[FLash] LinuxMod SP2 "Rebirth Edition"
c_ro87
сообщение 8.4.2009, 15:37
Пользователь №: 184 224
Модель телефона: Z6
Прошивка: LM SP1 RC3 Beta
Ok... here i come with the last Z6 flash, made by me..
his name LinuxMod SP2 "Rebirth Edition"
It is made using as base the Linuxmod SP1 RC3 frm CepiPerez
Changes respect RC3:
Bugs Arreglados:Bugs fixed:
*Camera config now is saved
*Iconrex fixed
*Data mode fixed
*New PictureFlow script with graphic gui
*tweaks menu now calls LinuxMod
*SOme icons will added, and some will changed
*Some scripts was rewrited
*New images
*Norris pack compatible
Let's se some apps and useful script's in the mod
Apps:
*Crack mounty by dimichxp, you can mount files in system folder
*FTP by Abram
*Web snapshot de syppey
*PictureFlow by c_ro87
*Z6Manager by CepiPerez manage a lots of features, just like BT time, alarm time, install and uninstall mpkg, manage znothief, etc
*zBackUp by racinglocura07
*am_mod by BeZ, icons in submenues
*cpufrequency by sEVANs
*zNothief by segnini75
Scripts, made by kleto, roks, tsbdlc, CepiPerez, racinglocura07 y c_ro87
*Refresh: refresh system process
*Web Link Sidebar:change orange bar links
*Font: change the font
*Bootlogo: change the bootloga
*Screen Boot: boot and screensaver simulator
*Camera mod: video resolution change to 240*320, 352*288
*Slider tone edit: change the slider tones
*SoftBox: Apps for working wth java, add apps to the menu, etc
*Cron: for program works
*JavaId: java name changer
*Java settings: java heap changer
*Java multitask: two java running at the same time
*Hide: hide folders
*Shortcuts: change the key shortcuts
*Compresed: compress files in tar, gz, tgz
Compatibility with the next file types
mpkg,txt,cfg,ini,phm,qkt,lp,mpkg,squashfs,cramfs,mtf,lin,sh,csh,chm,zip,rar,tar,gzip,gz,bz2,ttf,TTF, entre otros
Extras:
*Autorun in /ezxlocal/download/mystuff/.autorun.csh
*Abcisa font
*Slider tones, Blood, ShotGun y Afirmative/Negative
Know's bugs:
*If you change the font, the alarm don't will work
*If you active the Telnet & FTP option in z6manager the scripts come slow
SCREENSHOTS:
IPB Image IPB Image
IPB Image IPB Image
IPB Image IPB Image
IPB Image IPB Image
DESCARGA:
DOWNLOAD
or
DOWNLOAD
How to install:
*Flash over a .44r
*format the SD
*make a data clean
*enjoy
P/D: I hope you like this
salu!!
DaRk_dOg
сообщение 8.4.2009, 20:53
Пользователь №: 195 876
Модель телефона: Motorola Z6/V8
Thank you very very much! This version is great!!!!
man_of_dream
сообщение 9.4.2009, 6:52
Пользователь №: 188 812
Модель телефона: Nokia 5228
Прошивка: :)
могли и убрать этот серый квадрат))
nsk_modder
сообщение 9.4.2009, 14:16
Из: Новодвинск
Пользователь №: 92 444
Модель телефона: Z6
Прошивка: Самосбор
c_ro87,
respect
man_of_dream
сообщение 9.4.2009, 15:51
Прошивка: :)
how work this?)))
вопрос снят, разобрался)
интересно одно, почему когда включаешь иконки в подменю, телефон подключается в режиме "Карта памяти" без всяких проблем?
Сообщение отредактировал man_of_dream - 9.4.2009, 16:10
Rene
сообщение 10.4.2009, 3:23
Пользователь №: 73 537
Модель телефона: Z6+2G
Прошивка: PE2.0
Расскажи как ее прошить z6. блин не могу у меня судя по скриптам установка не начинается.
man_of_dream
сообщение 10.4.2009, 5:57
Прошивка: :)
там короче когда прошьешь, надо то общий сброс сделать или че то в этом роде)
а по поводу как прошить тебе сюда
Сообщение отредактировал man_of_dream - 10.4.2009, 5:58
Bender686
сообщение 10.4.2009, 12:05
Из: Ижевск
Пользователь №: 187 455
Модель телефона: ROKR EM-30
камера у всех работает после прошивки этого мода? и если не работает то что делать?
Rene
сообщение 10.4.2009, 12:11
Прошивка: PE2.0
Спасибо. Как прошить я знаю. надо было общую очистку делать. Только вот не пойму почему? Зачем так сделано?
peasduke
сообщение 10.4.2009, 13:19
Из: Россия. Красноярск
Пользователь №: 183 213
Модель телефона: ROKR Z6
Прошивка: R60_G_80.33.4ER
How skins installed?
Как скины установливать?
