5 страниц V < 1 2 3 4 > »
Прошивка Basic Plus, V8
abelenki
сообщение 13.4.2009, 2:44 Закрепленное сообщение!
Из: Russia, Perm
Пользователь №: 94 097
What is Basic Plus?
It is a basic unbranded NO_RSA firmware based on 80.46.1BR for 512MB V8 and 80.56.1BR for 2GB V8 with added 5 customization menus
(Change Bootlogo, Font Changer, Startup-/Shutdown Sound, Alarm Clock Timer and Reminder Sound), USB-Lan and Swap memory by default. That's it!
Now this space saving allowed to return to the old system of changing the language by flashing the CG46.
That is the Basic part!
The Plus part includes a Package Manager and you can install what you want and leave out what you don't want. There are 18 packages supplied, which would include the complete Evo 3 range, some have been upgraded, like zLauncher is version 2.1, pictureflow is upgraded and SlideShow is a development of pictureflow made by DeJe. You just have to copy the packages (*.tar.gz files) into /ezxlocal/download/mystuff/package. The Package Manager (you find it in the Package folder in the Main Menu) will install and uninstall packages. During installation you have to enter a menu name, for example you install zLauncher then you can call the menu whatever you want (e.g My Filesystem or Mein Dateienfresser), which is nice if you do not use english as your language. Secondly during installation you can associate file extentions, which most packages do not need. Also, because most Mods now come with a selection of languages and the packages are installed in /ezxlocal/download/mystuff/packages/apps, which is read/write filesystem, you can change the menus to your language. All packages menus will be installed in the Package folder below Package Manager, you either leave them there or you move them to somewhere else, your choice.
USB-Lan and Swap Memory are in the Settings menu, USB-Lan at the beginning and Swap Memory at the end, as you need to use Swap Memory only once to set up the swap file and activate it. After each reboot the swap file gets automatically activated. I have not included the Java HEAP Setting package as I have set the the default HEAP size to the maximum of 4096KB by default.
If you really MUST use Windows Explorer instead of FTP then shutdown the swap file first then change to USB Setting Memory Card and connect with USB cable to PC, the V8 will not hang itself.
MPlayer, because of its /mmc/mmca1/Programms path requirement has been not supplied as a package. However the MPlayer menu exists under Multimedia and all you have to do is copy the included MPlayer folder into /ezxlocal/download/mystuff/Programms on the 512MB V8 or into /mmc/mmca1/Programms on the 2GB V8, that's all.
Another change is that the ezx_flexbit.cfg is now under /ezxlocal/download/appwrite/flexbit, this allows to change the flexbit without the need to flash a CG43 every time you edited the ezx_flexbit.cfg. Just copy your new ezx_flexbit.cfg file into this folder and reboot.
I have tried to make this firmware as simple as possible, as from the comments about Evo 3 saw that a lot just could not get the hang of the different language system and how to handle it.
The need for a Package Manager was always high on the list, also the result of comments and requests like "we do not need this, but can we have that..." and then "we do not need that, but can we have this...", so now everybody can decide themselves what they want and what not.
There are already 2 package management system around (PEP and mpkg), so why creating a new one? Well, I was hoping that there would be a PEP for V8, but that project got put on hold and by request of the PEP creators I could not port it to V8, so that left only mpkg. Now mpkg might be fine for the Z6, but it is not good enough for the V8 and the reasons are that mpkg packages are installed from and onto the Z6 SD card (/mmc/mmca1) this path exists only on 2GB V8, but not on 512MB V8, secondly mpkg packages for Z6 do not work on V8, they need modification in order to work on the V8 (huge potential for future post " I installed mpkg package, but it does not work ."). Thirdly the icon management of mpkg produces only black exclamation marks on yellow background (mpkg uses one icon for std and ani icons, no small icon). which honestly does not look nice to have on your phone. Fourthly the AppID creation is rather simple and the V8 always has been quite fuzzy with "home made" AppID's. So, I either rewrite mpkg to fit V8 and change Z6 mpkg packages into V8 mpkg packages, which still leaves the door wide open for people to install Z6 mpkg packages on V8 and wonder why they do not work. So I decided against that option and created my own package management. Anyway Linux is all about choice, so there you go!
