9 страниц V  1 2 3 > »
ilove3d 141CR full unsigned (NO RSA)
Arch0n
сообщение 6.1.2009, 21:41
Пользователь №: 141 493
Модель телефона: rokr E8
difference between 0207 magicX:
usb storage mode bug fixed
added mgs skins click & installation
higer priority for autorun scripts
support much easier theme setup , no need to care about svg files or reboot
flashing steps:
1. kill rsa bootloader
(for version >>06.A3 ONLY<< )(created by dimichxp & yakk). if your phone is Engineering one, skip
2. flash this f/w
3. flash any language pack if you prefer another language other than English or Chinese
kernel mods:
disabled moto_secure modules
enabled swap support
autorun scripts:
1 first scripts ( for SOS usage :-) )
/mmc/mmca1/first.txt
/mmc/movinand1/first.txt
2 custom fonts ( unrecognizable files )
/mmc/movinand1/unKnown/myfont.ttf
/mmc/movinand1/unKnown/mynum.ttf
3 common autorun scripts
/ezxlocal/autorun.txt
/mmc/mmca1/autorun/S??* (TF card root)
/mmc/movinand1/unKnown/S??* ( unrecognizable files )
click & play:
.lin .sh executable programs
almost all type of archive files
.mgx third party programs pack
.mgs third party skins pack
( .mgx .mgs structure see other doc. )
programs in office-tools:
mpkgbox
handles mgx programs installed in your phone
easy themes
bundled with default themesetup, users no need care about what's this
installing skins by your hands:
mystuff/skins/:
create a skin dir, without space or non-English name
put in your traditional skin files like iconres.ezx and others
create svg folder in your skin folder, put in your flow files, eg. xxx.svg
Скачать:
http://tab.net.ua/sites/files/site_name.arch0n/id.92045/
http://upload.com.ua/get/900632177/
http://depositfiles.com/files/csgajc47n
http://www.rapidshare.ru/880375
Если у вас 14.1CR_A с подписанной CG52:
также, заменён ленгпак на 02ЕЕ, включающий необходимые нам языки.
http://tab.net.ua/sites/files/site_name.arch0n/id.92044/
http://www.rapidshare.ru/883433
http://fileshare.in.ua/1758940
http://upload.com.ua/get/900637657/
Сообщение отредактировал Arch0n - 17.1.2009, 16:18
jon_83
сообщение 7.1.2009, 5:23
Из: Воронеж
Пользователь №: 113 889
Модель телефона: maxx V6,ROKR E8
Прошивка: 9B.COR
кто ставил отпишитесь стоит или нет ставить эту прошивку у меня R6713_G_71.14.1CR_A boot 06.a3
Сообщение отредактировал jon_83 - 7.1.2009, 6:20
Sem4ik
сообщение 7.1.2009, 8:31
Из: Таганрог
Пользователь №: 179 823
Модель телефона: Charm (MB502)
Прошивка: 14
сверху официальной ставится? и вообще по русски можно?
сообщение 7.1.2009, 8:49
прошивка ставится только на телефону с убраной РСА.А рса убрано только на одном буте.Тут не важно какая прошивка,тут важно какой бут ,иначе,поставив патч не на тот бут вы получите труп.
siber 777
сообщение 7.1.2009, 10:25
Пользователь №: 187 441
Модель телефона: motorokr e8
поверх 07 й можно шить или надо разбирать с заменой групп 31
Сообщение отредактировал siber 777 - 7.1.2009, 10:31
jon_83
сообщение 7.1.2009, 12:55
Из: Воронеж
Прошивка: 9B.COR
ну так результаты какие стоит ставить или нет???? а то в соседней теме написано что не работает(может я не так понял конечно)
Splash.666
сообщение 7.1.2009, 20:55
Пользователь №: 43 036
Модель телефона: iPhone 3Gs 16Gb
Прошивка: 4.0
Интересует следующее: Можно ли шить, имея установленную оффициальную 1CR из MSU с бутом 06.a3 и пропатченой RSA?
MixXxer
сообщение 7.1.2009, 21:38
Из: Беларусь
Пользователь №: 106 007
Модель телефона: MotoROKR E8
так вот это "kill rsa bootloader (created by dimichxp & yakk). if your phone is Engineering one, skip" как раз и значит, что рса обязательно должна быть пропатчена
n0kul0
сообщение 8.1.2009, 9:13
Пользователь №: 111 249
Модель телефона: Motorola E8+4gb
Прошивка: Z-Mod E8 rev.2.1.0
Поделись, если не сложно, как ты пропатчил RSA после прошивки официальной 1CR_A... Можно в личку)
Splash.666
сообщение 8.1.2009, 11:35
Прошивка: 4.0
У меня после обновления через MSU бут остался такой же. Не изменился.
