Прошивка Basic Plus, V8
abelenki
сообщение 13.4.2009, 2:44
Из: Russia, Perm
Пользователь №: 94 097
Модель телефона: Atrix 4G
Прошивка: 2.3.6 - 4.5.2A
What is Basic Plus?
It is a basic unbranded NO_RSA firmware based on 80.46.1BR for 512MB V8 and 80.56.1BR for 2GB V8 with added 5 customization menus
(Change Bootlogo, Font Changer, Startup-/Shutdown Sound, Alarm Clock Timer and Reminder Sound), USB-Lan and Swap memory by default. That's it!
Now this space saving allowed to return to the old system of changing the language by flashing the CG46.
That is the Basic part!
The Plus part includes a Package Manager and you can install what you want and leave out what you don't want. There are 18 packages supplied, which would include the complete Evo 3 range, some have been upgraded, like zLauncher is version 2.1, pictureflow is upgraded and SlideShow is a development of pictureflow made by DeJe. You just have to copy the packages (*.tar.gz files) into /ezxlocal/download/mystuff/package. The Package Manager (you find it in the Package folder in the Main Menu) will install and uninstall packages. During installation you have to enter a menu name, for example you install zLauncher then you can call the menu whatever you want (e.g My Filesystem or Mein Dateienfresser), which is nice if you do not use english as your language. Secondly during installation you can associate file extentions, which most packages do not need. Also, because most Mods now come with a selection of languages and the packages are installed in /ezxlocal/download/mystuff/packages/apps, which is read/write filesystem, you can change the menus to your language. All packages menus will be installed in the Package folder below Package Manager, you either leave them there or you move them to somewhere else, your choice.
USB-Lan and Swap Memory are in the Settings menu, USB-Lan at the beginning and Swap Memory at the end, as you need to use Swap Memory only once to set up the swap file and activate it. After each reboot the swap file gets automatically activated. I have not included the Java HEAP Setting package as I have set the the default HEAP size to the maximum of 4096KB by default.
If you really MUST use Windows Explorer instead of FTP then shutdown the swap file first then change to USB Setting Memory Card and connect with USB cable to PC, the V8 will not hang itself.
MPlayer, because of its /mmc/mmca1/Programms path requirement has been not supplied as a package. However the MPlayer menu exists under Multimedia and all you have to do is copy the included MPlayer folder into /ezxlocal/download/mystuff/Programms on the 512MB V8 or into /mmc/mmca1/Programms on the 2GB V8, that's all.
Another change is that the ezx_flexbit.cfg is now under /ezxlocal/download/appwrite/flexbit, this allows to change the flexbit without the need to flash a CG43 every time you edited the ezx_flexbit.cfg. Just copy your new ezx_flexbit.cfg file into this folder and reboot.
I have tried to make this firmware as simple as possible, as from the comments about Evo 3 saw that a lot just could not get the hang of the different language system and how to handle it.
The need for a Package Manager was always high on the list, also the result of comments and requests like "we do not need this, but can we have that..." and then "we do not need that, but can we have this...", so now everybody can decide themselves what they want and what not.
There are already 2 package management system around (PEP and mpkg), so why creating a new one? Well, I was hoping that there would be a PEP for V8, but that project got put on hold and by request of the PEP creators I could not port it to V8, so that left only mpkg. Now mpkg might be fine for the Z6, but it is not good enough for the V8 and the reasons are that mpkg packages are installed from and onto the Z6 SD card (/mmc/mmca1) this path exists only on 2GB V8, but not on 512MB V8, secondly mpkg packages for Z6 do not work on V8, they need modification in order to work on the V8 (huge potential for future post " I installed mpkg package, but it does not work ."). Thirdly the icon management of mpkg produces only black exclamation marks on yellow background (mpkg uses one icon for std and ani icons, no small icon). which honestly does not look nice to have on your phone. Fourthly the AppID creation is rather simple and the V8 always has been quite fuzzy with "home made" AppID's. So, I either rewrite mpkg to fit V8 and change Z6 mpkg packages into V8 mpkg packages, which still leaves the door wide open for people to install Z6 mpkg packages on V8 and wonder why they do not work. So I decided against that option and created my own package management. Anyway Linux is all about choice, so there you go!
You might find that the Customize menu looks a bit different, this was done on purpose.
OK, I could not have done this without the help, inspiration and testing from DeJe (faq4mobiles.de) and DaRk_dOg (MMUS et al.), their work, ideas and contribution helped to shape this firmware. THANKS!