You might find that the Customize menu looks a bit different, this was done on purpose.
OK, I could not have done this without the help, inspiration and testing from DeJe (faq4mobiles.de) and DaRk_dOg (MMUS et al.), their work, ideas and contribution helped to shape this firmware. THANKS!
But a big thank you has to go out to all the other unnamed modders, who's work, modified or not, found their way also into this firmware. THANK YOU!
As with all my work, this firmware is also free for everybody to change, use parts of it or simply print out the code and wallpaper your room with it.
Автор:
rasputin007
Оригинальный топик:
modmymoto.com
Описание:
1. Прошивка No RSA.
2. Лэнгпак шьётся по-старому, через RSDLite.
3. Теперь дополнительные программы устанавливаются пакетами, аналогично PEP, только они имеют свой формат. (т.е. теперь можно выборочно ставить то, что тебе нужно). Пакеты нужно копировать в /ezxlocal/download/mystuff/package, а потом инсталлировать или дизинсталлировать через Package Manager. В процессе инсталляции пакета, вы можете присвоить ему любое имя, а также ассоциировать с ним любые расширения (для большинства пакетов это не нужно).
4. USB-Lan и Swap Memory находятся в меню Settings. Swap Memory нужно запустить и настроить всего лишь один раз. Он активируется автоматически после ребута или включения телефона.
5. Если не активировать файл подкачки (Swap Memory), телефон теперь можно подключать в режиме мемори-карты, и при этом он зависать не будет.
6. Java HEAP автоматически установлен на максимальное значение - 4096KB.
7. MPlayer не включен в виде пакета, а устанавливается по-старому. Т.е. просто скопируйте его в /ezxlocal/download/mystuff/Programms на V8 512MB или в /mmc/mmca1/Programms на V8 2GB. Ярлык на него уже установлен в прошивке и находятся в Multimedia.
8. Файл ezx_flexbit.cfg теперь находится по этому пути - /ezxlocal/download/appwrite/flexbit. Теперь его можно спокойно редактировать, перезаливать в телефон и перезагружаться, чтобы изменения вступили в силу (разборка, редактирование, сборка и прошивка CG43 больше не требуется).
9. Видео-камера теперь снимает в разрешении 352x288.
Порядок прошивания:
1. Bootloader A3.CF (если у вас какой-либо другой бутлоадер).
2. Bootloader A3.CF No RSA.
3. Прошивка Basic Plus Update (прошивайте версию прошивки, соответствующую вашей модели телефона - 512MB или 2GB. Для Luxury Edition прошивайте версию 2GB).
4. Лэнгпак LP002EE.
Файлы:
Bootloader A3.CF
512MB Basic Plus Update
2GB Basic Plus Update
LP002EE - UK English, German, Russian, Ukrainian, French, Spanish & Portuguese; Russian voice commands only
Basic Plus Update Packages
MPlayer
V8 Modding Guide
Сообщение отредактировал XXX_S_B - 20.2.2013, 16:09
любопытнный
сообщение 22.6.2009, 7:01
Пользователь №: 183 849
Модель телефона: Motorola Accompli 008
Прошивка: ОЧЕРЕДНАЯ
А как на этой прошивке ставить скины?
Добавлено позже (22.6.2009, 10:15):
Пробовал ставить через Темеменеджер-скин установился но в темах его нет,ставил через skins/skins1...то же ничего не получилось.Подскажите плиз,что делать?Если кто знает как Темеменеджер заставить работать с этой прошивкой-отпишитесь!
Advokat_d
сообщение 23.6.2009, 9:28
Пользователь №: 155 462
Модель телефона: V3i,V8 2гига
Прошивка: R601_G_80.56.15R
любопытнный,
скины сливай в папки /ezxlocal/download/mystuff/Skins там 3 папки skin1.skin2.skin3 туда и сливай
любопытнный
сообщение 23.6.2009, 12:39
Прошивка: ОЧЕРЕДНАЯ
А на карту?
