5 страниц V < 1 2 3 4 5 >
Прошивка Basic Plus, V8
abelenki
сообщение 13.4.2009, 2:44 Закрепленное сообщение!
Из: Russia, Perm
Пользователь №: 94 097
What is Basic Plus?
It is a basic unbranded NO_RSA firmware based on 80.46.1BR for 512MB V8 and 80.56.1BR for 2GB V8 with added 5 customization menus
(Change Bootlogo, Font Changer, Startup-/Shutdown Sound, Alarm Clock Timer and Reminder Sound), USB-Lan and Swap memory by default. That's it!
Now this space saving allowed to return to the old system of changing the language by flashing the CG46.
That is the Basic part!
The Plus part includes a Package Manager and you can install what you want and leave out what you don't want. There are 18 packages supplied, which would include the complete Evo 3 range, some have been upgraded, like zLauncher is version 2.1, pictureflow is upgraded and SlideShow is a development of pictureflow made by DeJe. You just have to copy the packages (*.tar.gz files) into /ezxlocal/download/mystuff/package. The Package Manager (you find it in the Package folder in the Main Menu) will install and uninstall packages. During installation you have to enter a menu name, for example you install zLauncher then you can call the menu whatever you want (e.g My Filesystem or Mein Dateienfresser), which is nice if you do not use english as your language. Secondly during installation you can associate file extentions, which most packages do not need. Also, because most Mods now come with a selection of languages and the packages are installed in /ezxlocal/download/mystuff/packages/apps, which is read/write filesystem, you can change the menus to your language. All packages menus will be installed in the Package folder below Package Manager, you either leave them there or you move them to somewhere else, your choice.
USB-Lan and Swap Memory are in the Settings menu, USB-Lan at the beginning and Swap Memory at the end, as you need to use Swap Memory only once to set up the swap file and activate it. After each reboot the swap file gets automatically activated. I have not included the Java HEAP Setting package as I have set the the default HEAP size to the maximum of 4096KB by default.
If you really MUST use Windows Explorer instead of FTP then shutdown the swap file first then change to USB Setting Memory Card and connect with USB cable to PC, the V8 will not hang itself.
MPlayer, because of its /mmc/mmca1/Programms path requirement has been not supplied as a package. However the MPlayer menu exists under Multimedia and all you have to do is copy the included MPlayer folder into /ezxlocal/download/mystuff/Programms on the 512MB V8 or into /mmc/mmca1/Programms on the 2GB V8, that's all.
Another change is that the ezx_flexbit.cfg is now under /ezxlocal/download/appwrite/flexbit, this allows to change the flexbit without the need to flash a CG43 every time you edited the ezx_flexbit.cfg. Just copy your new ezx_flexbit.cfg file into this folder and reboot.
I have tried to make this firmware as simple as possible, as from the comments about Evo 3 saw that a lot just could not get the hang of the different language system and how to handle it.
The need for a Package Manager was always high on the list, also the result of comments and requests like "we do not need this, but can we have that..." and then "we do not need that, but can we have this...", so now everybody can decide themselves what they want and what not.
There are already 2 package management system around (PEP and mpkg), so why creating a new one? Well, I was hoping that there would be a PEP for V8, but that project got put on hold and by request of the PEP creators I could not port it to V8, so that left only mpkg. Now mpkg might be fine for the Z6, but it is not good enough for the V8 and the reasons are that mpkg packages are installed from and onto the Z6 SD card (/mmc/mmca1) this path exists only on 2GB V8, but not on 512MB V8, secondly mpkg packages for Z6 do not work on V8, they need modification in order to work on the V8 (huge potential for future post " I installed mpkg package, but it does not work ."). Thirdly the icon management of mpkg produces only black exclamation marks on yellow background (mpkg uses one icon for std and ani icons, no small icon). which honestly does not look nice to have on your phone. Fourthly the AppID creation is rather simple and the V8 always has been quite fuzzy with "home made" AppID's. So, I either rewrite mpkg to fit V8 and change Z6 mpkg packages into V8 mpkg packages, which still leaves the door wide open for people to install Z6 mpkg packages on V8 and wonder why they do not work. So I decided against that option and created my own package management. Anyway Linux is all about choice, so there you go!