But a big thank you has to go out to all the other unnamed modders, who's work, modified or not, found their way also into this firmware. THANK YOU!
As with all my work, this firmware is also free for everybody to change, use parts of it or simply print out the code and wallpaper your room with it.
Автор:
rasputin007
Оригинальный топик:
modmymoto.com
Описание:
1. Прошивка No RSA.
2. Лэнгпак шьётся по-старому, через RSDLite.
3. Теперь дополнительные программы устанавливаются пакетами, аналогично PEP, только они имеют свой формат. (т.е. теперь можно выборочно ставить то, что тебе нужно). Пакеты нужно копировать в /ezxlocal/download/mystuff/package, а потом инсталлировать или дизинсталлировать через Package Manager. В процессе инсталляции пакета, вы можете присвоить ему любое имя, а также ассоциировать с ним любые расширения (для большинства пакетов это не нужно).
4. USB-Lan и Swap Memory находятся в меню Settings. Swap Memory нужно запустить и настроить всего лишь один раз. Он активируется автоматически после ребута или включения телефона.
5. Если не активировать файл подкачки (Swap Memory), телефон теперь можно подключать в режиме мемори-карты, и при этом он зависать не будет.
6. Java HEAP автоматически установлен на максимальное значение - 4096KB.
7. MPlayer не включен в виде пакета, а устанавливается по-старому. Т.е. просто скопируйте его в /ezxlocal/download/mystuff/Programms на V8 512MB или в /mmc/mmca1/Programms на V8 2GB. Ярлык на него уже установлен в прошивке и находятся в Multimedia.
8. Файл ezx_flexbit.cfg теперь находится по этому пути - /ezxlocal/download/appwrite/flexbit. Теперь его можно спокойно редактировать, перезаливать в телефон и перезагружаться, чтобы изменения вступили в силу (разборка, редактирование, сборка и прошивка CG43 больше не требуется).
9. Видео-камера теперь снимает в разрешении 352x288.
Порядок прошивания:
1. Bootloader A3.CF (если у вас какой-либо другой бутлоадер).
2. Bootloader A3.CF No RSA.
3. Прошивка Basic Plus Update (прошивайте версию прошивки, соответствующую вашей модели телефона - 512MB или 2GB. Для Luxury Edition прошивайте версию 2GB).
4. Лэнгпак LP002EE.
Файлы:
Bootloader A3.CF
512MB Basic Plus Update
2GB Basic Plus Update
LP002EE - UK English, German, Russian, Ukrainian, French, Spanish & Portuguese; Russian voice commands only
Basic Plus Update Packages
MPlayer
V8 Modding Guide
Сообщение отредактировал XXX_S_B - 20.2.2013, 16:09
abelenki   Прошивка Basic Plus   13.4.2009, 2:44
KLON 3   Ну и кто нибуть попробовал это чудо? Хотелось бы у...   13.4.2009, 10:10
abelenki   Ну и кто нибуть попробовал это чудо? Хотелось бы ...   13.4.2009, 10:12
ben1508   А ассациация расширений к мплееру как сделать?   13.4.2009, 13:30
ashy57   Работает ли в данной прошивке (в частности, в верс...   14.4.2009, 18:23
ben1508   у меня и в соединении флеш не соединяется. телефон...   14.4.2009, 19:18
любопытнный   В этой прошивке есть звук напоминания о пропущенно...   16.4.2009, 5:48
abelenki   3 новых пакета от kleto, портированные DaRk_dOg с ...   17.4.2009, 2:24
DaRk_dOg   3 новых пакета от [b]kleto, портированные DaRk_dO...   17.4.2009, 12:15
Advokat_d   Вот сделал скрины Прикольная прошивка clap;a...   17.4.2009, 14:18
OlgaJah   Ставила 2 раза прошивку на телефон и 2 раза телефо...   18.4.2009, 11:43
KLON 3   Advokat_d выложи плиз свой flexbit.С меня +   18.4.2009, 17:12
Advokat_d   Advokat_d выложи плиз свой flexbit.С меня + ДЕ...   18.4.2009, 17:41
rasputin007   Я нашел ошибку с 2GB версия, своп памяти не устана...   18.4.2009, 18:22