Добавлено позже (23.6.2009, 15:49):
Advokat_d, А вшитые Алькали,Пуш на свои можно как-нибудь заменить не разбирая прошивки?
Добавлено позже (23.6.2009, 15:55):
Ну и залил скины в /ezxlocal/download/mystuff/Skins там 3 папки skin1.skin2.skin3 туда и сливай-перезагрузил телефон:как было в темах Алькали,Голден,Индиум и Пуш так и осталось! Сэтой прошивкой хожу недели три-не глючит,вот только со скинами не пойму никак.
NosFire
сообщение 23.6.2009, 15:41
Из: Санкт - Петербург
Пользователь №: 198 449
Модель телефона: е398\v8 2Gb\Atrix
Прошивка: .42r\.1br\CM7.1
Создавай новую тему, или копию (потом редактируешь) и оболочку указывай скин который ты залил. С флешки мона примаунтить, только после ребута слетает это дело
любопытнный
сообщение 24.6.2009, 12:39
Прошивка: ОЧЕРЕДНАЯ
Свою проблему решил очень просто:удалил папки Skins на карте и в телефоне,после этого нормально заработал Темеменеджер,поставил скины на карту и в память телефона.Вдруг понадобится еще кому.Спасибо всем за помощь!
Let
сообщение 25.6.2009, 11:20
Из: г. Барнаул
Пользователь №: 5 459
Прошивка: >_<
любопытнный, или ещё кто, обьясните, что такое "Темеменеджер", с меня +
Vermin, после установки исправленного updater-а не устанавливаются новые пакеты, Package Manager пишет что "Нет пакета для установки", хотя они там имеются, подскажи как это исправить.
У меня телефон тоже не коннектится как флешка, изредка подключается, но при этом виснет намертво, swap не активирован.
любопытнный
сообщение 26.6.2009, 7:37
Прошивка: ОЧЕРЕДНАЯ
Прога для установки скинов-Темеменеджер
Прикрепленный файл ThemeManager_V0.1.1.zip   ( 80.98 килобайт ) Кол-во скачиваний: 167
abelenki
сообщение 29.6.2009, 4:11
Из: Russia, Perm
в закреплённом сообщении обновлено V8 Modding Guide в соответствии со следующим заявлением rasputin007:
Yesterday I found out that the previously mksquashfs command line
mksquashfs /path to CG folder/* /path to where to put CG.smg -le
does NOT include any "hidden" folder like .backup (dot in front of folder name).
This missing of .backup folder in CG36 brings the Reset function to hang the V8.
The correct mksquashfs command line should be without the /*, like
mksquashfs /path to CG folder /path to where to put CG.smg -le
Now hidden folder are included.
Evo 3, Basic Plus and MPKG Basic have this faulty Reset function.
I have updated the V8 Modding Guide and MPKG Basic.
You can just make a CG36 reflash to keep your current setup.
I thought you should know about this and possibly pass this on as this could affect other Motomagx firmwares, when using the "old" style mksquashfs command.
Ras
Сообщение отредактировал abelenki - 29.6.2009, 4:49
Let
сообщение 29.6.2009, 10:30
Из: г. Барнаул
Прошивка: >_<
А можно краткий смысл того, что несёт в себе обновление?
abelenki
сообщение 29.6.2009, 10:36
Из: Russia, Perm
обновлена только прошивка MPKG Basic. остальные нужно обновлять самому.
смысл в том, что rasputin007 неправильно указывал синтаксис комманды mksquashfs, из-за этого не включались скрытые папки типа .backup. как следствие - в этих прошивках не работает Reset (ведёт к зависанию прошивки).
Сообщение отредактировал abelenki - 29.6.2009, 10:37
D-flasher
сообщение 29.6.2009, 15:02
Из: Уфа City
Пользователь №: 179 991
Модель телефона: Nokia 5530
Прошивка: 40
скиньте пожалуйста пакеты:slideShow,pictureFlow,vWeblink
Frezerovshik
сообщение 9.7.2009, 7:23
Пользователь №: 179 253
Объясните как на этом флэше восстановить бэкап? а то в меню ничего подобного ненахожу sad.gif
зы стоял линуксмод 3 но рса
и + к тем, у кого не подключается в режиме флэшки- комп видит 2 диска, но при попытке открытия выдаёт вставьте диск sad.gif(
Сообщение отредактировал Frezerovshik - 9.7.2009, 7:42
abelenki
сообщение 9.7.2009, 7:26
Из: Russia, Perm
есть 2 специальных пакета для этого:
2GBackup.tar.gz
512MBackup.tar.gz
находятся в Basic Plus Update Packages в закреплённом сообщении.
