Цитата(CrayZor @ Вчера, 19:33)
Есть у меня такая программулина
Цитата(sun2 @ Вчера, 19:53)
ROFSBUILD - Rofs image builder V2.01 (Build 573)
Copyright © 1996-2006 Symbian Software Ltd.
Syntax: ROFSBUILD [options] obeyfilename
Option: -v verbose, -?, -s[log|screen|both] size summary
-d<bitmask> set trace mask (DEB build only)
-compress compress executable files where possible
-compressionmethod none|inflate|bytepair to set the compression
none compress the image.
inflate compress the image.
bytepair compress the image.
-coreimage <core image file> Obey file keywords:
file File to be copied into ROFS
data same as file
rofsname output file for ROFS image
romsize size of ROM image
hide[HWVD] Exclude named file from ROM directory structure
alias[HWVD] Create alias for existing file in ROM directory structure
rename[HWVD] Change the name of a file in the ROM directory structure
rofssize maximum size of ROFS image
romchecksum desired 32-bit checksum value for the whole image
version ROFS image version number
time ROFS image timestamp
extensionrofs Start of definition of optional Extension ROFS
extensionrofsname ROFS image on which extension ROFS is based
rem comment
stop Terminates OBEY file prematurely
romchecksum desired 32-bit checksum value for the whole ROFS image
coreimage Core image to be used for extension directory structure
autosize Automatically adjust maximum image size to actual used
filecompress Non-XIP Executable to be loaded into the ROM compressed
fileuncompress Non-XIP Executable to be loaded into the ROM uncompressed
patchdata Patch exported data
File attributes: attrib File attributes in ROM file system
stack ?
fixed Relocate to a fixed address space
priority Override process priority
uid1 Override first UID
uid2 Override second UID
uid3 Override third UID
heapmin Override initial heap size
heapmax Override maximum heap size
capability Override capabilities
unpaged Don't use demand paging for this file
paged Use demand paging for this file
data same as file
rem comment
stack ?
