desktop_walkman, on behalf of the desktop that shows the time, the interface for the walkman
The rest and so on (Note: iris for the past Xiaoyu's colorful interface)
Another: a patch version of the map for migration 0x10c3e800 (increase has been offset start-CG1), non-offset this, please make its own decisions
Revised: 16 hexeditor (such as UltraEdit32, etc.) to open elf, search 0x10c3e800, replace your address migration
PP_reader_1.1
Прикрепленный файл ppreader_no_patch.zip   ( 26.93 килобайт ) Кол-во скачиваний: 526
Прикрепленный файл pp_reader_v1.1.zip   ( 98.57 килобайт ) Кол-во скачиваний: 622
Increase:
1, to support the GBK code, that can display traditional.
2, in the setting / folder under map.set document offset patch, the hex address of the patch + CG1 address, I provided a patch for the use of 398. 398 can not use the default for 0x10C3E800.
3, at the right point in time to read software code to open the menu option to resolve the utf_8 file to open in the first few garbled.
1, the English word would be forcibly cut off, did not get
2, does not support L7E ...
3, to replace paper map, the size of 47k.
Patch file also changed, and 398 in place are adequate.
Other models to find your own! ! !
After the test, did not play in the system memory of the 398 patch can not run on non-patch version! ! !
Color Clock
1.6
Прикрепленный файл Color_T_v1.6.zip   ( 9.53 килобайт ) Кол-во скачиваний: 601
Color_T v1.3
Прикрепленный файл Color_T_v1.3.zip   ( 69.38 килобайт ) Кол-во скачиваний: 701
Author: Kalvinxp (bimonthly)
Source: EDY Прикрепленное изображениеПрикрепленное изображениеПрикрепленное изображение
0 1 2 3 4 5 ... F
0x00000000 XX XX XX bond packages
0x00000010 XX XX clock line coordinates of the clock ordinate
0x00000020 XX XX XX hours of high color
0x00000030 XX XX XX hours of low color
0x00000040 XX XX XX isolation: the color
0x00000050 XX XX XX high-minute color
0x00000060 XX XX XX low-minute color
0x00000070 XX XX XX XX XX XX this line of the first byte as a font type, 2 bytes for the border or shadow (0 without any results,Plus 1 frame, plus 2 after the shadow of the shadow of the former plus 3); the first 3-5 bytes for the effect of color ,No. 6 bytes for the digital space
PS: XX on behalf of a byte
ElfOpen2.4.1
Прикрепленный файл ElfOpen_2.4.1.zip   ( 27.14 килобайт ) Кол-во скачиваний: 673
thanks for om2804!
mma_ucp:
Phone book
Dialling services ---- Quick dial, voice dial, and attribution for (Fixed dial), Incall setup, RecentCall, Call Forward
Message
Security
ELF & JAVA procedures ---- JAVA procedures, MOTO Manager (AIM), ELF (mixing machine), FELX procedures (WEB shortcut), SEEM editor (Mobile QQ), HEX editor (themes)
Access to the network ---- browser, StoredPages,WebHistory,GotoURL,BRWSetup,WebSessions
Multimedia---- Sounds,Pictures,Video,ITUNES,Camera,VideoCamera
Tools ---- alarm clock, DateBook, calculator, voice record, data backup tools (IM), SIM APP
settings----Personalize,IntlSetup,JAVAtools,CarSetting,PhoneStatus,FEM
MMRingStyle
Shortcuts
Connection ---- Bluetooth, USBSetting, sync, network, airpin mode, headset
