Доброго времени суток, господа.
Обновился вот до 8.10 в надежде, что моя Моторола Z6 будет нормально работать с ней, т.к. ядро посвежее все таки и заявлена поддержка этого телефона. Да не тут то было. "Переход" - "Устройство USB" вываливает такую ошибку:
Cannot invoke CheckForMedia on HAL: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken
Дистриб последний 8.10 Intrepid Ibex
# uname -a
Linux silver-laptop 2.6.27-7-generic #1 SMP Thu Oct 30 04:18:38 UTC 2008 i686 GNU/Linux
# lsusb
Bus 005 Device 008: ID 22b8:6426 Motorola PCS
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 002: ID 062a:0000 Creative Labs Optical mouse
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
# dmesg | tail
[ 1516.533688] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1516.538352] sd 6:0:0:0: [sdb] 3987208 512-byte hardware sectors (2041 MB)
[ 1516.540313] sd 6:0:0:0: [sdb] Write Protect is off
[ 1516.540321] sd 6:0:0:0: [sdb] Mode Sense: 03 00 00 00
[ 1516.540324] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1516.543213] sdb:
[ 1546.688080] usb 5-1: reset high speed USB device using ehci_hcd and address 8
[ 1546.839807] sd 6:0:0:0: [sdb] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK,SUGGEST_RETRY
[ 1546.839821] end_request: I/O error, dev sdb, sector 3987072
[ 1546.839828] Buffer I/O error on device sdb, logical block 49838
Кто-то может помочь в этой проблеме?
# uname -a
# lsusb
# dmesg | tail
[ 1516.543213] sdb:
