2 страниц V  1 2 >
Linuxmod4 test Ver2 by Rasputin, font and VUI mod !
anhvu2875
сообщение 17.8.2008, 22:28
Пользователь №: 152 593
As the first font mod, which ran automatically at poweron, made the firmware quite buggy,
I changed it now to a manual font mod installation (vui mod as well), which seems to make the firmware run much smoother now,
but BEFORE you can use these mods you have to make sure that certain files are in place on the V8 or it will not work.
In the next step you can see what files are needed and where they have to go.
Mod instructions for Linuxmod4-test2
Font Mod:
With this firmware comes an example font (MyFont.ttf and MyNumber.ttf)
which you have to copy into the fonts/font1 folder on the user memory (/ezxlocal/download/mystuff/fonts/font1).
As you can see both font files are the same, only the file names are different.
Any True Type font you want to use has to be in exactly the same format (2 files, called MyFont.ttf and MyNumber.ttf).
Example: ariel.ttf, copy and rename into MyFont.ttf, copy ariel.ttf again and rename into MyNumber.ttf, done!
Just create those 2 files and copy them into any empty font folder (fonts/font1, fonts/font2 .....fonts/font5).
After each new poweron the V8 will use the original font, because the font mod is not run automatically,
you have to run it manually by going to Tweaks->Font Changer and then choose from font1 to font5,
press the choosen menu and wait untill the poweron animation and sound runs again and your choosen font will be displayed.
If you run the font mod already, let's say font1, but you want to change to font3,
you have to powerdown the V8 and poweron again , only then can you choose a different font.
One word of advice, some fonts are displayed bigger then others at the same size, if you want to use one of those fonts you have to adjust the font size in the skin ini files.
VUI Mod:
This is the voice command mod, only needed if you want italian or german voice commands,
as english and french are already present.
Just copy the content of the vui folder into the vui folder on your V8 user memory (/ezxlocal/download/mystuff/vui).
Then go to Tweaks and press "vui mod" menu, nothing happens, but it is done.
V8 512MB Linuxmod4 test ver2
V8 2GB Linuxmod4 test ver2
Сообщение отредактировал anhvu2875 - 17.8.2008, 22:32
FFEHOT
сообщение 18.8.2008, 5:16
Из: Рязань
Пользователь №: 173 442
Модель телефона: V8
Прошивка: стандарт
Чтото не совсем понятно что это и что делает. По русски объяснит ктонибудь что это и как это?
Velizariy
сообщение 18.8.2008, 5:30
Пользователь №: 162 798
Модель телефона: Motorola Z6
Прошивка: PE последний
Так как первый шрифтовой модуль, который работал автоматически в poweron, сделавшим совсем кабриолетом микропрограмм, Я изменил это теперь в ручную шрифтовую установку модуля (vui модуль также), который кажется, делает микропрограммами запускать значительно разглаживающее устройство теперь, но ПРЕЖДЕ, ЧЕМ Вы можете использовать эти модули, которые Вы должны убедиться, что определенные файлы поступают на V8 или он не будет работать.
В следующем шаге, который Вы можете видеть как какие файлы - нужно и где они должны ходить.
Инструкции Модуля для test2 Linuxmod4-
Шрифтовой Модуль:
С этими микропрограммами приходит шрифт примера (MyFont.ttf и MyNumber.ttf) какое Вы должны копировать в fonts/font1 папку в памяти потребителя (/ezxlocal/download/mystuff/fonts/font1).
Как Вы можете видеть оба шрифтовых файла - те же, только файловые имена другие.
Любой шрифт Типа Истины, который Вы хотите использование должно быть в точно том же формате (2 файла, назвавших MyFont.ttf и MyNumber.ttf).
Пример: ariel.ttf, копировать и переименовываться в MyFont.ttf, копировать ariel.ttf снова и переименовываться в MyNumber.ttf, сделанным!
Просто создайте те 2 файла и копируйте их в любую пустую шрифтовую папку (fonts/font1, fonts/font2.....fonts/font5).
После каждый новый poweron V8 использует оригинальный шрифт, поскольку шрифтовой модуль не работает автоматически, Вы должны запустить это вручную ходя Преобразователю Tweaks->Font затем выбирается из font1 до font5, нажимает меню choosen и ожидает untill оживление poweron и звуковые прогоны снова и ваш choosen шрифт будет отображен.
Если Вы запускаете шрифтовой модуль уже, пусть font1, но Вы хотите измениться на font3, Вы должны powerdown V8 и poweron снова , только тогда можете ли Вы выбрать другой шрифт.
