2 страниц V  1 2 >
(New) MP MOTOHELIC with good DSM, бут 07 д0
сообщение 17.9.2008, 16:07
заметил что данной прошивки нету на форуме, поэтому решил создать тему
оригинал здесь http://motohell.com/index.php?topic=3245.0здесь
(New) MP MOTOHELIC with good DSM for long life batt.
This MP is for E398/ROKR with BL 07.D0
Firmware : R373_G_0E.30.49R
Flex : GCKK............
DSP : 623BAB00
GT/PT : MOTOHELIC EDITED
DRM : EDIT NEW ICON
Technology : Quad-band GSM
Language : 002E English 6 fonts
- Abolish Alarm OFF from list
- Abolish control by illumination Java
- Access main menu everywhere
- Access to seem 004a from corelets
- Add new simbol ± І і œ Œ Ÿ
- Alarm 5m
- Auto delivery report sms 1.18
- Autokeypad lock
- Autostart Java from DateBook
- bg_in_player_v2.3n_49R
- Blacklist
- Brightness
- Camera button 1x camera 2x videocam
- Cancelation check signature java
- Change display timeout activity
- Change menu opcode
- Change menu sound,pic,video
- Change ringstyle with Menu+#
- Change simbols order
- Change zoom
- Changes the record format YY-MM-DD_HHMM
- Clock on SS
- Complete access to the file (Java,BT,OBEX)
- Date format
- Dictaphone_not_pick
- diktophone_1min
- Flashlight star+star
- Green call dialled & received calls
- Icon of received calls in ss
- Increase quantity autoredial
- Increase Data notice
- Increasing bell replaced the Preferred Card
- Java black background
- Java full access patch
- Java Heap_J1100_C1496
- Java killer
- Java with the cable works
- Keysound replace Battery Savings
- Master Clear & Master Reset Failure
- Mma skin 3.0
- MMS 1000kb
- MP3 bitrate up to 320kb
- New recent call
- No busy audio channels by lowbatt tone
- No del call on sim change
- No sound volume 1.01
- NoJavaIcon
- Patch 6 fonts CG1_49R
- Pseudo Playlist 5.0
- Quick access sound & picture
- Redial in 5sc
- Reflect corelet in the list java
- Removal limitation system file
- Removal of the pressures of keys 112 and 911
- Removal unnecessary TF folder
- Remove checking safety and addresses
- Remove drm the protection
- remove ID the melody of subscriber from sms 1.13
- Send SMS on Phonebook leftsoftkey
- Set default Rsoft in web sessions
- Sort date or alphabet in animation
- The illumination of keyboard instead of the indicator
- Time and Name in the list of the alarm clock
- time_update_mod 10sek
- unlimit_dictophone_mms_email
- Unlock all seem
- update time interval sms reminder 2m_2m_2m
Notes :
- Phone Unlock Code : 1234
- Phone Security Code : 000000
- To Delete, Move, Copy, or Assign to Categories for files on Sounds, Pictures, and Videos...
you have to Mark the file first with press "0" button
- If the iTunes doesn't load correctly, please delete iTunes folder on TF.
- Copy the Elf folder (incl. in package) onto your TF for running ELF.
- Sorry,i used custweakup&custgoodbay from motousers
Thx to:
- Genius Russian Motomodders @ motofan.ru, motohell.com, modmymoto.com, motousers.or.id
- gayoe, Zh@ng-L14ng, Poer the RedkingMaster, zigot, sysmaster, montox, jithinSK,
motomaniacs,MATRICE, ritza_ll.gie_lanz
- All people who help me on this MP, sory if I can't mention one by one
перевод через гугл
Микропрограммы: R373_G_0E.30.49R
Flex: GCKK ............