You might find that the Customize menu looks a bit different, this was done on purpose.
OK, I could not have done this without the help, inspiration and testing from DeJe (faq4mobiles.de) and DaRk_dOg (MMUS et al.), their work, ideas and contribution helped to shape this firmware. THANKS!
But a big thank you has to go out to all the other unnamed modders, who's work, modified or not, found their way also into this firmware. THANK YOU!
As with all my work, this firmware is also free for everybody to change, use parts of it or simply print out the code and wallpaper your room with it.
Автор:
rasputin007
Оригинальный топик:
modmymoto.com
Описание:
1. Прошивка No RSA.
2. Лэнгпак шьётся по-старому, через RSDLite.
3. Теперь дополнительные программы устанавливаются пакетами, аналогично PEP, только они имеют свой формат. (т.е. теперь можно выборочно ставить то, что тебе нужно). Пакеты нужно копировать в /ezxlocal/download/mystuff/package, а потом инсталлировать или дизинсталлировать через Package Manager. В процессе инсталляции пакета, вы можете присвоить ему любое имя, а также ассоциировать с ним любые расширения (для большинства пакетов это не нужно).
4. USB-Lan и Swap Memory находятся в меню Settings. Swap Memory нужно запустить и настроить всего лишь один раз. Он активируется автоматически после ребута или включения телефона.
5. Если не активировать файл подкачки (Swap Memory), телефон теперь можно подключать в режиме мемори-карты, и при этом он зависать не будет.
6. Java HEAP автоматически установлен на максимальное значение - 4096KB.
7. MPlayer не включен в виде пакета, а устанавливается по-старому. Т.е. просто скопируйте его в /ezxlocal/download/mystuff/Programms на V8 512MB или в /mmc/mmca1/Programms на V8 2GB. Ярлык на него уже установлен в прошивке и находятся в Multimedia.
8. Файл ezx_flexbit.cfg теперь находится по этому пути - /ezxlocal/download/appwrite/flexbit. Теперь его можно спокойно редактировать, перезаливать в телефон и перезагружаться, чтобы изменения вступили в силу (разборка, редактирование, сборка и прошивка CG43 больше не требуется).
9. Видео-камера теперь снимает в разрешении 352x288.
Порядок прошивания:
1. Bootloader A3.CF (если у вас какой-либо другой бутлоадер).
2. Bootloader A3.CF No RSA.
3. Прошивка Basic Plus Update (прошивайте версию прошивки, соответствующую вашей модели телефона - 512MB или 2GB. Для Luxury Edition прошивайте версию 2GB).
4. Лэнгпак LP002EE.
Файлы:
Bootloader A3.CF
512MB Basic Plus Update
2GB Basic Plus Update
LP002EE - UK English, German, Russian, Ukrainian, French, Spanish & Portuguese; Russian voice commands only
Basic Plus Update Packages
MPlayer
V8 Modding Guide
Сообщение отредактировал XXX_S_B - 20.2.2013, 16:09
любопытнный
сообщение 16.7.2009, 13:49
Пользователь №: 183 849
Модель телефона: Motorola Accompli 008
Прошивка: ОЧЕРЕДНАЯ
Vermin, Спасибо! Работает,установил со второй попытки,перезагрузился-запустил и всё ОК! При входящем звонке выбрасывает в главное меню,но играю всего 15 мин,может и приработается
Добавлено позже (16.7.2009, 16:50):
Тел В8 2 Гига
abelenki
сообщение 16.7.2009, 15:12
Из: Russia, Perm
Quake работает великолепно. я даже заменил текущий конфиг на свой, с более удобным управлением, и перепаковал - всё работает без глюков. спасибо большое!!
а вот Z6Pico устанавливается нормально, но во время запуска ничего не происходит. может с паковкой ошибка? слишком глубокая вложенность tar и gzip архивов...
