Ok here is the MP.
It is R4441D_G_08.01.03R + DSP 63343400 from
R4441D_G_08.03.05R.Complitely stable and without flickering
effect but faster than the original R4441D_G_08.01.03R.Can be
used for downgrading too.It becomes with my flex cos i have
more than 55 patches that are applied and some changes i made
in the flex that comes from the patches.I think this mp puts
the end of the upgrading of the v3i cos it has the most of
it.Also the elfs are supported.
The dsp(CG3) can be used only with my(R4441D_G_08.01.03R) not
with the other one cos i ported it to and with another software
can couse damage or rebooting while getting calls or trying to
paly mp3 or acc files.
Patches are:
1.elf-pack.01
2.Full java list
3.I tap always on in corelets
4.MMS 512 KB.Everything is set don't touch the message size in
mms message setup.otherwise you will get 300kb
5.MP3 Bitrate 320
6.Register-needed by the elf patch
7.SMS MMS with it's own ID
8.reboot chat.reboot menu for restarting the phone instead the
chat menu.
9.usb charging instead animation
10.activity main display 20 40 sec
11.vibration in java.dot dot
12.extensions set to on-needed by several patches
13.extension on-needed by several patches
14.delivery report set to always on
15.outer screen like v360.three lines
16.dictophone 1 minute when speaking
17.access_к_выполнению_кода_из_корелета.fpa
18.access_к_запуску_функций_из_корелета1.fpa
19.access_к_проигрываню_тона_из_корелета1.fpa
20.access_к_РАМ_из_корелета1.fpa
21.access_к_seem_4а_in_corelet.fpa
22.access_к_system_files.fpa
23.access_к_hidden_folders.fpa
24.overwriting the protected seems
25.run java form calendar without confirming
26.different times of rings in the alarm clock
27.different order of the writing letters and symbols
28.corelets are shown in java
29.measure for pictures 200%,250% and 50%
30.Clock in the alarm clock
31.not deleting of the recent and dilled calls on a sim
changing
32.new date format
33.new file format
34.corelets should be installed without checking the signed
attribute
35.new keys adaptation when flip closed
36.keypad always goes out when display goes out
37.keypad light-on off in settings menu
38.outer display activity 3 seconds
39.receiving all files over bluetooth
40.Fifth group-white and black lists in categories made for
ignoring the callers
41.saving everything in seems-needs to be included for oder
patches
42.allows the WVIM melodies to be changed
43.Translation
44.switched to off DRM protection
45.switched to off the checking of the addess and security in
java
46.bigger bluetooth powering on
47.bigger amount of autoredail and a signal while receving
calls(change the sound from ans machine option in ring styles)
48.bigger itap 10 kb
49.bigger java heap 1500kb and corelets heap 20kb bigger heap
for elf files
50.deleting of all useless folders in the phone memory
51.deleting of all useless folders in the memory card
memory-needs to be done manually.after that reset the phone and
thats it(sounds pictures kjava and videos)
52.different color in java
53.java runs when usb connected
54.clock in status bar 2.0-fixing skin problem.
55.different brightness of the display
56.clock beep in every hour can be switched to of from settings
Put the elf folder to b/ and restart the phone.but do this
before flashing my MP.
7 skins that i think are the most perfect skins for the v3i
Full EDGE Enabled
I left my Phone numbers and some pictures cos i am too lazy to
delete it now and reflashing the phone.Just delete it and
delete the phonebook.You can delete the categories but you need
not to delete the black list category and white list
category,the are used from the patch black and white list.
Lnaguage -Bulgarian and English.
If you have some questions please post it here and i will
answer ot it.
Have a nice modding and Cheers for the Latest Best MP of the
Year.
The MP has dual boot #+red key-dualboot,,,*+red key-testpoint mode(blank mode),,,#+*+red key normal boot.
GOOGLE TRANSLATE IN RUSSIAN FOR THE RUSSIAN BROTHERS
Ok здесь прошивка.
Именно R4441D_G_08.01.03R + 63343400 с DSP
R4441D_G_08.03.05R.Complitely стабильной и без дрожания
эффект, но быстрее, чем оригинал R4441D_G_08.01.03R.Can быть
используется для понижения too.It становится с моим гибкого cos Я
более 55 патчей, которые применяются и некоторые изменения, я сделал
в гибкой, что исходит от patches.I думаю, что это ставит Т. пл
окончания модернизации v3i cos она имеет большинство
it.Also elfs поддерживаются.
Dsp (CG3) могут быть использованы только с моего (R4441D_G_08.01.03R) не
с другой cos портирован я ему и с другого программного обеспечения
может couse повреждение или перезагрузки при получении звонки или попытки
paly или аcc mp3-файлов.
Патчи являются:
1.elf-pack.01
2.Full java списка
3.I крана всегда в corelets
4.MMS 512 KB.Everything настроен не прикасайтесь размер сообщения в
мм сообщение setup.otherwise вы получите 300kb
5.MP3 Битрейт 320
6.Register-нуждаются эльф патч
7.SMS MMS с его собственным ID
8.reboot chat.reboot меню для перезапуска телефона вместо
чат меню.