Одно слово совета, некоторых шрифтов отображено большим затем другие в том же размере, если Вы хотите использовать один из тех шрифтов Вы должны регулировать шрифтовой размер в ini файлах кожи.
МОДУЛЬ VUI:
Это - речевой командный модуль, только нужно если Вы хотите итальянские или немецкие речевые команды, как английский и французский уже присутствуют.
Просто скопируйте содержимое vui папки в vui папку в вашей памяти пользователя V8 (/ezxlocal/загрузка/mystuff/vui).
Затем пойдите в Щипки и нажимайте меню "vui модуля", ничто не случается, но сделано.
сообщение 18.8.2008, 5:43
нечего нового...
anhvu2875
сообщение 18.8.2008, 7:51
qwerzxcv
QUOTE
нечего нового...
this Linuxmod4 ver2 will fix all bugs of the old Linuxmod4 ver1
the font mod will not run automatic . Font mod and VUI are in TWEAKS folder !
FFEHOT
сообщение 18.8.2008, 8:34
Из: Рязань
Модель телефона: V8
Прошивка: стандарт
Цитата(anhvu2875 @ 18.8.2008, 7:51) *
qwerzxcv
чё?
А вообще мне интересно пару вещей: большой ли шрифт при входящем звонке на внешнем экране и меньше ли он тормозит, а то 3мод ваще беда тупой, видео и песни по 30 секунд открывает. А ещё иногда тело перезагружалось после окончания разговора.
Сообщение отредактировал FFEHOT - 18.8.2008, 8:45
Frezerovshik
сообщение 18.8.2008, 10:06
Пользователь №: 179 253
Пишет что пофиксены все ошибки 1 версии. НО ГЛАВНАЯ ОШИБКА ИСПРАВЛЕНА? ТЕПЕРЬ ТЕЛЕФОН АДЕКВАТНО РЕАГИРУЕТ НА ВХОДЯЩИЙ ЗВОНОК?
SunChase
сообщение 18.8.2008, 21:44
Пользователь №: 161 792
Незнаю что и откуда но весч работает постабильнее и получше предыдущей бетки.Автору зачёт smile.gif
FFEHOT
сообщение 19.8.2008, 5:13
Из: Рязань
Модель телефона: V8
Прошивка: стандарт
Ставил кто это? Отписывайтесь.
SunChase
сообщение 19.8.2008, 9:48
FFEHOT,
Угу.Я вчера поставил.
За 12 часов работы вроде ниединого глюка.Посравнению с предыдущей версией работает более гладко.МПлеер работает ровнее.Фонты и всё такое в твиках теперь настраиваются.Да и сам телефон вроде легче.
Правда на внешнем экране тач-кнопками нельзя читать сообщения.Но а так вроде всё гут.
FFEHOT
сообщение 19.8.2008, 10:08
Из: Рязань
Модель телефона: V8
Прошивка: стандарт
blink.gif не одно, так второе
Frezerovshik
сообщение 19.8.2008, 10:11
Цитата(SunChase @ 19.8.2008, 20:48) *
FFEHOT,
Не фигасебе "правда". Это бооольшой баг. Мне лично эта функция пришлась ну очень по душе.
А что с отображением звонка на внешнем дисплее? Исправил? (я так понял по твоему посту на форуме распутина что этот баг исправлен?)
зы: что с голосовым управлением? работает? если да то где можно вязть русское, на форуме гдето видел ссылеку не помню где :\
Сообщение отредактировал Frezerovshik - 19.8.2008, 10:12
SunChase
сообщение 19.8.2008, 11:50
FFEHOT, ну незнаю незнаю.Мож я чёт нетак сделал.Мне смс пришла када я спал и я спокойно мог спросоня непопадать по сенсорным кнопкам shuffle.gif
Frezerovshik,
незнаю что у вас там было но лично у меня на всех версиях(включая эту) всегда спокойно отображался звонок на внешнем дисплее.
С голосовым управлением я вообще неразбирался так как этой функцией никогда непользовался такчто тут сказать немогу.
Ну а в общем прошива удачная
Добавлено позже (19.8.2008, 15:29):
Frezerovshik,
да и чё ты паришся.Тут сделано как в стандартной прошиве - просмотр сообщений на внешнем экране с помощью боковых кнопок smile.gif
Frezerovshik,
Frezerovshik
сообщение 19.8.2008, 13:01
Да это собственно ерунда сообщения. У меня внешний экран на звонки не реагирует вот беда в чём sad.gif Шас прошьюсь этой версией мб заработает...