Сообщение отредактировал abelenki - 17.7.2009, 3:30
Vermin
сообщение 17.7.2009, 0:20
Пользователь №: 64 122
Модель телефона: V635; V8
Прошивка: Своя; Basic Plus
Проверил еще раз, работает. А в /mmc/mmca1/ появляется .Programs/Z6Pico?
Собрал Doom
и моды к нему.
doomFreedoom и MODs_CS. Моды после запуска можно удалить. Выбираются моды после запуска prboom.
abelenki
сообщение 17.7.2009, 3:36
Из: Russia, Perm
у меня V8 512MB. программа устанавливается в /ezxlocal/download/mystuff/package/app/Z6Pico. как я и думал, там лежит нераспакованный архив и другие файлы:
ezxpico.lin
Z6Pico.sh
Z6Pico.tar.gz
попытался их удалить и записать вместо них распакованные файлы и папки эмулятора:
[Capture]
[ROM]
[Save]
ezxpico
pico.csh
z6pico.cfg
Сообщение отредактировал abelenki - 20.7.2009, 3:47
Vermin
сообщение 17.7.2009, 4:50
Цитата(abelenki @ 17.7.2009, 12:36) *
у меня V8 512MB.
Все понятно. В mpkg сделано тоже для 2Gb. Походу это важно для эмулятора. Вечером гляну. Попробую сделать чтоб и у тебя работало. А вот с ScummVM проблемы. Запускаться то он запускается, а вот игры видеть не хочет. Как я понял ему dat файлы нужны?
Сообщение отредактировал Vermin - 22.7.2009, 0:06
abelenki
сообщение 17.7.2009, 5:04
Из: Russia, Perm
странно. когда я тестировал Z6Pico на прошивке 512MB MPKG Basic, он у меня работал...
игры кладутся в ScummVM\games (уже после установки пакета). у каждой игры должна быть своя папка внутри games. затем надо добавить игру через GUI ScummVM, как показано на скриншоте в этом посте:
MPKG-пакеты для прошивок Elysseum/MPKG Basic
просьба выложить ScummVM для Basic Plus - тоже хочется потестировать...
Сообщение отредактировал abelenki - 17.7.2009, 5:14
Vermin
сообщение 17.7.2009, 5:54
Держи
попробуй.
Добавлено позже (18.7.2009, 9:28):
Еще два мода для Doom. Plutonia и Evilution
Сообщение отредактировал abelenki - 20.7.2009, 3:49
abelenki
сообщение 19.7.2009, 2:47
Из: Russia, Perm
Вот. Должен работать на обоих версиях телефонов. Ромы теперь кидать в ezxlocal/download/mystuff/packages/apps/Z6Pico/ROM для V8 512Mb, и mmc/mmca1/packages/apps/Z6Pico/ROM для V8 2Gb. Сам не проверял, но должно работать. Пробуйте!
теперь Z6Pico устанавливается правильно - в папку ezxlocal/download/mystuff/packages/apps/Z6Pico/. правда, устанавливается без папок ROM, Save, Capture. пришлось создать их вручную. но после запуска эмулятора опять ничего непроисходит sad.gif
Держи попробуй.
ScummVM устанавливается без проблем. далее создал папку ScummVM\games, закинул туда 3 папки с играми Gobliiins 1-3. далее добавил все 3 игры через GUI эмулятора. запускаются все 3 игры, НО... ни одна из боковых клавиш (Smart, Volume Up/Down) не действует в играх как левый клик мыши. соответственно, в играх не удаётся ничего сделать. хотя, вроде все 3 боковые кнопки работают, а Volume Down больше похожа на двойной клик одной из кнопок мыши...
Сообщение отредактировал abelenki - 20.7.2009, 3:50
Vermin
сообщение 22.7.2009, 0:10
RockBox port Z6/V8 by CepiPerez.