Сообщение отредактировал peasduke - 10.4.2009, 15:41
CrayZor
сообщение 10.4.2009, 16:38
Пользователь №: 167 295
Модель телефона: E398, ROKR E1, X2, G100
Прошивка: In development
Объясните мне тупому как установить этот мод. Я прошил его на чистую 44R, затем отформатировал флешку как написано, сделал общий сброс. Но то что там должно быть непоявилось, кроме новой обоины и иконок в диспечере файлов, я ничего нового необнаружил, нет новых программ и скриптов, ничего нового, может где есть ссылка на эти проги, ткните носом, вообщем помогите.
man_of_dream
сообщение 10.4.2009, 16:48
Прошивка: :)
общий сброс и удаление всех данных пробовал?
Сообщение отредактировал man_of_dream - 10.4.2009, 16:48
CrayZor
сообщение 10.4.2009, 17:30
Всё уже разобрался.
S.E.R.E.G.A.
сообщение 10.4.2009, 17:48
Из: Волгодонск
Пользователь №: 177 003
Модель телефона: Moto Z3
Вобщем прошился я на этот мод, всё сделал я так: 1. Прошился я на чисту 44р. 2. Прошил мод. 3. Отформатировал флешку. 4. Удалил все данные. Затем тел. перезагрузился, на флешке создались папки: Font, Images. Затем вродебы тело ещё раз перезагрузился, вобщем он перезагружался раза 4. И мод был полностью установлен.
Добавлено позже (10.4.2009, 20:50):
Добавлено позже (10.4.2009, 20:51):
Добавлено позже (10.4.2009, 20:53):
Добавлено позже (10.4.2009, 21:01):
Кто ни будь знает как устонавливать темы через Z6Manager? Через zLauhener и SoftBoxs не выходит!
Добавлено позже (10.4.2009, 21:04):
Извените что пишу несколько раз одно и тоже. Просто интернет тормозит, и пишу я с телефона!
Rene
сообщение 11.4.2009, 19:36
Прошивка: PE2.0
А почему не хотят устанавливаться MPKG files из темы Z6 Manager, install/uninstall/control MPKG's and other options
S.E.R.E.G.A.
сообщение 12.4.2009, 16:44
Из: Волгодонск
Кто ни будь знает как на этом моде устонавливать темы? Подскажите плиз!!!
peasduke
сообщение 14.4.2009, 15:27
Походу никто не знает, кроме автора. Я лично так и недопёр как ставить скины... Мод то как бы не плохой. Непривычный правда какойто, после наших WkTools и zMod, да и краткого мануала никакого автор не выложил. В общем откатываюсь на стандартную прошивку...
marvin_89
сообщение 17.6.2009, 22:54
Пользователь №: 188 080
Модель телефона: MotoRokr Z6
а можно сюда как-то приспособить mPlayer ?
ХРОН
сообщение 18.6.2009, 0:01
Пользователь №: 148 368
Модель телефона: Z6, ZN5, Atrix HD
Прошивка: рабочая
marvin_89 можно по любому, я где-то встречал мплеер упакованніый в мпкг.
D-flasher
сообщение 18.6.2009, 4:47
Из: Уфа City
Пользователь №: 179 991
Модель телефона: Nokia 5530
Прошивка: 40
кто на этой прошивке сидит выложите пожалуста программу PictureFlow
abelenki
сообщение 18.6.2009, 5:14
Из: Russia, Perm
Пользователь №: 94 097
Модель телефона: Atrix 4G
Прошивка: 2.3.6 - 4.5.2A
вот:
http://file.qip.ru/file/84461884/a8d824c8/MPlayer.html
marvin_89
сообщение 18.6.2009, 7:47
abelenki спасибо!
Добавлено позже (18.6.2009, 10:52):
abelenki
сообщение 18.6.2009, 7:54
Из: Russia, Perm
Цитата(marvin_89 @ 18.6.2009, 13:47) *
abelenki спасибо!
устанавливать, как все MPKG-пакеты ты устанавливаешь.
marvin_89
сообщение 18.6.2009, 7:58
а как я устанавливаю MPKG-пакеты ? laugh.gif до этого ещё не разу их не устанавливал .
Сообщение отредактировал marvin_89 - 18.6.2009, 7:58
S.E.R.E.G.A.
сообщение 18.6.2009, 10:22
Из: Волгодонск
marvin_89,
зайди в z6manager пролистай до конца в право и выбири пункт: Packages to insall
marvin_89
сообщение 18.6.2009, 10:38
у меня последний пунтк z6manage это список скинов . а сами MPKG-пакеты не важно куда на карту кидать ?
Demonius
сообщение 19.6.2009, 23:49
Пользователь №: 82 484
Модель телефона: V500 & ROKR Z6
Прошивка: motonice & PE3.. 4FR
народ а как руссифицировать Z6manager в этой сборке?