DSP: 623BAB00
GT / PT: MOTOHELIC отредактирован
DRM: изменить новый значок
Технология: "четверки" в диапазоне GSM
Язык: 002E Английский 6 шрифтов
- Сигнал отменить взлет из списка
- Отменить управление освещением Java
- Доступ главном меню во всем мире
- Доступ к показаться 004А из сердечника
- Добавить новое обозначение ± І і œ Œ медицинских
- Сигнал 5м
- Автоматический отчет о доставке смс 1,18
- Autokeypad замок
- Autostart Java от DateBook
- Bg_in_player_v2.3n_49R
- Черный список
- Яркость
- Камера 1x кнопка камеры 2x videocam
- Отмена проверки подписи Ява
- Изменение отображения тайм деятельности
- Изменения в меню opcode
- Изменения в меню звук, фото, видео
- Изменение ringstyle с Меню + #
- Изменение порядка simbols
- Изменение масштаба
- Изменение формата записи YY-MM-DD_HHMM
- Часы на С.С.
- Полный доступ к файлу (Java, BT, OBEX)
- Дата формата
- Diktophone_1min
- Фонарик звезда + звездой
- Зеленые призывают набранных И получил звонки
- Икона получили вызовы в СС
- Увеличение количества autoredial
- Увеличение Данные уведомления
- Повышение колокол заменили Желателен карточки
- Java черном фоне
- Java полный доступ патча
- Java убийца
- Java с кабелем работает
- Keysound заменить батареи Экономия
- Мастер Открытый И сброс провал
- ММА кожи 3,0
- MMS 1000kb
- MP3 битрейт до 320kb
- Новые вызовы
- Нет занят аудио каналов lowbatt тон
- Нет деле слово SIM-изменения
- Нет звука 1,01
- NoJavaIcon
- Патч 6 шрифтов CG1_49R
- Псевдо Плейлист 5,0
- Быстрый доступ звук И картина
- Повтор в 5sc
- Отражение corelet в списке Ява
- Снятие ограничений системных файлов
- Удаление давления клавиш 112 и 911
- Удаление ненужных папок TF
- Удалить проверку безопасности и адресов
- Удалить технологии DRM защита
- Удалить ID мелодия абонента с смс 1,13
- Отправьте SMS по телефонной leftsoftkey
- Установка по умолчанию Rsoft в веб-сессиях
- Сортировка даты или алфавит в анимации
- Подсветка клавиатуры вместо индикатора
- Время и название в списке будильника
- Time_update_mod 10sek
- Unlimit_dictophone_mms_email
- Открой, как все
- Интервал времени обновления SMS-напоминание 2m_2m_2m
Примечания:
- Телефон Открой Код: 1234
- Телефон Защитный код: 000000
- Удалять, перемещать, копировать, или присвоить Категории файлов на звуками, картинками и видео ...
Вы должны Марк файл сначала нажмите кнопку "0" кнопка
- Если iTunes не загружается корректно, пожалуйста, удалите папку iTunes на TF.
- Скопировать папку "Эльф" (включая в упаковке) на ваш TF для запуска ELF.
- Извините, я использовал custweakup И custgoodbay из motousers
Режим THX на:
- Гений российского Motomodders@motofan.ru, motohell.com, modmymoto.com, motousers.or.id
- Gayoe, Ж. @ нг-L14ng, Poer RedkingMaster, zigot, sysmaster, montox, jithinSK,
motomaniacs, MATRICE, ritza_ll.gie_lanz
- Все люди которую мне помочь в этом КП, сортировки, если я не могу не упомянуть один за другим
скачать
зеркало
всем приятного пользывания
блеш бекап 3.0.6, у меня прошился ним норм
скины с монстра+мма. к сожилению всё в одной папке так как пришлось разобрать прошу
Сообщение отредактировал Claus398 - 22.9.2008, 13:49
HosTeL
сообщение 17.9.2008, 17:17
Пользователь №: 170 508
хммм ! надо поставить smile.gif посмореть чё как ! поставлю напишу ! smile.gif
сообщение 17.9.2008, 18:07
я поставил, улёт. дрм класс, шрифты в ставнении с нашими просто прелесть, и 2 супер скина
пока лагов не замитил, на английском правда всё но я свои телефоны знаю так что мне хоть на китайском
рекомендуюю
HosTeL
сообщение 18.9.2008, 10:46
Lexa-Lexa
сообщение 18.9.2008, 12:31
Пользователь №: 101 694
Прошивка: MPX398
сообщение 18.9.2008, 13:48
HosTeL,
тиховат?