Сообщение отредактировал Vermin - 22.7.2009, 23:59
Ig-man
сообщение 29.7.2009, 17:51
Пользователь №: 175 583
Модель телефона: Droid Razr Maxx HD
Прошивка: Android 4.4.2
183.46.15.XT926.Verizon.en.US
спасибо! "большой" проигрыватель..)) единственное, что в нем понравилось - работающий эквалайзер. но звук ИМХО все равно не лучше "родного". а что сильно не понравилось - батарейку жрет со страшной силой и телефон греет!!!
очень хочется для v8: просто работащий эквалайзер. че та на джаве ничего не нашел...может не там искал? спасибо, если кто подскажет.
и еще вопрос: как mplayer настроить, чтобы FM радио слушать? скачал с сайта "мегафон" прогу на джаве для прослушки радио через инет, но при выборе любого канала - выдает "ощибка подключения" (хотя через v8 броузер на любой сайт зайти могу). спасибо.
abelenki
сообщение 30.7.2009, 3:06
Из: Russia, Perm
laugh.gif на J2ME не может быть эквалайзера. он может быть только нативным.
laugh.gif Mplayer - для проигрывания видео- и аудио-файлов с диска телефона. на V8 нет FM-ресивера. как ты собираешься слушать FM-радио?? и потоковое аудио и видео из интернет Mplayer тоже не играет.
Сообщение отредактировал abelenki - 30.7.2009, 3:06
Fenniks
сообщение 5.8.2009, 11:14
Пользователь №: 81 832
Модель телефона: V8 Expresso 2gb
тыкните пожалуйста где почитать чтоб расположение меню поменять?
Сообщение отредактировал Fenniks - 5.8.2009, 11:20
Vermin
сообщение 6.8.2009, 6:03
А тему всю посмотреть? Вот ТУТ найди мой пост и скачай zMenuEditor
Advokat_d
сообщение 17.8.2009, 11:00
Пользователь №: 155 462
Модель телефона: V3i,V8 2гига
Прошивка: R601_G_80.56.15R
А игр одоптированных Duke Nukem 3D (eduke32). DosBox for Z6 . нету?....
Vermin
сообщение 17.8.2009, 13:48
У меня пока времени нет. Не до этого. Мож кто другой сделает.
Сообщение отредактировал Vermin - 18.8.2009, 0:22
любопытнный
сообщение 18.8.2009, 8:24
Прошивка: ОЧЕРЕДНАЯ
Advokat_d, Давай 100% рабочие РЕР или MPKG я попробую перепаковать под tar.gz
pirsn
сообщение 21.10.2009, 11:12
Из: Одесса
Пользователь №: 206 492
Модель телефона: Razr Maxx
Прошился этой прошивкой, но забыл зарядить батарею перед прошивкой. Это на работе батареи может сказаться? Спрашиваю, потому-что прошивал свой планшет Nokia N810, там обязательное условие 100% заряд батареи, т.к. при первом старте новой проши, она отмечает текущую степень заряда как максимальный и в дальнейшем его таковым и считает.
Сообщение отредактировал pirsn - 22.10.2009, 8:15
pirsn
сообщение 21.10.2009, 14:26
Из: Одесса
Ранее критиковал модифицированные прошивки, но эта мне нравится все больше... smile.gif
Но бочку меда портит ложка дегтя... Не могу поставить ни одного пакета. Устанавливаю строго по написанному в теме, но Package manager не видит ничего. Может есть какая-то распространенная ошибка? Просто ранее в собщениях уже такое встречал.
Сообщение отредактировал pirsn - 23.10.2009, 7:13
Vermin
сообщение 24.10.2009, 14:47
Опиши как устанавливаешь ты. Проблем быть не должно!
pirsn
сообщение 26.10.2009, 9:21
Из: Одесса
Устал бороться, откатился на стандартую R601 G 80.56.15R. Пакеты не ставились, почему-то не работала клавиша плеера, подтормаживал иногда в контактах и , с чем не смог справиться - упорно отказывался звонить поставленным рингтоном, первый раз такое видел.