SunChase
сообщение 19.8.2008, 13:32
Frezerovshik,
если что пиши мне в Асю(227158598) мож подскажу чтот
Добавлено позже (19.8.2008, 18:03):
Frezerovshik,
тякс.Звиняй.Ошибся насчёт внешнего экрана.Пашет сенсорика.Наверн просто спросоня я неосилил попасть по тауч клавишам shuffle.gif
Blad790
сообщение 19.8.2008, 17:07
Пользователь №: 167 975
Модель телефона: razr2 v8 512mb
Прошивка: Project Evolution V8
А как вы запустили мплеер? я скопировал его с прошлого мода но он не работает
SunChase
сообщение 19.8.2008, 19:26
Blad790,
ничё ненадо копировать.Он находится в Мультимедии.Запускается оттуда и всё гут
Blad790
сообщение 19.8.2008, 19:40
дак если дже не копировать всеравно не запускается. нажимаю на него но ничего не происходит.
Chepurnoff
сообщение 19.8.2008, 20:22
Из: Тюмень - Пенза - Саратов
Пользователь №: 157 192
Прошивка: zMod
Ту бир ор нот ту бир?
Мод нормальный, у меня глюков нет, пришлось правда перезалить фотки что стояли на вызовах, покорежились немного почему-то
SunChase
сообщение 19.8.2008, 22:51
Blad790,
ты из под чего и на что шил?
Blad790
сообщение 20.8.2008, 5:14
шил на прожект еволютион для в8.
FFEHOT
сообщение 20.8.2008, 5:15
Из: Рязань
Модель телефона: V8
Прошивка: стандарт
Вы мне скажите, стоит ставить взамен 3го мода или нет? А то просто так не хочется заново бекапить телефонную книгу и всю медию. Кста, какие там скины? Мож скринов выложил бы кто blush.gif
Frezerovshik
сообщение 20.8.2008, 7:26
SunChase
Спасибо за помощ сейчас буду шиться smile.gif Распутин на форуме написал что все проблемы изза фонт мода и без него всё должно пахать на ура.
SunChase
сообщение 20.8.2008, 11:53
Blad790,
Power of Linux Project Evolution?Оо.Он для Z6 а не для V8.
Ладно начнём с простого.
Скачай оригинальную прошивку для своего телефона.
Прошей её.Проверь - есть ли какието бзики которые у тя были при ЛМ.Если нет то дело в том как прошивался телефон или в самой прошиве.
Дальше прошиваеш телефон.Потом по желанию дошивает русский лэнг.
Внизу я кратко опишу как прошивал я(вдруг пригодится)
1.Выключаем телефон и включаем с помощью сочитаний клавиш #+*+сама кнопка включения телефона(телефон включится в неком подобии Доса)
2.Включаем РДС Лайт.Подключаем в этом режиме телефон к компьютеру через шнур.Рдс Лайт должен его определить.
3.Через РДС выбираем эту прошивку и шьём.Телефон отобразит прошитие.РДС будет показывать % завершённости.
4.Потом телефон перезагрузится и включится.Но шнур вытаскивать рано.РДС будет дальше дописывать прошивку.Дождись пока там закончится Эксекутион.РДС(лично у меня) показывает в конце сообщение:Manualy power up the phone.Просто выключаем и включаем телефон.И всё.Телефон готов к работе.
По желанию потом берётся прошивка с руским лэнгом и такой же методикой дошивается на телефон.Всё.У меня пашет отлично всё.
FFEHOT, Ну ЛМ3а неплохой.В ЛМ4 Распутин вфигачил пару примочек интерестненьких:Шрифты,ЕФМ(для установки нестандартных прог),МПлеер(ну с ним я ещё грызусь - определяю какой максимальный формат он жуёт).И вродебы всё.Ну может чуток быстрее стало тело.
Я себе его поставил изза плеера лично.Ну и кажется чуток исправлен баг со скинами.
Добавлено позже (20.8.2008, 14:54):
Frezerovshik,
да незачто
Blad790
сообщение 20.8.2008, 12:02
да я так все и делаю. сама проша работает нормально . не работает только мплеер. а насчет прошлой прошивки то я имел ввиде прошу с pep менеджером. кстати странность: прошил лм4 первой версией и плеер там работает но после обновления до второй версии перестает.
KLON 3
сообщение 20.8.2008, 12:23
Из: Voronez
Пользователь №: 90 456
Модель телефона: v3i,V8 512M
Прошивка: Basic Plus
Дуги,у кого нибуть на 512 версии заработал MPlayer? Если да,то отпишитесь как добились.
