ilove3d 141CR full unsigned (NO RSA)
Arch0n
сообщение 6.1.2009, 21:41
Пользователь №: 141 493
Модель телефона: rokr E8
difference between 0207 magicX:
usb storage mode bug fixed
added mgs skins click & installation
higer priority for autorun scripts
support much easier theme setup , no need to care about svg files or reboot
flashing steps:
1. kill rsa bootloader
(for version >>06.A3 ONLY<< )(created by dimichxp & yakk). if your phone is Engineering one, skip
2. flash this f/w
3. flash any language pack if you prefer another language other than English or Chinese
kernel mods:
disabled moto_secure modules
enabled swap support
autorun scripts:
1 first scripts ( for SOS usage :-) )
/mmc/mmca1/first.txt
/mmc/movinand1/first.txt
2 custom fonts ( unrecognizable files )
/mmc/movinand1/unKnown/myfont.ttf
/mmc/movinand1/unKnown/mynum.ttf
3 common autorun scripts
/ezxlocal/autorun.txt
/mmc/mmca1/autorun/S??* (TF card root)
/mmc/movinand1/unKnown/S??* ( unrecognizable files )
click & play:
.lin .sh executable programs
almost all type of archive files
.mgx third party programs pack
.mgs third party skins pack
( .mgx .mgs structure see other doc. )
programs in office-tools:
mpkgbox
handles mgx programs installed in your phone
easy themes
bundled with default themesetup, users no need care about what's this
installing skins by your hands:
mystuff/skins/:
create a skin dir, without space or non-English name
put in your traditional skin files like iconres.ezx and others
create svg folder in your skin folder, put in your flow files, eg. xxx.svg
Скачать:
http://tab.net.ua/sites/files/site_name.arch0n/id.92045/
http://upload.com.ua/get/900632177/
http://depositfiles.com/files/csgajc47n
http://www.rapidshare.ru/880375
Если у вас 14.1CR_A с подписанной CG52:
также, заменён ленгпак на 02ЕЕ, включающий необходимые нам языки.
http://tab.net.ua/sites/files/site_name.arch0n/id.92044/
http://www.rapidshare.ru/883433
http://fileshare.in.ua/1758940
http://upload.com.ua/get/900637657/
Сообщение отредактировал Arch0n - 17.1.2009, 16:18
Arch0n   ilove3d 141CR full unsigned (NO RSA)   6.1.2009, 21:41
jon_83   кто ставил отпишитесь стоит или нет ставить эту пр...   7.1.2009, 5:23
Sem4ik   сверху официальной ставится? и вообще по русски мо...   7.1.2009, 8:31
Bogd@n   прошивка ставится только на телефону с убраной РС...   7.1.2009, 8:49
siber 777   поверх 07 й можно шить или надо разбирать с замено...   7.1.2009, 10:25
jon_83   ну так результаты какие стоит ставить или нет???? ...   7.1.2009, 12:55
Splash.666   Интересует следующее: Можно ли шить, имея установл...   7.1.2009, 20:55
MixXxer   Интересует следующее: Можно ли шить, имея установ...   7.1.2009, 21:38
n0kul0   Интересует следующее: Можно ли шить, имея установ...   8.1.2009, 9:13
Splash.666   У меня после обновления через MSU бут остался тако...   8.1.2009, 11:35
MixXxer   У меня после обновления через MSU бут остался так...   8.1.2009, 13:45
siber 777   а чем патчить? рсд лайт? Добавлено позже (8.1.20...   8.1.2009, 12:18
TRUE   НА Офф НЕ РАБОТАЕТ(((9пишет НОУ РСА и куча ошибок(...   8.1.2009, 16:08
klaraivanovna   Чего вы Муму мучаете! Пристали к бедному буту...   8.1.2009, 17:06
Arch0n   По-идее так и должно быть, но у меня почему-то от ...   8.1.2009, 17:12
zidane   Arch0n, +1.. тоже самое..=(   8.1.2009, 17:14