Vermin
сообщение 28.10.2009, 12:57
Ты единственный столкнувшийся с такими проблеммами на этой прошивке. Может стоило прошиться еще раз?
prSapphire
сообщение 31.10.2009, 17:46
Из: Владивосток
Пользователь №: 56 874
Модель телефона: Atrix 4G/Milestone
Прошивка: MIUI v4/MIUI GB
в ожидании чуда ))
Возникло несколько вопросов. Очень рад буду любой помощи, сам я понять как-то не в силах.
Итак, первое, не могу назначить на архивные файлы ассоциации. И проблема даже не в этом, хоть и пишет что архив распакован, но на самом деле ничего похожего. Почему?
Второе, ява адаптер файлы не хочет переделывать, точнее превращает их в 22 кб файлы, которые естественно не работает.
Третье, софтбокс не дает права приложениям. Точнее дает, но они после этого не работают, пишут ошибку проверки сертификата.
Это как бы основное, но еще появился странный глюк. Если пакеты устанавливать и удалять, сначала идет смещение по меню, потом телефон на мертво виснет и может помочь только прошивка заново. Уже дважды за двое суток.
Кстати, телефон 512 версии.
Жду помощи. Спасибо заранее.
Mоторчег
сообщение 1.11.2009, 5:52
Пользователь №: 132 481
Модель телефона:
присоединяюсь, софтбокс корежит яву
prSapphire
сообщение 3.11.2009, 6:02
Из: Владивосток
в ожидании чуда ))
Раньше на форуме народ был активнее, как-то старался помочь другим.
Или видимо решения этих проблем нет и она не только у меня.
Не понимаю тогда в чем смысл этих всех пакетов, если они не работают должным образом. Архиватор не распаковывает, адаптер не переделывает нормально яву и прочее. Короче, они и есть (пакеты) и толку от них нет.
любопытнный
сообщение 3.11.2009, 10:39
Прошивка: ОЧЕРЕДНАЯ
prSapphire, https://forum.motofan.ru/index.php?act=Attach&type=post&id=204269 У меня такое было после установки этого обновления.Выход простой:сначала всё установил или удалил
потом обновился,но тел на 2Гб.
ГлюЧный_МоторчеГ-Л7,
Переустанавливал раз 10-сейчас работает:наверное прижился...
prSapphire, Раньше на форуме народ был активнее, как-то старался помочь другим
Культ Зэт6 к сожалению
prSapphire
сообщение 3.11.2009, 10:50
Из: Владивосток
в ожидании чуда ))
любопытнный,
Насчет этого обновления я тоже догадался что всё дело с зависанием из-за него. Но это не объясняет почему пакеты нормально не работают, я всё про тот же софтбокс, адаптер и архиватор. Они ни до, ни после обновления не работали sad.gif
это обидно, хотелось бы права яве и её адаптацию проводить сразу на лету через телефон, а не каждый раз бежать к ноутбуку.
prSapphire
сообщение 6.11.2009, 10:51
Из: Владивосток
в ожидании чуда ))
Итак, небольшие выводы которые успел сделать.
Минусы: iTap быстро забывает слова, причем везде. Arcman справляется только с форматом tar.gz, всё остальное ему не по силам. Javaadapter не корректно работает, точнее совсем не работает. SoftBox после некоторой раскачки дает права яве, с этим наконец проблем нет, но вот иконки приходиться возвращать самому. К остальным пакетам особых притензий нет. Либо не нужны, либо работают. Зато, после обновления, удалять пакеты лучше не стоит, грозит полным зависом телефона, спасает только прошивка сначала. У MPlayer меню вызываться не хочет.
Плюсы: работает быстро, и почти все возможное может выполнить.
Vermin
сообщение 7.11.2009, 11:57
На счет удаления пакетов. Если удалять пакеты установленные после установки удаления, то все нормально удаляется. Еще не стоит рассортировывать установленные программы по папкам. Иначе после удаления какого либо пакета исчезают все ярлыки.
prSapphire
сообщение 8.11.2009, 4:59
Из: Владивосток
в ожидании чуда ))
Не факт. Пакеты у меня лежат без папок, а вот ява разбросанна по папкам. Результат один, удалять нельзя. Слетают ярлыки и телефон просто уходит в постоянный вис. Риск большой, но яву удалять можно, проблем не возникает. Пакеты лучше не трогать
Vermin
сообщение 8.11.2009, 11:34
Видимо зависит от конкретного телефона. Ставил и удалял уже кучу прог.
