Причина закрытия (TEQUILA 30-11-2008): Опять флуд...
Qtopia-LM5, new rasputin007's mod
Legis
сообщение 30.10.2008, 19:07
Из: Питер
Пользователь №: 62 183
Модель телефона: Atrix 4G
Прошивка: Home Base
rasputin007 в очередной раз порадовал нас своим творением:
This is for the really lazy ones or the ones that can not get Qtopia to work on their V8.
Just flash this firmware and when https://motofan.ru/soft/ РСД says PASS connect FTP and copy the qtopia.img file into /ezxlocal/download/mystuff.
Then press the Tweaks->Qtopia, wait for a few seconds and then close and open the flip, hey presto Qtopia is running.
To get out of Qtopia you need to press and hold the poweroff key then choose "Shutdown device", but you still need to remove the battery to get back into your old V8. One advantage is that, in case, there is a new Qtopia image you then just need to replacew the old one and then you can try it again.
This firmware is basically the LM5-alpha1, but the firmware it is based on has changed. For the 512MB version it is the 80.46.1BR and for the 2GB version it is the 80.56.1BR as those firmwares are the latest and most improved ones, including that voice command bug when using the "check date" command, no more "February October.....", now it is "Today is October.....", but there are a few other improvements compared to the previous 80.56.15R firmware, which I have used for both LM5-alpha1 firmwares.
I had a real hard time, thanks to T-Mobile (original 80.46.1BR and 80.56.1BR are T-Mobile branded firmwares), who branded the Call Voicemail menu in Messages in a totally new dimension, it would not let you enter your own voicemail number or in the 512MB version it connected autmatically to the german T-Mobile voicemail. I finally found the source of this which was in the CG44 and CG43. The CG43 was no problem, but the CG44 is a digital signed CG and therefore can not be edited and changing it meant that also the DRM key for all the wallpapers, screensavers and ringtones were gone, which caused even more trouble as the firmwares have only stock skins. I tried to stay as close to unbranded stock as possible, the rest is up to you.
After hours, days and weeks of changing and testing I finally have something that works.
I have only tested the mods and the most known problem points, like create new themes, create new contacts, media player etc.
All works as before in LM5-alpha1, but read the ReadMe.txt file so you know what you have to place where and where you can find the menus for it.
The MPlayer menu for the 512MB version has been fixed as there was a path fault in the LM5-alpha1.
Most likely the alarm clock bug is still there, have not tested it yet. (Well, I have to leave some work for you to do!)
512MB Qtopia-LM5
2GB Qtopia-LM5
http://www.rasputin007.co.uk/New-Forum/vie...?f=28&t=440
з.ы. в общем тот же ЛМ5, но с кьютопией, новой прошей и парами исправленных баговsmile.gif
Сообщение отредактировал Legis - 30.10.2008, 19:08
сообщение 30.10.2008, 19:22
в ней(кьютопии) чтонибудь кроме дисплея и клавы работает?
andrey_moto
сообщение 30.10.2008, 19:45
Из: minsk
Пользователь №: 168 066
Прошивка: E1®dar15
peverell
Чет, не понимаю, кутопия там работает или просто как бы скин берется оттуда? Наверное сказал глупость. Ну чтож кто прошил скрин в студию и пояснения сюда же
Legis
Из: Питер
Прошивка: Home Base
чутка попозже поставлю и отпишусь.
Сообщение отредактировал Legis - 30.10.2008, 19:45
Kefir.net
сообщение 30.10.2008, 20:08
Из: Беларусь, Могилёв
Пользователь №: 118 873
Модель телефона: L9 / RAZR² V8
Прошивка: .22.07R/LMFusion3
Да нет, судя по описанию, кутопия тут будет та же..Просто запустить её можно будет из соответствующего пункта меню..вот и всё..Неинтересно..
Что-то подобное уже есть, один из pep пакетов..
Сообщение отредактировал Kefir.net - 30.10.2008, 20:12
Abram
сообщение 30.10.2008, 20:14
Прелесть какая гадость
Из: .ru - рідна Україна
Пользователь №: 44 825
Прошивка: CyanogenMod
Да, кутопия там та же, моя сборка. Ничего интересного. Как не работало, так и не работает, Рас у меня о ней спрашивал на днях.
tdktdk
сообщение 31.10.2008, 8:44
Пользователь №: 138 821
Модель телефона: Motorola V8 (512Mb)
Прошивка: LinuxMod5
Все работает как следует?
Можно ли набора номера до тех пор, пока я Qtopia?
Legis
сообщение 31.10.2008, 9:47
Из: Питер
Прошивка: Home Base
tdktdk,
Abram
сообщение 31.10.2008, 10:28
Legis,
Что же ты говоришь, что можно звонить?..
Legis
сообщение 31.10.2008, 15:08
Из: Питер
Прошивка: Home Base
ShinG0
сообщение 31.10.2008, 17:24
Из: България, София
Пользователь №: 172 885
Прошивка: .46R+Custom
QUOTE(Legis @ 31.10.2008, 9:47) *
tdktdk,
Works perfectly what?
