How to make icons depend on skin not on drm (V3i)?
braian-k
сообщение 6.9.2008, 1:00
Из: Argentina
Пользователь №: 163 127
Модель телефона: V3i
hello everybody, I have some skins I would like to use in my phone but need to know a bit how to make them depend on the skin an not on drm. I read some tutorials in other pages but I can't fully understand and I also would like to know DRM icons table and number of skin icons. Thank you.
citroen
сообщение 6.9.2008, 9:51
MotoAuto
Из: Minsk, Belarus
Пользователь №: 95 640
Теперь иконки Itunes, Usb и тд берутся из скина!
braian-k
сообщение 7.9.2008, 1:16
Из: Argentina
Thank you for the link, but I can't understand even with a translator. Could somobody please translate this? thanks.
elvis
сообщение 7.9.2008, 3:22
Пользователь №: 162 964
Модель телефона: e770_V3X
Прошивка: 85.9b.E1P
you should open MMA Advanced editor, then with help of it open mma_ucp from needed skin. after opening you should select needed link, then right mouse click on it and select MODIFY ITEM, there you can find 3 fields, there you must to put numbers of icons(i give you numbers in table, in first field- first number, in second - second, if i dont give you some number it mean that you should leave field empty)
there is table:
Videocamera 39,55
Itunes 550,551,552
Usb 143,144
Airplain mode 481,482,483
voice call 500,501,502
PTT 187,188,189
if some number will not work you can change it on other number for example if 39,55(videocamera) will not work you can put in fields of videocamera numbers of other link you want to display(videocamera will be started but icon can be other)
P.S. sorry if i do some mistake in translate, my english not very good
Сообщение отредактировал elvis - 7.9.2008, 3:26
How to make icons depend on skin not on drm (V3i)? · For English speaking members · Forum
Текстовая версия Сейчас: 3.8.2025, 14:27
