abstract mp v3x by uwie, abstract mp v3x by uwie
uwie
сообщение 11.4.2009, 6:55
Пользователь №: 183 590
Модель телефона: v3x
firmware: E6P firmware
flex: abstract
drm: historical drm
skin: evo, historical, heartless, extremerazr, russomax, desolate, blackmmv2
font: 26 fonts en ita ru ukr spain turkish with all itap
java: itunes, ebuddy, DAP, Google maps, VirtualCorelet, Wincore, YBlite, MMA mobile editor, Skintools, mp3 tools, ctheme, my space
shortcut using videocall key
videocall key + 1 = corelet
videocall key + 2 = Itunes
videocall key + 3 = virtual corelet
videocall key + 4 = wincore
videocall key + 5 = skin
to unload corelet:
1. itunes = press '#' then left soft key then choose 'red circle with cross inside'
2. virtual corelet = press menu then unload VC
3. wincore = press start then unload
to change corelet
unload first corelet which running then use the shortcut that i explained above, then call corelet (videocall key + 1)
attention : the heap is small and this was max heap, so don't be surprised if corelet closed suddenly with message application error..just run corelet with shortcut again and call corelet again...
about elf (press smartkey)
1. iTvolume.elf.. this elf to make itunes sound more able to be controlled..when u call corelet itunes.. run iTvolume.elf first then call corelet.. then press the volume key up until it reach max or volume down until zero in itunes..
after that use number 2 to increase the volume and number 8 to decrease the volume
2. getmypds.elf... this elf to backup your pds in drive a...
3. headset.elf... .
4. funlights.elf... the flash and keypad will blink blink if we have incoming call
5. autolock.elf... it can lock automaticly
6. Stime.elf.. it can show the time when we play java application
7. light.elf.. it was created for e770v but it can be used for v3x too.. it increase the brightness and make it dark if we do nothing to our phone..
8. hex editor.elf.. its for hex editing..
9. BT saver.elf... its recomended to give autorun.. i save all data that we download using our browser java or dekstop browser in b/recieved/
10.switch to boot.. it can used to go to bootloader.. but i don't recommend this when u want to flash an mp...
11.multibkg. elf... zedder said it can change background every 8 minutes.. it's working
12.flex editor.elf.. it's for flex (cg2 code) editing.. u can add some function using LG Flex editor
something that u must know about cg2 code or abstract flex
1. all network band i have included..
2. browser key can be used to take screenshot..
3. videocall key can be used to shortcut.. if u want to make shortcut.. just press and hold videocall key
4. smartkey for elf
5. when u play java,, u won't be distrubbed by sms.. java application priority
about cg1..
1. dualboot..
2. bootscreen changed..
3. 'software update' in phone status be replaced with enter bootloader..
4. C+C to turn on flash light when u got black out...
about drm..thanks to citroen..
it used historical drm..
about font.. thanks to $mert nick.. for creating this multifont 26 font en italy russia ukraina spain turkish with all itap...
thanks to slay to convert to different bootloader..
how to flash
1. download the correct bootloader..full charge battery first.. then backup your websession first,, flash with motokup only with slow speed..then upload your backup websession using Bezols's P2KTools P2K_Toolsor p2kcommander..
2. create folder b/recieved --(btsaver.elf function) can save any downloaded file that unsupported by motorola
3. create folder e/mobile/picture/multi (place your wallpaper to be changed automaticly every 8 minutes... multi bkg.elf)
note:
i didn't responsible for anything.. take your own risk..read all guides before flashing.. hope u like it.. don't compare with another mp..each mp has minus and plus.. any critic i'll accept to improve it next time
i want to thanks to
$mert (nick)-for multifont 25 font spain, italy en russia,turkish, with all itap..
slay- for some wallpaper and converting to another bootloader
citroen- historical drm and inspiring alot and so many help,and historical skin
zedder, mig, chick_v, only sun for some elf
semssedin- for lending me some icon drm and heartless skin and some question
paule213- for evo, and russomax skin
extreme razr v3x skin author- for extreme razr skin
black mmv2 skin author- for black mmv2 skin
desolate author- for desolate skin
elvis, for answering some question
and all people who helps me alot and answering my dump question...
forgive me if there is some one left that i mentioned...