MixXxer, я по твоему читать не умею? Вопрос другой был - можно ли это шить на ОФФ прошивку 1CR?
siber 777
сообщение 8.1.2009, 12:18
а чем патчить? рсд лайт?
Добавлено позже (8.1.2009, 12:29):
бут надо патчить, сам патч есть в этом же архиве,только патч на 06а3 бут!!!,на другие буты будет труп телефона!!!! smile.gif, попробую шить если ленг найду тк я понял проша без русского
Сообщение отредактировал siber 777 - 8.1.2009, 12:37
MixXxer
сообщение 8.1.2009, 13:45
Из: Беларусь
во всяком случае можно попробывать прошить) а вообще думаю что можно.
TRUE
сообщение 8.1.2009, 16:08
Из: Тюмень
Пользователь №: 146 455
Модель телефона: Е8
Прошивка: какая есть
Добавлено позже (8.1.2009, 21:34):
похоже дело в монстре самом потому что я прошил родную 1цр в буте пишет ноу рса а прошивка запускается
klaraivanovna
сообщение 8.1.2009, 17:06
Пользователь №: 185 158
Модель телефона: Droid Maxx
Чего вы Муму мучаете! Пристали к бедному буту! mad.gif Сборка пойдет на младших бутах тем кому повезло и стоит у них 06.A9 бут пока не видать этого монстра в лучшем положении те у каго бут 06.А3 насколько я понял нужно его пропачить и ставить другой неподписаный проблем меньше и ставить что угодно можно . Поправте если неправ! shuffle.gif
Arch0n
сообщение 8.1.2009, 17:12
По-идее так и должно быть, но у меня почему-то от этого патча толку 0. Только в буте надпись другая, но телефон после прошивки этим релизом или, например, 07Р, только выдаёт эрроры. Отписывался об этом в соседней теме.
zidane
сообщение 8.1.2009, 17:14
Пользователь №: 136 304
Модель телефона: ve66
Arch0n, +1.. тоже самое..=(
TRUE
сообщение 8.1.2009, 17:15
Из: Тюмень
Модель телефона: Е8
дело такое, была официальная 1CR, прошил E8_06A3_KILL_RSA_unsigned.sbf РСА снялся, но сама прошивка ilove3d_141CR_unsigned.sbf не запускается в буте пишется куча ошибок, прошил я снова на оффициальную, все работает, в буте пишет: NO RSA. в чем дело не кто не знает?
klaraivanovna
сообщение 8.1.2009, 17:28
Arch0n,
а с пропаченного бута неслазил если от 07 поставить ? Я вот имею счастье общения с бутом 06.A9 поэтому и не рыпаюсь. Но насколько я понял делать надо так пачиш бут и слазиш с него на другой!
Оговорюсь! Особенно новиньким ! Прежде чем с бутом колдовать 10 РАЗ надо подумать !!!!! Все подобные манипуляции могут привести к смерти тела!!!
Сообщение отредактировал klaraivanovna - 9.1.2009, 14:20
@SEM*
сообщение 9.1.2009, 11:50
(M)LuckyMan
Из: Earth
Пользователь №: 126 920
Прошивка: Android 11 & 14
Интерессная темка. Но ввиду риска замены бута ( надеюсь что то что написал klaraivanovna уберёт RSA ) я пока подожду, пока и так функционала хватает.
сообщение 9.1.2009, 13:00
встала нормально (до этого была 07.02)
zidane
сообщение 9.1.2009, 13:08
похоже она не ставиться только у тех, кто прошивал 1CR_А...
siber 777
сообщение 9.1.2009, 14:02
встала нормально тока она без русского лэнга, поменял лэнг все нормально только скрипт русский в треках не понимает sad.gif
Сообщение отредактировал siber 777 - 9.1.2009, 14:03
zidane
сообщение 9.1.2009, 14:05
siber 777, до этого какая прошивка стояла?