03FC instant messaging (IM)
03D1 (chat room)
03DF (AIM)
03ED (WEB shortcut)
03DE (themes)
03D9 (Mobile QQ)
039A (fixed dial-up)
Please use P2KTOOL hidden settings
The more open, and then put mma_ucp
The MMA for the E398. Other models, a separate production ~
new
Backupsms
Прикрепленный файл backupsms__09_08_31.zip   ( 14.28 килобайт ) Кол-во скачиваний: 495
CODE
IN1=0x04E6
IN2=0x04E7
OUT1=0x07CD
OUT2=
PATH=file://b/backups/
CODE
[SMST]
app=/b/Elf/MotoCmd/smsv.elf
type=id
09-08-31
Amendments to the multi-page copies of reading support. (Known Bug: Unable to get part of the recipient)
Skin.elf
CODE
[SKI]
app=/b/Elf/MotoCmd/Skin.elf
type=id
new
Auto change skin when you startup your phone
Skins in dick a
Skins in dick c
Please add to AutoRun
PP_DnpEditor:
Прикрепленный файл PP_DnpEditor.elf   ( 19.44 килобайт ) Кол-во скачиваний: 784
UnRAR/Un7z:
CODE
[RAR]
app=/b/Elf/MotoCmd/unrar.elf
CODE
[7z]
app=/b/Elf/MotoCmd/un7z.elf
6Elfs only for 79R
Gomeno(Lock Application --> JAVA APPS)
flashlight on VOICE + VOICE :
Lockvideo(Lock Application --> Headset)
Screener picture:
newPlug-in for MotoCMD: ConfigEditor oт 林子 English Verson by Last1left
Прикрепленный файл ConfigEditor_eng.zip   ( 8.35 килобайт ) Кол-во скачиваний: 521
для редактирования файлов: .res .ini .menu .lng.run
CODE
[INI]
app=/a/Elf/MotoCmd/ConfigEditor.elf
[MENU]
[RES]
[LNG]
[RUN]
new DEC HEX BIN Converter oт 林子 English Verson by Last1left
Прикрепленный файл NumBasis_eng.zip   ( 6.38 килобайт ) Кол-во скачиваний: 438
new Motocmd2.0
QUOTE(Fenja @ 1.9.2009, 17:43) *
Campanula, in what of difference between MotoCmd.elf, MotoCmd-DDRM.elf, MotoCmd-DXDRM.elf?
CODE
MotoCmd.elf don't need Icons
MotoCmd-DDRM.elf is old Verson
Please use MotoCmd-DXDRM.elf
Icons for MotoCmd
Please add in your DRM!(CG15)
695                 mp3.amr .m4a .mid
696                 device
697                 dir
698                 txt .umd .doc .lng .lrc .smst
699                 elf
700                 exe
701                 html
703                 jad
704                 jar
705                 main
706                 null
707                 rar
708                 sys
709                 video.3gp .mp4
710                 zip
711                 ini .cfg .set .run .lib .rlt .rm .pat
712                 mei .jc
713                  Waiting..
CODE
Register=0x03DC
Map=110F0824
Sytem=0;Hidden system files: 0/no 1/yes
ReadLast=1;Read last open Folder: 0/no 1/yes
ChangeType=1;Scroll Display file names : 0/no 1/yes
UseZipBrowser=1;ZIP Browser Switch:1 use MotoCmdZIP, 0 use MotoCmd Plug-in(UnZip.elf)
BookDir=/a/Elf/MotoCmd/bmk/Ebook.txt;file of BookDir
AutoDir=/a/Elf/MotoCmd/AutoRun.elf;file of AutoRUN
DrmDir=/a/Elf/MotoCmd/Adddrm.elf;file of Adddrm
HexDir=/a/Elf/MotoCmd/HexEditor.elf;file of HexDir
TxtDir=/a/Elf/MotoCmd/Ztxtedit.elf;file of TXTEdit
[MEI]
app=/a/Elf/MotoCmd/ElfInstaller.elf
[JC]
app=/a/Elf/MotoCmd/Jc.elf
[GIF]
app=/a/Elf/MotoCmd/Iv.elf
AutoRun for MotoCmd2.0, No AutoRun
Adddrm for MotoCmd2.0,Plaese Add to AutoRun
Example:b/Moto/Drm/Green/329-336.gif
Open MotoCmd2.0,You can Long press 0,Then Press Menu,Update battery pack.
