4 страниц V < 1 2 3 4 >
Прошивка Evolution 3, V8
abelenki
сообщение 22.1.2009, 9:07 Закрепленное сообщение!
Из: Russia, Perm
Пользователь №: 94 097
This is the NO_RSA Evolution 3 firmware, which is an updated version of Evolution 2 with Snesx.
The changes are:
new "System Management" submenu under Tweaks which includes
- Swap Memory, so you can add extra physical memory to your V8, so the V8 does not have to unload stuff and load new stuff into RAM memory, it can now use a certain size of the User Memory (512MB V8) or the 2GB memory (2GB V8) to store memory loaded stuff. It should make the V8 perform faster under heavy multi tasking. Just click the menu, select the swap memory size you want to use and wait, then press the menu again and it will offer the option to activate the swap memory, do that. Once the swap memory is setup it will be always there, unless you delete it of course, but it needs to be activated after every reboot. You can check the status of this swap memory with
-System Info, which will display the currently used memory and swap memory with adjustable refresh circles.
-Phone Firewall is an application that can be used to block certain phone numbers and there is the option to block unkown numbers as well, perfect if you want to setup the phone for your kids.
In the "Utilities" submenu there are 3 new menus
- Arcman, looks like zLauncher, but is for archiving file and folders as well as unpacking compressed files, the MPlayer.rar file that is included unpacks perfectly, which brings me to another point. MPlayer had to be removed from automatic installation because it just took too much space. Now 2GB V8 should already have it in place as the 2GB memory does not get wiped when flashing a complete firmware. The 512MB V8 however needs to have the MPlayer.rar file copied into /ezxlocal/download/mystuff/Programms (note the 2m's!! in Programms as there is another Programs folder), then use Arcman to Extract->Extract Here and reboot, now MPlayer will be working on the 512MB V8. 2GB V8's that do not have a "Programms" folder in /mmc/mmca1, have to create one and use the same method.
-Cronometer is like a stopwatch, but you also can take times for certain stages (Mark button)
-V8 Screenshots lets you take screenshots of any menu and store them on the V8, you can adjust the number of screenshots to be taken, the timing when they will be taken and where you want to store them, User Memory (512MB V8 and 2GB V8) and 2GB memory (2GB V8 only). Once you have taken some screenshots, you have to rename the screenshot files with zLauncher or they will be overwritten the next time you take screenshots again. you can find them in /ezxlocal/download/mystuff/snapshot and /mmc/mmca1/snapshot.
The zLauncher got updated as well and works now as a TextViewer as well, but you also can edit existing and opened text files, but you also can edit scripts, sh files, and save them. Because of the much more powerfull potential that zLauncher posses, it has been password protected (password: 1234), you can of course change that password to whatever you like. This way only the person/persons that know the password can have total access to the filesystem. For example you can create a new folder in the User Memory or the 2GB memory and call it .whatever, now if you add the "dot" in front of the name then File Manager will not be able to see this folder, but zLauncher will be. So you can have a "hidden" folder in which you can save/store stuff that is not meant to be seen by everybody and because zLauncher is password protected you are the only one that has access to it. I tried the ZHidenFolder mod, which basically does the same, but because zLauncher still can see those "hidden" folders there was not much point in using that HiddenFolder mod. Also FTP programs like FileZilla can see those "dot"name folders.
You can change the language of Cronometer and Phone Firewall, but not through the app menu, that somehow does not work. But if you look at /ezxlocal/download/mystuff/apps/language/English, open that with wordpad and change the words of the right hand side to the words of your language and save it as "Italian" or whatever, then you can change the cfg files for Cronometer and Phone Firewall to use your language.
A very big THANK YOU has to go to all those people that made those Z6 mods, without their work our V8 would be less interesting, also I have to thank DaRk_dOg for his tireless help to get this up and running and his help in testing the 512MB version, this thanks also has to go to Protector who tested the 2GB version.
