Low Battery - the sound, how to change the sound
Gabri
сообщение 26.8.2008, 23:05
Пользователь №: 178 724
Модель телефона: Motorola c385
Прошивка: R365_G_0B.03.06R
Hi, all ! I put a new software to my phone (c385) and when my battery was low there were a new sound. I tried to change the file with my preference , I put the same name as the previous but it didn't work. May some body help me and tell me how to put the audio file that I want to hear when my battery is low dntknw.gif
сообщение 27.8.2008, 8:17
What new software with a new sound was?
Gabri
сообщение 27.8.2008, 10:55
I just installed "Прошивка R365_G_0B.D3.06R" and there were a new sound so I learned that I can change this sound. I tried to do so by changing the file and putting the same name (LBatLow.wav) as the previous but it didn't work... Do you have any idea how can I replace it ?
сообщение 27.8.2008, 11:40
Activate in seem 0032_0001
Offset 82 bit 6 - ”WAV_UI_AVAILABLE”
Parameters WAV of a file:
1. Bitrate: 64 Kb/s
2. Frequency of digitization: 8 kHz
3. Width of the channel: 8 bits
4. Without compression, standard: PCM
5. Mono
Дай телефону право голоса !
Gabri
сообщение 27.8.2008, 12:53
How can I edit that file tomato.gif Can I use FlexTools or I will need something else smile.gif
PS : Ok I can edit it with P2K Seem Edit but on Offset 82 bit 6 it says : "Keypad : Keynote Sound for Keypresses - on/off" unsure.gif
Сообщение отредактировал Gabri - 27.8.2008, 15:53
anhvu2875
сообщение 30.8.2008, 23:01
Пользователь №: 152 593
Gabri
Check again pls , or try to use P2KT or https://forum.motofan.ru/index.php?showforum=68 Р2KAE
IPB Image
IPB Image
Gabri
сообщение 31.8.2008, 22:02
Oh, so that's in "Hidden settings" wink.gif I was searching in seem editor ...
Thanks a lot both of you
Low Battery - the sound, how to change the sound · For English speaking members · Forum
Текстовая версия Сейчас: 17.9.2025, 8:18
