4 страниц V « < 2 3 4
Прошивка Evolution 3, V8
abelenki
сообщение 22.1.2009, 9:07 Закрепленное сообщение!
Из: Russia, Perm
Пользователь №: 94 097
This is the NO_RSA Evolution 3 firmware, which is an updated version of Evolution 2 with Snesx.
The changes are:
new "System Management" submenu under Tweaks which includes
- Swap Memory, so you can add extra physical memory to your V8, so the V8 does not have to unload stuff and load new stuff into RAM memory, it can now use a certain size of the User Memory (512MB V8) or the 2GB memory (2GB V8) to store memory loaded stuff. It should make the V8 perform faster under heavy multi tasking. Just click the menu, select the swap memory size you want to use and wait, then press the menu again and it will offer the option to activate the swap memory, do that. Once the swap memory is setup it will be always there, unless you delete it of course, but it needs to be activated after every reboot. You can check the status of this swap memory with
-System Info, which will display the currently used memory and swap memory with adjustable refresh circles.
-Phone Firewall is an application that can be used to block certain phone numbers and there is the option to block unkown numbers as well, perfect if you want to setup the phone for your kids.
In the "Utilities" submenu there are 3 new menus
- Arcman, looks like zLauncher, but is for archiving file and folders as well as unpacking compressed files, the MPlayer.rar file that is included unpacks perfectly, which brings me to another point. MPlayer had to be removed from automatic installation because it just took too much space. Now 2GB V8 should already have it in place as the 2GB memory does not get wiped when flashing a complete firmware. The 512MB V8 however needs to have the MPlayer.rar file copied into /ezxlocal/download/mystuff/Programms (note the 2m's!! in Programms as there is another Programs folder), then use Arcman to Extract->Extract Here and reboot, now MPlayer will be working on the 512MB V8. 2GB V8's that do not have a "Programms" folder in /mmc/mmca1, have to create one and use the same method.
-Cronometer is like a stopwatch, but you also can take times for certain stages (Mark button)
-V8 Screenshots lets you take screenshots of any menu and store them on the V8, you can adjust the number of screenshots to be taken, the timing when they will be taken and where you want to store them, User Memory (512MB V8 and 2GB V8) and 2GB memory (2GB V8 only). Once you have taken some screenshots, you have to rename the screenshot files with zLauncher or they will be overwritten the next time you take screenshots again. you can find them in /ezxlocal/download/mystuff/snapshot and /mmc/mmca1/snapshot.
The zLauncher got updated as well and works now as a TextViewer as well, but you also can edit existing and opened text files, but you also can edit scripts, sh files, and save them. Because of the much more powerfull potential that zLauncher posses, it has been password protected (password: 1234), you can of course change that password to whatever you like. This way only the person/persons that know the password can have total access to the filesystem. For example you can create a new folder in the User Memory or the 2GB memory and call it .whatever, now if you add the "dot" in front of the name then File Manager will not be able to see this folder, but zLauncher will be. So you can have a "hidden" folder in which you can save/store stuff that is not meant to be seen by everybody and because zLauncher is password protected you are the only one that has access to it. I tried the ZHidenFolder mod, which basically does the same, but because zLauncher still can see those "hidden" folders there was not much point in using that HiddenFolder mod. Also FTP programs like FileZilla can see those "dot"name folders.
You can change the language of Cronometer and Phone Firewall, but not through the app menu, that somehow does not work. But if you look at /ezxlocal/download/mystuff/apps/language/English, open that with wordpad and change the words of the right hand side to the words of your language and save it as "Italian" or whatever, then you can change the cfg files for Cronometer and Phone Firewall to use your language.
A very big THANK YOU has to go to all those people that made those Z6 mods, without their work our V8 would be less interesting, also I have to thank DaRk_dOg for his tireless help to get this up and running and his help in testing the 512MB version, this thanks also has to go to Protector who tested the 2GB version.
This typical, I just have decided to release Evo 3 and along comes a very useful mod (thanks to DaRk_dOg) which really would finish off the Evo 3 firmware. This Mod can be found under the System Management and is called CPU Frequency. Well as the name says you can adjust the MHz frequency of the CPU.
Автор:
rasputin007
Оригинальный топик:
modmymoto.com
Порядок прошивания:
1. Bootloader A3.CF (если у вас какой-либо другой бутлоадер).
2. Bootloader A3.CF No RSA.
3. Прошивка Evolution 3 (прошивайте версию прошивки, соответствующую вашей модели телефона - 512MB или 2GB. Для Luxury Edition прошивайте версию 2GB).
