2 страниц V < 1 2
Прошивка Elysseum, V8
abelenki
сообщение 19.4.2009, 3:23 Закрепленное сообщение!
Из: Russia, Perm
Пользователь №: 94 097
Support telnet, ssh, ftp (Connections modem&tools)
Support mpkg
bash version 4.0.0
kernel patch
unlock insmod
Applications installed:
MPKGLauncher by CepiPerez
Pictureflow by c_ro87
vAlarm by c_ro87
vBTTime by c_ro87
vWebLink by kleto
Konsole by tikva
vSYSInfo by c_ro87
vFM by rusiki
vTView by rusiki
vScreenshoter by c_ro87
mySkinDelete by kleto
vBackUp by kleto
vCleaner by c_ro87
Binaries show features:
readconfig
setconfig
showColorPicker
showTextContent
showDatePicker
showFilePicker
showlistbox
showMultiSelect
showNotify
showNumPicker
showProgress
showQ
showRadio
showTextEntry
showTimePicker
by Lasly, letterb, ilove3d, CepiPerez, flamefox.
Installer mpkg by kleto
Kernel:
my old kernel patch done
my kernel patch now made ext2, ext3, swap, no security
2 autorun:
autorun primary: /ezxlocal/startmount.conf
autorun secondary: /ezxlocal/download/mystuff/.Autorun/*
Supported extensions:
text: txt ini phm cpp h desktop cfg conf
packages: mpkg ins tar gz bz2 rar zip 7z iso cab ........
font: ttf
application: lin sh csh
skin: chm
Skin:
Alkali: Motorola inc.
CMCC: Motorola inc.
Luxury Mosaic: eisbar
Plush: Motorola inc.
Swap options:
1 activation by default compcache (You can turn off in /ezxlocal/download/mystuff/.Autorun/autorun)
2 used SwapMem to create swap file (not included)
3 partitioning /mmc/mmca1 (busybox fdisk /dev/mmca)
Skin: Use .chm edit the address
Font: just select it then you have to restart the new font
Flexbit: edit ezx_flexbit.cfg in "/ezxlocal/download/appwrite/setup" then reboot to see changes
Attention:
mpkg of z6 are not compatible (environment LinXtend not necessary now)
mpkg of z6 you want?
you delete mpkg
if [ "$LX_ENV" != "true" ]
then
. /ezxlocal/LinXtend/etc/initenv
fi
Автор:
kleto
Оригинальный топик:
modmymoto.com
Порядок прошивания:
1. Bootloader A3.CF (если у вас какой-либо другой бутлоадер).
2. Bootloader A3.CF No RSA.
3. Прошивка Elysseum (прошивайте версию прошивки, соответствующую вашей модели телефона - 512MB или 2GB. Для Luxury Edition прошивайте версию 2GB).
4. Лэнгпак LP002EE.
Файлы:
Bootloader A3.CF
512MB Elysseum
2GB Elysseum
LP002EE - UK English, German, Russian, Ukrainian, French, Spanish & Portuguese; Russian voice commands only
Сообщение отредактировал abelenki - 14.7.2009, 8:32
abelenki
сообщение 17.6.2009, 2:59
Из: Russia, Perm
вот метод, чтобы телефон не зависал в режиме memory-карты, если на ней есть скины:
http://modmymoto.com/forums/showthread.php?t=503131
(работает только для версии 2GB).
Сообщение отредактировал abelenki - 17.6.2009, 3:04
A.C.
сообщение 29.6.2009, 8:34
Из: Moskau
Пользователь №: 141 223
Модель телефона: V8 2GB EXPRSO
Прошивка: Elysseum+ edition
отлично. прошился практически без проблем, установил нестандартный скин против зависания телефона.
(СуДоКу лучше, чем на стандартной прошивке)
Ни у кого не было такого: конкретно второй звонок в день не работает? Набираю номер первый раз - всё нормально, разговариваю. Потом пытаюсь позвонить кому-то ещё - телефон не доходит даже до гудков, пишет "The network is busy". Перезагрузка не помогает. Через несколько часов проходит само.
и ещё вопрос: как включается эта Опера? всё меню облазил - иконки "Опера" нет.