This typical, I just have decided to release Evo 3 and along comes a very useful mod (thanks to DaRk_dOg) which really would finish off the Evo 3 firmware. This Mod can be found under the System Management and is called CPU Frequency. Well as the name says you can adjust the MHz frequency of the CPU.
Автор:
rasputin007
Оригинальный топик:
modmymoto.com
Порядок прошивания:
1. Bootloader A3.CF (если у вас какой-либо другой бутлоадер).
2. Bootloader A3.CF No RSA.
3. Прошивка Evolution 3 (прошивайте версию прошивки, соответствующую вашей модели телефона - 512MB или 2GB. Для Luxury Edition прошивайте версию 2GB).
4. Чтобы установить русский лэнгпак, копируем содержимое архива с LP002EE в /ezxlocal/download/mystuff/apps/language/.
Файлы:
Bootloader A3.CF
512MB Evolution 3, 512MB Evolution 3 Video Update (исправлена функция Reset и добавлена съёмка видео в 288x352)
2GB Evolution 3, 2GB Evolution 3 Video Update (исправлена функция Reset и добавлена съёмка видео в 288x352)
LP002EE - UK English, German, Russian, Ukrainian, French, Spanish, Portuguese; Russian voice commands only
MPlayer
Evolution 3 User Guide
Language Guide
V8 Modding Guide
Сообщение отредактировал abelenki - 25.8.2009, 8:51
Legis
сообщение 25.2.2009, 21:27
Из: Питер
Пользователь №: 62 183
Модель телефона: Atrix 4G
Прошивка: Home Base
любопытнный,
дык это ленг именно для проши эволюшн
а для стандартной шей .sbf
Сообщение отредактировал Legis - 25.2.2009, 21:28
abelenki
сообщение 26.2.2009, 4:06
Из: Russia, Perm
Цитата(любопытнный @ 25.2.2009, 18:05) *
abelenki, А нельзя ли сделать на русском? И как-то с установкой языкового пакета не всё ясно:на сайте Распутина есть 2 пакета-один распакованый,а другой в формате sbf. Не нашел точно какой ставить и способ установки на форуме предлагается разный. Если не затруднит дайте ссылочку именно для 2GB Evolution 3.
ставить лэнг нужно по этой инструкции и брать оттуда архив (об этом уже много раз писалось):
http://www.rasputin007.co.uk/storage/webpages/cg46/
aciddon
сообщение 26.2.2009, 20:44
Из: Украина, Донецк
Пользователь №: 130 096
Модель телефона: RAZR2 V8
Прошивка: Evolution 3
Я не пойму одного.
Vermin
сообщение 27.2.2009, 2:53
Пользователь №: 64 122
Модель телефона: V635; V8
Прошивка: Своя; Basic Plus
В каком подменю? Цифры только в подменю "Интернет".
aciddon
сообщение 27.2.2009, 7:13
Из: Украина, Донецк
Вот таких например.
ben1508
сообщение 27.2.2009, 8:51
Пользователь №: 188 387
Прошивка: basic plus
Поменял пороль на
3лаунчере. Теперь
он не запускается.
Подскажите,
пожалуйста, в каком
файле он
находится?
Все, разобрался...
Сообщение отредактировал ben1508 - 27.2.2009, 9:38
tdktdk
сообщение 27.2.2009, 10:16
Пользователь №: 138 821
Модель телефона: Motorola V8 (512Mb)
Прошивка: LinuxMod5
@aciddon
The problem maybe in the skin using...i dont know...
I use V8 512MB
Screenshots:
IPB Image
IPB Image
aciddon
сообщение 27.2.2009, 21:08
Из: Украина, Донецк
tdktdk,
Возможно, хотя врятли.
А что за скин у тя???Где брал???
Vermin
сообщение 28.2.2009, 12:43
Попробуй скин другой. Или еще раз прошей. У меня нормально все. Даже не знаю че может быть....