OlgaJah   Я нашел ошибку с 2GB версия, своп памяти не устан...   19.4.2009, 12:17
rasputin007   UPDATE I have updated Basic Plus with the package ...   19.4.2009, 19:08
OlgaJah   UPDATE I have updated Basic Plus with the package...   20.4.2009, 6:49
rasputin007   Thank You Добавлено позже (20.4.2009, 11:38): Пр...   20.4.2009, 21:48
OlgaJah   Luckely there are other 2GB V8 firmwares, that mi...   21.4.2009, 8:06
rasputin007   I tried them but liked Evolution 3 more as it is ...   21.4.2009, 23:32
abelenki   в закреплённом сообщении обновлена прошивка 512MB ...   21.4.2009, 2:39
abelenki   2 новых пакета, портированных DaRk_dOg: 1. vShutD...   24.4.2009, 2:39
SSDD   Возник вопрос. Ни у кого не было проблем с bluetoo...   26.4.2009, 8:34
Ig-man   Basic Plus Update Packages - это что? куда и чем е...   1.5.2009, 12:17
NosFire   [b]Basic Plus Update Packages - это что? куда и ч...   1.5.2009, 12:47
tursunbay   MPlayer не работает.   2.5.2009, 10:12
abelenki   MPlayer не работает. работает. качай его из зак...   2.5.2009, 12:42
Shadow09   А где можно найти ещё приложений на эту прошивку??...   11.5.2009, 4:25
abelenki   А где можно найти ещё приложений на эту прошивку?...   11.5.2009, 5:06
Shadow09   все приложения, которые существуют для Basic Plus...   11.5.2009, 11:48
rasputin007   все приложения, которые существуют для Basic Plus...   13.5.2009, 16:01
Vermin   Теоретически переделать не так сложно. Я сделал па...   11.5.2009, 14:02
Shadow09   А куда Package Manager устанавливает файлы??? Где ...   12.5.2009, 11:18
Ant-ON   А куда Package Manager устанавливает файлы??? Где...   12.5.2009, 11:58
FFEHOT   Ребят, а есть ленг с русским нормальным русским яз...   12.5.2009, 12:55
Chepurnoff   Он их пишет туда же куда и ява пишется... Не, тута...   12.5.2009, 19:39
Shadow09   Chepurnoff, а где иконки от приложений он(Package ...   13.5.2009, 4:21
любопытнный   Где он этот фонт менеджер? Как-то всё нужно делать...   13.5.2009, 10:37
ravex   народ меню в мплеере как вызывается? у меня его по...   13.5.2009, 17:56
Chepurnoff   Меню - Customise - второй таб - Change Font Вота...   13.5.2009, 18:10
Vermin   Кому надо собрал в пакет zTaskMan от Ant-ON. Запус...   14.5.2009, 9:27
Chepurnoff   Сделал что-то типа обновления. Что получаем после...   16.5.2009, 17:36
Vermin   Вот сделал для 2Gb версии. А то менеджер пакетов н...   18.5.2009, 2:53
NosFire   Вот сделал для 2Gb версии. А то менеджер пакетов ...   20.5.2009, 19:30
Vermin   После апдейта появился не очень то приятный баг. ...   21.5.2009, 2:48
NosFire   Есть такое, Спасибо! Исправил! Не созда...   21.5.2009, 10:32
Vermin   Вот еще несколько пакетов. - Программа для редакт...   18.5.2009, 14:48
KLON 3   Вот еще несколько пакетов. Это только у меня или...   19.5.2009, 5:39
Vermin   Понял в чем причина. Они для 2Gb версии. Я про 512...   19.5.2009, 14:06
Shadow09   Некоторые приложения, которые я смог перенести на ...   20.5.2009, 4:29
RocketDog   А есть возможность на этой прошивке давать права J...   20.5.2009, 21:11
Shadow09   А есть возможность на этой прошивке давать права ...   21.5.2009, 4:21
Vermin   Выкладываю SoftBox. По просьбам трудящихся так ска...   21.5.2009, 14:26
NosFire   :lol: Нашел еще 1 баг и 1 недоработку, насчет бага...   21.5.2009, 18:17
Vermin   :lol: Нашел еще 1 баг и 1 недоработку, насчет баг...   23.5.2009, 14:12
RocketDog   а что конкретно кидать в /ezxlocal/download/mystuf...   21.5.2009, 18:35
NosFire   а что конкретно кидать в /ezxlocal/download/mystu...   21.5.2009, 18:44
fillrate   Странный глюк. Подключаю мотор в режиме флешки. Ко...   24.5.2009, 17:43