QUOTE
map is our Chinese Transcoding
For example:
Map=110F0824 ,This is a patch of gb2uc. It's used to gbk to uc
UnZip.elf PP_lrc.elf LRCPlayer.elf MotoCmd.elf ....must to use this patch (Map=10C3E800)
ZtxtEdit.elf use 3 maps
1:patch (Map=110F0824) :gbk to uc
2:gb2big5.map : gb to big5
3:uc2gbk.map : :uc to gbk ,This is used to edit txt.
Russian friends, British friends ,Do not need to use maps....
give you the src of ZtxtEdit , MotoCmd2.0.0.1 and LRCPlayer1.4
Прикрепленный файл motocmd2.0_scr.rar   ( 165.03 килобайт ) Кол-во скачиваний: 443
Спасибо всем разработчикам эльфпака и эльфов!
Сообщение отредактировал Campanula - 6.9.2009, 6:55
Прикрепленный файл ElfOpen_2.3.1.zip   ( 33.39 килобайт ) Кол-во скачиваний: 547
Прикрепленный файл ElfOpen_2.3.zip   ( 32.16 килобайт ) Кол-во скачиваний: 356
Прикрепленный файл LRCplayer_1.1.zip   ( 179.46 килобайт ) Кол-во скачиваний: 547
Прикрепленный файл Color_T_1.1.zip   ( 81.69 килобайт ) Кол-во скачиваний: 734
Прикрепленный файл Color_T_v1.2.zip   ( 68.73 килобайт ) Кол-во скачиваний: 509
Прикрепленный файл LRCplayer_1.2.1.zip   ( 363.82 килобайт ) Кол-во скачиваний: 858
Прикрепленный файл LRCplayer_1.2.zip   ( 189.02 килобайт ) Кол-во скачиваний: 978
Прикрепленный файл LRCPlayer_1.3.zip   ( 440.51 килобайт ) Кол-во скачиваний: 436
Прикрепленный файл backupsms__09_6_20.zip   ( 13.7 килобайт ) Кол-во скачиваний: 424
Прикрепленный файл Memorandum_V1.0.zip   ( 18.46 килобайт ) Кол-во скачиваний: 468
Прикрепленный файл backupsms__09_6_23.zip   ( 15.07 килобайт ) Кол-во скачиваний: 435
Прикрепленный файл Memorandum_V1.1.zip   ( 176 килобайт ) Кол-во скачиваний: 581
Z.d.u.n.e.X
сообщение 27.2.2009, 11:59
Из: Poland
Пользователь №: 186 451
Модель телефона: LG GT540
Прошивка: Android
Color_T 1.6
+bugfix (обновление)
ElfOpen 2.4
Сообщение отредактировал Z.d.u.n.e.X - 4.3.2009, 20:35
Прикрепленный файл Color_T_v1.6.zip   ( 9.53 килобайт ) Кол-во скачиваний: 92
Campanula
сообщение 9.4.2009, 7:34
UnRar.elf
This file by E314521(www.motoedy.cn)
The reasons for cell phone memory
Therefore, only the following file decompression 60K
TXT general can not extract the ELF test
Simply extract the RAR was very complicated so I do not know
Unable to extract a lot of paper
Now only the use of plug-CMD
No list of all open automatically extract into the current directory
CODE
[RAR]
Сообщение отредактировал Campanula - 9.4.2009, 7:53
jzy20
сообщение 9.4.2009, 7:41
Пользователь №: 177 583
Модель телефона: E770V
Прошивка: R25
看看你们在这里有一个互动的循环
我们就没人发展了
Campanula
сообщение 9.4.2009, 7:45
QUOTE(jzy20 @ 9.4.2009, 15:41) *
看看你们在这里有一个互动的循环
我们就没人发展了
fkcoder
сообщение 9.4.2009, 11:07
Eve
Из: Новокузнецк
Пользователь №: 68 287
russians don't understand china language. Write in English or Russian please
Добавлено позже (9.4.2009, 14:32):
Campanula, unrar have extract RAR with txt file.. but extract in current folder is badly. Say to E314521 please that he replace current extract to extarct to RAR-named folder. And elf not understand russian symbols in files...