Сообщение отредактировал Vermin - 28.2.2009, 12:43
-=WEST=-
сообщение 28.2.2009, 17:09
Из: Питер
Пользователь №: 153 665
Модель телефона: E398+V8+ROKR E8
Прошивка: 49R, 56.1BR, 1CR_A
народ, как вы ставили на этот МОД(512Mb) - Mplayer, а то чет у меня не получается... дам + за помощь
Сообщение отредактировал -=WEST=- - 28.2.2009, 17:50
aciddon
сообщение 28.2.2009, 21:49
Из: Украина, Донецк
Vermin,
Скины не помогают.
Так у тебя вместо циферок иконки????
KLON 3
сообщение 1.3.2009, 6:58
Из: Voronez
Пользователь №: 90 456
Модель телефона: v3i,V8 512M
Прошивка: Basic Plus
В архиве с прошивкой есть MPlayer.rar ,его нужно закинуть в папку Programms. Затем распоковать встроенным Arcman иперезагрузить тел. Собственно все.
Bam_Margera
сообщение 1.3.2009, 12:40
Пользователь №: 194 576
Модель телефона: Razr2 V8, SE M600i
Сделал как сказал! когда нажимаю на MPlayer в папке мультимедия вылезает такая фишка как менеджер. и там выбераецца путь Programms/там архив и сама папка/в папке два bin. MPlayer и z6Mplayer при выборе и того и другого никаких изменений нет!!!!! чо делать???
-POSHIK-
сообщение 1.3.2009, 12:55
Из: Днепропетровск
Пользователь №: 137 121
Модель телефона: Z6
Bam_Margera, выбери видео файл
MadHZ
сообщение 1.3.2009, 13:28
Пользователь №: 187 942
Модель телефона: RAZR V8
Прошился на V8 нормально, руссификатор накатил - все работает! shout.gif Но, может быть, кто-нибудь скажет, если тут нет теперь RSA и вообще все круто, как убрать долбаное блямканье каждые 5 минут при низком заряде батареи??? ph34r.gif
Frezerovshik
сообщение 1.3.2009, 14:50
Пользователь №: 179 253
Цитата(aciddon @ 27.2.2009, 18:13) *
Скажите что за скин и где взять плиз? знаю есть грэс виста но она по другому выглядит sad.gif
И еще: в режиме карты мало того что тело зависает даже со стоковым скином и приходится дергать батарею после юзания, так ещё и в ехплорере открывается толкьо карта памяти, а память телефона не открывается (устройство не обнааруженено или типо того) что заструдняет работу с ней. Как пофискить можно?
и наконец:
ААААААА прошлая проша была линуксмод 5. Сделал там бескап. Сейчас на этой прошивке жму рестор- пишет типо сделано саксесфули. Перезагружаю- ноль эффекта. НИЧЕГО НЕ ВОССТАНОВИЛОСЬ. ладно настройки- ерунда. НО вот список контактов не восстанавливается это БОРОДА. поэтому аааа помогите плиз sad.gif(
Сообщение отредактировал Frezerovshik - 1.3.2009, 15:20
aciddon
сообщение 1.3.2009, 16:24
Из: Украина, Донецк
Frezerovshik,
Ну скорее всего что уже не восстановишь.
Просто я обычно не доверяю всем этим бекапам и сохраняю контакты всегда Motorola Phone Tools которая идёт в комплекте и тебе на будущее советую smile.gif
Добавлено позже (1.3.2009, 18:35):
Фикс к данной проше.
Проблема:
Пропавшее меню оператора(SIM Application)
Решение:
Качаем файлы которые в аттаче(для каждой из моделей).
В архиве 2 файла - UserRegistry и UserMenuTree.
Подключаем телефон в режиме FTP.
Копируем эти файл в /ezxlocal/download/appwrite/am/.
Перезагружаемся.
Теперь в Органайзере(Office Tools) вместо последнего пункта Sync(который ничего не делал) появиться меню оператора(SIM Application). Будет называться в зависимости от вашей симки.