9.usb зарядки вместо анимации
10.activity основному дисплею 20 40 сек
11.vibration в java.dot точка
12.extensions ВКЛ-необходимо несколько патчей
13.extension о необходимости несколько патчей
14.delivery набор отчетов, всегда по
15.outer экране, как v360.three линий
16.dictophone 1 минута, когда речь
17.access_ к_выполнению_кода_из_корелета. ИОО
18.access_ к_запуску_функций_из_корелета1. ИОО
19.access_ к_проигрываню_тона_из_корелета1. ИОО
20.access_ к_РАМ_из_корелета1. ИОО
21.access_ к_ seem_4 а_ in_corelet.fpa
22.access_ к_ system_files.fpa
23.access_ к_ hidden_folders.fpa
24.overwriting охраняемых кажется
25.run java виде календаря без подтверждения
26.different раза колец в будильнике
27.different порядок написания букв и символов
28.corelets показаны на Яве
29.measure для работы с картинками 200%, 250% и 50%
30.Clock в будильнике
31.not исключив из последних и dilled призывает симулятор
меняющимся
32.new формат даты
33.new формат файла
34.corelets должны быть установлены без проверки подписан
атрибут
35.new ключи адаптации, когда флип закрыт
36.keypad всегда выходит, когда выходит дисплей
37.keypad световой по покинуть в меню Настройки
38.outer показывать вида деятельности 3 секунд
39.receiving все файлы, над bluetooth
40.Fifth группы-белые и черные списки по категориям для
игнорируя звонящих
41.saving все кажется-должно быть включено для заказу
патчи
42.allows WVIM мелодии, подлежащие изменению
43.Translation
44.switched Отключено DRM защиты
45.switched выходного контроля addess и безопасности в
java
46.bigger bluetooth Включение
47.bigger сумму autoredail и сигнал при receving
звонков (изменение звука с анс машина варианта в кольцо стилей)
48.bigger itap 10 кб
49.bigger java 1500kb кучи и кучи corelets больше 20kb куче
файлы для эльф
50.deleting всех ненужных папок в памяти телефона
51.deleting всех ненужных папок в памяти
память-нужно сделать manually.after, что сбросить телефон и
thats его (звуки kjava фотографии и видеозаписи)
52.different цвет на Яве
53.java работает, когда подключен usb
54.clock в статусной строке 2.0-фиксации кожи проблемы.
55.different яркость дисплея
56.clock звуковой сигнал в любой час может быть изменен на срок от настроек
Положить эльф папку для б / и перезапустить phone.but это сделать
до мигания мой MP.
7 шкур, что я думаю, являются наиболее совершенным скины для v3i
Полный EDGE позволило
Я покинул мой Телефоны и несколько фотографий cos утра я слишком лениво
удалить сейчас и reflashing phone.Just удалите его и
удалить phonebook.You можете удалять категории, но Вы должны
Не удаляйте черный список категорий и белый список
категорию, используются с патч черный и белый список.
Lnaguage-болгарских и Английский.
Если у вас есть вопросы, пожалуйста, разместить его здесь, и я буду
Ответ от ней.
Желаем творческих modding и Cheers по Последние Best MP
Год.
MP имеет двойную загрузку # + красный ключ-кого ,,,*+ красный ключ-testpoint режим (режим пустым ),,,#+*+ красный ключ нормальной загрузке.
FLASH ONLY WITH P2K EASY TOOLS 3.9
FLASH САМО С P2K EASY TOOLS 3.9
FULL MP:
http://rapidshare.com/files/142386999/FULL_MP.rar
Reflash with patch-trans heap.Both java and corelets uses one heap 1500 interchangable and with bigger elfs heap.The Full MP is with patch 1500 java 20 corelet and bigger elfs.
Russian-
Reflash с патч-транс heap.Both Ява и corelets использует одну кучу 1500 взаимозаменяемы и при больших elfs heap.The Полный MP патч с 1500 java 20 corelet и больше elfs
http://rapidshare.com/files/142896271/new.rar
ELFS:
http://rapidshare.com/files/142387397/Elf.rar
five more skins are inside i am not making the screens of it.sorry.just flash the mp and try it you will like it.cheers:))))
еще пять шкур находятся внутри я не сделать экранов от него. извините. просто флэш-MP и попробовать его вам понравится. cheers
THE OTHER SKINS ARE
iPHONE MOTO, IRON WORK, MOTOX, MOTONOIR ,PRADA
NEW SKIN FOR THE MP Snowfire:
you can get the skin here: http://rapidshare.com/files/146965963/snowfire.rar
Сообщение отредактировал simba4 - 20.9.2008, 21:01
Patches are:
1.elf-pack.01
2.Full java list
5.MP3 Bitrate 320
chat menu.
changing
32.new date format
33.new file format
attribute
patches
43.Translation
java
for elf files
Full EDGE Enabled
answer ot it.
Year.
Ok здесь прошивка.
Патчи являются:
1.elf-pack.01
2.Full java списка
5.MP3 Битрейт 320
чат меню.
меняющимся
32.new формат даты
33.new формат файла
атрибут
игнорируя звонящих
патчи
43.Translation
java
файлы для эльф
до мигания мой MP.
Ответ от ней.
Год.
FULL MP:
Russian-
ELFS:
THE OTHER SKINS ARE