Z.d.u.n.e.X
сообщение 9.4.2009, 13:29
Из: Poland
Прошивка: Android
QUOTE(lavmen @ 9.4.2009, 13:07) *
we don't understand, but Campanula come from EDY and he understand
Campanula
сообщение 9.4.2009, 13:59
lavmenOnly text. now…
Z.d.u.n.e.X
сообщение 10.4.2009, 10:36
Из: Poland
Прошивка: Android
[09-04-10] SignShow v1.0 by JustinLee
English description:
"SignShow v1.0" is a simple programe to show your signature on home screen.
You can import words in the file "SignShow.txt", then they will show on home screen. But now only one row could be showed, the language should be english or chinese, for the programe is not completed and the show is depended on dot-matrix font within english & chinese characters. Meanwhile, the dot-matrix font named "SignShow.font" supported is unique, others may be supported in future!
The Descriptionon of configuration "SignShow.cfg" is :
oxoo-the coordinates of x;
oxo1-the coordinates of y;
0x02~0x04-the color(RGB);
0x05~-x07-the eject button.
IPB Image
Besides once words is exchanged , there is no need to rerun the programe. Just press the red button, the screen will be refreshed!
Wish you enjoy it!
UnRar 10.04.2009
Сообщение отредактировал Z.d.u.n.e.X - 10.4.2009, 18:21
Прикрепленный файл SignShow_v1.0.zip   ( 113.36 килобайт ) Кол-во скачиваний: 139
ilnr
сообщение 10.4.2009, 21:15
Из: Kazan
Пользователь №: 182 692
Прошивка: R452J_ G _08.22.07R
Поставил Color_T_v1.3, но как мне его редактировать и чем, он очень мелкий у меня. (пожалуйста по подробней)
Z.d.u.n.e.X
сообщение 11.4.2009, 16:13
Из: Poland
Прошивка: Android
Un7z.elf
это пачка от E314521(www.motoedy.cn)
CODE
[7z]
Сообщение отредактировал Z.d.u.n.e.X - 11.4.2009, 16:14
Z.d.u.n.e.X
сообщение 13.4.2009, 10:04
Из: Poland
Прошивка: Android
QUOTE
03D1 (chat room)
03DF (AIM)
03ED (WEB shortcut)
03DE (themes)
03D9 (Mobile QQ)
A кто может сказать мне CommendID для Меню-Персонализация-Cкины?
http://cid-1f3becbc4444c6df.skydrive.live....o/commandid.PNG
@Campanula: Could you change language Flex.elf to Polish?
Flex number = Numer flex
Change model = Zmien model
Sent event = Wyslij zdarzenie
Security = Zabezpieczenia
Backup PDS = Backup PDS
ToneDb killer = ToneDb killer
Backup shourtcut = Backup skrotow
Сообщение отредактировал Z.d.u.n.e.X - 13.4.2009, 16:13
Campanula
сообщение 13.4.2009, 12:38
QUOTE(Z.d.u.n.e.X @ 13.4.2009, 18:04) *
Here you are :Flex
BackUps is here:/B/Elf/BackUps/
Сообщение отредактировал Campanula - 13.4.2009, 13:02
Z.d.u.n.e.X
сообщение 13.4.2009, 16:10
Из: Poland
Прошивка: Android
Fix Polish lang:
Flex number = Zmień flex
Change model = Zmień model
Sent event = Wyślij zdarzenie
-Security code = Kod zabezpieczający
-Unlock code = Kod odblokowujący
Backup PDS = Kopia PDS
ToneDb killer = ToneDB Killer
Backup shourtcut = Kopia skrotуw
-Backup shourtcut = Kopiuj skroty
-Restore shourtcut = Przywrуć skroty
Menu title:
www.motoedy.cn = Ustawiania Flexu
Security Unlock = Kody
ShourtCut = Skroty
Сообщение отредактировал Z.d.u.n.e.X - 14.4.2009, 8:03
MaratMD
сообщение 14.4.2009, 20:33
Пользователь №: 180 950
У кого нить ваще работает Unrar,Un7z.Всё куда надо прописал...