Sniper2009
сообщение 2.8.2009, 17:20
Из: Ukraine
Пользователь №: 203 764
Модель телефона: motorola xprt
Прошивка: android 2.3.5.
А не мог бы кто нибудь выложить файл devdetail.wbxml (нахожится по адречсу ezxlocal/download/appwrite/setup/devdetail.wbxml)только после полного сброса телефона когда в стандартной опере,не установлны профили?Буду очень благодарен
спасибо уже не надо
Сообщение отредактировал Sniper2009 - 3.8.2009, 9:23
CherT
сообщение 19.8.2009, 14:52
Из: РБ Минск
Пользователь №: 183 709
Модель телефона: MOTOROLA Z6
Прошивка: 46R + LM SP2
Народ помогите разобраться . Не уверен что это из-за мода, но раньше до прошивки такого вроде не было. Если зажать в любой момент вправо на пару секунд то выскакивает на весь экран окно с некой информацией причем меняющейся и что это не понятно вот пример:
P Serving Misc А
BC0815s * 47.068B
BC0815 Egid00636
ну и так в том е духе много чего написано...
-POSHIK-
сообщение 19.8.2009, 15:42
Из: Днепропетровск
Пользователь №: 137 121
Модель телефона: Z6
Это из-за прошивки мода. Это информация про сети, соты... Как убрать не знаю, давно читал про эту штуку, кажется что то в инженерном меню или флексбите нужно отключить
CherT
сообщение 20.8.2009, 8:13
Из: РБ Минск
Совершенно верно, вчера накопал инженерное меню там FTS Options там FTS Availbility там установить параметр off для отключения.
Но вот появился новый вопрос :
не все проверял но насчет txt могу с полной увереностью заявить что тело не открывает их никак, пробывал раз 10 разные файлы. и еще на скринах видно меню в виде иконок, а не списка, у меня 2 раза переключалось в такой режим само как-то но потом возвращалось к списку. Это баг или глюк или как это включить: http://i41.tinypic.com/4ilbva.png
Сообщение отредактировал CherT - 20.8.2009, 8:15
Waver
сообщение 8.10.2010, 7:46
Из: Конотоп
Пользователь №: 218 714
Модель телефона: RIZR Z6, ROKR E8
Прошивка: LinuxMod SP2 RE
вопрос следующий: на СТОКе при зажатии во время разговора зелёной кнопки включается диктофон. на МОДе подобного поведения не наблюдается. как бы мне пошаманить, шобы всё-таки диктофон во время разговора можно было вызвать нажатием одной-единственной кнопки?
amatory666
сообщение 25.10.2010, 1:01
Пользователь №: 146 806
Модель телефона: E398,K1,Z6
Прошивка: ковыряю еще))
ребят,доброе время.
заранее извиняюсь если где-то писали или уже кого-то тыкали нужными частями тела... pardon.gif
вообщем вопрос такой: купил z6 радости полные штаны...нашел прошивку linuxmod 3.0 у испанцев,вроде все гуд,но не могу понять как ставить mpkg приложения!? helpsmilie.gif
VINRARUS
сообщение 25.10.2010, 10:00
Термоядерный
Из: Чорнобиль
Пользователь №: 211 044
Прошивка: 740 MHz: Z6 and ZN5
youtu.be/A_yQLYLiSGQ
Во первых: поздравляю с приобретанием недорогого СУПЕРМОЩНОГО тела! dribble.gif clap1.gif
Во вторых: поставь себе лучше "Project Evolution 3.1" от отечественного производителя grin.gif , там много преимуществ, да и PEP пакетов щас намного больше чем MPKG.
Правда на мотофане этой прошы нету, у нее свой сайт есть, поетому введи в гугиле "Project Evolution 3.1".
amatory666
сообщение 25.10.2010, 10:55
VINRARUS
просто,тут много мнений что лучше,кто-то говорит что mpkg устарело,а рер "разворачивает на всю",кто-то наоборот. и была у меня такая проблема,что после установки РЕ 2. тело жестоко грелось и конфиги проца с тела я немог отредактировать,и были жестокие тупняки,а вот с этим все норм...только с установкой пакетов разобраться не могу(
Сообщение отредактировал amatory666 - 25.10.2010, 10:55
VINRARUS
сообщение 25.10.2010, 11:56
Термоядерный
Из: Чорнобиль
amatory666, в PE для установки пакетов нада просто кликнуть на рер пакет с диспетчера файлов, а в LM точно незнаю, но вроде в z6manager можна выбирать што установить.
Ну в РЕ 3.1 я такого незаметил, и к томуже LM на 46R, а РЕ на 4FR, с которой тел дольше жывет. И торможение тела с РЕ устраняется одним скриптом (там на форуме есть).
amatory666
сообщение 25.10.2010, 18:11
ОК,пасибо за инфу grin.gif ...надо попробывать)))займусь сегодня ночером)))
[FLash] LinuxMod SP2 "Rebirth Edition" · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 4.8.2025, 21:14