TRUE   дело такое, была официальная 1CR, прошил E8_06A3_K...   8.1.2009, 17:15
klaraivanovna   Arch0n, а с пропаченного бута неслазил если от 07...   8.1.2009, 17:28
@SEM*   Интерессная темка. Но ввиду риска замены бута ( на...   9.1.2009, 11:50
metallsatanist   встала нормально (до этого была 07.02)   9.1.2009, 13:00
zidane   похоже она не ставиться только у тех, кто прошивал...   9.1.2009, 13:08
siber 777   встала нормально тока она без русского лэнга, поме...   9.1.2009, 14:02
zidane   siber 777, до этого какая прошивка стояла?   9.1.2009, 14:05
Okhotnik   Встала нормально. Ставил на 02.07R Magic_X. Ленг п...   9.1.2009, 15:16
siber 777   была 07r, имхо что если пропатчить то без разниц...   9.1.2009, 18:05
zidane   siber 777, да не без разницы.. читай тут пост№83   9.1.2009, 18:10
siber 777   zidane, эту тему я читал так там про бут пишут а н...   9.1.2009, 18:13
zidane   siber 777, нет еще..завтра попробую..   9.1.2009, 18:26
siber 777   а проша сама гуд все как обещали мпкгбокс скины мо...   9.1.2009, 18:27
zidane   от ленга в мпкгбокс скриптах язык не поменяется...   9.1.2009, 18:31
klaraivanovna   zidane, проша неставится -дело в буте ! Насче...   9.1.2009, 18:35
zidane   zidane, проша неставится -дело в буте ! нез...   9.1.2009, 18:45
siber 777   да скрипты хрен с ними я читал можно любые постави...   9.1.2009, 18:55
yakk   Для тех кто успел постаавить полную 1CR_A - обсужд...   9.1.2009, 19:26
TRUE   Для тех кто успел постаавить полную 1CR_A - обсуж...   10.1.2009, 12:18
Arch0n   Добавил: Версию для телефоном, с прежде стоявшей 1...   9.1.2009, 21:23
@SEM*   Arch0n тогда по идее если у меня проша с неподписа...   9.1.2009, 21:38
siber 777   Arch0n тогда по идее если у меня проша с неподпис...   10.1.2009, 9:28
Arch0n   Сначала бут, а потом то, что находится под надпись...   9.1.2009, 22:09
E2008   выложите пожалуйста русский лэнг на эту прошу в sb...   10.1.2009, 13:22
Bogd@n   карта РСА подписей   10.1.2009, 13:48
TRUE   карта РСА подписей а я зыковой пакет какая груп...   10.1.2009, 19:21
Льоша   а если я уже скачал прошивку с цг31 а у меня 71.14...   10.1.2009, 14:42
siber 777   Льоша,юзай прогу рекалк и читай темы сборка разбор...   10.1.2009, 15:00
Льоша   Льоша,юзай прогу рекалк и читай темы сборка разбо...   10.1.2009, 16:36
Arch0n   46.   10.1.2009, 19:33
TRUE   попытался собрать эту прошу с цг31 и цг 52 от офиц...   10.1.2009, 20:02
Arch0n   Не забыл перед тем, как сделал ReCalc Checksum, по...   10.1.2009, 20:06
TRUE   не ставил, а я и не знал.. методом тыка делал( До...   10.1.2009, 20:23
siber 777   Спасибо!! Поюзал прогу,собрал,прошил-все ...   10.1.2009, 20:54
Льоша   , увеличил своп при помощи своп мем на 64мб, а к...   11.1.2009, 14:15
Sem4ik   держи в архиве есть файл S01swap.txt его скопируе...   11.1.2009, 16:18
-=WEST=-   мне кажется все ето самовнушение. телефон как тор...   11.1.2009, 16:32
Sereg_K   Народ, кто прошивался, отписывайтесь плз о впечатл...   12.1.2009, 8:43
E2008   выложите пожалуйста русский лэнг в sbf формате...   11.1.2009, 16:09
Arch0n   Многозадачность жавы, нативный плеер и т.п. - тепе...   11.1.2009, 16:38
Bogd@n   это можно было делать и до того как рса была.... ...   11.1.2009, 17:31
Abram   Arch0n, Угу. Не стоит ничего на пути - так давай,...   11.1.2009, 23:46
Arch0n   Я сам не против помочь, но 1. Из-за учёбы мало вре...   12.1.2009, 7:41