VEX
сообщение 14.4.2009, 21:19
Из: Нижний Новгород
Пользователь №: 156 303
Модель телефона: e398,V3,T190,L7
Прошивка: R373_44R_v2.8
MaratMD, у меня работает,но только Unrar,извлекает небольшие файлы по 50-80кб(если бльше то тел виснет и перезагружается),тестировал в основном на тексте(имя файла должно быть латинскими буквами),а Un7z почему-то не работает.
BiLaZ
сообщение 14.4.2009, 21:33
Из: Украина, Киев
Пользователь №: 145 012
Прошивка: R373_G_0E.30.49R
оперативки что-ли не хватает...
MaratMD
сообщение 15.4.2009, 12:48
Чё то странно...У мя даже Unrar не работает!Un7z тоже.Пробовал извлечь патч.Ноль реакций.
Сержант л7е
сообщение 16.4.2009, 17:38
Из: Н. Новгород
Пользователь №: 140 784
Модель телефона: samsung i900 witu
Прошивка: wm6.5
Телефон Л7е. Unrar - reboot, 7z - полёт нормальный!
Campanula
сообщение 20.4.2009, 6:18
PP_DnpEditor
auther:psjatqpgf(www.motoedy.cn)
Can someone tell me:Why i cann't edit this post Elf's by motoedy[China]
and cann't edit this : look at the picture
Сообщение отредактировал Campanula - 20.4.2009, 6:29
Прикрепленный файл PP_DnpEditor.elf   ( 19.2 килобайт ) Кол-во скачиваний: 305
Campanula
сообщение 21.4.2009, 7:25
PP_DnpEditor.elf
fix
Прикрепленный файл PP_DnpEditor.elf   ( 19.44 килобайт ) Кол-во скачиваний: 206
croccio
сообщение 21.4.2009, 10:41
Пользователь №: 161 521
Модель телефона: L7 Slvr, c350
where we can find the string id?
packpunk
сообщение 8.5.2009, 17:51
Из: Indonesia
Пользователь №: 196 643
Модель телефона: ROKR E8 | E1 | E398
Hi..
I'm using MotoCMD 2.0.1 with this following motocmd.ini:
SYTEM=0
Register=0x02dc
Map=10C3E800
I want to add on ElfOpen 2.4, of course on ElfOpen.txt I add:
CODE
02dc;file://b/Elf/System/MotoCMD/MotoCMD.elf!
So, with that even code, what should I add on the mma_ucp?
Thanks.
Сообщение отредактировал packpunk - 8.5.2009, 17:52
Самоха
сообщение 9.5.2009, 8:39
Пользователь №: 93 303
Модель телефона: E1
А по русски не судьба?
fkcoder
сообщение 9.5.2009, 9:42
Eve
Из: Новокузнецк
Самоха, не судьба. packpunk из Китая. В школе надо было английский учить
packpunk
сообщение 9.5.2009, 9:53
Из: Indonesia
I'm from Indonesia btw.
So, Anybody can help me about the MotoCMD and ElfOpen?
Campanula
сообщение 9.5.2009, 9:54
QUOTE(packpunk @ 9.5.2009, 1:51) *
Hi..