ravex   Странный глюк. Подключаю мотор в режиме флешки. К...   25.5.2009, 23:59
Антоха-ха-ха   После установки Лэнг пака Комп флешку видит, но за...   28.5.2009, 6:56
любопытнный   А как на этой прошивке ставить скины? Добавлено п...   22.6.2009, 7:01
Advokat_d   любопытнный, скины сливай в папки /ezxlocal/downl...   23.6.2009, 9:28
любопытнный   А на карту? Добавлено позже (23.6.2009, 15:49): A...   23.6.2009, 12:39
NosFire   Создавай новую тему, или копию (потом редактируешь...   23.6.2009, 15:41
любопытнный   Свою проблему решил очень просто:удалил папки Skin...   24.6.2009, 12:39
Let   любопытнный, или ещё кто, обьясните, что такое ...   25.6.2009, 11:20
любопытнный   Прога для установки скинов-Темеменеджер   26.6.2009, 7:37
abelenki   в закреплённом сообщении обновлено V8 Modding Guid...   29.6.2009, 4:11
Let   А можно краткий смысл того, что несёт в себе обнов...   29.6.2009, 10:30
abelenki   А можно краткий смысл того, что несёт в себе обно...   29.6.2009, 10:36
D-flasher   скиньте пожалуйста пакеты:slideShow,pictureFlow,vW...   29.6.2009, 15:02
Frezerovshik   Объясните как на этом флэше восстановить бэкап? а ...   9.7.2009, 7:23
abelenki   Объясните как на этом флэше восстановить бэкап? а...   9.7.2009, 7:26
Ig-man   расскажите вкратце, что за пакеты входят в Basic_P...   11.7.2009, 15:18
abelenki   расскажите вкратце, что за пакеты входят и[выреза...   11.7.2009, 15:35
ashy57   В этой прошивке режим Media Sync не функционирует ...   11.7.2009, 16:03
Ig-man   А куда делась в "органайзер-справка"? У ...   13.7.2009, 10:37
abelenki   кто-нибудь может портировать эмулятор Z6Pico и игр...   15.7.2009, 4:12
A.C.   abelenki так ведь: messages>Templates>Text ...   15.7.2009, 6:47
Vermin   Выкладываю эмулятор и игру [url=http://rapidshar...   15.7.2009, 14:41
любопытнный   Vermin, Спасибо! Работает,установил со второй ...   16.7.2009, 13:49
abelenki   Quake работает великолепно. я даже заменил текущий...   16.7.2009, 15:12
Vermin   а вот Z6Pico устанавливается нормально, но во вре...   17.7.2009, 0:20
abelenki   Проверил еще раз, работает. А в /mmc/mmca1/ появ...   17.7.2009, 3:36
Vermin   у меня V8 512MB. Все понятно. В mpkg сделано то...   17.7.2009, 4:50
abelenki   Все понятно. В mpkg сделано тоже для 2Gb. Походу ...   17.7.2009, 5:04
Vermin   просьба выложить ScummVM для Basic Plus - тоже хо...   17.7.2009, 5:54
abelenki   теперь Z6Pico устанавливается правильно - в папк...   19.7.2009, 2:47
Vermin   RockBox port Z6/V8 by CepiPerez.   22.7.2009, 0:10
Ig-man   RockBox port Z6/V8 by CepiPerez. спасибо! ...   29.7.2009, 17:51
abelenki   очень хочется для v8: просто работащий эквалайзер...   30.7.2009, 3:06
Fenniks   тыкните пожалуйста где почитать чтоб расположение ...   5.8.2009, 11:14
Vermin   тыкните пожалуйста где почитать чтоб расположение...   6.8.2009, 6:03
Advokat_d   А игр одоптированных Duke Nukem 3D (eduke32). Dos...   17.8.2009, 11:00
Vermin   А игр одоптированных Duke Nukem 3D (eduke32). Do...   17.8.2009, 13:48
любопытнный   Advokat_d, Давай 100% рабочие РЕР или MPKG я попро...   18.8.2009, 8:24
pirsn   Прошился этой прошивкой, но забыл зарядить батарею...   21.10.2009, 11:12
pirsn   Ранее критиковал модифицированные прошивки, но эта...   21.10.2009, 14:26
Vermin   Ранее критиковал модифицированные прошивки, но эт...   24.10.2009, 14:47
pirsn   Устал бороться, откатился на стандартую R601 G 8...   26.10.2009, 9:21
2 страниц V  1 2 >
Прошивка Basic Plus, V8 · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 18.7.2025, 16:41