GandjaFuzz
сообщение 3.7.2009, 17:20
Motofuzzer
Пользователь №: 26 583
Модель телефона: ZN5 T-Mobile
Прошивка: 2CR_128
как решить проблему с зависанием? у меня V8 2GB. прошиваю. при наборе текста виснет
ravex
сообщение 5.7.2009, 0:06
Из: Питер
Пользователь №: 31 141
Модель телефона: L7, V8
Прошивка: LinuxMod 5 Pre-Final
GandjaFuzz
или так
Прошивка Elysseum
или вот так
Прошивка MPKG Basic (не пугайся названия темы, там файло от обоих прошивок)
Сообщение отредактировал ravex - 5.7.2009, 0:07
m@mont
сообщение 10.8.2009, 19:42
Пользователь №: 181 077
Модель телефона: Motorola RazR*2 V8
Прошивка: Basic Plus
Прошивка Elysseum или вот так Прошивка MPKG Basic (не пугайся названия темы, там файло от обоих прошивок)
Проблема та же зависает при наборе текста! Пробывал менять стандартный путь к скину не выходит, остается прежний скин! Если есть возможность установить скин по другому как отдельный, поскажите может это решит проблему или опишите по шагам как заменять стандартный скин на свой по шагам: какой скин для этого лучше ипользовать, какие файлы куда класть, где что переименовывать! А то эта проблема уже достала. Заранее спасибо!
любопытнный
сообщение 17.8.2009, 13:43
Пользователь №: 183 849
Модель телефона: Motorola Accompli 008
Прошивка: ОЧЕРЕДНАЯ
сложи все файлы ini и ezx в /ezxlocal/download/mystuff/Others/skins/
а в /ezxlocal/download/appwrite/setup/ найди файл ezx_theme.cfg
в нем две последние строчки
CurrentSkin = /ezxlocal/download/mystuff/Others/skins/ - это путь к файлам скина который ты загрузил
CurrentTheme = /ezxlocal/download/appwrite/setup/theme/User_0.chm - это файл настроек мелодий картинок и тд.
Так пробовал?
ravex
сообщение 19.8.2009, 9:13
Из: Питер
Кто-нибудь уже Дюка или Кваку 2 пытался ставить на нашу прошу?
При установке пакета выдает следующее
Sorry. no package installed:
Elysseum, V8
Свап стоит 64 Мегабайта
Let
сообщение 19.8.2009, 13:26
Из: г. Барнаул
Пользователь №: 5 459
Прошивка: >_<
ravex, Charles Manson, логично, эти пакеты надо сначала адаптировать под V8
Charles Manson
сообщение 22.8.2009, 8:49
Пользователь №: 100 147
Модель телефона: Samsung i9190
Let, Ещёб кто подсказал каким образом она (адаптация) производится. shuffle.gif
Anton-988
сообщение 15.6.2010, 17:28
Пользователь №: 214 865
Модель телефона: v3i
Сделал как написано здесь
скин поменялся, но при подключении тел. виснет, еще не работает видеокамера, версия 512 мб., помогите пожалуйста smile.gif , а может есть более лучшая прошивка для версии 512мб.? кроме f3, на ней тоже видеокамера не работает.
любопытнный
сообщение 16.6.2010, 7:24
Прошивка: ОЧЕРЕДНАЯ
Попробуй этуhttps://forum.motofan.ru/index.php?showtopic=172360
sense
сообщение 10.7.2011, 10:39
Пользователь №: 228 120
Модель телефона: Xt5
Всем привет!
Не подскажите как увеличить количество последних набранных номеров с 20 , ну хотя бы до 100.
Заранее спасибо!
VINRARUS
сообщение 10.7.2011, 12:27
Термоядерный
Из: Чорнобиль
Пользователь №: 211 044
Прошивка: 740 MHz: Z6 and ZN5
youtu.be/A_yQLYLiSGQ
sense,
sense
сообщение 14.7.2011, 19:38
Цитата(VINRARUS @ 10.7.2011, 12:27) *
sense,
VINRARUS
сообщение 14.7.2011, 20:12
Термоядерный
Из: Чорнобиль
sense,
HeX редактор + бинарник отвечающий за ету инфу + хорошое везение + большое желание + корвалол + шото по крепче
Сообщение отредактировал VINRARUS - 14.7.2011, 20:13
Прошивка Elysseum, V8 · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
2 страниц V < 1 2
Текстовая версия Сейчас: 5.8.2025, 9:28