4. Чтобы установить русский лэнгпак, копируем содержимое архива с LP002EE в /ezxlocal/download/mystuff/apps/language/.
Файлы:
Bootloader A3.CF
512MB Evolution 3, 512MB Evolution 3 Video Update (исправлена функция Reset и добавлена съёмка видео в 288x352)
2GB Evolution 3, 2GB Evolution 3 Video Update (исправлена функция Reset и добавлена съёмка видео в 288x352)
LP002EE - UK English, German, Russian, Ukrainian, French, Spanish, Portuguese; Russian voice commands only
MPlayer
Evolution 3 User Guide
Language Guide
V8 Modding Guide
Сообщение отредактировал abelenki - 25.8.2009, 8:51
Serger75
сообщение 17.11.2009, 9:14
Пользователь №: 69 755
Модель телефона: RAZR
Походу, его-будильник после перезагрузки тела нужно выкл. затем вкл. - работает. Чтобы окончательно проверить, настрой второй будильник на вкл. через пару минут, если гуд, то и второй утром сработает.
P.S. Пока мне надоели все моды, откатился на прошивку "без брендов".
Vermin
сообщение 18.11.2009, 8:32
Пользователь №: 64 122
Модель телефона: V635; V8
Прошивка: Своя; Basic Plus
Цитата(KoJIoBASS @ 17.11.2009, 14:20) *
У кого-нибудь были проблемы с будильником на этой прошивке?
Вчера прошился, сегодня с утра будильник не зазвонил, на рабочем столе уведомление о будильнике осталось.
А прочтика, дружочек тему от начала и до конца, глядишь и найдешь ответ на свой вопрос. Одно могу сказать, будильник тут работает.
KoJIoBASS
сообщение 19.11.2009, 10:26
Пользователь №: 174 352
Модель телефона: RAZR 2 V8 2Gb
Прошивка: Fusion 3
В общем, на следующий день сработал, сегодня тоже, может прокатило smile.gif
KoJIoBASS
сообщение 19.11.2009, 17:28
Прошивка: Fusion 3
Ещё прикольнее, мотор не повис, но последний звонок принял часа три назад, а те кто звонили позже слышали "абонент не доступен", был smile.gif
Решил позвонить с телефона- сбой операции, или как-то так.
Перезагрузка помогла. Так что же было?
Vermin
сообщение 20.11.2009, 3:14
У меня раз на этой прошивке тоже так было. Перезагрузка помогла. Больше не повторялось.
alkrv
сообщение 16.12.2009, 11:21
Пользователь №: 202 510
Модель телефона: rokr e8
Прошивка: r6713...14C_A
Может кто то выложит evo_3_cpu v512mb на какой нибудь файлообменник. А то через gprs с qip.ru все нервы убил, раз пять качал , то на 5 мб то на 7 обрывает и все!
Сообщение отредактировал alkrv - 16.12.2009, 11:23
Fearless
сообщение 28.12.2009, 14:25
Из: Орёл
Пользователь №: 64 233
Модель телефона: V8
Прошивка: evo3
кто знает как установить лэнг?? залил содержимое архива с LP002EE в /ezxlocal/download/mystuff/apps/language/ , но при этом поменялся только шрифт..... а сайт распутина с мануалом не открывается:( хэлп пипл!!!!
Vermin
сообщение 29.12.2009, 0:42
Язык то теперь в настройках установите.
Fearless
сообщение 29.12.2009, 13:49
Из: Орёл
Модель телефона: V8
Прошивка: evo3
в том то и дело что в настройках только English и Automatic:( мне бы и на англ без проблем только вот записная книжка косячно отображается без русского языка в лэнге:(
Vermin
сообщение 30.12.2009, 0:46
Еще раз по пунктам как и что делал.
Fearless
сообщение 30.12.2009, 13:24
Из: Орёл
Модель телефона: V8
Прошивка: evo3
все, теперь все заработало... верятно необходимо было прошить ту часть прошивки с video update
Сообщение отредактировал Fearless - 30.12.2009, 14:36
ProRocK7
сообщение 23.2.2010, 16:18
Пользователь №: 112 896
Модель телефона: V8
подскажите, плз, как установить на evolution3 нативные приложения, pep пакеты я понял тут бесполезны, да?
Vermin
сообщение 24.2.2010, 7:17
Только ручками или через SoftBox. Шей BasicPlus, практически тоже самое, только пакеты есть.
Сообщение отредактировал Vermin - 24.2.2010, 7:19
сообщение 23.4.2010, 20:40
Что-то никак у меня русский не появляется.