Lexa-Lexa
сообщение 19.9.2008, 12:32
Прошивка: MPX398
тиховат... а еще русского нету, буковки отображаются , а писать нельзя, а так симпатичный!
сообщение 19.9.2008, 12:45
Lexa-Lexa,
вот держи архивчик, в нём патч на 6 шрифтов, звук норм, и ленг русский от vic ток
Сообщение отредактировал Claus398 - 19.9.2008, 12:47
сообщение 19.9.2008, 17:22
если чо не так с архивом то напишите
Слайф
сообщение 19.9.2008, 17:41
Из: Нижний Новгород
Пользователь №: 175 543
Прошивка: The Life 2
Rahim
сообщение 19.9.2008, 17:47
Из: Баку
Пользователь №: 103 929
Прошивка: почти ФранкейштейН
а у меня тело умерло после прошивки
сообщение 19.9.2008, 19:27
Rahim,
а как ты шил? на что?
Radik86
сообщение 20.9.2008, 7:54
Из: Елабуга
Пользователь №: 121 557
Прошивка: UMP 79R
сообщение 20.9.2008, 12:21
Radik86,
сылка пашит, так у всех кто качает, я даунлоад менеджером скачал норм
вот так ссыла, кому неудобно пишите переложу в другое место
http://www.megaupload.com/?d=2IYEOS5A
Rahim
сообщение 20.9.2008, 14:43
Из: Баку
Цитата(Claus398 @ 19.9.2008, 22:27) *
Rahim,
забыл на какую прошивку ставил
прошил фб3 последная версия тело умерло потом прошил убитый тел LoveComesAgain тел заработал
сообщение 20.9.2008, 20:13
Rahim,
попробуй снова
Alek1989
сообщение 20.9.2008, 21:38
Пользователь №: 98 294
Модель телефона: Rokr E1
Прошивка: R373_G_0E.30.42R
У меня когда етот ленг ставлю выскакивает- RDL SIG ERROR 39:02!Что делать?
сообщение 21.9.2008, 8:37
Alek1989,
ты чем шьёш? через фб 2.62 отлично шьётся
Alek1989
сообщение 21.9.2008, 10:30
Так и шью!Мож дело в том что у меня е1??
сообщение 21.9.2008, 12:08
Alek1989, а бут и проша?
случайно не та что в инфе?
Berlinys
сообщение 21.9.2008, 12:17
Пользователь №: 180 850
Модель телефона: Motor E398
хм...нажимаю начать скачать прошивку - выдаёт иероглифы в виде текста...что ж такое то? sad.gif
Alek1989
сообщение 21.9.2008, 12:18
проша MP_MOTOHELIC_with_good_DSM_for_E1-ROKR!А бут как понимаешь 0A02!
Unerso
сообщение 21.9.2008, 18:50
Из: Vin, Ukraine
Пользователь №: 83 076
Прошивка: R373_G_0E.30.49R
Цитата(Claus398 @ 19.9.2008, 15:45) *
Lexa-Lexa,
Добавлено позже (21.9.2008, 21:52):
fine
сообщение 21.9.2008, 19:00
Из: Солнечногорск
Пользователь №: 172 036
Прошивка: UMP79R
Зачем заливать на всякие ультра турбо аплоудеры?
Достаточно скинуть нка депозит, спокойно удобно и все довольны =\
Не могу с этих трех ссылок нифига скачать, уж простите =\
Eduardu
сообщение 21.9.2008, 19:15
Из: Мичуринск city
Пользователь №: 155 699
Модель телефона: E 398
Прошивка: Dream reality v.1.1
Киньте скины что ли плиз, а то чет расхавилили, у меня загорелось, а качать весь монстр нет возможности(((
Berlinys
сообщение 22.9.2008, 7:53
Толи я дурак толи чё...но скажите "2008-08-28_192453. фб3" - это файл прошивки? т.е нужно прошивать исключительно ФБ3 - прошил включаю ...я был на проше "TheLifeIINextGen.shx" - осталось всё тоже самое только поменялся шрифт, язык на английский, заставка на вкл. а всё остальное от старой прошивки...чё такое непойму (даже заставка на раб.столе неизменилась)))
Unerso
сообщение 22.9.2008, 11:48
Из: Vin, Ukraine
проверь все ли кодовые группы ты прошиваеш!