Сообщение отредактировал aciddon - 1.3.2009, 16:36
Прикрепленный файл 2GB_Sim_Apps.rar   ( 7.97 килобайт ) Кол-во скачиваний: 103
Прикрепленный файл 512_Sim_Apps.rar   ( 7.96 килобайт ) Кол-во скачиваний: 98
tursunbay
сообщение 1.3.2009, 20:56
Пользователь №: 131 947
Модель телефона: RAZR2 V8, Z6
aciddon
После загрузки 512_Sim_Apps пропали все ява приложения и в папку "игры и приложения" ничего не ставится...
Legis
сообщение 1.3.2009, 23:21
Из: Питер
Прошивка: Home Base
тоже мучался...
в итоге скопировал вручную только 1 файлик, вроде main.db
сначала создал бекап на новой проше, заменил этот файл, и восстановил бэкап; справочник восстановилсяsmile.gif
Сообщение отредактировал Legis - 1.3.2009, 23:22
aciddon
сообщение 2.3.2009, 12:38
Из: Украина, Донецк
tursunbay,
Итак. Говорю сразу, претензии все не ко мне, а к Распутину smile.gif .
Делаешь бекап на телефоне. Подключаешься в ФТП режиме. Копируешь в какую-нибудь папку твои приложения, в которую можно зайти с Диспетчеров Файлов в телефоне. Просто заново инсталируешь и всё вернёться на места свои.
Но вот что я разузнал.
На 512 модели иконки в подменю не доступны.
Точнее если их включаешь, то фотки которые делаешь(как я понял) сохраняються в неизвестную папку.
Как их и где включать я в данны момент пытаюсь выяснить у него, т.к. если во флексбите включить данный флажок то ничего не появиться.
Вот орригинал текста:
Only 2GB has little icons (19x19), but 512MB has numbers in front of submenus. The reason is that one flexbit (line5 offset B1) is disabled in the 512MB. This flexbit changes the numbers into small icons, but also changes the File Manager name into My Favourites. Unfortunately this flexbit, when enabled on the 512MB, also stores all taken photos from the camera in the "unkown" folder instead of the Picture folder. Took me weeks to figure that out and because there were more complains about the wrong photo storage folder then about missing small icons this flexbit has been left out from the 512MB versions since LM5.
But you can change that yourself. Copy and open /ezxlocal/download/appwrite/setup/ezx_flexbit.cfg with FlexBit Editor and enable that flexbit (add a tick), save it, copy back on V8 and reboot, now all submenus will have little icons and your photos will be in the "unkown" folder.
Сообщение отредактировал abelenki - 6.3.2009, 4:26
MadHZ
сообщение 5.3.2009, 6:39
Замечена проблема на прошивке NO RSA Evolution 3 / V8! Наипаршивейшая вещь. После перепрошивки телефон стал жрать батарею раза в 2.5 быстрее, чем на старой. Было замечено, что несколько убыстрился интерфейс. Соответственно, путём эмпирических заключений было выявлено, что жор появляется из-за максимальной скорости внутреннего процессора телефона по-умолчанию (видимо, в предыдущих прошивках скорость процессора регулировалась динамически или же была минимальна в режиме standby). Встроенный в Evo3 скрипт для регулировки частоты - не работает! точнее, он срабатывает, но после первого же звонка или sms всё возвращается на круги своя, и таким макаром батарейки уже не хватает даже на 7 часов standby! Это безобразие shuffle.gif
Может быть, кто-то уже менял частоту процессора по-умолчанию? где хранится эта настройка? выставлю себе по-минимуму, а когда нужна будет шустрость, буду включать вручную. Потому что пользоваться телефоном в режиме, когда зарядки не хватает на 1 световой день - не-воз-мож-но. (раньше хватало на 36 часов).