Abram   Arch0n, "Я ездил на велосипеде, могу вам пом...   12.1.2009, 19:15
TRUE   че вы переживаете? китайцы вам наделают нативных п...   12.1.2009, 19:34
Abram   TRUE, Угу. Вон для Z6 я SDK выложил - много насып...   12.1.2009, 19:55
TRUE   TRUE, Угу. Вон для Z6 я SDK выложил - много насы...   13.1.2009, 18:10
-=WEST=-   это лишь начало я уверен Пробовал ставить на пат...   14.1.2009, 22:22
E2008   прошил этой прошей Е8 теперь не включаеться пишет ...   12.1.2009, 20:05
~Oleg~   E2008, Ну если у тебя снята рса то прошей той прош...   13.1.2009, 1:52
E2008   E2008, Ну если у тебя снята рса то прошей той про...   13.1.2009, 4:35
Abram   И где ж это ты патч на 06.А9 нашел? Или ты патч д...   15.1.2009, 0:06
-=WEST=-   И где ж это ты патч на 06.А9 нашел? Или ты патч д...   15.1.2009, 1:01
Abram   -=WEST=-, О, так я слоу bigsmile;. Надо, видимо, ...   15.1.2009, 1:37
yakk   -=WEST=-, про эту прошу я уже не раз писал что она...   15.1.2009, 3:28
-=WEST=-   -=WEST=-, про эту прошу я уже не раз писал что он...   15.1.2009, 10:43
yakk   я все пробовал из со своим 31 и вообще без него, ...   15.1.2009, 11:30
-=WEST=-   Попробуй вообще не опираться на ту прошивку что з...   15.1.2009, 13:45
Arch0n   Возможно неправильно собрал. Перед ReCalc Checksum...   15.1.2009, 13:50
-=WEST=-   Возможно неправильно собрал. Перед ReCalc Checksu...   15.1.2009, 13:55
yakk   -=WEST=- прошей поверх работающей прошивки только ...   15.1.2009, 14:44
-=WEST=-   -=WEST=- прошей поверх работающей прошивки только...   15.1.2009, 14:56
yakk   cg36 - корневая файловая система, рано или поздно ...   15.1.2009, 15:18
dan47   :helpsmilie: Народ,у меня 07R ilove3d c RSA и бут...   16.1.2009, 8:19
@SEM*   Arch0n а если я просто новый прошью бут ( кстати...   16.1.2009, 12:13
-=WEST=-   P.S.3 Если не будет проверки RSA то по идее можно...   16.1.2009, 15:53
Bogd@n   да Разработка софта под MOTOMAGX   16.1.2009, 15:18
dan47   Народ,у меня 07R ilove3d c RSA и бут 06.A3 что ...   16.1.2009, 16:15
antonuch   так что особенного в прошивке, кто скажет?так и не...   16.1.2009, 21:50
Abram   Получать от меня -5 за дубль поста. bigsmile;   17.1.2009, 2:55
andrey_moto   у всех нормально скачался архив спрошивкой? у меня...   17.1.2009, 14:44
Kisiller   я поставил себе "Прошивка R6713_G_71.14.1CR_A...   18.1.2009, 16:02
klaraivanovna   Kisiller, можеш ! а можеш и не заморачиватся...   18.1.2009, 16:13
@SEM*   Вобщем прошивку китайскую не качал. Попробую щас т...   20.1.2009, 12:35
-=WEST=-   Просто походу только на буте без RSA будет работа...   20.1.2009, 13:08
@SEM*   Вобщем прошил я этот бут на "1CR_A с CG31 от ...   20.1.2009, 14:20
E2008   Вобщем прошил я этот бут на "1CR_A с CG31 от...   20.1.2009, 16:16
Льоша   Вобщем прошил я этот бут на "1CR_A с CG31 от...   20.1.2009, 18:23
Bogd@n   в этой прошивке ядро стандартное,не патченое   20.1.2009, 15:41
Йа Санёг   Свап на скорость работы самого телефона (перемещен...   20.1.2009, 19:51
-=WEST=-   Свап на скорость работы самого телефона (перемеще...   21.1.2009, 13:32
zidane   выложите плиз файлы папки /ezxlocal/download/mystu...   21.1.2009, 5:35
Cj-7   у меня проша R6713_G_71.14.1CR_A ( с неподписаной ...   21.1.2009, 14:27
Bogd@n   помоему кг35   21.1.2009, 15:09
4 страниц V  1 2 3 > »
ilove3d 141CR full unsigned (NO RSA) · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 15.9.2025, 1:54