SYTEM=0
Register=0x02dc
Map=10C3E800
CODE
Thanks.
SYTEM=0
Register=0x0000
Map=10C3E800
packpunk
сообщение 9.5.2009, 10:12
Из: Indonesia
Campanula
сообщение 14.5.2009, 13:17
two elfs for 79R
Прикрепленный файл __65303___65305_Lvideo0.2.zip   ( 2.16 килобайт ) Кол-во скачиваний: 88
oniech
сообщение 14.5.2009, 14:30
Из: Indonesia
Пользователь №: 188 975
Модель телефона: Е398
Прошивка: E398@Rokr oprekerz
Thanx Campanula!why elfopen cant run on disk a/ or c/,can you make its work?then can you make elf or patch the cuckoo for 49r like on mp Dream a reality
Campanula
сообщение 16.5.2009, 5:17
AutoRecord for 79R
Campanula
сообщение 18.5.2009, 6:51
Gameno_1.1 for 79R
Как я понял нужно в Защита телефона=>Блокировка приложения=>игры и приложения=> поставить <заблокировать>. И при входе в игры он спрашивает код разбокировки. Но когда я ввожу код, выскакиваю на рабочий стол.
Please put this patch in CG1 0f 79R
flashlight on VOICE + VOICE:
Сообщение отредактировал Campanula - 22.5.2009, 2:07
Campanula
сообщение 22.5.2009, 2:08
Two elfs for 79R
PowerDown and StartUp
Campanula
сообщение 10.6.2009, 6:52
For 79R
Thanks to Alesha_Pl
Fix:
Сообщение отредактировал Campanula - 10.6.2009, 7:00
Alesha_Pl
сообщение 10.6.2009, 7:49
Из: Россия, г.Петрозаводск
Пользователь №: 42 716
Прошивка: 49R+EP1+EP2
Campanula, give me this elf
http://74.125.43.132/translate_c?hl=ru&...GfNtn0VpuYcMQWQ
Please
Campanula
сообщение 10.6.2009, 9:06
QUOTE(Alesha_Pl @ 10.6.2009, 15:49) *
Here you are
If you want to have SRC,I will ask to author and give the SRC to you smile.gif
He order to study, not a long time to exchange
Прикрепленный файл baidu09_01_21.zip   ( 25.84 килобайт ) Кол-во скачиваний: 87
STiCK
Из: Ростов-на-Дону
Пользователь №: 175 402
Модель телефона: Samsung S4
Прошивка: 4.3
16.02.14-ветка об эльфах. Приступ ностальгии.
Цитата(Campanula @ 14.5.2009, 18:17) *
two elfs for 79R
65303_65305_Lvideo0.2.zip
А что делает этот эльф? протестировать не на чем, а всё-таки интересно smile.gif Я правильно понимаю: он должен из MotoCMD вызывать родной видеоплеер?
ENG Hey, whats do this elf? Is it open standart videoplayer from MotoCMD?
Campanula
сообщение 10.6.2009, 9:08
QUOTE(STiCK @ 10.6.2009, 17:06) *
STiCK
сообщение 10.6.2009, 9:10
Из: Ростов-на-Дону
Прошивка: 4.3
Сообщение отредактировал STiCK - 10.6.2009, 9:11
Alesha_Pl
сообщение 10.6.2009, 11:02
Campanula,
Добавлено позже (10.6.2009, 15:12):
Цитата(Campanula @ Сегодня, 15:19)
I will give the SRC of Qiche.elf to you
Ok!!!
Сообщение отредактировал Alesha_Pl - 11.6.2009, 4:37
Campanula
сообщение 10.6.2009, 11:19
QUOTE(Alesha_Pl @ 10.6.2009, 19:02) *
Elfs by motoedy[China], new:more elfs 05.09.2009 · Эльфы, их разработка и портирование · Forum
Текстовая версия Сейчас: 26.7.2025, 17:23