Ну или же, если никто с этим не разбирался, полезу сам ковырять. Хуцкеры, итить колотить. Шрифт модный и кучу всяких ненужных приложений -- не забыли! А с такой важной фичей почему-то до конца не разобрались sad.gif
Просьба отписаться, если знаете что-либо полезное по данной теме!
Vermin
сообщение 5.3.2009, 10:52
Багов с батареей не заметил. Хватает на то же время. Частота, когда телефон не загружен - по минимуму. Правда я ниразу не использовал скрипт изменения частоты, не нужно мне это. Может в этом и дело.
aciddon
сообщение 5.3.2009, 13:19
Из: Украина, Донецк
MadHZ,
Тож не заметил, т.к. изначально батарея никогда не нравилась на этой модельке.
Распутин выпустил профиксеную прошу с Пропавшим меню оператора(SIM Application).
http://www.mediafire.com/rasputin007
В архиве с прошивкой так же идёт мануал по установке языка, бут лоадер, mplayerm, мануал по Evolution 3.
Также по данной ссылке можно скачать lang pack'и.
rasputin007
сообщение 6.3.2009, 14:53
Из: UK
Пользователь №: 184 705
Прошивка: Nothing for too long
I have rewritten the V8 Modding Guide and uploaded it to Mediafire.
Just download it (11.8MB) and open the index.html file, bookmark it for easier reference. All links to bigger files have been corrected (also Mediafire).
MadHZ
сообщение 6.3.2009, 18:42
Big thnx m8! Ras, could you explain why my V8 stayed at 560Mhz after writting any sms and couldn't get the right speed (133Mhz) back? That's why my battery discharged at 6-7Hrs on Evo3... There are no such a bugs at the older firmwares. How to fix that?
The speed changed but couldn't get to the normal: well, I found this bug on the sms reading/writing feature but I cant be sure that there is no any other places where it could appear... still exploring.
Добавлено позже (6.3.2009, 18:44):
append: if I changed the speed with mod script (supplyed with the Evo3 firmware) by my hands - the battery is not discharging and all seems to be OK. stink.gif
rasputin007
сообщение 6.3.2009, 19:36
Из: UK
This CPU Frequency mod came in the last minute from the Z6. I checked it if it is working and then included it in Evo 3. Unknown to me there are other factors that influence the CPU speed, that's why the set speed does not stays forever. I managed to change the script (NOT in any firmware) so that after setting the CPU speed to 532Mhz it always stays there until the next reboot, by simply setting the "op" file to read-only, so the V8 could not change it, but after reboot this "op" file is back to read/write.
This script could do with some improvements, because at the moment it is just a toy.
Сообщение отредактировал rasputin007 - 6.3.2009, 19:37
abelenki
сообщение 7.3.2009, 17:32
Из: Russia, Perm
vFM file manager для Evo 3:
http://modmymoto.com/forums/showthread.php?t=436061
Сообщение отредактировал abelenki - 7.3.2009, 17:36
k-z
сообщение 10.3.2009, 10:55
Из: Владивосток (пос.Славянка)
Пользователь №: 163 027
Модель телефона: motoroi XT720/Photon 4G
Прошивка: 4.1.2
истирическое :)
делаю всё как написал, сначала a3.cf потом a3.cf no_rsa , только но рса не ставится, рдс говорит fail, я теперь и не знаю что делать, как быть? sad.gif
abelenki
сообщение 10.3.2009, 11:00
Из: Russia, Perm
как так? ты через что шьёшь? надо шить через РСД Lite 3.9 или выше.
1. сначала прошиваем bootloader A3.CF. после прошивки телефон перегружается.
2. потом прошиваем bootloader no RSA A3.CF. после прошивки телефон перегружается.
3. всё. после этого можно спокойно шить Evolution 3. главное не перепутать, и прошить нужную Evo 3 (512MB или 2GB, в зависимости от твоей модели телефона).