FFEHOT
сообщение 20.8.2008, 13:09
Из: Рязань
Модель телефона: V8
Прошивка: стандарт
сообщение 20.8.2008, 13:14
да,РЕ есть и для в8
Frezerovshik
сообщение 20.8.2008, 13:18
Ппц. У мню новая беда вылезла- статус строка на внешнем экране дублируется внизу и получается очень и очень не очень (извиняюсь за каламбур). Хотя в стандартной теме это выглядит как фича и то если не врубать плеер или другие тач функуии.
А так всё ок.
зы: где можно почитать про фем?
зы2: некоторые менюшки (по крайней мере в твиксах) пропадают с изменением скина.
Сообщение отредактировал Frezerovshik - 20.8.2008, 13:34
SunChase
сообщение 20.8.2008, 14:09
Blad790,
У меня бывали моменты что первых пару раз МПлеер незапускался.Я просто перегружал телефон и всё работало.У тебя В8 на 2ГБ?
Frezerovshik, за голосовое я ничего сказать немогу так как испокон веков им непользуюсь.
А со статус строками - то попробуй просто скины поменять.Я пробовал ставить скин от Z6 и он явно "неналазил" то там тоже каламбур имелся.
Хотя всёже странновато - на стандартной тоже какбы проблем неимелось.Как предположение:Может както логотип оператора сдвигает экран...Но тут я безсилен smile.gif
Добавлено позже (20.8.2008, 17:15):
FFEHOT,
Да на скринах ничё особого нет:
Blad790
сообщение 20.8.2008, 14:48
нее. у меня на 512мб. ладно видно не судьба пользоваться плеером ток что откатился до pe для в8 sad.gif threaten.gif
Frezerovshik
сообщение 20.8.2008, 14:58
Трабла с статус строкой рошла после перезагрузки. Т.е. надо перезагружаться после применения каждой темы как я понял sad.gif
А где можно тогда почитать про голосовое?
Мне как бы тоже не особо нужно то наличие такой фичи меня обязывает уметь её использовать хотя бы для демонстрации возможностей телефона. Да и вообще прикольно что телефон говрить умеет smile.gif
зы: и всётаки что за фем и как его юзать скажите ктонибудь?!
Сообщение отредактировал Frezerovshik - 20.8.2008, 14:59
SunChase
сообщение 20.8.2008, 15:12
Blad790,
неспеши.Вот тебе темочка: Установка и запуск MPlayer и других прог
Там написано как самому устанавливать МПлеер.Почитай.Вдруг поможет.
Frezerovshik,
Ну у меня и без того всё гут.Но тут каждому своё.Если тебе нада голосовуху то найди в предыдущем релизе ЛМ4 гдет в начале пишут как русскую болталку вставлять и куда.Эт всё что я могу сказать за это smile.gif
ФЕМ или ЕФМ?
FFEHOT
сообщение 20.8.2008, 17:47
Из: Рязань
Модель телефона: V8
Прошивка: стандарт
SunChase
сообщение 20.8.2008, 18:50
FFEHOT,
у меня спокойно запускается...
FFEHOT
сообщение 21.8.2008, 5:03
Из: Рязань
Модель телефона: V8
Прошивка: стандарт
SunChase ты просто прошил ЛМ4 и Мплеер заработал???
SunChase
сообщение 21.8.2008, 11:29
FFEHOT,
именно
FFEHOT
сообщение 21.8.2008, 11:44
Из: Рязань
Модель телефона: V8
Прошивка: стандарт
SunChase тогда в чём проблема??? чё он не работает??? Как его научить???
Frezerovshik
сообщение 21.8.2008, 11:48
По видимому никто не нашёл бг или он толкьо у меня но: при установке какого либо приложения пишет "сбой установки" sad.gif раньше всё гуд было
зы: фем вроде. в меню твикс
SunChase
сообщение 21.8.2008, 13:28
FFEHOT,
извини я ошибся.Качаеш МПлеер и ложиш его по такой траэктории:Карта памяти - Програмс...и туда закинь папку мплеера и всё гут.Извини я просто забыл.У меня эта папка осталась с прошлого раза
Frezerovshik,
ЕФМ у меня лично пишет.Зайди в темку Установка МПлеер и т.д(я выкладывал ссыль повыше) и там почитай.
Linuxmod4 test Ver2 by Rasputin, font and VUI mod ! · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
2 страниц V  1 2 >
Текстовая версия Сейчас: 12.9.2025, 16:32