dowload
0671 -- Download
0681/0682 -- Download
0683/0684 -- Download
Сообщение отредактировал citroen - 29.9.2009, 19:26
uwie   abstract mp v3x by uwie   11.4.2009, 6:55
citroen   uwie, nice/ good work   11.4.2009, 9:50
uwie   thanks to all people in motofan.. sory for beginne...   11.4.2009, 10:47
mettis   как я понимаю в этом монстре нету русского языка?   11.4.2009, 11:38
citroen   mettis, а 1 пост читать кто будет ????   11.4.2009, 11:40
mettis   mettis, а 1 пост читать кто будет ???? упс, т...   11.4.2009, 14:08
jzy20   great you did it   12.4.2009, 1:37
uwie   thanks man.. jzy20 is there any elf for v3x..??   12.4.2009, 6:21
jzy20   uwie, now? NO we can not get the src of the othe...   13.4.2009, 2:01
CrashX   good work!!! а как он сделал дрм, вер...   13.4.2009, 5:55
citroen   CrashX, верикальный дрм я еще давно выкладывал н...   13.4.2009, 6:30
uwie   he2x.. so many thanks for citroen.. i dont underst...   13.4.2009, 12:55
bullof   Всем привет! Сitroen, можно подробнее про эльф...   16.4.2009, 14:35
bullof   Всем привет! Сitroen, можно подробнее про эль...   18.4.2009, 4:13
Nicons2008   Прошивка поёдет на Е770?? citroen: нет.   17.4.2009, 15:28
citroen   bullof, сегодня поставлю себе прошу. завтра отдел...   18.4.2009, 12:39
Хэнкок   тема воообще куууул!!!! круче неё ...   20.4.2009, 13:39
zeDDer   citroen, если ты хочешь ставить ради того что бы с...   21.4.2009, 15:58
citroen   zeDDer, да лан. :) поюзаю пару часиков. может ещ...   22.4.2009, 8:27
bullof   Citroen, все в ожидании!   24.4.2009, 17:53
e.n.o.t   самый стабильно рмаботающий монстр с эльфами, 10 д...   25.4.2009, 11:51
citroen   Эльфы с монстра. Говорите что еще Вам надо с этого...   26.4.2009, 20:53
jzy20   citroen, anyone who still work on elves? i do no...   27.4.2009, 2:36
citroen   jzy20, zeDDer , Chik , MIG Search for them throu...   27.4.2009, 8:16
bullof   Citroen спасибо за эльфы! И вопрос, почему в э...   27.4.2009, 13:59
citroen   bullof, недоделан наверное у меня бывает такое. п...   29.4.2009, 12:49
lonely_boy   citroen, Обьясни мне пожалуйста по этим эльфам сл...   2.5.2009, 16:15
citroen   light.elf - вообще, по мне, так не нужный эльф.......   3.5.2009, 11:57
e.n.o.t   iTvolume.elf- в iTunes с помощью кнопок 2 и 8 норм...   3.5.2009, 19:26
lonely_boy   e.n.o.t, а iTvolume.elf в VC может нормально её ...   4.5.2009, 10:35
lonely_boy   citroen, а можешь с него ещё мультиленг слить и в...   5.5.2009, 3:45
e.n.o.t   lonely_boy только в iTunes   6.5.2009, 8:54
MonstrE1   cool monsterpack дейстивельно понравился монстр м...   9.5.2009, 10:20
maxsena   Поставил данный монстр и теперь у меня во всех ась...   14.5.2009, 13:16
citroen   maxsena, скорее всего из-за того что стоит старый...   14.5.2009, 19:00
maxsena   А где взять откаты с этого монстра? И еще вопрос: ...   15.5.2009, 4:46
SoiL   Ребята, я подскажите, как сменить дрм тут? Только ...   5.6.2009, 20:10
citroen   SoiL, шить обычно. но после прошивки смени все ск...   6.6.2009, 6:42
Hekp@   Добавлено (6.6.2009, 21:14) Здравствуйте, я проши...   6.6.2009, 21:06
Hekp@   Мульти ленг я уже скинул сам, спасибо за помощь за...   9.6.2009, 20:31
TitMan   как вырубить DRM по бокам...а то когда играешь в я...   11.6.2009, 17:12
citroen   TitMan, ставить горизонтальный дрм. и заменить ск...   12.6.2009, 9:01
total v3   Обновите ссылку для 0682 а то она уже не доступна   26.9.2009, 6:44
Snejny   total v3, http://www.4shared.com/file/135684934/55...   29.9.2009, 17:28
total v3   Огромное спасибо)   2.10.2009, 3:52
total v3   Парни а как через P2k Ae назначить на кнопку видео...   8.10.2009, 22:07
citroen   total v3, сколько ты еще будешь задавть этот вопр...   9.10.2009, 17:24
total v3   Ну я не только у тебя спрашиваю,может кто нормальн...   9.10.2009, 21:05
A-lex   Не могу найти откаты к этой прошивки(требуется отк...   29.4.2010, 13:43
citroen   A-lex, напомни что за патч хипа стоит ?   30.4.2010, 9:54
A-lex   На 3008 kb...   30.4.2010, 12:37
abstract mp v3x by uwie, abstract mp v3x by uwie · Кастомные прошивки для Motorola 3G · Forum
Текстовая версия Сейчас: 3.9.2025, 8:33
