Бекап телефонов на линуксе + новый sbf_recalc, скачать
mcandre
сообщение 14.1.2009, 13:51
Пользователь №: 123 452
Модель телефона: Atrix
позитивное!
Думаю, что все тут знают английский. Вроди, где-то уже такое видел на мотофане.
Part 1 - Back-Up Instructions;
1] Download the MM-Back-Up by Lucrece,
2] Download the Loader for your phone, Add the loader to the MM-Back-Up folder.
3] Connect your phone while it is already in bootloader mode!
(while off press & hold, * and # and power)
4] Select loader and the CG's you need/want backed up,
5] Press "Read",
Part 2 - CG Editing Instructions;
by krippler
If you want to use the CG37 and CG48 files returned from you phone,
just do the following before compiling the .sbf file.
Download a Hex Editor, any one will do you don't need to do anything fancy.
I used a freeware one available HERE.
1] Open CG37.smg
2] Jump to address: 947FFF (Note: This is a Hex value)
3] Delete all the entries after that one
4] Save the changes
5] Do the same thing with CG48.smg but jump to: 737FFF (Note: This is a Hex value)
6] After this the steps for creating a SBF file are detailed in posts above
IMPORTANT:
Make sure you only delete the values after the jump addresses,
If you delete the jump address you will end up with a corrupted flash.
Part 3 - Flash Compiling Instructions;
by InsecureSpike
Download SBF-Recalc 1.2.9
Before you make the .sbf Flash File you first need to get 2 more files,
these can ONLY be found in a STOCK FLASH FOR YOUR PHONE,
The flash making Guide is Split into 2 parts,
Part 1 - Obtaining the Missing Files
1] Open SBF-Recalc 1.2.9, and press Open Flash-File, and navigate to Stock Flash File for YOUR phone,
2] Now press Split Flash-File, all the CG's will be split from the Stock Flash, Close SBF-Recalc 1.2.9, Open.
3] Delete ALL the CG files, so you are left with .hmg & RAMDLD.smg
Part 2 - Making the Flash
1] Add all the CG files MMBackUp pulled from your phone, to the folder with the 2 new files in,
2] Next give ALL the files a name, MUST BE THE SAME NAME
Example;
my_phones_backup.hmg
my_phones_backupCG31.smg
my_phones_backupCG34.smg
my_phones_backupCG35.smg
my_phones_backupCG36.smg
my_phones_backupCG37.smg
my_phones_backupCG41.smg
my_phones_backupCG42.smg
my_phones_backupCG43.smg
my_phones_backupCG44.smg
my_phones_backupCG45.smg
my_phones_backupCG46.smg
my_phones_backupCG48.smg
my_phones_backupCG49.smg
my_phones_backupCG50.smg
my_phones_backupCG52.smg
my_phones_backupCG60.smg
my_phones_backupCG61.smg
my_phones_backupRAMDLD.smg
3] Open SBF-Recalc 1.2.9, and press Open CG-Folder,
4] Press the "Advanced" option, and tick "Caluclate All CG's New" & "Write New Descriptor",
5] Now press ReCal Checksum, once done,
6] Press Create SBF-File, this may take some time,
7] Once you get the Done message
8] Close SBF-Recalc 1.2.9, and flash the NEW file to your phone with the newest https://motofan.ru/soft/ РСД Lite.
Возможности нового sbf_recalc - вроди те же, но есть одна возможность для любителей программы Flash and Backup. Когда надо описать кодовые группы перед вычиткой какого-то нового телефона, программа их покажет.
Сообщение отредактировал mcandre - 14.1.2009, 13:52
Прикрепленный файл SBF_Recalc_1.2.9.rar   ( 751.95 килобайт ) Кол-во скачиваний: 231
Abram
сообщение 14.1.2009, 14:11
Прелесть какая гадость
Из: .ru - рідна Україна
Пользователь №: 44 825
Прошивка: CyanogenMod
По-моему, всем давно известно.
BeZ
сообщение 14.1.2009, 15:08
Moto(sh)Coder
Пользователь №: 743
а нафига оно вообще надо?
сделай бакап фалов и не парься
mcandre
сообщение 14.1.2009, 15:30
позитивное!
ну вычитать из телефона, например, яз пакет..
Abram
сообщение 15.1.2009, 0:19
mcandre,
Какой? Кому это нужно?
А считать ленг можно и в телнете.
mcandre
сообщение 15.1.2009, 8:02
позитивное!
ну, может, кому-то и нужно..
может, кто-то имеет редкий языковой пакет и хочет им поделится..
кстати, пробовал забекапить кодэгруппы своего V8_512. программа не читает 46, 49, 52 кодегруппы.
BeZ
сообщение 15.1.2009, 8:50
Moto(sh)Coder
Пользователь №: 743
mcandre,
поэтому нафиг оно и не надо
mcandre
сообщение 15.1.2009, 11:10
позитивное!
Ну, хотя бы SBF_Recalc_1.2.9 новый.
BeZ
сообщение 15.1.2009, 11:11
Moto(sh)Coder
Пользователь №: 743
mcandre,
Soshok
сообщение 4.2.2009, 17:33
Из: Борисполь
Пользователь №: 135 561
Модель телефона: Z6 'n' U9
Прошивка: 44R and OER
mcandre, мне прога выдаёт sorry, can't insert additional CG's...
Error CG's to long...
чё делать?
mardariy
сообщение 4.2.2009, 18:01
Пользователь №: 22 440
чё делать?
читать вот это
1] Open CG37.smg
4] Save the changes
IMPORTANT:
ВНИМАТЕЛЬНО!) а вообще их можно заменить кг37 и 48 выдранными из любой прошивки для вашего телефонабони не отличаются,разве что маркировками по флексам... это userfs и mass_storage
Бекап телефонов на линуксе + новый sbf_recalc, скачать · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 13.9.2025, 7:28