Okhotnik
сообщение 9.1.2009, 15:16
Пользователь №: 187 583
Модель телефона: E8
Прошивка: 1CR_A MagicX
Встала нормально. Ставил на 02.07R Magic_X. Ленг поставил от 02.07R.
siber 777
сообщение 9.1.2009, 18:05
была 07r, имхо что если пропатчить то без разницы какая была smile.gif шил https://motofan.ru/soft/ РСД lite 4.4.1
zidane
сообщение 9.1.2009, 18:10
siber 777, да не без разницы.. читай тут пост№83
siber 777
сообщение 9.1.2009, 18:13
zidane, эту тему я читал так там про бут пишут а не про прошивку или ты имеешь ввиду подписанную 52 ю группу?
Добавлено позже (9.1.2009, 18:20):
zidane а то что советовали пробовал?
Добавлено позже (9.1.2009, 18:25):
а что со скриптами может лэнг надо взять от 07r?
Сообщение отредактировал siber 777 - 9.1.2009, 18:15
zidane
сообщение 9.1.2009, 18:26
siber 777, нет еще..завтра попробую..
siber 777
сообщение 9.1.2009, 18:27
а проша сама гуд все как обещали мпкгбокс скины мона прям на флэху кидать и тд пока все не распробовал, буду пробовать лэнг от 07й
Сообщение отредактировал siber 777 - 9.1.2009, 18:30
zidane
сообщение 9.1.2009, 18:31
от ленга в мпкгбокс скриптах язык не поменяется...
klaraivanovna
сообщение 9.1.2009, 18:35
zidane,
проша неставится -дело в буте ! Насчет русского переведи сам прогу у мпкгбокс есть перевод почитай тут 1x.xxR umagx by ilove3d
zidane
сообщение 9.1.2009, 18:45
Цитата(klaraivanovna @ 9.1.2009, 23:35) *
zidane,
Сообщение отредактировал zidane - 9.1.2009, 19:01
siber 777
сообщение 9.1.2009, 18:55
да скрипты хрен с ними я читал можно любые поставить, да ничего от смены лэнга не изменилось
yakk
сообщение 9.1.2009, 19:26
Из: Днепропетровск
Пользователь №: 90 408
Модель телефона: milestone
не нужен..
Для тех кто успел постаавить полную 1CR_A - обсуждаемая здесь прошивка не подойдет один в один на ваш телефон, т.к. в составе с ней идет cg31 с предыдущей security-версией, так же как не подойдет, прошивка с cg31 от 07R из соседней темы..
Хотя рса после патча бута обходится - телефон такую кодовую группу не примет.. самое простое что можно попробовать - залить прошивку с которой телефон нормально запускается (1CR_A или что нить еще), а затем прошить эту прошивку без cg31, или пересособранную со своим работающим cg31..
если у кого есть время, желание и способности - лучше, если патч на бут уже установлен и работает, - пробуйте самостоятельно пересобрать хотя бы простейшие цг - типа 52, шить их и смотреть как на это реагирует телефон..
ps: лучше, если кто может - попросите китайцев, чтобы не лепили такие вот сборки - где всё сразу включено - только лишние вопросы будут возникать с версиями цг wink.gif, ну или пусть хотя бы тестируют на всех возможных вариантах..
Сообщение отредактировал yakk - 10.1.2009, 3:47
Arch0n
сообщение 9.1.2009, 21:23
Добавил:
Версию для телефоном, с прежде стоявшей 14.1CR_A с подписанной CG52. Т.е. в ней заменена ЦГ31 и заодно ленг ЦГ46 на 02ЕЕ.
Ссылки в первом посте.
@SEM*
сообщение 9.1.2009, 21:38
(M)LuckyMan
Из: Earth
Arch0n тогда по идее если у меня проша с неподписанной CG52 то мне шить этот бут а потом прошу китайскую с замененной CG31 ( от 07R) и CG46 (лэнгпак). У меня бут 06A3
Arch0n
сообщение 9.1.2009, 22:09
Сначала бут, а потом то, что находится под надписью "Скачать:". Можно пересобрать и прошить сразу с новым ленгом или прошить его отдельно, это уже не имеет значения...
siber 777
сообщение 10.1.2009, 9:28
если шьешь поверх официальной 1cra то да, а если поверх 07й то надо только лэнг поменять
TRUE
сообщение 10.1.2009, 12:18
Из: Тюмень
Модель телефона: Е8
без cg31 цг31 за что отвечает?
E2008
сообщение 10.1.2009, 13:22
Из: г. Казань
Пользователь №: 165 980
Модель телефона: ROKR E8
Прошивка: Z-Mod E8 2.4.4
выложите пожалуйста русский лэнг на эту прошу в sbf формате
ilove3d 141CR full unsigned (NO RSA) · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 16.9.2025, 15:24