Добавлено позже (9.7.2009, 13:27):
такой прошивки нет. есть Linuxmod Fusion 2.
Сообщение отредактировал abelenki - 9.7.2009, 7:28
Ig-man
сообщение 11.7.2009, 15:18
Пользователь №: 175 583
Модель телефона: Droid Razr Maxx HD
Прошивка: Android 4.4.2
183.46.15.XT926.Verizon.en.US
расскажите вкратце, что за пакеты входят в Basic_Plus_Update_Packages.zip?
мог понять после установки и удаления только:
-zLauncher.tar.gz - файловый менеджер по типу нортона коммандера
-SYSinfo.tar.gz - для показа загрузки проца и мемори
-reboot.tar.gz - не надо жать красную кнопку дважды
-firewall.tar.gz - типа для создания черного списка звонящих, а где узнать поподробней?wink.gif
-equalizer.tar.gz - эквалайзер, но сам не проверял как работает
остались вот эти и из названия не понять:
2GBackup.tar.gz
512MBackup.tar.gz
arcman.tar.gz
bt_on_off.tar.gz
bt_timer.tar.gz
cpu_frequency.tar.gz
cronometer.tar.gz
EFM.tar.gz
eKonsole.tar.gz
pictureflow.tar.gz
refresh.tar.gz
SlideShow.tar.gz
snesx.tar.gz
v8_screenshot.tar.gz
vFM.tar.gz
weblink_sidebar.tar.gz
Расскажите, если не трудно, про что они или ссылочку киньте. Спасибо!
Сообщение отредактировал abelenki - 13.7.2009, 6:22
abelenki
сообщение 11.7.2009, 15:35
Из: Russia, Perm
Цитата(Ig-man @ 11.7.2009, 21:18) *
расскажите вкратце, что за пакеты входят и[вырезан мат]они надо в Basic_Plus_Update_Packages.zip?
названия у всех пакетов говорящие. если проблемы с английским, воспользуйся словарём. про backup читай в предыдущем посте.
ashy57
сообщение 11.7.2009, 16:03
Пользователь №: 51 655
Модель телефона: Razr2 V8
В этой прошивке режим Media Sync не функционирует тоже (прочти во всех модифицированных прошивках , к сожалению, это повторяется)?
Ig-man
сообщение 13.7.2009, 10:37
А куда делась в "органайзер-справка"? У меня только одни названия разделов Справки. У всех так?
abelenki
сообщение 15.7.2009, 4:12
Из: Russia, Perm
кто-нибудь может портировать эмулятор Z6Pico и игру Quake с Elysseum/MPKG Basic на Basic Plus?
Добавлено позже (15.7.2009, 10:33):
подскажите, где хранится файл с шаблонами для быстрого ответа на SMS через внешний экран. хочется его отредактировать и записать свои шаблоны.
Сообщение отредактировал abelenki - 15.7.2009, 4:50
A.C.
сообщение 15.7.2009, 6:47
Из: Moskau
Пользователь №: 141 223
Модель телефона: V8 2GB EXPRSO
Прошивка: Elysseum+ edition
abelenki
так ведь: messages>Templates>Text Templates>Options
и там Create template или Edit уже готового
Vermin
сообщение 15.7.2009, 14:41
Пользователь №: 64 122
Модель телефона: V635; V8
Прошивка: Своя; Basic Plus
Выкладываю эмулятор
и игру Quake.
У меня запускаются. Просьба проверить эмулятор и отписаться. Самому нет времени искать ромы.