%Чтобы установить русский лэнгпак, копируем содержимое архива с LP002EE в /ezxlocal/download/mystuff/apps/language/%
Папки "language" у меня там нет. Есть "languages". Создал нужную, скопировал, перезагрузился - результата нет. Скопировал в languages - снова ничего. В теле только английский и автомат.
Offset
сообщение 23.4.2010, 20:48
Leo
Пользователь №: 126 712
Прошивка: 2BR
А ленг прошить с русским вера не позволяет?
- Самая лучшая, на мой взгляд, это [MP] Linuxmod Fusion 3 V8-2Gb/512mb по крайней мере хоть чем-то отличается от остальных клонов.
сообщение 24.4.2010, 4:26
Ну вроде как в теме несколько раз указано, что русский ставить на этот мод надо исключительно по мануалу автора. То есть именно копированием нужных файлов. А прошивка ленга то ли просто не помогает, то ли проблемы в моде вызывает.
В общем русский завёл переносом файлов по этому адресу %/ezxlocal/download/mystuff/language/%
Только при этом пропал шрифт мода. Вопрос теперь, почему мои действия отличны от указанных но работают? И как вернуть шрифт мода?
И да. Linuxmod тоже сейчас попробую.
Сообщение отредактировал xGooPhx - 24.4.2010, 4:28
Vermin
сообщение 25.4.2010, 23:52
Насколько я помню в двухгиговой версии путь ленга /ezxlocal/download/mystuff/language/
Шрифт мода с русским языком работать не будет! В нем нет русских символов!
krivedko
сообщение 4.6.2010, 18:58
Из: Магнитогорск
Пользователь №: 211 239
Модель телефона: v8
Скажите, у меня одного к фтп не подключается? В настройках соединения - Modem & Tools, потом открываю FTP, вставляю кабель, нажимаю Yes - не могу подключиться по ftp. Что я сделал не так?
Vermin
сообщение 7.6.2010, 23:35
Поставь в настройках просто Tools.
CJstyle
сообщение 5.8.2010, 5:51
Пользователь №: 177 888
Модель телефона: Motorola K1m, V82GB
Прошивка: 24.5_01.14.HA
Люди скажите плиз, почему я меню "Сброс Настроек" если выбираю удалить все данные, телефон пару секунд нормально показывает загрузку шкалы, а потом ТУПО виснет! Ждал мин 15 потом надоело и выдернул батарею!
CJstyle
сообщение 6.8.2010, 9:00
Заметил особенность! Перешил я телефон на Evolution и решил проверить как он работает в режиме карты памяти!
На мое удивление все запустилось! И была возможна и работа с памятью телефона, и с карточкой до перезагрузки!
Моему счачстью не было границ, пока не поставил LANG PACK: LP002EE - UK English, German, Russian, Ukrainian, French, Spanish, Portuguese; Russian voice commands only
После того как я поставил этот Lang Pack, все как и должно было повисло на мертво, но работа с картой памяти была возможна а с памятью телефона нет!
Может попробовать поставить какой-то другой LANG PACK?!
А я то сначала думал что память не работает из за видео мода!
Сообщение отредактировал CJstyle - 8.8.2010, 6:51
Vermin
сообщение 6.8.2010, 14:46
Лэнг в этой прошивке лежит в пользовательской памяти телефона, от этого и зависания в режиме "карта памяти".
CJstyle
сообщение 8.8.2010, 6:48
И как поправить?! Скажите плиз?!
И еще вопрос, при подключении гарнитуры мигает внешний зеленый индикатор зарядки, очень раздражает, как убрать?! В папке funlight только bluetooth
А так же заметил что в прошлой прошивке при использовании голосовых комманд, если не выбиралась не одна, телефон сам закрывал меню, а здесь не закрывает... как исправить?!
Сообщение отредактировал CJstyle - 8.8.2010, 6:50
Vermin
сообщение 8.8.2010, 12:16
как исправить?!
Перейти на другую прошу.
CJstyle
сообщение 20.8.2010, 10:59
А есть прошивка Evolution 2 к примеру? Мне просто нужна прошивка с таким же главным меню (иконками)
Vermin
сообщение 20.8.2010, 14:18
Есть. И 2 И 1 и целых 5 Linuxmod'ов.
entertainment
сообщение 17.10.2010, 17:14
Пользователь №: 220 703
Модель телефона: razr2 v8
Прошивка: linuxmod 5.1
подскажите пожалуйста,в чём может быть дело,устанавливаю прошивку и пишет
""critical error B655 EDDC"" перед этим стояло еще линукс3 и линукс5.
бут стоит ac3f no_rsa
Прошивка Evolution 3, V8 · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 5.8.2025, 0:46