любопытнный
сообщение 10.11.2009, 9:47
Прошивка: ОЧЕРЕДНАЯ
Vermin, Случаем duke nukem под Бейсик+ нет? Или напиши как адаптировать pep или MPKG. я делал так:распаковывал MPKG,создавал папку apps.укладывал в неё файлы дальше всё запаковывал в tar.gz -не работает.Таким же способом пробовал перепаковывать пакет от А1200/Е6 не запускается вообще.Описания принципа адаптации на форуме есть.но нет частностей по В8.Поделись секретом ,если не тяжело.
Vermin
сообщение 10.11.2009, 12:42
Все собираюсь собрать. Даже начал, но не успел. Завтра постараюсь сделать. Там не только собрать надо, но еще пути править надо. Еще я собираюсь либы отдельно сделать, чтоб не шли одни и теже с каждым пакетом.
miccca
сообщение 11.11.2009, 18:36
Пользователь №: 146 928
Модель телефона: Motorola V8 2Gb
а почему после прошивки у меня шрифт квадратиками?
Добавлено позже (11.11.2009, 18:49):
и ещё при прошивке bootloader пишет Err:A5.694E.24
Добавлено позже (11.11.2009, 20:21):
о ! заработало только теперь у меня нет папки package что с этим делать?
Vermin
сообщение 12.11.2009, 0:23
Прошить еще раз.
prSapphire
сообщение 12.11.2009, 4:20
Из: Владивосток
в ожидании чуда ))
При шрифте квадратиками ищи Customise, переходи на вторую вкладку ищи в ней Change Font и заменяй его на Default. Квадраты превращаются в привычные буквы. smile.gif
Насчет ошибки с бутом, убедись что прошиваешь верный, со снятым RSA.
А вот про исчезазание папки, сказать ничего не могу. Такого у меня не было 0_0
Vermin
сообщение 12.11.2009, 7:30
Выбрал время и предоставляю вашему вниманию DukeNuken 3D. Сначала нужно установить либы.
Внимание! либы запускать НЕ НУЖНО! После установки пакет можно удалить чтоб ярлык не болтался в меню. Не забываем, что после установки
Прикрепленный файл eduke32.tar.gz   ( 970.94 килобайт ) Кол-во скачиваний: 295
в папку с приложением нужно скопировать GRP файл. Подробнее об этом тут.
З.Ы. На 512M скорее всего не пойдет, так как либам нужен путь /mmc/mmca1/.system/ для файла конфигурации, которого на данных телефонах просто нет.
любопытнный
сообщение 12.11.2009, 14:09
Прошивка: ОЧЕРЕДНАЯ
Vermin, Сбылась мечта идиота!!!! Установил без проблем- тестирую,просто в восторге.Как переназначить выход на красную кнопку?
Vermin
сообщение 13.11.2009, 0:37
Цитата(любопытнный @ 12.11.2009, 22:09) *
VerminКак переназначить выход на красную кнопку?
Сейчас сам над этим бьюсь.
Разобрался. Надеюсь к вечеру выложу обновление. Кнопки можно будет переназначить. Кстати на 512M версии Duke работать должен, но без переназначения кнопок
Сообщение отредактировал Vermin - 13.11.2009, 3:10
Sufy
сообщение 15.11.2009, 11:52
Из: Ближнее Замкадье
Пользователь №: 27 061
Прошивка: MIUI
abelenki,
поправьте в описании: на 2-х гиговой версии пакеты надо кидать в корень папки mmc/mmca1/package/
по указанному в описании адресу не работает. да и папки package по умолчанию там нет
любопытнный
сообщение 17.11.2009, 8:03
Прошивка: ОЧЕРЕДНАЯ
Vermin, Шансов нет?
Прошивка Basic Plus, V8 · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 5.9.2025, 5:13