любопытнный
сообщение 16.7.2009, 13:49
Прошивка: ОЧЕРЕДНАЯ
Vermin, Спасибо! Работает,установил со второй попытки,перезагрузился-запустил и всё ОК! При входящем звонке выбрасывает в главное меню,но играю всего 15 мин,может и приработается
Добавлено позже (16.7.2009, 16:50):
Тел В8 2 Гига
abelenki
сообщение 16.7.2009, 15:12
Из: Russia, Perm
Quake работает великолепно. я даже заменил текущий конфиг на свой, с более удобным управлением, и перепаковал - всё работает без глюков. спасибо большое!!
а вот Z6Pico устанавливается нормально, но во время запуска ничего не происходит. может с паковкой ошибка? слишком глубокая вложенность tar и gzip архивов...
Сообщение отредактировал abelenki - 17.7.2009, 3:30
Vermin
сообщение 17.7.2009, 0:20
Проверил еще раз, работает. А в /mmc/mmca1/ появляется .Programs/Z6Pico?
Собрал Doom
и моды к нему.
doomFreedoom и MODs_CS. Моды после запуска можно удалить. Выбираются моды после запуска prboom.
abelenki
сообщение 17.7.2009, 3:36
Из: Russia, Perm
у меня V8 512MB. программа устанавливается в /ezxlocal/download/mystuff/package/app/Z6Pico. как я и думал, там лежит нераспакованный архив и другие файлы:
ezxpico.lin
Z6Pico.sh
Z6Pico.tar.gz
попытался их удалить и записать вместо них распакованные файлы и папки эмулятора:
[Capture]
[ROM]
[Save]
ezxpico
pico.csh
z6pico.cfg
Сообщение отредактировал abelenki - 20.7.2009, 3:47
Vermin
сообщение 17.7.2009, 4:50
Цитата(abelenki @ 17.7.2009, 12:36) *
у меня V8 512MB.
Все понятно. В mpkg сделано тоже для 2Gb. Походу это важно для эмулятора. Вечером гляну. Попробую сделать чтоб и у тебя работало. А вот с ScummVM проблемы. Запускаться то он запускается, а вот игры видеть не хочет. Как я понял ему dat файлы нужны?
Сообщение отредактировал Vermin - 22.7.2009, 0:06
abelenki
сообщение 17.7.2009, 5:04
Из: Russia, Perm
странно. когда я тестировал Z6Pico на прошивке 512MB MPKG Basic, он у меня работал...
игры кладутся в ScummVM\games (уже после установки пакета). у каждой игры должна быть своя папка внутри games. затем надо добавить игру через GUI ScummVM, как показано на скриншоте в этом посте:
MPKG-пакеты для прошивок Elysseum/MPKG Basic
просьба выложить ScummVM для Basic Plus - тоже хочется потестировать...
Сообщение отредактировал abelenki - 17.7.2009, 5:14
Vermin
сообщение 17.7.2009, 5:54
Держи
попробуй.
Добавлено позже (18.7.2009, 9:28):
Еще два мода для Doom. Plutonia и Evilution
Сообщение отредактировал abelenki - 20.7.2009, 3:49
abelenki
сообщение 19.7.2009, 2:47
Из: Russia, Perm
Вот. Должен работать на обоих версиях телефонов. Ромы теперь кидать в ezxlocal/download/mystuff/packages/apps/Z6Pico/ROM для V8 512Mb, и mmc/mmca1/packages/apps/Z6Pico/ROM для V8 2Gb. Сам не проверял, но должно работать. Пробуйте!
теперь Z6Pico устанавливается правильно - в папку ezxlocal/download/mystuff/packages/apps/Z6Pico/. правда, устанавливается без папок ROM, Save, Capture. пришлось создать их вручную. но после запуска эмулятора опять ничего непроисходит sad.gif
Держи попробуй.
ScummVM устанавливается без проблем. далее создал папку ScummVM\games, закинул туда 3 папки с играми Gobliiins 1-3. далее добавил все 3 игры через GUI эмулятора. запускаются все 3 игры, НО... ни одна из боковых клавиш (Smart, Volume Up/Down) не действует в играх как левый клик мыши. соответственно, в играх не удаётся ничего сделать. хотя, вроде все 3 боковые кнопки работают, а Volume Down больше похожа на двойной клик одной из кнопок мыши...