You can play music files with Qtopia? You can play video files with Qtopia? You can play java games with Qtopia? You can make calls with Qtopia?
This is just mod with Qtopia build-in. But this Qtopia is only for presentation (without any options to emulate sound, or install java games, or play video, or make calls).
That's it.
Kefir.net
сообщение 31.10.2008, 17:42
Yes, you are right. The only advantage of this mod is more simple way to run Qtopia. Thats all!
andrey_moto
сообщение 31.10.2008, 17:58
Из: minsk
Прошивка: E1®dar15
peverell
н-дааа, тогда не пойму в чем смысл? Это же уже было! Если не ошибаюсь ее можно было даже при помощи скрипта запустить. ОБЪЯСНИТЕ СМЫСЛ ВСЕГО ЭТОГО!
Kefir.net
сообщение 31.10.2008, 18:06
D-Prime
сообщение 31.10.2008, 19:48
Пользователь №: 176 838
Модель телефона: Z6, E398
Прошивка: У вас такой нет
Kefir.net, наверно чтоб ленивые не "парились" со скриптами... Может распутину надоели вопросы "Как? куда? чем?" вот он и сделал laugh.gif
Kefir.net
сообщение 31.10.2008, 20:15
Так если бы с неё толк был...а так она пока только "на посмотреть"..
NPman
сообщение 31.10.2008, 20:29
Из: Oren
Пользователь №: 141 260
Прошивка: 2.1
Абрам уже давно её дал посмотреть..
Legis
сообщение 31.10.2008, 20:44
Из: Питер
Прошивка: Home Base
That's it.
I simply misunderstood the question: thought that work of mod in general is meant, not just Qtopia, sorry
Добавлено позже (1.11.2008, 0:49):
смысл есть, хотя бы это: для 512 мб поправлен баг с мплеером, новая версия проши, ну и для ленивых кьютопияsmile.gif
rasputin007
сообщение 2.11.2008, 23:04
Из: UK
Пользователь №: 184 705
Модель телефона: RAZR2 V8
Прошивка: Nothing for too long
QUOTE(Kefir.net @ 31.10.2008, 17:42) *
Exactly!
People hear about Qtopia, but do not know what it looks like. Now they can see for themself.
That is all I wanted.
Now everybody can have a look at this Qtopia, running on top a V8 firmware, and decide if they like what they see or not.
Linux is about the freedom to choose, but how can you choose if there is no alternative?
I am aware that Qtopia is not fully working with Motorola Linux phones and I would love to change this, but my Linux skills do NOT reach that level. I am not a programmer.
Точно!
Люди узнали о Qtopia, но не знаю, что он выглядит. Теперь они могут увидеть себя.
Это все, что я хотел.
Теперь каждый может посмотреть на эту Qtopia, бег на вершине V8 микропрограммы, и решить, если им нравится то, что они видят, или нет.
Linux идет о свободе выбора, но как вы можете выбирать, если нет альтернативы?
Я отдаю себе отчет в том, что Qtopia не в полной мере сотрудничает с Motorola Linux телефоны, и я хотели бы изменить это, но мой Linux навыки не достигают этого уровня. Я не программист.
anhvu2875
сообщение 4.11.2008, 1:57
Пользователь №: 152 593
rasputin007
Qtopia will be developed in V8 completely , hope so ! smile.gif smile.gif smile.gif clap.gif biggrin.gif
Kefir.net
сообщение 4.11.2008, 9:33
How it can be done?..
BeZ
сообщение 4.11.2008, 9:39
Moto(sh)Coder
Пользователь №: 743
похоже тут кто-токого-то не понял.....
Abram
сообщение 4.11.2008, 15:44
BeZ,
Тут кто-то наивно надеется, что Qtopia заработает, стоит лишь поправить какой-то секретный конфиг или помолиться Аннунаху.
BeZ
сообщение 4.11.2008, 17:51
Moto(sh)Coder
Пользователь №: 743
Abram,
вротмненоги, жду секретного конфига от Аннунаха laugh.gif clap.gif laugh.gif
rasputin007
сообщение 6.11.2008, 22:42
Из: UK
QUOTE(anhvu2875 @ 4.11.2008, 1:57) *
rasputin007
Just learning Qtopia image creation and my brain is already close to overload. shades.gif
miccca
сообщение 28.11.2008, 12:26
Пользователь №: 146 928
Модель телефона: Motorola V8 2Gb
Прошивка: R601_G_80.56.15R
а что такое собственно кютопия?
Котенок™
сообщение 28.11.2008, 12:50
Пользователь №: 155 008
Прошивка: 4.2.2 / 4.0.4
10 лет под знаком "М"
miccca, а что такое собственно google?
miccca
сообщение 29.11.2008, 18:54
to Котенок™ ваууу как круто зашутила!!! ты не дочь жванецкого? можно подумать ты когдато чего то незнала а хотела узнать , и вопрос этот я задал потому как нигде не нашёл на форуме про кютопию
Abram
сообщение 29.11.2008, 18:58
miccca,
Во-первых, Котенок™ - это парень. Во-вторых, justgoogleit!
Qtopia-LM5, new rasputin007's mod · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 12.9.2025, 14:21