Advokat_d
сообщение 12.3.2009, 13:15
Пользователь №: 155 462
Модель телефона: V3i,V8 2гига
Прошивка: R601_G_80.56.15R
Извеняюсь за повтор.....У КОГО КАМЕРА НА ЭТОЙ ПРОШИВКЕ РАБОТАЕТ НОРМАЛЬНО?
У меня снимает фото и камера поршиво.....помогите кто-то мажет плиз tomato.gif
aciddon
сообщение 12.3.2009, 17:50
Из: Украина, Донецк
Advokat_d,
Так в чём именно проблема???
Просто я не сильно снимаю, да вроде всё так и осталось как было.
Advokat_d
сообщение 12.3.2009, 22:34
Цитата(aciddon @ 12.3.2009, 19:50) *
Advokat_d,
А снимает телефон вот так....
hakk
сообщение 14.3.2009, 23:36
Из: Україна, Луцьк
Пользователь №: 123 306
Модель телефона: Nokia 1208
Прошивка: RH-105
сори заплужил тока бут перешил.... шею мод...
Err:A5,694E,24 что это что делать???
Сообщение отредактировал abelenki - 16.3.2009, 3:47
Offset
сообщение 30.3.2009, 20:07
Leo
Пользователь №: 126 712
Прошивка: 2BR
Advokat_d, такая проблемы была на L7e. Решилось она передергивание шлейфа камеры. т.е. высунули и всунули заново. И нормально заработала. smile.gif
VOVAH
сообщение 31.3.2009, 9:46
Из: г.Норильск
Пользователь №: 134 489
Модель телефона: V3>V3x>V8>V9>D2G
Help! Не шьется bootloader a3.cf. Сейчас прошивка R601_G_80.54.60R с бутом a3.cd.
Антоха-ха-ха
сообщение 31.3.2009, 12:47
Пользователь №: 53 930
Модель телефона: V8 512mb
Прошивка: LM5_SP1_LP0039B
Нет непомогло оригинальный бут R601_G_80.56.1BR_Bootloader_A3.CF выдает ошибку.
Прошивка вроди встала но похоже криво.
1 после замены папки Language подкл. тело на родном скине всеровно приходится дергать батарею
2 Устанавливаю мп плеер через EFM он тоже не работает
3 Пытаюсь дать права кд Плееру через райт подключаю телефон как флеху и тут выскакивает ошибка
какая непомню.
Сообщение отредактировал Антоха-ха-ха - 31.3.2009, 14:48
aciddon
сообщение 31.3.2009, 16:24
Из: Украина, Донецк
Антоха-ха-ха,
Передёргиваешь когда подключаетсья в режиме Флешки???Если да тогда это нормально.
Юзай ФТП и не надо будет передёргивать.
Антоха-ха-ха
сообщение 1.4.2009, 4:55
Как тока начал прошивать экран не загорелся вроди все работало ошибку не выдовал
Дошол до 100% итут у меня села батарея поставил на зарядку.
после повторения операции опять вылетела ошибочка таже самая и в этот раз экран включается и выдается ошибка mad.gif
И сразу спрошу а какой ФТП лучше использовать
Сообщение отредактировал abelenki - 1.4.2009, 11:18
любопытнный
сообщение 1.4.2009, 7:34
Пользователь №: 183 849
Модель телефона: Motorola Accompli 008
Прошивка: ОЧЕРЕДНАЯ
Вроде об этом никто не писал:программа Flash&Backup предназначенная дляР2К-телефонов разобрала прошивки ЛМ5 и ЭВО3 по кодовым группам и собрала в формате SHX.только CG42 почему-то отображается зачеркнутой.Может это кому пригодится тк сам проверить не могу,пока осваиваю F3
abelenki
сообщение 1.4.2009, 7:47
Из: Russia, Perm
что значит какой FTP лучше? FTP-клиент? любой бесплатный. я использую плагин к FAR.
Сообщение отредактировал abelenki - 1.4.2009, 11:19
Прошивка Evolution 3, V8 · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 5.8.2025, 0:46