Сообщение отредактировал abelenki - 20.7.2009, 3:50
Vermin
сообщение 22.7.2009, 0:10
RockBox port Z6/V8 by CepiPerez.
Сообщение отредактировал Vermin - 22.7.2009, 23:59
Ig-man
сообщение 29.7.2009, 17:51
спасибо! "большой" проигрыватель..)) единственное, что в нем понравилось - работающий эквалайзер. но звук ИМХО все равно не лучше "родного". а что сильно не понравилось - батарейку жрет со страшной силой и телефон греет!!!
очень хочется для v8: просто работащий эквалайзер. че та на джаве ничего не нашел...может не там искал? спасибо, если кто подскажет.
и еще вопрос: как mplayer настроить, чтобы FM радио слушать? скачал с сайта "мегафон" прогу на джаве для прослушки радио через инет, но при выборе любого канала - выдает "ощибка подключения" (хотя через v8 броузер на любой сайт зайти могу). спасибо.
abelenki
сообщение 30.7.2009, 3:06
Из: Russia, Perm
laugh.gif на J2ME не может быть эквалайзера. он может быть только нативным.
laugh.gif Mplayer - для проигрывания видео- и аудио-файлов с диска телефона. на V8 нет FM-ресивера. как ты собираешься слушать FM-радио?? и потоковое аудио и видео из интернет Mplayer тоже не играет.
Сообщение отредактировал abelenki - 30.7.2009, 3:06
Fenniks
сообщение 5.8.2009, 11:14
Пользователь №: 81 832
Модель телефона: V8 Expresso 2gb
тыкните пожалуйста где почитать чтоб расположение меню поменять?
Сообщение отредактировал Fenniks - 5.8.2009, 11:20
Vermin
сообщение 6.8.2009, 6:03
А тему всю посмотреть? Вот ТУТ найди мой пост и скачай zMenuEditor
Advokat_d
сообщение 17.8.2009, 11:00
А игр одоптированных Duke Nukem 3D (eduke32). DosBox for Z6 . нету?....
Vermin
сообщение 17.8.2009, 13:48
У меня пока времени нет. Не до этого. Мож кто другой сделает.
Сообщение отредактировал Vermin - 18.8.2009, 0:22
любопытнный
сообщение 18.8.2009, 8:24
Прошивка: ОЧЕРЕДНАЯ
Advokat_d, Давай 100% рабочие РЕР или MPKG я попробую перепаковать под tar.gz
pirsn
сообщение 21.10.2009, 11:12
Из: Одесса
Пользователь №: 206 492
Модель телефона: Razr Maxx
Прошился этой прошивкой, но забыл зарядить батарею перед прошивкой. Это на работе батареи может сказаться? Спрашиваю, потому-что прошивал свой планшет Nokia N810, там обязательное условие 100% заряд батареи, т.к. при первом старте новой проши, она отмечает текущую степень заряда как максимальный и в дальнейшем его таковым и считает.
Сообщение отредактировал pirsn - 22.10.2009, 8:15
pirsn
сообщение 21.10.2009, 14:26
Из: Одесса
Ранее критиковал модифицированные прошивки, но эта мне нравится все больше... smile.gif
Но бочку меда портит ложка дегтя... Не могу поставить ни одного пакета. Устанавливаю строго по написанному в теме, но Package manager не видит ничего. Может есть какая-то распространенная ошибка? Просто ранее в собщениях уже такое встречал.
Сообщение отредактировал pirsn - 23.10.2009, 7:13
Vermin
сообщение 24.10.2009, 14:47
Опиши как устанавливаешь ты. Проблем быть не должно!
pirsn
сообщение 26.10.2009, 9:21
Из: Одесса
Устал бороться, откатился на стандартую R601 G 80.56.15R. Пакеты не ставились, почему-то не работала клавиша плеера, подтормаживал иногда в контактах и , с чем не смог справиться - упорно отказывался звонить поставленным рингтоном, первый раз такое видел.
Прошивка Basic Plus, V8 · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 18.7.2025, 3:01