20Xray08
сообщение 22.9.2008, 12:43
Пользователь №: 168 475
Модель телефона: Motopola E398
Залейте русский ленг плиз заново
Berlinys
сообщение 22.9.2008, 12:56
В моём случае Фб3 видит 5 групп такие как:
CG1- програмное обеспечение
CG3- програмное обеспечение
CG4- языковой пакет
CG15-графический пакет
CG18-цыфровая подпись
всё правильно?..или чё то нето?
сообщение 22.9.2008, 13:02
Berlinys,
когда жмёш скачать нажми на правую кнопку и сохранить как, потом подожди немного, могу перезалить, только ссылку полную давай
Alek1989,
This MP is for E398/ROKR with BL 07.D0, ты куда вообще смотриш то? в начале смотри, сразу подскринами, ложную инфу не пиши, ато из за тебя могут телефоны полететь
Unerso,
да я вот проверил, засада. щас поищу извени. У КОГО ЕСТЬ ПАТЧ ПРОЗЬБА КИНУТЬ
Berlinys,
прошивать фб3, прошивальщик щас залью.
20Xray08,
ленг рабочий!!!, качайте через менеджер закачек а не через браузер, это глюк на фане
Eduardu,
скины щас будут
Добавлено позже (22.9.2008, 13:15):
скины и фб3 в первом посте
Alek1989
сообщение 22.9.2008, 14:46
Claus398 не тупи!Читай: Download ROKR E1 version на том же сайте!Ты куда смотришь??Етот монст и на е1 есть!
сообщение 22.9.2008, 17:11
Alek1989,
это ты не тупи, какая разница что там написано, я чотко выложил прошу для бута 07д0, е398.
Добавлено позже (22.9.2008, 17:17):
fine,
напиши что перезолить
Berlinys,
да
Alek1989
сообщение 22.9.2008, 17:24
Та я туже прошу скачал для е1 на е398мод, там же де и ты!И вопрос не зря в етой теме задал!
сообщение 22.9.2008, 18:23
Alek1989,
для е1 не вылаживал, нормально всё описано в первом посте, для какой проши и на какой бут, просто нада перечитать сначала первый пост.
если бы я для бута 02А0 вылаживал бы то написал бы
20Xray08
сообщение 22.9.2008, 19:20
Ребята ..обьясните как патч поставить ато вроде все правильно днлаю а он ошибку пишет в виде доллара (фб3)
Извеняюсь разобрался!,!!!
Чето натворил теперь в язык заходиш там дето 6 одинаковых шрифтов и один украинский...очень хотел бы шрифт нокиа стандартный в той проше оставить...и русский мелкий и тонкий...подскажите как сделатьт или есть ли у когото готовое?
Сообщение отредактировал 20Xray08 - 22.9.2008, 19:40
KAA-77
сообщение 23.9.2008, 8:18
Пользователь №: 172 119
Модель телефона: E-398
20Xray08, ты просто выбирай их по очереди и увидишь, что они на самом деле разные
сообщение 23.9.2008, 13:46
20Xray08,
нада патч и соответсвующий ленг, тот что у меня на эту прошу почемуто неложится sad.gif sad.gif sad.gif
Unerso
сообщение 23.9.2008, 13:54
Из: Vin, Ukraine
ну что кто нить нашол подходящий патч и ленг???
а да и ещё, кто нить знант как отключить этот звук когда блокируш клаву на уличном стиле?
tsesaleks
сообщение 23.9.2008, 14:02
Из: Тюмень
Пользователь №: 147 944
Прошивка: R4441D_G_08.03.05R
Никакой патч применять не надо, там уже есть патч, просто нужно поставить ленг.
Сообщение отредактировал tsesaleks - 23.9.2008, 14:03
Прикрепленный файл vic66fonts.rar   ( 479.88 килобайт ) Кол-во скачиваний: 188
KAA-77
сообщение 23.9.2008, 14:53
tsesaleks, архив битый
2 страниц V  1 2 >
Текстовая версия Сейчас: 28.7.2025, 3:34
